wow that's really clever. But maybe in openSCAD2 we should try to make it
siompler like have dictionaries - e.g. Python dictionaries, or LISP like
association lists.
E.g. stuff = {"name1" : 10, "name2" : 20, "name3" : [12,22]}
and stuff["name1"] returns 10.
The loss of assign has helped to make the code more readable.
and we have mandatory and optional and keyword arguments to modules which is
great.
View this message in context: http://forum.openscad.org/Ignoring-unknown-variable-issue-tp13156p13168.html
Actually with the latest version of OpenSCAD we have a couple of interesting
features which make possible to emulate associative arrays (or dictionaries)
easily...
A simple example script:
// Associative arrays...
default_values = [
["a", 10],
["b", 20],
["bb", 100]
parameters = [
["bb", 200]
// Get value from associative array
function ar_get(ar, key) =
let(idx = search([key],ar)[0])
ar[idx][1];
// Merge 2 arrays (values from ar2 overrides ar1)
function ar_merge(ar1, ar2) = [ for (elem = ar1)
let(idx = search([elem[0]],ar2)[0])
[elem[0], idx != [] ? ar2[idx][1] : elem[1]]
// Example:
echo ("Default bb is:", ar_get(default_values, "bb"));
merged_values = ar_merge(default_values, parameters);
echo ("Actual bb is:", ar_get(merged_values, "bb"));
View this message in context: http://forum.openscad.org/Ignoring-unknown-variable-issue-tp13156p13173.html
interesting features which make possible to emulate associative arrays (or
dictionaries) easily...
default_values = [
["a", 10],
["b", 20],
["bb", 100]
Indeed. We had a discussion about this here
http://forum.openscad.org/Digging-into-search-td12421.html . it was when
the change made.
However, it requires array of [key,val]s, means to type in lots of [ ],
which is I try to avoid. So in my hash parameter model, I use a flat array
like [ "a", 10, "b", 20, "bb", 100 ].
In fact, it doesn't need latest version of OpenSCAD to come up with several
user function for array of [key,val]'s to work like an associate array.
But it's just my personal taste. Your code does solve the problem and would
probably run faster than mine.
Btw, if your keys are all numerical, you can simply use lookup:
function get_cylinder_h(p) = lookup(p, [
[ -200, 5 ],
[ -50, 20 ],
[ -20, 18 ],
[ +80, 25 ],
[ +150, 2 ]
for (i = [-100:5:+100]) {
// echo(i, get_cylinder_h(i));
translate([ i, 0, -30 ]) cylinder(r1 = 6, r2 = 2, h =
get_cylinder_h(i)*3);
$ Runsun Pan, PhD
$ -- OpenScad_DocTest ( Thingiverse ), faces , Offliner
View this message in context: http://forum.openscad.org/Ignoring-unknown-variable-issue-tp13156p13175.html
when using Search I had all kinds of problems in that these two will match:
"grip", "grip-2" when searching for "grip". I.e same for any
substring that starts the same.
Also lookup does interp if there is no match. I wasn't sure I could
count on it for lookups if my field wasn't in the list - but I didn't
extensively test it.
default_values = [
["a", 10],
["b", 20],
["bb", 100]
the change made.
[ -200, 5 ],
[ -50, 20 ],
[ -20, 18 ],
[ +80, 25 ],
[ +150, 2 ]
$ Runsun Pan, PhD
Checked by AVG - www.avg.com
Version: 2015.0.6081 / Virus Database: 4392/10233 - Release Date: 07/15/15
match:
You probably had the 'wrong' syntax...
The documentation wrote
Note: If match_value is a vector of strings, search will look for exact
string matches.
So you need to search for ["grip"], not just "grip"
View this message in context: http://forum.openscad.org/Ignoring-unknown-variable-issue-tp13156p13183.html
Hmm. If I'm reading that hash table approach correctly then isn't it open to
'undefs' in my code if I mistype the hash key? This seems to apply to both
the hash table definition and anywhere I want to lookup hash values in my
code.
The method I use explicitly defines the properties of my 'object', which
means I get the benefits of the compiler telling me if I've tried to access
a non-existent property:
--- code ---
stuff1 = [10, 2, "red"];
stuff2 = [20, 5, "blue"];
function stuff_length(stuff) = stuff[0];
function stuff_width(stuff) = stuff[1];
function stuff_colour(stuff) = stuff[2];
example(stuff1);
module example(myStuff)
echo( stuff_length(myStuff) );
echo( stuff_width(myStuff) );
echo( stuff_color(myStuff) ); <--- fails with a warning in the
compiler window as "stuff_color()" is undefined
--- /code ---
The drawback is having to maintain the ordered list but I don't see that
being any more onerous than maintaining the keys for every list with the
hash table approach - the order of the parameters in the list doesn't
actually matter (unless you suffer from tidy code OCD like I do!) as we are
abstracting via "property accessors".
Another benefit to using this approach is that you can have derived
properties that are based on calculations of the explicit ones:
function stuff_area(stuff) = stuff_length(stuff) * stuff_width(stuff);
View this message in context: http://forum.openscad.org/Ignoring-unknown-variable-issue-tp13156p13187.html
I think both methods have also different use cases...
The 'property array' is nice when you have a whole set of objects with
different attributes (like all screw types, bearings, ...)
The hashes are more convenient when you have a base object with (a lot of)
default properties and you want to instantiate it with just a couple of
changes: you don't have to define the complete array, just the amended
key/value.
View this message in context: http://forum.openscad.org/Ignoring-unknown-variable-issue-tp13156p13190.html
In that scenario I'd use a 'constructor' for my object with default
parameters
function new_stuff(length = 10, width = 2, colour = "yellow")
= [length, width, colour];
myNewPartialObject = new_stuff(width = 15);
I can see how this can start becoming difficult to maintain though if those
definitions change regularly. I do remember reading the hashtable approach
and thinking that it would be useful for certain cases - I just haven't hit
a scenario yet where I have felt the need to refactor.
View this message in context: http://forum.openscad.org/Ignoring-unknown-variable-issue-tp13156p13191.html
This is all great info. Thanks for it.
I'd like to ask an open question though (because OpenSCAD2 is being
designed).
What do you think woudl be the 'best' way to make this work in OpenSCAD2 ?
Should we add a new accessing method, or type or way of doing this so we
don't need to create special code to do it ?
What aspects of the work arounds are the valuable ones ?
View this message in context: http://forum.openscad.org/Ignoring-unknown-variable-issue-tp13156p13193.html
access a non-existent property:
My current version of the hash looks like this:
It covers the cases of undef:
which can be made to give up a warning:
I have a code to do the string substitution:
So it is possible to make it behave exactly like the compiler warning you
talk about (even more, actually).
The hash would become (note: untested):
$ Runsun Pan, PhD
View this message in context: http://forum.openscad.org/Ignoring-unknown-variable-issue-tp13156p13197.html
