I downloaded the Windows ZIP and tried to run the EXE, and my
anti-malware software (AVG) quarantined the EXE because of
FileRepMalware, whatever that is.
On 8/4/2022 10:49 AM, William F. Adams via Discuss wrote:
I guess this "problem" may be because the file/exe is seen so rarely by
the AVG software
https://appuals.com/what-is-filerepmalware-and-should-you-remove-it/
I glanced at the manual, and I cannot imagine creating anything complex
using this technique. It is cute, and may be educational, but I feel
that it would be useless for a real world application. Perhaps someone
will show me an example proving me wrong.
by the AVG software
FileRepMalware, whatever that is.Jon
I downloaded the the .zip file from GitHub. I didn't see any exe file
which wouldn't matter since I'm running Linux. When I expanded the .zip
file, there was a lot of C# source files, but no instructions on
compiling it. I tried to delete the folder and it failed. The only
thing left in the folder was a file named something like .nfs00000
something. I tried deleting it from root. It failed because it was in
use! I rebooted and managed to remove it.
Now I'm going to have to run diagnostic programs to see if it left
anything behind.
I did download the Linux executable. It looks like all those other 3D
CAD programs which I threw out when I discovered OpenSCAD.
I suppose that it might seem familiar to people used to AutoCAD or the like.
After finding that .nfs000 whatever file in the source, I wouldn't trust
it. It probably does have the FileRepMalware code.
Bob
1980: movie industry went to the Supreme Court to try to ban the VCR.
2002: 46% of their income is from rentals.
by the AVG software
Looking at the example on github, (I'm not wasting time downloading it)
it looks as if it is renamed openscad commands/script, linked together
in a similar way as other visual programming methods, e.g. ibm visual
age. It seems a very convoluted way of creating objects, far too much
granularity. I started reverse engineering the graph into openscad, and
it was tedious verbose code. Probably, that three hole plate would be 5
or 6 lines in openscad. I suppose it saves learning openscad syntax, but
that has been replaced by something which on the face of it looks more
complex. I suppose it may be useful for some, (the cylinder presents a
list of options which can be selected, for instance) but the graphical
representation defeats one of the main benefits of openscad, - text code
that can be easily shared.
That is the problem with freecad and other software. (except freecad
will at least generate huge multi-matrix code.)
Best wishes,
Ray
.zip file, there was a lot of C# source files, but no instructions on
in use! I rebooted and managed to remove it.
anything behind.
like.
trust it. It probably does have the FileRepMalware code.
Here's some code to create the plate, using the same variable names as
the example, but some values i guessed.
size=[50,40,8];
h_dm=4;
h_num=3;
margin=7;
module plate()
cube(size);
for (j=[1:1:h_num]){
d=(size[0]-margin-margin)/(h_num-1);
translate([margin+((j-1)d),size[1]/2,-size[2]])
cylinder(d=h_dm,h=3size[2],$fn=18);
plate();
for me, that is more understandable than the graphical method which has
some weird symbols. Familiarity breeds, etc.
it) it looks as if it is renamed openscad commands/script, linked
together in a similar way as other visual programming methods, e.g.
ibm visual age. It seems a very convoluted way of creating objects,
far too much granularity. I started reverse engineering the graph into
openscad, and it was tedious verbose code. Probably, that three hole
plate would be 5 or 6 lines in openscad. I suppose it saves learning
openscad syntax, but that has been replaced by something which on the
face of it looks more complex. I suppose it may be useful for some,
(the cylinder presents a list of options which can be selected, for
instance) but the graphical representation defeats one of the main
benefits of openscad, - text code that can be easily shared.
Best wishes,
Ray
This is not something that will work for everyone, but why tear it down for that? If it gives people some additional options or an easier
start to learn OpenSCAD, that's good, no?
I would not try to create designs via nodes/visual design if it's just the low-level nodes. But just imagine writing the scripts for higher
level modules and just assemble those in a visual design.
My go-to example for this is https://icestudio.io/ which is a similar tool for designing FPGA code. I would not like clicking together a
complex design by connecting hundreds or thousands of gates. But I can see some nice potential for having scripts defining complex blocks,
like RAM / CPU / IO and representing those in the visual editor.
