Front end suggestion
W
wibbly
Sun, Sep 6, 2015 8:34 AM
Love the new front end, makes things very easy to use.
There is one thing that I would love to see. We now have icons across the
top of the editor. We also have the very useful cheat sheet. Would it be
possible to link the two to save typing and syntax errors. I think it would
make things very simple for newbies and get them on board.
I have a template at the top of which is a commented out list of all of my
most commonly used commands. I just copy and paste the commands into my code
whenever I need them.
Eg
translate([0,0,0])rotate([0,0,0])cube([0,0,0],center=true);
If I don't need to 'translate' or 'rotate' I just leave the values as '0'.
If there was a simple icon bar at the top that allowed me to select
cylinder, cube, sphere etc etc all that I would need to do is click on it to
get the command to create the shape, and then enter the parameters. No
syntax errors, and no trying to figure out where the mysterious errors are.
I use openscad to design plastic models with multiple parts that are 3D
printed separately due to print bed constraints. So my code is in module
format, and I just have a list of modules at the end, and comment out the
ones I am not printing prior to exporting to STL.
Probably pushing the boat out with this additional request, but if Openscad
could identify module names, and hold them in a drop down list, it would be
great to just click on the module that I wanted to export, name it, and
export it.
It's a great tool, took me a while to get to grips with it, but use it daily
now.
Rob
View this message in context: http://forum.openscad.org/Front-end-suggestion-tp13708.html
Love the new front end, makes things very easy to use. There is one thing that I would love to see. We now have icons across the top of the editor. We also have the very useful cheat sheet. Would it be possible to link the two to save typing and syntax errors. I think it would make things very simple for newbies and get them on board. I have a template at the top of which is a commented out list of all of my most commonly used commands. I just copy and paste the commands into my code whenever I need them. Eg translate([0,0,0])rotate([0,0,0])cube([0,0,0],center=true); If I don't need to 'translate' or 'rotate' I just leave the values as '0'. If there was a simple icon bar at the top that allowed me to select cylinder, cube, sphere etc etc all that I would need to do is click on it to get the command to create the shape, and then enter the parameters. No syntax errors, and no trying to figure out where the mysterious errors are. I use openscad to design plastic models with multiple parts that are 3D printed separately due to print bed constraints. So my code is in module format, and I just have a list of modules at the end, and comment out the ones I am not printing prior to exporting to STL. Probably pushing the boat out with this additional request, but if Openscad could identify module names, and hold them in a drop down list, it would be great to just click on the module that I wanted to export, name it, and export it. It's a great tool, took me a while to get to grips with it, but use it daily now. Rob -- View this message in context: http://forum.openscad.org/Front-end-suggestion-tp13708.html Sent from the OpenSCAD mailing list archive at Nabble.com.
GC
Gary Crowell
Sun, Sep 6, 2015 3:07 PM
I like the features of the new editor too, but I don't use it.  I like the
autocomplete and in-line help offered by my thing
http://www.thingiverse.com/thing:167899 for use in Notepad++ as an
external editor.  I haven't noticed any other editors that offer both for
OpenSCAD.
When I type 'tr' it opens the following drop-down list:
translate ([
translate ([0, 0, 0])
translate ([0, 0, 0]) cube (size = [1, 1, 1]);
translate ([0, 0, 0]) cylinder (h =
translate ([0, 0, 0]) rotate (a = [0, 0, 0]) cube (size = [1, 1, 1]);
translate ([0, 0, 0]) rotate (a = [0, 0, 0]) cylinder (h =
This is much like your commented list, except that it is available at a few
keystrokes rather than a copy-and-paste.  And there are similar lists for
nearly every keyword, where appropriate. I don't include 'center' in the
above list, because it has it's own autocomplete with 'ce'.
Typing 'rotate(' opens the following tooltip:
rotate ()
rotate (a = [x, y, z]) {...} - rotates the object 'a' degrees around the
origin.
Also: rotate (a = deg, v = [x, y, z]) {...} - rotates the object 'a'
degrees around the axis specified by the vector.
And again, nearly every keyword is represented.
I could never get the autocomplete/tooltip files to work with any Notepad++
version later than 6.5.3, but all older versions are available on the
Notepad++ website. At least for OpenSCAD, I haven't noticed that newer
versions offer anything significant.
I'm a pretty inexperienced user of OpenSCAD, so the autocomplete lists
reflect what I've found useful.  I'm sure there are many entries that could
be added - I'd welcome suggestions.
code
Eg
to
export it.
daily
now.
Rob
I like the features of the new editor too, but I don't use it. I like the autocomplete and in-line help offered by my thing <http://www.thingiverse.com/thing:167899> for use in Notepad++ as an external editor. I haven't noticed any other editors that offer both for OpenSCAD. When I type 'tr' it opens the following drop-down list: *translate ([* *translate ([0, 0, 0])* *translate ([0, 0, 0]) cube (size = [1, 1, 1]);* *translate ([0, 0, 0]) cylinder (h =* *translate ([0, 0, 0]) rotate (a = [0, 0, 0]) cube (size = [1, 1, 1]);* *translate ([0, 0, 0]) rotate (a = [0, 0, 0]) cylinder (h =* This is much like your commented list, except that it is available at a few keystrokes rather than a copy-and-paste. And there are similar lists for nearly every keyword, where appropriate. I don't include 'center' in the above list, because it has it's own autocomplete with 'ce'. Typing 'rotate(' opens the following tooltip: *rotate ()* *rotate (a = [x, y, z]) {...} - rotates the object 'a' degrees around the origin.* *Also: rotate (a = deg, v = [x, y, z]) {...} - rotates the object 'a' degrees around the axis specified by the vector.* And again, nearly every keyword is represented. I could never get the autocomplete/tooltip files to work with any Notepad++ version later than 6.5.3, but all older versions are available on the Notepad++ website. At least for OpenSCAD, I haven't noticed that newer versions offer anything significant. I'm a pretty inexperienced user of OpenSCAD, so the autocomplete lists reflect what I've found useful. I'm sure there are many entries that could be added - I'd welcome suggestions. On Sun, Sep 6, 2015 at 2:34 AM, wibbly <rob@hitenter.co.uk> wrote: > Love the new front end, makes things very easy to use. > > There is one thing that I would love to see. We now have icons across the > top of the editor. We also have the very useful cheat sheet. Would it be > possible to link the two to save typing and syntax errors. I think it would > make things very simple for newbies and get them on board. > > I have a template at the top of which is a commented out list of all of my > most commonly used commands. I just copy and paste the commands into my > code > whenever I need them. > > Eg > translate([0,0,0])rotate([0,0,0])cube([0,0,0],center=true); > > If I don't need to 'translate' or 'rotate' I just leave the values as '0'. > If there was a simple icon bar at the top that allowed me to select > cylinder, cube, sphere etc etc all that I would need to do is click on it > to > get the command to create the shape, and then enter the parameters. No > syntax errors, and no trying to figure out where the mysterious errors are. > > I use openscad to design plastic models with multiple parts that are 3D > printed separately due to print bed constraints. So my code is in module > format, and I just have a list of modules at the end, and comment out the > ones I am not printing prior to exporting to STL. > > Probably pushing the boat out with this additional request, but if Openscad > could identify module names, and hold them in a drop down list, it would be > great to just click on the module that I wanted to export, name it, and > export it. > > It's a great tool, took me a while to get to grips with it, but use it > daily > now. > > Rob > > > > > > > -- > View this message in context: > http://forum.openscad.org/Front-end-suggestion-tp13708.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > -- ---------------------------------------------- Gary A. Crowell Sr., P.E. <http://www.ipels.idaho.gov/>, CID+ <http://dc.ipc.org/html/default.htm> Linkedin <http://www.linkedin.com/in/garyacrowellsr> Elance <http://www.linkedin.com/redirect?url=http%3A%2F%2Fgaryacrowellsr%2Eelance%2Ecom&urlhash=kJm9> KE7FIZ <http://www.arrl.org> Things <http://www.thingiverse.com/garyacrowellsr/designs> RocketryCNC <https://www.etsy.com/shop/RocketryCNC?ref=l2-shopheader-name>
N
Neon22
Sun, Sep 6, 2015 8:10 PM
Hi Gary, thanks for your notepad++ work. I did a remix and it works for me in
6.8.1.
The autocomplete & inline help is great.
The other thing I value in notepad++ is the auto highlighting of identical
words. So if I mark a variable (say) then by scrolling I can see everywhere
that variable is used without additional keystrokes.
View this message in context: http://forum.openscad.org/Front-end-suggestion-tp13708p13713.html
Hi Gary, thanks for your notepad++ work. I did a remix and it works for me in 6.8.1. The autocomplete & inline help is great. The other thing I value in notepad++ is the auto highlighting of identical words. So if I mark a variable (say) then by scrolling I can see everywhere that variable is used without additional keystrokes. -- View this message in context: http://forum.openscad.org/Front-end-suggestion-tp13708p13713.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Sep 7, 2015 4:08 AM
Gary, I think you will find the problem with the newer version of NP++ is it
doesn't like spaces in the keyword. I just removed the spaces, not ideal for
how I like to format it.
I mentioned it on the NP++ forum some time ago, but they are not as
responsive as this place.
Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :)  - Obviously inclusion of works of previous authors is not included in the above.
View this message in context: http://forum.openscad.org/Front-end-suggestion-tp13708p13722.html
Gary, I think you will find the problem with the newer version of NP++ is it doesn't like spaces in the keyword. I just removed the spaces, not ideal for how I like to format it. I mentioned it on the NP++ forum some time ago, but they are not as responsive as this place. ----- Newly minted Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) - Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Front-end-suggestion-tp13708p13722.html Sent from the OpenSCAD mailing list archive at Nabble.com.
GC
Gary Crowell
Wed, Sep 9, 2015 3:54 AM
Ok, I've got the urge to do some more work on the AutoComplete and ToolTips
file for Notepad++.  I've been adding the new keywords and the ones I'd
missed before.  Also largely expanding the descriptions and adding examples
where I can (too bad it can't embed images or links).  I've also added some
help_... entries that display the keywords in the same categories as the
cheat sheet, with short explanations, and a help_keyword entry that
displays all of the keywords.  The file is now at least 3x the size it was.
I've got a bit more to do, but I'll put that up as a new item on
Thingiverse in a few days.
On Sun, Sep 6, 2015 at 10:08 PM, MichaelAtOz oz.at.michael@gmail.com
it
for
stupid...
Ok, I've got the urge to do some more work on the AutoComplete and ToolTips file for Notepad++. I've been adding the new keywords and the ones I'd missed before. Also largely expanding the descriptions and adding examples where I can (too bad it can't embed images or links). I've also added some help_... entries that display the keywords in the same categories as the cheat sheet, with short explanations, and a help_keyword entry that displays all of the keywords. The file is now at least 3x the size it was. I've got a bit more to do, but I'll put that up as a new item on Thingiverse in a few days. On Sun, Sep 6, 2015 at 10:08 PM, MichaelAtOz <oz.at.michael@gmail.com> wrote: > Gary, I think you will find the problem with the newer version of NP++ is > it > doesn't like spaces in the keyword. I just removed the spaces, not ideal > for > how I like to format it. > > I mentioned it on the NP++ forum some time ago, but they are not as > responsive as this place. > > > > ----- > Newly minted Admin - PM me if you need anything, or if I've done something > stupid... > > Unless specifically shown otherwise above, my contribution is in the > Public Domain; To the extent possible under law, I have waived all > copyright and related or neighbouring rights to this work. This work is > published globally via the internet. :) - Obviously inclusion of works of > previous authors is not included in the above. > > The TPP is no simple “trade agreement.” Fight it! > http://www.ourfairdeal.org/ time is running out! > -- > View this message in context: > http://forum.openscad.org/Front-end-suggestion-tp13708p13722.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > -- ---------------------------------------------- Gary A. Crowell Sr., P.E. <http://www.ipels.idaho.gov/>, CID+ <http://dc.ipc.org/html/default.htm> Linkedin <http://www.linkedin.com/in/garyacrowellsr> Elance <http://www.linkedin.com/redirect?url=http%3A%2F%2Fgaryacrowellsr%2Eelance%2Ecom&urlhash=kJm9> KE7FIZ <http://www.arrl.org> Things <http://www.thingiverse.com/garyacrowellsr/designs> RocketryCNC <https://www.etsy.com/shop/RocketryCNC?ref=l2-shopheader-name>
Wed, Sep 9, 2015 8:15 AM
Von: "Gary Crowell" garyacrowellsr@gmail.com
If you feel like adding more information as the mentioned images / links, it
would be cool if that info still would end up somewhere. This might become very
useful when continuing with: https://github.com/openscad/openscad/pull/905
Von: "Gary Crowell" <garyacrowellsr@gmail.com> > Ok, I've got the urge to do some more work on the AutoComplete and ToolTips > file for Notepad++.  I've been adding the new keywords and the ones I'd > missed before.  Also largely expanding the descriptions and adding examples > where I can (too bad it can't embed images or links).  I've also added some > help_... entries that display the keywords in the same categories as the > cheat sheet, with short explanations, and a help_keyword entry that displays > all of the keywords.  The file is now at least 3x the size it was. > If you feel like adding more information as the mentioned images / links, it would be cool if that info still would end up somewhere. This might become very useful when continuing with: https://github.com/openscad/openscad/pull/905 ciao, Torsten.
