I was investigating ways of filleting cylinders to make "cup" shapes and
thought I would be clever by hulling a torus with a regular cylinder, but I
consistently get a "non manifold" error when slicing the output.
Here is my code:
fillet_radius = 5;
inner_r = 30;
outer_r = inner_r+5;
cup_height = 70;
// outer cup
cylinder(h=cup_height, r=outer_r);
// inner cavity
translate([0, 0, fillet_radius])
Cup(cup_height, inner_r, fillet_radius);
module Cup(height, radius, fillet_radius)
hull()
Ring_torus(R = radius-fillet_radius, r = fillet_radius);
cylinder(h = height-fillet_radius, r = radius);
module Ring_torus(R, r)
rotate_extrude()
translate([R, 0, 0])
circle(r);
I have tried unioning the various parts before hulling, and also replacing
the hull with unions of cylinders (one large one, one small one, and a ring
torus to bridge the two) but the error persists.
I've tried adding fudge factors in case there's a problem at the toroidal
'equator' but it doesn't help.
Interestingly, the problem doesn't occur if I don't union or hull the torus
with a cylinder. Is there a winding issue with objects created with
rotate_extrude() that only manifests when unioned with another object?
View this message in context: http://forum.openscad.org/Non-manifold-when-union-or-hull-a-torus-created-with-rotate-extrude-tp10448.html
I can't see any problems with the latest dev-snapshot on Linux. The exported
STL looks good in NetFabb.
Weird - got an email reply from Marius but it didn't show up on nabble.
kintel wrote
but I consistently get a "non manifold" error when slicing the output.
I quickly tested your file and opened it in Slic3r. Everything looks fine
there (using OpenSCAD-2014.12.07 on Mac an the latest Slic3r).
Could you specify which version of OpenSCAD, which OS as well as where you
get non-manifold errors reported?
I'm still on the 11.05 snapshot of OpenSCAD on OSX - I'll update it later
and try again. I haven't tried running it through netfabb so I'll do that
too.
It sounds like Slic3r might be my problem - I tend to use whichever version
that is bundled with Repetier Host, and I have been a little lax in updating
this across all of my machines lately (I use a combination of OSX and
Windows).
View this message in context: http://forum.openscad.org/Non-manifold-when-union-or-hull-a-torus-created-with-rotate-extrude-tp10448p10468.html
God works in mysterious ways... ;)
View this message in context: http://forum.openscad.org/Non-manifold-when-union-or-hull-a-torus-created-with-rotate-extrude-tp10448p10472.html
I read that one on nabble, it must have been deleted.
View this message in context: http://forum.openscad.org/Non-manifold-when-union-or-hull-a-torus-created-with-rotate-extrude-tp10448p10473.html
