Working around CGAL color limitations, mesh post processing.
U
ufomorace
Sat, Sep 5, 2015 8:03 AM
Presently OpenSCAD doesnt support color render files.
Industry standard seems to be VRML2 and X3D, either color polygons or UV
colors.
I'm thinking of putting together a code which can compare the triangles of
an original colored mesh and the openscad CGAL mesh, find matching vertices
and coincident polygons, and color them based on the input file.
That is where it gets complex, perhaps you can provide advice on different
coincident-polygon comparisons, and potential pitfalls.
First I have to obtain openscad STL and the colored mesh so that they can
exist in the same mesh engine, with a list of triangles and vertices and
colors in arrays.
We already have that within openscad, except that i am a n00b programmer so
i would probably code it on another mesh engine. Then i have to get a VRML2
conversion code. I have to compare every polygon in one mesh to every
polygon in another mesh, to see if they exist on the same plane? If yes, to
see if they overlap as triangles? If they do share the same space then it's
safe to presume that they should be the same color, and thus to color the
entire openscad mesh and save it as VRML2.
Please advise me on the difficulties of the task? :) Is there any reason why
CGAL won't one day implement a similar post processing for colored mesh?
View this message in context: http://forum.openscad.org/Working-around-CGAL-color-limitations-mesh-post-processing-tp13698.html
Presently OpenSCAD doesnt support color render files. Industry standard seems to be VRML2 and X3D, either color polygons or UV colors. I'm thinking of putting together a code which can compare the triangles of an original colored mesh and the openscad CGAL mesh, find matching vertices and coincident polygons, and color them based on the input file. That is where it gets complex, perhaps you can provide advice on different coincident-polygon comparisons, and potential pitfalls. First I have to obtain openscad STL and the colored mesh so that they can exist in the same mesh engine, with a list of triangles and vertices and colors in arrays. We already have that within openscad, except that i am a n00b programmer so i would probably code it on another mesh engine. Then i have to get a VRML2 conversion code. I have to compare every polygon in one mesh to every polygon in another mesh, to see if they exist on the same plane? If yes, to see if they overlap as triangles? If they do share the same space then it's safe to presume that they should be the same color, and thus to color the entire openscad mesh and save it as VRML2. Please advise me on the difficulties of the task? :) Is there any reason why CGAL won't one day implement a similar post processing for colored mesh? -- View this message in context: http://forum.openscad.org/Working-around-CGAL-color-limitations-mesh-post-processing-tp13698.html Sent from the OpenSCAD mailing list archive at Nabble.com.
U
ufomorace
Sat, Sep 5, 2015 8:52 AM
Wiki says that X3D is the newest generation of VRML format. Meshlab and
Blender source code perhaps contain good examples of X3D file conversion. I
have found a conversion code for unity3D called unityx3d, so i could
probably do it all in Unity3d in a couple of days, the result would be a bit
impractical.
View this message in context: http://forum.openscad.org/Working-around-CGAL-color-limitations-mesh-post-processing-tp13698p13700.html
Wiki says that X3D is the newest generation of VRML format. Meshlab and Blender source code perhaps contain good examples of X3D file conversion. I have found a conversion code for unity3D called unityx3d, so i could probably do it all in Unity3d in a couple of days, the result would be a bit impractical. -- View this message in context: http://forum.openscad.org/Working-around-CGAL-color-limitations-mesh-post-processing-tp13698p13700.html Sent from the OpenSCAD mailing list archive at Nabble.com.
N
Neon22
Sat, Sep 5, 2015 11:07 AM
Personally I think this is a stopgap measure until - as they have indicated -
OpenSCAD eventually supports this feature (primarily for multiple
extruders).
So I'd have to say use a simple format to do this and not such a complex
format.
Specifically I suggest obj, or the proposed amf, as an export. But it
depends on what your final use is for this file and what that app needs.
  • IMHO VRML1,2 is out and X3D is a massive pile 99% of which you don't
    need.
  • OBJ is read by everyone especially if you keep it simple which in this
    case I believe it would be.
View this message in context: http://forum.openscad.org/Working-around-CGAL-color-limitations-mesh-post-processing-tp13698p13703.html
Personally I think this is a stopgap measure until - as they have indicated - OpenSCAD eventually supports this feature (primarily for multiple extruders). So I'd have to say use a simple format to do this and not such a complex format. Specifically I suggest obj, or the proposed amf, as an export. But it depends on what your final use is for this file and what that app needs. - IMHO VRML1,2 is out and X3D is a massive pile 99% of which you don't need. - OBJ is read by everyone especially if you keep it simple which in this case I believe it would be. -- View this message in context: http://forum.openscad.org/Working-around-CGAL-color-limitations-mesh-post-processing-tp13698p13703.html Sent from the OpenSCAD mailing list archive at Nabble.com.
N
Neon22
Sat, Sep 5, 2015 11:14 AM
more discussion has been had on amf, 3mf and color in these two posts (at
least):
View this message in context: http://forum.openscad.org/Working-around-CGAL-color-limitations-mesh-post-processing-tp13698p13704.html
more discussion has been had on amf, 3mf and color in these two posts (at least): - http://forum.openscad.org/Now-in-color-td13392.html - http://forum.openscad.org/New-3MF-file-format-td12525.html -- View this message in context: http://forum.openscad.org/Working-around-CGAL-color-limitations-mesh-post-processing-tp13698p13704.html Sent from the OpenSCAD mailing list archive at Nabble.com.
B
bobc
Sat, Sep 5, 2015 3:38 PM
It sounds a little complicated, I'm not sure if it would work. Where is the
original colored mesh derived from?
I have a version of OpenSCAD which implements rendered color, it use Carve
library so is also quite a bit faster than CGAL, although several useful
features of CGAL are not supported such as hull, minkowski. It can output
multiple STLs (one per color), or an AMF with one color per volume. I would
like to add other formats such as X3D.
To guide development it would be useful to have more use cases. So if you
have any sample models, and what the output mesh is to be used for, please
let me know.
View this message in context: http://forum.openscad.org/Working-around-CGAL-color-limitations-mesh-post-processing-tp13698p13706.html
It sounds a little complicated, I'm not sure if it would work. Where is the original colored mesh derived from? I have a version of OpenSCAD which implements rendered color, it use Carve library so is also quite a bit faster than CGAL, although several useful features of CGAL are not supported such as hull, minkowski. It can output multiple STLs (one per color), or an AMF with one color per volume. I would like to add other formats such as X3D. To guide development it would be useful to have more use cases. So if you have any sample models, and what the output mesh is to be used for, please let me know. -- View this message in context: http://forum.openscad.org/Working-around-CGAL-color-limitations-mesh-post-processing-tp13698p13706.html Sent from the OpenSCAD mailing list archive at Nabble.com.
U
ufomorace
Sun, Sep 6, 2015 8:37 AM
Hi Bobc, a carve version sounds ingenous. There is color by vertex and by
polygon and by uvs, i have found that PLY also does color by vertex, it's a
surprise to me, i was just thinking of color by triangle only because it is
a clear contrast. Shapeways seems to only accept vrml2 and x3d files for
color. It's to render any kinds of unions made with different color cubes. i
was hoping to print variations of this code in color:
https://dl.dropboxusercontent.com/u/114667999/randfms.scad
Neon22, yes it's a bit unwieldy x3d given all the xml, ill have to triple my
magnesium supplements prior to reading the specifications doc :D I will have
to read what they say on the discussion page as it sounds confusing. It's
much more difficult for me to understand a programming library to find where
the triangles and indices are kept than to actually write code to compare
all the source file triangles to the rendered file and copy the rendered
file ones so that they are the same as the input colors.
View this message in context: http://forum.openscad.org/Working-around-CGAL-color-limitations-mesh-post-processing-tp13698p13709.html
Hi Bobc, a carve version sounds ingenous. There is color by vertex and by polygon and by uvs, i have found that PLY also does color by vertex, it's a surprise to me, i was just thinking of color by triangle only because it is a clear contrast. Shapeways seems to only accept vrml2 and x3d files for color. It's to render any kinds of unions made with different color cubes. i was hoping to print variations of this code in color: https://dl.dropboxusercontent.com/u/114667999/randfms.scad Neon22, yes it's a bit unwieldy x3d given all the xml, ill have to triple my magnesium supplements prior to reading the specifications doc :D I will have to read what they say on the discussion page as it sounds confusing. It's much more difficult for me to understand a programming library to find where the triangles and indices are kept than to actually write code to compare all the source file triangles to the rendered file and copy the rendered file ones so that they are the same as the input colors. -- View this message in context: http://forum.openscad.org/Working-around-CGAL-color-limitations-mesh-post-processing-tp13698p13709.html Sent from the OpenSCAD mailing list archive at Nabble.com.
U
ufomorace
Wed, Sep 9, 2015 1:41 AM
So i am checking this X3D format controversy. So far it's fascinating.
Attempting to save a cube file with different colors on different faces, at
first glance it would be very easy to make an X3D file parser that saves
suitable files from .scad renders:
The X3D header and footer definition code can be only 4-5 lines:
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE X3D PUBLIC &quot;http://www.web3d.org/specifications/x3d-3.3.dtd&quot; &quot;&quot;> <X3D> <Scene> <Shape> //some vertex and color arrays, see example1.x3d example1.x3d <http://forum.openscad.org/file/n13748/example1.x3d> </Shape> </Scene> </X3D>
color by vertex has to be set to false and there has to be a colorIndex
array, perhaps there has to be multiple materials in the X3D it said.
