Assume the following (a slightly simplified example)
There are two axles (one long and one short) with a knot (sphere) between them.
On the short one, a wheel is placed.
This code below puts these parts together.
butMy wish is to turn the wheel and the short axle (and maybe the knot) for example 20 degrees (right / left), around the knot.
(not at the center of the wheel and short axle)
$fn=100;
// axle1 (the long one)length1 = 10;width1 = 3;x1=10;y1=10;z1= 0;
// axle2 (the short one)length2 = 3;width2 = 3;
// The "knot"knot = width1 + 2;
// wheelwheelDiam = 20;wheelWidth = 8;x2=x1+length2;y2=y1;z2=z1;
// Create the Axle1translate([x1, y1, z1]) rotate([0,-90,0]) cylinder(h=length1, d=width1);
// Create the Axle2translate([x1, y1, z1]) rotate([0,90,0]) cylinder(h=length2, d=width2);
// Mount the "knot"translate([x1, y1, z1]) sphere(d=knot);
// Mount the Wheeltranslate([x2, y2, z2]) rotate([0,90,0]) cylinder(d=wheelDiam, h=wheelWidth);
