Hey everybody
I am in my first week of Openscad, hope you will help me in the right
direction.
I think I may have made a mess of my project, but I hope you can see what I
did wrong.
My difference() text cutout on one arm of my project is not working properly
I know most of my code should be cleaned up, but my project goes haywire
every time I change something at this point, and I really just want a rough
prototype for printing.
Best
Anders
My project (the part in bold should be my problem):
//rotering af urholder til print:
rotate([90,150,0]){
//rundt rør
rotate([0,0,60]){
cylinder(h=45, r=26, center=true, $fn=150);
cylinder(h=41, r=23, center=true, $fn=80);
translate([22,0,0]){
rotate([0,90,0])cube([46,40,9], center=true);}}
translate([16,0,0]){
rotate([0,90,0])cube([45,38,3], center=true);}
//venstre fod
translate([0,-33,30]){
rotate(a=45, v=[1,0,0]){ cube([34,3,50],center=true);
//trækker indersiden af cylinder fra
cylinder(h=45, r=24, center=true, $fn=80);
//hul til snor til rorline
translate([8,-30,30]){
rotate([-45,0,0]){ cylinder(h = 10, r=2, center = true, $fn=60);}}
//trækker skrå sider på fod fra
translate([8,-52,0]){
rotate(a=-15,v=[0,0,1]){ cube([55,55,55]);
mirror([1,0,0]){
//højre fod
mirror([0,0,1]){
//Navn i urholder
rotate([0,-90,90]){
translate([-8,-5,-10]){
linear_extrude(height=20){
text("NBL", $fn=150);}}
///trækker indersiden af cylinder fra
///trækker skrå sider på fod fra
rotate(a=-15,v=[0,0,1]){ cube([55,55,55]);}}
mirror([1,0,0]){
//bagerste fod
translate([-30,-23,0]){
rotate(a=20, v=[0,0,1]){ cube([50,3,45],center=true);
//trækker hul til urrem fra
rotate([0,-90,45]){
cylinder(h=62, r1=23, r2=14, center=true, $fn=80);}
cylinder(h=46, r=23, center=true, $fn=80);
translate([-47,-28,-43]){
rotate(a=-15,v=[0,-1,0]){ cube([55,55,55], center=true);}}
mirror([0,0,1]){
rotate(a=-15,v=[0,-1,0]){ cube([55,55,55], center=true);}}}
//platform til sugekop h
translate([0,-52,54]){
rotate(a=10,v=[1,0,0]){
cube([17,3,15], center=true);}}
translate([0,0,55]){
rotate([90,0,0]){
cylinder(h=120, r=2.5, center=true, $fn=200);}}
//platform til sugekop v
mirror([0,0,1]){
rotate([90,0,0]){
//platform til sugekop bag
translate([-60,-31.5,0]){
cube([17,3,26], center=true);}
translate([-61,0,0]){
rotate([90,0,0]){
[ For anybody else: the * in front of the mirror() invocation is the
forum software saying "bold". ]
I think you're having two problems:
Let's apply some indentation:
mirror([0,0,1]){
//Navn i urholder
rotate([0,-90,90]){
linear_extrude(height=20, convexity=10){
cube([55,55,55]);
mirror([1,0,0]){
cube([55,55,55]);
//bagerste fod
Now the problem becomes more apparent. You have a cube and the text,
minus a cylinder, minus two cubes.
Option 1: add in another difference():
mirror([0,0,1]){
difference() { // NEW
//Navn i urholder
rotate([0,-90,90]){
cube([55,55,55]);
mirror([1,0,0]){
cube([55,55,55]);
//bagerste fod
Option 2: Move the text out to be a child of the original difference()
(and duplicate the transformations):
mirror([0,0,1]){
translate([0,-33,30]){ // COPIED
//Navn i urholder
rotate([0,-90,90]){ // MOVED
cube([55,55,55]);
mirror([1,0,0]){
cube([55,55,55]);
//bagerste fod
Thank you so much. (:
I ended up adding an extra difference and it looks great! Added a cube to
hold the 2 floating pieces in my B. But i don't really get how it makes a
difference, as you only moved it below my translate and rotate? Is there a
maximum of how many elements i can subtract with difference?
I guess I am just being blinded by my own hideous code. :-)
Best
Glad to be of assistance.
Or just don't have it punch all the way through.
No, but look at the indentation.
When you say
A;
B;
C;
you are asking for A, subtract B, subtract C. Each of A, B, and C can
be arbitrarily complex.
Here's what you had written:
//Navn i urholder
rotate([0,-90,90]){
That entire "translate" block is the A in the difference operation. The
first thing being subtracted from the object, the B in the difference,
is the cylinder. You're saying something like (ignoring translates and
rotates)
(cube plus text) minus cylinder minus cube minus cube
My "option 1", adding in another difference(), makes it be
(cube minus text) minus cylinder minus cube minus cube
and my "option 2", pulling the text out, makes it be
cube minus text minus cylinder minus cube minus cube
Indentation is your friend. Be obsessive about it.
