gearModule.scad http://forum.openscad.org/file/n11323/gearModule.scad
I've just written this code that creates a gear based on different
parameters. I just posted it here to see if anyone has any suggestions for
improvements or extra details I can add. Also I thought that someone might
benefit from this if they aren't able to make a gear themselves.
Basically, what do you think? How can this be improved? And enjoy!
View this message in context: http://forum.openscad.org/Gear-Making-Code-tp11323.html
Teeth need to be involutes (think of trapezoids warped along the circle that
forms the circular pitch of the gear).
And have a look at https://github.com/openscad/MCAD/blob/dev/gears/involute_gears.scad.
Kind regards,
Loong Jin
Wouldn't it work well enough if it wasn't involute?
View this message in context: http://forum.openscad.org/Gear-Making-Code-tp11323p11360.html
Well that depends what your usage will be.
(1) For the virtual world, a non-involute shape will work fine.
(2) For the physical world, it can be no doubt maked to 'work', at least for a
little while, especially if it is carrying virtually no load and the spacings
can be iterated until they mesh and one has little concern for noise or life
time of the gears.
(3) For the physical world with a real load, maybe not so much :-)
Nice description at wikipedia:
http://en.wikipedia.org/wiki/Involute_gear
Phil(f) in WI
Thanks. I'll just give it go on my schools 3D printer and see what happens.
What the worst that can happen. Besides the filament isn't too expensive
anyway.
View this message in context: http://forum.openscad.org/Gear-Making-Code-tp11323p11369.html
If you try a bit of code like this at the end of your file to instantiate 2
gears:
rotate($t*360) //First gear rotation
gear(numberOfTeeth,widthOfTeeth,heightOfTeeth,thicknessOfGear,radiusOfHoleForShaft,sidesOfShaft);
translate([48, 0, 0]) //Second gear X offset for first (48 units is a guess)
rotate(360/40-$t*360, [0, 0, 1]) //Second gear rotation + 1/2 tooth offset
you can view it in animate mode ($t can be made to represent the frame time,
causing gears to rotate). Looking at the meshing point in the animation, I
suspect your gears may jam at a 48 unit separation.
View this message in context: http://forum.openscad.org/Gear-Making-Code-tp11323p11370.html
anyway.
Sure, if your aim is to learn why non-involute gears aren't good. But if you
want to make usable gears with minimal effort, why not just use MCAD's gear
generator? The involute teeth are all generated nicely already, and all you need
to do is play with the arguments.
Kind regards,
Loong Jin