If you have Blender, you can make a color cube and save as X3D as an example
file, and then copy the beginning and end text into an x3d parsing routing
and write the arrays differently. I don't have blender i would be happy if
someone sends a multi material x3d file.
Afterwards, I found out what X3D is all about. it /can/ save concise 3d
files, and it can also display 3d files in crazy ways in smartphones and web
browsers.
It's an amazing file format, it can contain alot of lighting and scene
information and even do some kinds of extrusion of pentagons and stuff...
I found this amazing page with examples, i am  going to attempt to turn this
into a colored cube
http://examples.x3dom.org/example/x3dom_twoSidedMaterial.html  and then i
can write x3d parsing program. i write very simple code so anything i do
with triangle indices post processing of an STL should be easy to port to
openSCAD.
i found  this
http://examples.x3dom.org/example/x3dom_multiIndex-large.xhtml  and  this
http://examples.x3dom.org/example/x3dom_vertCols.xhtml  ... Amazing file
format. It is equivalent to VRML2 for our 3d kinds of files, they are both
fine formats.
Ok the name X3D is boring, so i will just have to put on my 3dkini and play
some netbool :D
View this message in context: http://forum.openscad.org/Working-around-CGAL-color-limitations-mesh-post-processing-tp13698p13748.html
So i am checking this X3D format controversy. So far it's fascinating. Attempting to save a cube file with different colors on different faces, at first glance it would be very easy to make an X3D file parser that saves suitable files from .scad renders: The X3D header and footer definition code can be only 4-5 lines: <?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE X3D PUBLIC &quot;http://www.web3d.org/specifications/x3d-3.3.dtd&quot; &quot;&quot;> <X3D> <Scene> <Shape> //some vertex and color arrays, see example1.x3d example1.x3d <http://forum.openscad.org/file/n13748/example1.x3d> </Shape> </Scene> </X3D> color by vertex has to be set to false and there has to be a colorIndex array, perhaps there has to be multiple materials in the X3D it said. If you have Blender, you can make a color cube and save as X3D as an example file, and then copy the beginning and end text into an x3d parsing routing and write the arrays differently. I don't have blender i would be happy if someone sends a multi material x3d file. Afterwards, I found out what X3D is all about. it /can/ save concise 3d files, and it can also display 3d files in crazy ways in smartphones and web browsers. It's an amazing file format, it can contain alot of lighting and scene information and even do some kinds of extrusion of pentagons and stuff... I found this amazing page with examples, i am going to attempt to turn this into a colored cube <http://examples.x3dom.org/example/x3dom_twoSidedMaterial.html> and then i can write x3d parsing program. i write very simple code so anything i do with triangle indices post processing of an STL should be easy to port to openSCAD. >From this page of examples <http://examples.x3dom.org/simpleExamples.html> i found this <http://examples.x3dom.org/example/x3dom_multiIndex-large.xhtml> and this <http://examples.x3dom.org/example/x3dom_vertCols.xhtml> ... Amazing file format. It is equivalent to VRML2 for our 3d kinds of files, they are both fine formats. Ok the name X3D is boring, so i will just have to put on my 3dkini and play some netbool :D -- View this message in context: http://forum.openscad.org/Working-around-CGAL-color-limitations-mesh-post-processing-tp13698p13748.html Sent from the OpenSCAD mailing list archive at Nabble.com.
U
ufomorace
Wed, Sep 9, 2015 3:21 AM
Ok i have figured it out... here is an example of color per face cube file,
just have to write in different arrays.
View this message in context: http://forum.openscad.org/Working-around-CGAL-color-limitations-mesh-post-processing-tp13698p13749.html
Ok i have figured it out... here is an example of color per face cube file, just have to write in different arrays. -- View this message in context: http://forum.openscad.org/Working-around-CGAL-color-limitations-mesh-post-processing-tp13698p13749.html Sent from the OpenSCAD mailing list archive at Nabble.com.
U
ufomorace
Thu, Sep 10, 2015 11:42 AM
Ok i have written an X3D color per face parsing code. It writes color X3D and
i don't have the original colored vertex array from openscad so i can't
color my model as originally intentioned... I have tried instead to color it
by angle of the faces of the elements.
I just worked for 1 hour to understand why there is a difference in the
angles of the normals of triangles that are at the same angle, what
invisible mesh particularity is making my code bug slightly. So my
coloration results are not practical for the moment, i would nearly prefer
to code it directly into openSCAD for a solution. The x3d Export code i have
coded was very straightforwards and saves the files fine every time. All
that is missing is to compare the colors of the input mesh and write them to
the output mesh.
