Sun, Dec 13, 2020 1:18 AM
openscad -o out.echo test_hull.scad
AppRun.wrapped: src/value.cc:211: Value Value::clone() const: Assertion
`false && "unknown Value variant type"' failed.
Not sure how to debug this. I'm also having a hard time figuring out what's
going on in general because the error messages have wrong line numbers (past
the end of the file).
Sun, Dec 13, 2020 2:31 AM
It seems like adding an "echo" statement provokes this segfault. Not sure if
that's significant. I can get the code to fail without a segfault if I
remove echo statements.
what's
(past
> what's
> (past
> Discuss@.openscad
HL
Hans L
Sun, Dec 13, 2020 1:34 PM
Did you mean to include an example script in your post because I'm not
seeing anything?
if
what's
(past
seeing anything?
> if
> > what's
> > (past
> > Discuss@.openscad
Sun, Dec 13, 2020 1:57 PM
All I can tell you at the moment is that the problem is caused by running the
hull function from BOSL2, which was why I was wondering about
troubleshooting strategies. (The hull function doesn't always cause the
segfault, only sometimes.)
If I try to run the BOSL2 regression tests, specifically the file
tests/test_hull.scad, I get a segfault.
Do I need to do a binary search on the code (comment out half, see if it
works, etc) to try to isolate the problem more? There's no way to get any
information about what causes the problem since it just crashes.
seeing anything?
sure
if
what's
(past
> seeing anything?
> avm4@
>> sure
>> if
>> > what's
>> > (past
>> > Discuss@.openscad
> Discuss@.openscad
> Discuss@.openscad
HL
Hans L
Sun, Dec 13, 2020 2:46 PM
Normally for debugging, I would run the example on a debug build of
OpenSCAD, under gdb, and get a full backtrace as a first step.
We don't distribute binaries with full debug info since they take up a few
hundred extra MB of space, so you'd need to build from source yourself.
seeing anything?
sure
if
what's
(past
> the
> > seeing anything?
> > avm4@
> >> sure
> >> if
> Assertion
> >> > what's
> >> > (past
> >> > Discuss@.openscad
> > Discuss@.openscad
> > Discuss@.openscad
HL
Hans L
Wed, Dec 16, 2020 8:31 PM
Just a quick update. After much head scratching and diagnostics, the cause
was whittled down to a minimal test script, and the issue was logged in
Github: https://github.com/openscad/openscad/issues/3541
A PR has already been created to fix this class of error. With any luck
the fix should be merged shortly and included in upcoming RC3.
Thanks for the report.
seeing anything?
sure
if
what's
>> the
>> > seeing anything?
>> > avm4@
>> >> sure
>> >> if
>> Assertion
>> >> > what's
>> numbers
>> >> > (past
>> >> > Discuss@.openscad
>> > Discuss@.openscad
>> > Discuss@.openscad
Wed, Dec 16, 2020 9:13 PM
Thanks for the effort troubleshooting and reducing the problem.
cause
> cause
