Nice work,
Can you please explain in detail, how it works or how to use this.
This Design simply uses OpenSCAD Animate Feature to simulate the milling
process of a certain g code program.
Use it as simply as replacing the given gcode program with your own
one(right now only g0-g3 are supported)
-> dont put a semicolon between the gcodes but put only one at the end.
it is implemented by creating a deep chain of openscad childs.
Let me know ...
On Thu, Sep 14, 2023 at 9:16 AM Sanjeev Prabhakar sprabhakar2006@gmail.com
Nice work,
On Thursday, September 14, 2023 at 04:29:37 AM EDT, Guenther Sohler guenther.sohler@gmail.com wrote:
This Design simply uses OpenSCAD Animate Feature to simulate the milling process of a certain g code program.
That is a great idea, which I have been considering --- but at this time, there's no animation.
Use it as simply as replacing the given gcode program with your own one>(right now only g0-g3 are supported)>-> dont put a semicolon between the gcodes but put only one at the end.>>it is implemented by creating a deep chain of openscad childs.
Something like that.
I've been writing it up at:
https://willadams.gitbook.io/design-into-3d/programming
and the code is on Github, and I've posted a bit about it on the Maker Forums.
Hopefully this evening I'll have a complete proof-of-concept, w/ a screengrab from a 3rd party G-code previewer.
