I can't find anything wrong with that STL with either NetFabb or OpenSCAD,
so I don't understand how they can do more with an STL from FreeCAD. As far
as I know there are only ASCII and binary STLs and they contain the same
information. I don't think there is any way to embed any more information.
It might be worth checking if it is a binary / ASCII issue but it seems
very unlikely if they can open it.
On Wed, 16 Nov 2022 at 01:31, neri-engineering via Discuss <
From: neri-engineering neri-engineering@protonmail.com
Cc:
Bcc:
Date: Wed, 16 Nov 2022 01:30:41 +0000
Subject: [OpenSCAD] SolidWorks & OpenSCAD interoperability
Sorry if this has been asked many times before; I'm sure it has.
Today was a first; I visited a job shop (machine shop) that has very
advanced CAM / CNC tools. They use SolidWorks software.
I came there with my dinky STL files. Not even the simplest STL file that
I brought them was workable in SolidWorks. Yes they could open it and see
it, but nothing besides that. They could not measure the part along
different faces, they could not do CAM with it, etc. It's expected.
Especially if the STL is nothing but a set of 2D triangular faces in
3-space which make up a 2-manifold. For reference I attach the simplest
STL file that they were not able to do anything with (besides visualize in
SolidWorks), named 'green-shaft-join-pin.stl'.
I have been pursuing information in how to prevent the necessary
re-construction of my parts in SolidWorks. I found something like this:
Got it to work perfectly and with minimal effort.
Export as CSG from OpenSCAD
open CSG in FreeCAD
Save as STEP File
Open STEP in Solidworks and save as Solidworks Part.
Can now be edited and used in solidworks Assemblies
(Found here: https://reprap.org/forum/read.php?1,220486)
I will need to do something similar. Was wondering the best approach. Is
the above a suggested method? In particular they need to do Computer Aided
Manufacturing with my part. Also they need to make engineering drawings of
my part, which is super easy with SolidWorks. My parts have threads, which
I generated myself with polyhedron(). But I can remove those for
simplicity.
I was not anticipating this snafu. I will not abandon OpenSCAD because I
really like the way you can program a part and not point & click.
Maybe if I raised the segment count on my part it would help SolidWorks?
Just wondering.
The guys at the machine shop made mention that they've been able to open
STL files from other software (e.g. FreeCAD), in SolidWorks. Now I doubt
what they said to be True. Inherently the STL does not have sufficient
information to do CAM, without heuristics and guesswork (which may be built
into SolidWorks, or not). I don't have SolidWorks at my disposal so I have
to make intelligent guesses and give them revised files, asking them "How
does that work? Better?" So I need to take the most intelligent course of
action.
Respectfully,
Nerius
Sent with Proton Mail https://proton.me/ secure email.
From: neri-engineering via Discuss discuss@lists.openscad.org
Cc: neri-engineering neri-engineering@protonmail.com
Bcc:
