Hi, I'm a newbie and have just started exploring openScad. For some reason
whenever I try to create a module function, it returns a 'No top level
geometry to render' error. I've tried it multiple times and it always
results in this error. I'm clueless now. An example code and a screenshot of
the error are below.
radius=16;
sides=5;
thickness=1.5;
module polyshape(){
//outside part
offset(r=5,$fn=48)
circle(r=radius, $fn=sides);
//inside part which is being subtracted
offset(r=5-thickness,$fn=48)
circle(r=radius, $fn=sides);}
http://forum.openscad.org/file/n15744/Screen_Shot_2016-01-17_at_10.png
Thanks in advance!
View this message in context: http://forum.openscad.org/module-function-not-working-tp15744.html
This is pretty common for non-programmers.
The deal is you have created the module but you never invoke it.
you need to add the line:
polyshape();
in the main part of the program..I typically place it at the top
Darren
radius=16;
sides=5;
thickness=1.5;
module polyshape(){
//outside part
offset(r=5,$fn=48)
Thanks in advance!
A module is like a function definition: it defines a named "function" which
takes arguments, and returns geometry as a result. It doesn't "do" anything
by itself.
If you don't call the module, then no geometry is generated.
Add the following code to the end of your script, which calls the module:
polyshape();
of
radius=16;
sides=5;
thickness=1.5;
module polyshape(){
//outside part
offset(r=5,$fn=48)
Thanks in advance!
Thank you
View this message in context: http://forum.openscad.org/module-function-not-working-tp15744p15748.html
