I want to make a slightly curved cone, so it's a cylinder() call, but
I'd like about 15 degrees of bend in the cone over its' length. Think
of a curved Marlinspike, if you've done ropework.
There's no simple way. You need to construct a polyhedron.
There are libraries that will help you do this, mostly with the name
"sweep". Here is one such function:
https://github.com/revarbat/BOSL2/wiki/skin.scad#functionmodule-sweep
These generally operate by having you supply a polygon that is then
swept along a specified path to form a polyhedron.
Here's an example:
// Usual $fs, $fa, $fn control the number of sides of the circle.
$fs = 0.5;
step = 0.01; // Steps from 0 to 1 by this increment
bend = 15; // In degrees
height = 20; // Before bending
r1 = 3; // At base
r2 = 0; // At peak
path_transforms = [
for (t=[0:step:1-step])
xrot(bendt)
* translate([0,0,heightt])
* scale(1 + t*(r2-r1)/r1)
sweep(circle(r=r1), path_transforms);