1> i dont know what language OpenSCAD is written in
2> i dont know how private/static/reserved/next to window/void functions
work
3> i don't know what variables to save the input array to, for later
comparison to the output mesh, perhaps i should write it to a .txt file and
read it after CGAL has finised writing, i dont know.
4> Perhaps someone could supply me with a coding framework for openscad
where i have access to the input arrays of objects and their colors, and the
output ones, and from there i can write a code that saves a color x3d file.
http://forum.openscad.org/file/n13756/icos_colors.jpg
here is the x3d file i can save from an openscad .stl output:
MATRICES24620.x3d http://forum.openscad.org/file/n13756/MATRICES24620.x3d
View this message in context: http://forum.openscad.org/Working-around-CGAL-color-limitations-mesh-post-processing-tp13698p13756.html
Ok i have written an X3D color per face parsing code. It writes color X3D and i don't have the original colored vertex array from openscad so i can't color my model as originally intentioned... I have tried instead to color it by angle of the faces of the elements. I just worked for 1 hour to understand why there is a difference in the angles of the normals of triangles that are at the same angle, what invisible mesh particularity is making my code bug slightly. So my coloration results are not practical for the moment, i would nearly prefer to code it directly into openSCAD for a solution. The x3d Export code i have coded was very straightforwards and saves the files fine every time. All that is missing is to compare the colors of the input mesh and write them to the output mesh. 1> i dont know what language OpenSCAD is written in 2> i dont know how private/static/reserved/next to window/void functions work 3> i don't know what variables to save the input array to, for later comparison to the output mesh, perhaps i should write it to a .txt file and read it after CGAL has finised writing, i dont know. 4> Perhaps someone could supply me with a coding framework for openscad where i have access to the input arrays of objects and their colors, and the output ones, and from there i can write a code that saves a color x3d file. <http://forum.openscad.org/file/n13756/icos_colors.jpg> here is the x3d file i can save from an openscad .stl output: MATRICES24620.x3d <http://forum.openscad.org/file/n13756/MATRICES24620.x3d> -- View this message in context: http://forum.openscad.org/Working-around-CGAL-color-limitations-mesh-post-processing-tp13698p13756.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Sep 10, 2015 12:38 PM
Von: ufomorace ant.stewart@yahoo.com
C++
functions work
I'd say that's not a huge issue, following the examples of
the other exports is quite good enough to get started.
Actually the whole export part needs some refinement as it
currently has some code duplication due to different internal
data structures.
(e.g. https://github.com/openscad/openscad/issues/910,
https://github.com/openscad/openscad/issues/909)
I don't understand that part. The current export code simply
writes data directly into a file output stream as it iterates
over the mesh.
See:
https://github.com/openscad/openscad/blob/master/src/export.cc
I'm not sure what coding framework means. Depending on which
Operating System you are working the process differs a bit.
On a recent Linux system, it's probably easiest to follow
the steps from the readme on GitHub as essentially all the
dependencies are available from the distributions.
For Windows, there's a description to set-up a MSYS2 based
development environment in the Manual.
(https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Building_on_Microsoft_Windows)
On MacOS, the dependencies are best compiled separately, I
think, but there are scripts to help with that.
Von: ufomorace <ant.stewart@yahoo.com> > 1> i dont know what language OpenSCAD is written in > C++ > 2> i dont know how private/static/reserved/next to window/void > functions work > I'd say that's not a huge issue, following the examples of the other exports is quite good enough to get started. Actually the whole export part needs some refinement as it currently has some code duplication due to different internal data structures. (e.g. https://github.com/openscad/openscad/issues/910, https://github.com/openscad/openscad/issues/909) > 3> i don't know what variables to save the input array to, > for later comparison to the output mesh, perhaps i should > write it to a .txt file and read it after CGAL has finised > writing, i dont know. > I don't understand that part. The current export code simply writes data directly into a file output stream as it iterates over the mesh. See: https://github.com/openscad/openscad/blob/master/src/export.cc > 4> Perhaps someone could supply me with a coding framework > for openscad where i have access to the input arrays of > objects and their colors, and the output ones, and from there > i can write a code that saves a color x3d file. > I'm not sure what coding framework means. Depending on which Operating System you are working the process differs a bit. On a recent Linux system, it's probably easiest to follow the steps from the readme on GitHub as essentially all the dependencies are available from the distributions. For Windows, there's a description to set-up a MSYS2 based development environment in the Manual. (https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Building_on_Microsoft_Windows) On MacOS, the dependencies are best compiled separately, I think, but there are scripts to help with that. ciao, Torsten.
