Try some older versions as well in case this is a recent issue.
Perhaps someone else here on Windows have better experiences they can share?
On Sep 3, 2025, at 22:33, Nathan Sokalski njsokalski@hotmail.com wrote:
Thank you for that information. I tried getting OpenSCAD-2025.08.31-x86-64-Installer.exe, and it did not work. I had to turn off some security things like Windows Defender (but I think I had to do this with the other times when it did work, so I doubt that is the problem), and when I run the installer, it installs with (what looks like) no problem, but when I open a model, the console says
Loaded design …
Used file cache size: 6 files
The title also includes "OpenSCAD (Not Responding)". I don't know if Windows Defender is causing a problem during installation, or if there is something else, but I'm running out of ideas.
Nathan,
See my posts 'Windows 11, Long OpenSCAD start-up time', for me it takes ~20-25 seconds for the 'Not Responding' to clear.
Once running it seems normal.
I raised a GitHub issue:
https://github.com/openscad/openscad/issues/6158#issuecomment-3247753385
So it can be investigated. See if that describes your behaviour.
Let us know if it does not eventually give you a normal GUI window.
Is that by clicking on a .scad file to Open OpenSCAD?
I don't see that.
Try just running OpenSCAD and select 'New' (presuming you get the welcome screen), instead of clicking on a .scad file.
I think it has Design/Automatic-Reload&Preview set by default (turn that off), so depending on your model that may add some start time.
(presuming from file cache = 6 files, that it may not be trivial model?)
From: Marius Kintel via Discuss [mailto:discuss@lists.openscad.org]
Sent: Thursday, September 04, 2025 1:05 PM
To: Nathan Sokalski via Discuss
Cc: Nathan Sokalski; Marius Kintel
Subject: [OpenSCAD] Re: Can I get a previous nightly build?
Loaded design …
