Error message one line off
Michele
Thu, Jan 1, 2015 7:56 PM
In the following code
twidth = 2.0      // Width of teeth
smooth = 50 ;      // circle smoothing, higher is smoother but slower
The error is reported on the second line, with the red box positioned just
before the = sign.  The actual error is of course the missing ";" on the
first line.
version 2014.12.25 (git 73163f2), 32 bit Win XP
View this message in context: http://forum.openscad.org/Error-message-one-line-off-tp10863.html
In the following code twidth = 2.0 // Width of teeth smooth = 50 ; // circle smoothing, higher is smoother but slower The error is reported on the second line, with the red box positioned just before the = sign. The actual error is of course the missing ";" on the first line. version 2014.12.25 (git 73163f2), 32 bit Win XP -- View this message in context: http://forum.openscad.org/Error-message-one-line-off-tp10863.html Sent from the OpenSCAD mailing list archive at Nabble.com.
S
Scalpel78
Thu, Jan 1, 2015 8:29 PM
That is actually the correct handling of these kind of errors.
Remember that newlines are actually ignored in the code. Here is an example
that is valid;
test
20
word
"test"
If the first ; is removed then 'word' is the first place in the code where
the syntax is wrong, and that is where the error will pop up.
View this message in context: http://forum.openscad.org/Error-message-one-line-off-tp10863p10864.html
That is actually the correct handling of these kind of errors. Remember that newlines are actually ignored in the code. Here is an example that is valid; test = 20 ; word = "test" ; If the first ; is removed then 'word' is the first place in the code where the syntax is wrong, and that is where the error will pop up. -- View this message in context: http://forum.openscad.org/Error-message-one-line-off-tp10863p10864.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Michele
Thu, Jan 1, 2015 8:55 PM
OK then let me rephrase the comment.
Given that the construction <var> = <constant> <var> is syntactically
incorrect, the scanner should position the red box /before /the second var
rather than after it since the most likely assumption is that something
should have appeared between the constant and the second var, like an
operator or a ";".  IMHO.  Not a big deal.
View this message in context: http://forum.openscad.org/Error-message-one-line-off-tp10863p10866.html
OK then let me rephrase the comment. Given that the construction <var> = <constant> <var> is syntactically incorrect, the scanner should position the red box /before /the second var rather than after it since the most likely assumption is that something should have appeared between the constant and the second var, like an operator or a ";". IMHO. Not a big deal. -- View this message in context: http://forum.openscad.org/Error-message-one-line-off-tp10863p10866.html Sent from the OpenSCAD mailing list archive at Nabble.com.
