Hello,
after several happy and sometimes head-scratchy years with OpenSCAD I’m finally at asking the list something again. I’m trying to make a 3d puzzle of a truncated dodecahedron, using the maths in this file: https://www.printables.com/de/model/430670-truncated-icosahedron-rounded-soccer-form
Now, I have modules of puzzle pieces and places where they should go, and the puzzle pieces come in a large and a small version, made with offset. The puzzle pieces have an order and they sit in a list. I would like to take pieces from that list by index and with or without the offset. I tried it with children() but couldn’t find out how to get the offset-parameter across. Any idea how to do that?
Simplified code, and please just ignore the maths, the question is at the end of the code.
Thanks in advance!
Benjamin
// Parameters
s = 10; // basic edgelenth
gap = 0.4; // gap between puzzle pieces
t = s/2; // maximal thickness of shell
// Math (Thanks to Lukas Süss aka mechadense for typing it math into an OpenSCAD file!)
sph_diam = (s3)1/6sqrt(29/2+9/2sqrt(5));
rhex = s;
rpent = (s/2)/cos(54);
hhex = sqrt(pow(sph_diam,2)-pow(rhex,2));
hpent = sqrt(pow(sph_diam,2)-pow(rpent,2));
hh = (180-90-acos(-1/3sqrt(5))/2)2;
hp = atan(rhexcos(30)/hhex)+atan(rpentcos(72/2)/hpent);
pp = 2atan(rpent/hpent) + 2atan((s/2)/(hhex/cos(hh/2)));
// Building blocks
module five(n, gap=0)
translate([0,0,-hpent]) {
color("black") linear_extrude(t) offset(gap, $fn=10)
rotate([0, 0, 90]) circle(t, r=s/(2*sin(36)), $fn = 5);
linear_extrude(1) mirror([1,0,0]) text(str(n), size=s/2, valign="center", halign="center");
module six(n, gap=0)
translate([0,0,-hhex]) {
color("white") linear_extrude(t) offset(gap, $fn=10)
circle(t, r=s, $fn = 6);
// Flow control
module ball() {
// here I would like to do things with the pieces with or without the offset, for instance:
for (i = [0 : 2 : $children -1])
let(gap=gap)children(i);
// or
for (i = [1 : 2 : $children -1])
children(i, gap=0);
// but I don't know how
ball() {
rotate([hp,0,60]) five(1);
six(2);
rotate([hh,0,0]) six(3);
rotate([hh,0,0]) rotate([hh,0,60]) six(4);
rotate([hp+pp,180,0]) rotate([0,0,180]) five(5);
rotate([hh,0,0]) rotate([hh,0,-60]) six(6);
rotate([hp,0,-60]) five(7);
rotate([hh,0,-120]) six(8);
rotate([hp,0,180]) five(9);
Not sure if this what you mean, but you can pass values from a parent to
its children using $variables.
On Wed, 6 Sept 2023 at 19:41, Benjamin Wand benjamin.wand@web.de wrote:
Hello,
end of the code.
Thanks in advance!
Benjamin
// Parameters
OpenSCAD file!)
rhex = s;
// Building blocks
// Flow control
module ball() {
// or
children(i, gap=0);
ball() {
six(2);
That sounds right but I can’t find any code examples in the wikibook, they are all just referencing children by index and with no further parameter, could you point me to one? I’d like to say something like "give me child 4 with the offset and child 5 without."
(https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/User-Defined_Functions_and_Modules#Children)
Am 06.09.2023 um 20:50 schrieb nop head nop.head@gmail.com:
Not sure if this what you mean, but you can pass values from a parent to its children using $variables.
On Wed, 6 Sept 2023 at 19:41, Benjamin Wand <benjamin.wand@web.de mailto:benjamin.wand@web.de> wrote:
Hello,
Thanks in advance!
Benjamin
// Parameters
rhex = s;
// Building blocks
// Flow control
module ball() {
// or
children(i, gap=0);
ball() {
six(2);
Something like this:
module parent() {
let($offset = 1) children(4);
let($offset = 0) children(5);
Then in the child you can access $offset. It isn't passed a named argument
but it is accessible. A bit of an ugly work around for that fact you can't
pass parameters to children.
Hello,
end of the code.
Thanks in advance!
Benjamin
// Parameters
OpenSCAD file!)
rhex = s;
// Building blocks
// Flow control
module ball() {
// or
children(i, gap=0);
ball() {
six(2);
Mh, changing the offset in module five() or module six() or ball() does have an effect, but in module ball(), where I would want it, it won’t work. What am I missing?
The only option that comes to my mind is having all things in ball() twice, once with and once without the offset to be able to access it from module ball but that would be a bit of an ugly double code.
// Building blocks
module five(n, offset)
translate([0,0,-hpent]) { color("black") linear_extrude(t) rotate([0, 0, 90])
if (offset == true) { offset(gap, $fn=10)
circle(t, r=s/(2sin(36)), $fn = 5);}
else {
module six(n, offset)
translate([0,0,-hhex]) { color("white") linear_extrude(t)
circle(t, r=s, $fn = 6);}
else {
// Flow control
module ball() {
let($offset = false) children([1 : 2 : $children -1]);
let($offset = true) children([0 : 2 : $children -1]);
ball() {
six(2);
Am 06.09.2023 um 21:45 schrieb nop head nop.head@gmail.com:
module parent() {
Then in the child you can access $offset. It isn't passed a named argument but it is accessible. A bit of an ugly work around for that fact you can't pass parameters to children.
On Wed, 6 Sept 2023 at 20:42, Benjamin Wand <benjamin.wand@web.de mailto:benjamin.wand@web.de> wrote:
Am 06.09.2023 um 20:50 schrieb nop head <nop.head@gmail.com mailto:nop.head@gmail.com>:
Hello,
Thanks in advance!
Benjamin
// Parameters
rhex = s;
// Building blocks
// Flow control
module ball() {
// or
children(i, gap=0);
ball() {
six(2);
This may be a case of the "interesting" scoping behavior for $ variables
that I described in this thread:
https://lists.openscad.org/empathy/thread/YUCPSTGM45U27DSWTSJ5PXS6GVEFF6RT
You aren't using $offset in five and six. You have a parameter called
offset.
Try
ball() {
rotate([hp,0,60]) five(1, $offset);
six(2, $offset);
rotate([hh,0,0]) six(3, $offset );
rotate([hh,0,0]) rotate([hh,0,60]) six(4 , $offset );
rotate([hp+pp,180,0]) rotate([0,0,180]) five(5, $offset );
rotate([hh,0,0]) rotate([hh,0,-60]) six(6, $offset );
rotate([hp,0,-60]) five(7, $offset );
rotate([hh,0,-120]) six(8, $offset );
On Wed, 6 Sept 2023 at 21:54, Jordan Brown openscad@jordan.maileater.net
What am I missing?
Ooooh, that’s it, thanks a lot!
Am 06.09.2023 um 23:06 schrieb nop head nop.head@gmail.com:
You aren't using $offset in five and six. You have a parameter called offset.
Try
ball() {
six(2, $offset);
On Wed, 6 Sept 2023 at 21:54, Jordan Brown <openscad@jordan.maileater.net mailto:openscad@jordan.maileater.net> wrote:
This may be a case of the "interesting" scoping behavior for $ variables that I described in this thread:
