a warning message from the Mac OS build - itstool complaining about excape codes
V
vulcan_ (at) mac.com
Tue, Sep 23, 2025 8:21 PM
this is not in OpenSCAD code is it?
388 translated messages, 109 fuzzy translations, 169 untranslated messages.
/usr/local/Cellar/itstool/2.0.7_1/libexec/bin/itstool:223: SyntaxWarning: invalid escape sequence '\s'
if re.sub('\s+', ' ', text).strip() != '':
/usr/local/Cellar/itstool/2.0.7_1/libexec/bin/itstool:321: SyntaxWarning: invalid escape sequence '\s'
message = re.sub('\s+', ' ', message).strip()
/usr/local/Cellar/itstool/2.0.7_1/libexec/bin/itstool:459: SyntaxWarning: invalid escape sequence '\s'
return re.sub('\s+', ' ', self.locnote).strip()
/usr/local/Cellar/itstool/2.0.7_1/libexec/bin/itstool:461: SyntaxWarning: invalid escape sequence '\s'
return '(itstool) link: ' + re.sub('\s+', ' ', self.locnoteref).strip()
/usr/local/Cellar/itstool/2.0.7_1/libexec/bin/itstool:892: SyntaxWarning: invalid escape sequence '\<'
regex = re.compile('(.*) \<(.*)\>, (.*)')
/usr/local/Cellar/itstool/2.0.7_1/libexec/bin/itstool:927: SyntaxWarning: invalid escape sequence '\s'
if re.sub('\s+', '', prevtext) == '':
/usr/local/Cellar/itstool/2.0.7_1/libexec/bin/itstool:1471: SyntaxWarning: invalid escape sequence '\.'
locale_pattern = re.compile('([a-zA-Z0-9-]+)([A-Za-z0-9]+)?(@[A-Za-z0-9]+)?(\.[A-Za-z0-9]+)?')
[ 98%] Built target OpenSCAD
this is not in OpenSCAD code is it? > 388 translated messages, 109 fuzzy translations, 169 untranslated messages. > > /usr/local/Cellar/itstool/2.0.7_1/libexec/bin/itstool:223: SyntaxWarning: invalid escape sequence '\\s' > > if re.sub('\\s+', ' ', text).strip() != '': > > /usr/local/Cellar/itstool/2.0.7_1/libexec/bin/itstool:321: SyntaxWarning: invalid escape sequence '\\s' > > message = re.sub('\\s+', ' ', message).strip() > > /usr/local/Cellar/itstool/2.0.7_1/libexec/bin/itstool:459: SyntaxWarning: invalid escape sequence '\\s' > > return re.sub('\\s+', ' ', self.locnote).strip() > > /usr/local/Cellar/itstool/2.0.7_1/libexec/bin/itstool:461: SyntaxWarning: invalid escape sequence '\\s' > > return '(itstool) link: ' + re.sub('\\s+', ' ', self.locnoteref).strip() > > /usr/local/Cellar/itstool/2.0.7_1/libexec/bin/itstool:892: SyntaxWarning: invalid escape sequence '\\<' > > regex = re.compile('(.\*) \\<(.\*)\\>, (.\*)') > > /usr/local/Cellar/itstool/2.0.7_1/libexec/bin/itstool:927: SyntaxWarning: invalid escape sequence '\\s' > > if re.sub('\\s+', '', prevtext) == '': > > /usr/local/Cellar/itstool/2.0.7_1/libexec/bin/itstool:1471: SyntaxWarning: invalid escape sequence '\\.' > > _locale_pattern = re.compile('(\[a-zA-Z0-9-\]+)(_\[A-Za-z0-9\]+)?(@\[A-Za-z0-9\]+)?(\\.\[A-Za-z0-9\]+)?') > > \[ 98%\] Built target OpenSCAD
Tue, Sep 23, 2025 8:32 PM
No...
itstool
...this is used to handle translation of the application
meta data file (openscad.appdata.xml).
That error looks to me like running a python program with
an unsupported (newer) version of python that complains
about the regex not being marked as raw-string. But that's
just guessing.
On 23.09.25 22:21, vulcan_--- via Discuss wrote: > this is not in OpenSCAD code is it? No... > itstool ...this is used to handle translation of the application meta data file (openscad.appdata.xml). That error looks to me like running a python program with an unsupported (newer) version of python that complains about the regex not being marked as raw-string. But that's just guessing. ciao, Torsten.
