Sun, Jul 17, 2022 3:15 PM
Greetings all;
I think I may be in over my head.
This code starts to make cap to go on the ends of the handle rod for
this screw,
the remainder of a spherical knob being printed from TPU so serve as a
bumper
when the user lets go of the handle and the handle slides thru the hole
until
it hits the knob on the end of the handle. Because they are cheap by the
25 lb
pail, I want to drill into the end of an oak dowel for a 4" long #10
deck screw.
But the deck screw has a tulip head, not the usual tapered conical of a
flat
headed wood screw.
So I need to model that tulip shape with another module to be the final
difference
in this code:
module handle_washer()
{ $fn=180;
translate([0,0,-12])difference()
sphere(d=40);
translate([-22.5,-22.5,-33])cube(45);
translate([0,0,16])cylinder(h=10,d=4,center=true);
Ideas on how to go about that?
The only idea I can come up with is a 3mm diameter disk extruded to a
usable
thickness, offset so as to form a tulip shape if rotated about the 4mm shank
of the deck screw, and that then used as a difference under a conical
cylinder.
That I may be able to do, but it seems to me there ought to be a different,
better way.
Is there?
Thank you all. Take care and stay well.
Cheers, Gene Heskett.
Greetings all;
this screw,
bumper
until
25 lb
deck screw.
flat
headed wood screw.
difference
in this code:
{ $fn=180;
sphere(d=40);
usable
cylinder.
better way.
Is there?
- Louis D. Brandeis
Genes Web page <http://geneslinuxbox.net:6309/>
Michael Möller
Sun, Jul 17, 2022 5:05 PM
A picture of a Tulip Head of a screw ... when I google the term I get lots
of surgical implant stuff ... you're not doing surgical equipment are you?
On Sun, 17 Jul 2022 at 17:16, gene heskett gheskett@shentel.net wrote:
Greetings all;
this screw,
bumper
until
25 lb
deck screw.
flat
headed wood screw.
difference
in this code:
{ $fn=180;
sphere(d=40);
usable
shank
cylinder.
better way.
Is there?
On Sun, 17 Jul 2022 at 17:16, gene heskett <gheskett@shentel.net> wrote:
> Greetings all;
> this screw,
> bumper
> until
> 25 lb
> deck screw.
> flat
> headed wood screw.
> difference
> in this code:
> { $fn=180;
> sphere(d=40);
> usable
> shank
> cylinder.
> better way.
> Is there?
> - Louis D. Brandeis
trygve@totallytrygve.com
Sun, Jul 17, 2022 6:52 PM
A picture of a Tulip Head of a screw ... when I google the term I get lots of surgical implant stuff ... you're not doing surgical equipment are you?
Greetings all;
this screw,
bumper
until
25 lb
deck screw.
flat
headed wood screw.
difference
in this code:
{ $fn=180;
sphere(d=40);
usable
cylinder.
better way.
Is there?
Is the screw head one of these?
<https://en.wikipedia.org/wiki/Screw#Screw_head_shapes>
Trygve
Den 17. juli 2022 kl. 19.05.33 +02.00 skrev Michael Möller <private2michael@gmail.com>:
> On Sun, 17 Jul 2022 at 17:16, gene heskett <<gheskett@shentel.net>> wrote:
> > Greetings all;
> > this screw,
> > bumper
> > until
> > 25 lb
> > deck screw.
> > flat
> > headed wood screw.
> > difference
> > in this code:
> > { $fn=180;
> > sphere(d=40);
> > usable
> > cylinder.
> > better way.
> > Is there?
> > - Louis D. Brandeis
> > Genes Web page <<http://geneslinuxbox.net:6309/>>
> > To unsubscribe send an email to <discuss-leave@lists.openscad.org>
Sun, Jul 17, 2022 8:47 PM
Not hardly Michael, it's the knob on the end of a vise handle. And I am
changing my thinking a bit but the need for that shape isn't changed.
I'll move the flat face (the cube) to just clip off the the bottom, then
add a 19mm hole to fit over the end of the dowel, hollowing it out to
about the flat faces location. Then print a TPU sleeve with a 19mm bore
and a 25mm OD & 16 to 17mm long for the bumper.
This is the underside of the head of a commonly used here in the US
for a "deck" screw, holding the wooden planks of a front or back deck
or porch floor to its sub-framing on your house. Usually with a T25 or
so torx socket for a driving tool. google or DDG for deck screws should
get you some pix for reference.
I've got one of these making just to see if it fits the doweling.
{ $fn=180;
translate([0,0,15.50])difference()
sphere(d=40);
translate([-22.5,-22.5,-60.5])cube(45);
translate([0,0,-2.1])cylinder(h=27,d=19,center=true);
but I still need to see about the screw head socket on top of it.
And watching it form, its plain to see 40mm is too big, so I've
reduced it to 28mm and adjusted the rest to fit, but I think I've
found a bug, the ! in front of the sphere I expected to make it
transparent so I could see whats inside, but what it does do is
not helpful at all as it just turns it grey and solid.
Is that the intended behavior?
So I'll make this one next after I test fit whats making now.
module handle_cap()
{ $fn=180;
translate([0,0,5.5])difference()
sphere(d=28);
translate([0,0,9])cylinder(h=10,d=4,center=true);
translate([0,0,-0.6])cylinder(h=11,d=19,center=true);
translate([-22.5,-22.5,-50.5])cube(45);
Greetings all;
this screw,
bumper
until
25 lb
deck screw.
flat
headed wood screw.
difference
in this code:
usable
shank
cylinder.
better way.
Is there?
- Louis D. Brandeis
Genes Web page http://geneslinuxbox.net:6309/
{ $fn=180;
sphere(d=40);
module handle_cap()
{ $fn=180;
sphere(d=28);
>> Greetings all;
>> this screw,
>> bumper
>> until
>> 25 lb
>> deck screw.
>> flat
>> headed wood screw.
>> difference
>> in this code:
>> usable
>> shank
>> cylinder.
>> better way.
>> Is there?
>> - Louis D. Brandeis
- Louis D. Brandeis
Sun, Jul 17, 2022 9:35 PM
No, see attached pix, this is the screw I will be using, a #6 drywall
screw,
about 1.625" long. In looking at the #10 deck screws which are very
similarly
shaped, I came to the conclusion that drilling a pilot hole that big
would weaken
the oak at its position passing thru the bolt head, encouraging its
breakage.
So as mentioned in the last post, I've reduced the knob to 28mm in diameter
and adjusted the rest to fit. I've half or more of a 5lb box of this
screw, which will
not reach all the way thru the bolt's square head, needs a much smaller
pilot
hole etc. These screws are fairly hard steel, so the chances of popping the
head off are somewhere between slim and none.
But that should show the tulip shape I need to fit, somewhere around a
2.5 to
3mm radius with the outer edge being the preferred first contact point.
These have a #2 Phillips head. One Bosch #2 bit in variable speed drill
will drive
50 lbs of this screw. Unless you've a dummy running the drill. :o(>
Bosch makes
good stuff.
Thank you. Take care and stay well.
screw,
similarly
would weaken
breakage.
screw, which will
pilot
2.5 to
will drive
Bosch makes
good stuff.
> Trygve
- Louis D. Brandeis
WL
William Lugg
Sun, Jul 17, 2022 9:40 PM
Gene,
My money would be on just forming a standard countersunk hole for the
head. I wouldn't worry about perfectly matching the curvature of the
deck screw. Once it's all together, It won't matter and this doesn't
sound like a structural joint that will be under a significant amount of
tension either.
Just my $0.02.
Bill Lugg
{ $fn=180;
sphere(d=40);
module handle_cap()
{ $fn=180;
sphere(d=28);
Greetings all;
this screw,
bumper
until
25 lb
deck screw.
flat
headed wood screw.
difference
in this code:
usable
shank
cylinder.
better way.
Is there?
- Louis D. Brandeis
- Louis D. Brandeis
Gene,
tension either.
Just my $0.02.
Bill Lugg
> { $fn=180;
> sphere(d=40);
> module handle_cap()
> { $fn=180;
> sphere(d=28);
>>> Greetings all;
>>> this screw,
>>> bumper
>>> until
>>> 25 lb
>>> deck screw.
>>> flat
>>> headed wood screw.
>>> difference
>>> in this code:
>>> usable
>>> shank
>>> cylinder.
>>> better way.
>>> Is there?
>>> - Louis D. Brandeis
> - Louis D. Brandeis
Mon, Jul 18, 2022 5:04 PM
"!" means "show only this object". You probably mean "%", which means
"make this object transparent-gray, and don't include it in the final
model".
model".
Mon, Jul 18, 2022 5:55 PM
model".
I tried both, neither gave me the xray view I needed. I needed to
see the penetration of a cylinder into a sphere, the cylinder being the
socket space inside the sphere for the end of the dowel/handle that
plugs into the sphere. This is the knob on the ends of a vise handle
that keeps the handle from falling plumb out of the screw head
when the user lets go of the handle.
Simple concept,but drove OpenSCAD into very slow rendering in 22 lines
of code. But it worked well. Unfortunately the printer bricked itself while
trying to fix a flow problem which was only 25% of the flow needed to
print the parts. Fun and games this isn't. Changing the main board in a
Prusa MK3S is not in my definition of fun. Digging post holes for new fence
is. I should do more of it, but at 87 I'd druther pay a younger person. :-)
Thanks, take care and stay well, jordan.
> model".
- Louis D. Brandeis
Mon, Jul 18, 2022 9:28 PM
Like so?
%sphere(r=10);
cylinder(r=5, h=20);
Like so?
%sphere(r=10);
Tue, Jul 19, 2022 12:05 AM
model".
That does make it grey, but there's nothing transparent about it,
its solid grey and nothing inside it can be seen. It also fouls the first
argument of a difference(), making line 2 the base against which lines
3,4,5 are subtracted, definitely not useful.
This is last months AppImage.
2022.04.29.ai11816 (git 68c63f61b)
Thank you Jordan, take care and stay well.
> model".
- Louis D. Brandeis
Genes Web page<http://geneslinuxbox.net:6309/>
