echoing < and > characters
K
kitwallace
Tue, Nov 19, 2019 12:27 PM
I've only just noticed that
echo("< abc >");
echo("< abc >");
produces different output between versions 2015-03 and 2019-05
in the former the output from both lines is the same, in the later, the
first line is blank - plays havoc with my SVG generation!
bug or feature?
I've only just noticed that echo("< abc >"); echo("&lt; abc &gt;"); produces different output between versions 2015-03 and 2019-05 in the former the output from both lines is the same, in the later, the first line is blank - plays havoc with my SVG generation! bug or feature? -- Sent from: http://forum.openscad.org/
Tue, Nov 19, 2019 1:14 PM
Ii is a side effect of changing the log to be scrolling, a new class was
used. It now follows normal HTML rules IIRC.
echo("< abc >");
echo("< abc >");
bug or feature?
Ii is a side effect of changing the log to be scrolling, a new class was used. It now follows normal HTML rules IIRC. On Tue, 19 Nov 2019 at 12:14, kitwallace <kit.wallace@gmail.com> wrote: > I've only just noticed that > > echo("< abc >"); > echo("&lt; abc &gt;"); > > produces different output between versions 2015-03 and 2019-05 > > in the former the output from both lines is the same, in the later, the > first line is blank - plays havoc with my SVG generation! > > bug or feature? > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
