I
irevdev
Sat, Aug 15, 2020 11:05 AM
I recently been giving some love to a library I wrote to help with radii in
OpenSCAD.
Personally, the library is pretty bound to how I think about cading parts
now, I like to think it both helps with adding fillets as well as leveraging
the battle test paradigm of extruding from sketches of other cad packages
since it heavily uses polygons.
There are a number of function/modules, but the main api is
http://forum.openscad.org/file/t1892/easy-api.png
Though with some of the more recend editions I've been diving into
polyhedrons in order to round the end of polygons.
http://forum.openscad.org/file/t1892/polyRound-extrude.png
The feature list can be found here:
https://kurthutten.com/blog/round-anything-a-pragmatic-approach-to-openscad-design/
Github repo: https://github.com/Irev-Dev/Round-Anything
And originally I posted a thread here about it and got some really useful
feedback: http://forum.openscad.org/Rounded-Polygon-td21897.html
I would love to hear your thoughts/feedback.
OpenSCAD.
<http://forum.openscad.org/file/t1892/easy-api.png>
<http://forum.openscad.org/file/t1892/polyRound-extrude.png>
Sat, Aug 15, 2020 11:53 AM
I am very interested in rounding and your original library inspired me to
write a bunch of rounding functions, some of which are similar to yours.
Take a look at:
https://github.com/revarbat/BOSL2/wiki/rounding.scad
The BOSL2 library also has rounding parameters to cuboid() and cyl() and
reguar_ngon() to produce these basic shapes with rounding already applied.
I find this general capability indispensable and use the various rounding
features in the BOSL2 rounding library all the time.
I took a look at your listed examples and am curious what "point translation
helpers" does. Also, what is the difference between polyRoundExtrude and
radius extrude? I implemented something called offset_sweep that is similar
to this, though it takes arbitrary curves for the ends instead of just
fillet or roundover. You might want to show code examples on your page so
people can really see the API.
Take a look at:
I
irevdev
Sat, Aug 15, 2020 10:48 PM
Oh dam,
Nice, looks like some good functionality there. Glad to see my work live on
in another library. Sorry you had to dig through my code. I think/hope I've
improved since then.
Some of your example smoothing in 3d is really nice.
I do have some examples of the api here:
https://kurthutten.com/blog/round-anything-api/
And up offset_sweep looks like it very similar to extrudeWithRadius, the
difference between that and polyRoundExtrude is the latter uses polygon
point (or radiiPoints) instead of a 2d child. It make it less flexible 2d
children certainly cover more cases. Though by using polygon points directly
mean it's able to make the shape using the polyhedron and it makes it much
more performant, and I don't have to use the step method of extruding small
slices with offset. Here's a gif of the fn value changing. It makes for a
much smooth transition at much lower values of fn as well since there are no
steps.
https://twitter.com/IrevDev/status/1292223481728208897
Oh dam,
steps.
Sat, Aug 15, 2020 11:31 PM
I think I understand: you're using a stair-step type construction to create
the shape with extrudeWithRadius and you're constructing a polyhedron for
polyRoundExtrude.
My offset_sweep() will take any polygon, extrude it, and add rounding (or
some other end treatment) to either end. It sounds like it's the same
method as your polyRoundExtrude. I compute offsets of the input polygon
and use them to construct a polyhedron. The real challenge in doing this
was in writing an offset() function, and book keeping when points disappear
during offset. (It's very hard to write a robust offset function.) I also
have convex_offset_extrude, which is like your stair-step approach but it
uses hull to make slices with sloped boundaries. This means it won't work
on concave children. (Well, it will hull them.) I never thought the
stair-step modeling approach was acceptable.
What do you see as the missing functionality for rounding? What do you wish
you could do but you can't?
polyRoundExtrude.
I
irevdev
Sun, Aug 16, 2020 8:05 PM
Yup, stair-step. I did try the hull as well, but preferred the stair-step
over loosing the ability to use concave children. 👍
I don't have anything in mind that's missing.
Some times I wish the polygon could be used more like a "sketch" in other
cad packages, where you could add constrains instead of defining every
point, but that's got nothing to do with rounding.
Sun, Aug 16, 2020 10:36 PM
a "sketch" in other cad packages, where you could add
constrains instead of defining every point, but that's
How would you extend the language to express that?
Sun, Aug 16, 2020 10:42 PM
I'm not familiar with this "sketch" feature. What is it? How does it work?
AD
Ari Diacou
Mon, Aug 17, 2020 9:42 PM
I do rounding for cubes by hull()ing around spheres placed at the corners
(pulled in by the rounding radius, so my rounded cube has coplanar faces
with a regular cube).
Is your method faster than this?
work?
> work?
Mon, Aug 17, 2020 9:58 PM
I'm not sure who you're addressing here, or which method, exactly. Creating
a rounded cube by hulling spheres is a good method, and perhaps the fastest
way to do that job. I haven't done any time testing on this. You don't
need sophisticated rounding if you want to create a rounded cube. The
intention of my rounding library (and the other one mentioned) is to apply
rounding in more sophisticated ways, to more complex objects. What if you
want only parts of the cube rounded? (Probably your approach still
works...in some form...but it begins to get complicated.) What if you want
a concave object with rounding? You cannot round a concave polygon with
hull. What if you want a cube that is rounded at one end and flared out at
the other end for a smooth transition onto a plane?
I actually implemented a large polyhedron library that will compute all of
the platonic, archimedean and catalan solids. And I could not figure out a
correct way to round these solids---the method I implemented fails on the
catalan solids. Doing this as a hull of spheres is difficult because it's
hard to figure out where to put the spheres.
work?
> avm4@
>> work?
>> other
> Discuss@.openscad
> Discuss@.openscad
I
irevdev
Mon, Aug 17, 2020 10:09 PM
drxenocide, Your hulled sphere's sounds fine. Though I think it becomes
difficult for more complex shape is all. I'm not sure about speed.
Adrianv, sketching is very common in cad packages. See this video from about
10s to 40s he makes a sketch https://www.youtube.com/watch?v=CbPIs4MzvzU.
Basically a bunch of points and he adds constraints by adding dimensions,
though not all are dimensions. At one point he selects two lines and
constains them to be the same length. Other things that are common is
defining a line to be vertical or horizontal, or constrain two lines to be
parallel.
tpv, not sure. I did play with an experimental API like this
http://forum.openscad.org/file/t1892/experimental.png
Where "L" means take the value from the previous point, and the last line of
the polygon is defining that's it's supposed to be 45 from the Y axis and
each letter of "ayra" means something, maybe like absolute y . . I can't
remember. Obviously it could be cleaned up but I figure it a) doesn't shine
a light on normal sketches and b) is cumbersome. Ultimately sketching is a
GUI tool and not sure it can be translated to code in an intuitive way.
parallel.
<http://forum.openscad.org/file/t1892/experimental.png>
