Hi Andy, If you are 3d printing, I guess you are aware that holes
generally come out smaller than the size you give, them, depending on
quite few factors, so you can't be that precise, without a bit of
testing. If you are drilling, then holes come out bigger! If you are
designing, then holes come out at exactly the correct size.
On 28/08/2020 20:11, AndyY via Discuss wrote:
The holes arround the circle are getting screws for holding the magnet. So if
I have the holes in a little bigger size it does not matter if there are
some errors of the position.
Concerning you post @JordanBrown: This is a very important post for me!
Thank you. I guess the error comes from the calcuation in the OpenSCAD
engine? Which means that this is the error of the exactly position of the
holes. As I wrote in the previous post I immediatelly need to check the vars
($fs/$fa) for further designs. If you have some more internal informations,
I'd like to know it...
I get precise 3D printed holes every time, see
https://github.com/nophead/NopSCADlib#Polyholes for vertical holes and
https://github.com/nophead/NopSCADlib#Horiholes for horizontal holes.
And for holes printed in mid air without support
https://github.com/nophead/NopSCADlib#hanging_hole
So if
vars
informations,
me! Thank you.
Glad to be of assistance.
I guess the error comes from the calculation in the OpenSCAD engine?
No. It's that OpenSCAD (and every other tool that generates STL)
approximates circles as polygons.
The more sides that you give the polygon, the smaller the difference is
between the approximation and a true circle.
The error, as a fraction, is (cos(360/n/2)-1).
If you approximate a circle as a triangle, the error is -50%. That is,
considering the distance from the center to the vertices to be
"correct", the distance from the center of the "circle" to the middles
of the edges is 50% less than that.
Continuing:
Error %
3
-50%
4
-29%
6
-13%
10
-5%
15
-2%
30
-0.5%
60
-0.1%
120
-0.03%
The question there is how much inaccuracy you can tolerate, versus the
processing costs of the increasing complexity of the figure.
Which means that this is the error of the exactly position of the holes.
No. The exact position is quite precise, far more precise than you need
to care about for most purposes.[*]
[*] There are occasionally rendering issues that are related to
precise positioning and sizing of objects, but those are
mathematical / computational issues; they have no direct bearing on
the practical position of the objects in a physical object.
The errors are in the difference between the diameter that you ask for,
and the diameter (in some senses) that you get.
If we assume that your fabrication process is perfect - that your 3D
printer will produce exactly the object that you model - then if you ask
for a circle with a diameter of 10, and approximate it with three sides,
the largest rod that you can put through that hole has a diameter of 5.
If you approximate it with 15 sides, the largest rod you can put through
it has a diameter of 9.78. With 120 sides, it has a diameter of 9.997.
I believe my 3D printer has an X-Y positioning resolution of 0.1mm. It
has a 0.4mm nozzle, and the plastic squishes out a bit. I don't know
exactly how those will translate into dimensional accuracy, but for
discussion purposes it doesn't seem unreasonable to guess that my
dimensional accuracy is no better than 0.1mm - that is, if I ask for a
10x10x10mm cube, the X and Y sides will be somewhere between 9.9 and
10.1mm. (It's probably not really that good.)
With 15 sides, the error from the polygon approximation on a 10mm circle
is about 0.2mm, or twice the theoretical accuracy of the device. With
30 sides, the error is about 0.05mm, or half the accuracy of the
device. That's saying that going from 3 sides to 15 is a big win, and
going from 15 to 30 is a small win, but more than 30 (actually, more
than something in the low 20s) is pointless because the other errors in
the system will swamp this one.
If you're using some other fabrication technology - if, for instance,
you are milling and polishing metal - then your system will likely be
more accurate and you may have correspondingly tighter restrictions on
the modeling errors.
As I wrote in the previous post I immediately need to check the vars
informations, I'd like to know it...
$fn is easy. It says how many sides a circle has, period.
That's easy, but it's not what you really want. A 10mm circle with 15
sides is awfully close to a perfect circle - you might not be able to
see the polygon-ness when printed - but on a 100mm circle it would very
much look like a polygon. On the other hand, if you ask for 100 sides,
your 10mm circle will have sides that are only 0.3mm long, not quite
imperceptibly small. No one setting will work for both small and large
circles.
$fa and $fs are an attempt to let you define values that will "work" at
all sizes.
$fa means "don't bother adding sides if the angle is less than this".
$fs means "don't bother adding sides if each side is less than this".
OpenSCAD uses whichever yields fewer sides.
For typical values, $fa controls the behavior on large circles, and $fs
controls the behavior on small circles.
Note: $fn is very useful for a different purpose. It is how you
explicitly ask OpenSCAD for a regular polygon. If you want an octagon,
you can use circle(d=<whatever>, $fn=8) and you will get an octagon, no
matter how large the circle is.
Note: none of this is "internal". It is all part of how OpenSCAD is
defined to model circles.
I realized there was an error in my previous tables - I missed that the
actual diameter of the big circle was 34+10 = 44, not 34. Here's
corrected tables:
For the default values ($fs=2, $fa=12):
Sides
Vertices
Diameter
Edges
Diameter
Error
Error
Percent
Outer
30
44 43.76
-0.24
-0.5%
Inner
10
6
5.71
-0.29
-4.9%
With $fs=1 and $fa=8:
Sides
Vertices
Diameter
Edges
Diameter
Error
Error
Percent
Outer
45
44
43.89
-0.11
-0.2%
Inner
19
6
5.92
-0.08
-1.4%
On 2020-08-28 20:54, Ray West wrote:
Where's the naughty step?
There is nothing "naughty" about it. This thread shows various examples
on how to model a simple case using scripting languages. Regardless of
language being used, for most people the goal is to express it in a
efficient, but expressive way that feels natural. What feels natural is
highly subjective, so there will be many different solutions, even
within the same language.
