Re: Merging sub-assemblies?
Ray West
Wed, May 12, 2021 3:31 PM
On 12/05/2021 14:03, Terrypin via Discuss wrote:
Here's my version based on hull with cylinders. I also used the
exercise to learn how to work with modules, so that I can make more of
these in future.
Nice, glad you got there. Being critical, the rounded corners do not
look correct (as in the socket plate)., and you've still got to add the
blocks for the plate screw fixings, and probably cable holes and screw
holes.The internal radius should be less than the external. Still, If
you're happy, then that is good enough. I've written an extruded
version, I could post it, but maybe you'd rather try it for yourself,
although I've tried to include the steps in getting there. (and then
others can say I've got it wrong too 😁)
On 12/05/2021 14:03, Terrypin via Discuss wrote: > Here's my version based on hull with cylinders. I also used the > exercise to learn how to work with modules, so that I can make more of > these in future. Nice, glad you got there. Being critical, the rounded corners do not look correct (as in the socket plate)., and you've still got to add the blocks for the plate screw fixings, and probably cable holes and screw holes.The internal radius should be less than the external. Still, If you're happy, then that is good enough. I've written an extruded version, I could post it, but maybe you'd rather try it for yourself, although I've tried to include the steps in getting there. (and then others can say I've got it wrong too 😁)
AC
A. Craig West
Wed, May 12, 2021 3:56 PM
I find myself doing this sort of thing often enough that I have written a
chamfered cube module in my own library. it allows me to specify
exactly which edges are chamfered, and whether to use straight chamfers, or
rounded. Galloping featuritis has added a lot of code to it, I must admit...
these in future.
I find myself doing this sort of thing often enough that I have written a chamfered cube module in my own library. it allows me to specify exactly which edges are chamfered, and whether to use straight chamfers, or rounded. Galloping featuritis has added a lot of code to it, I must admit... On Wed, May 12, 2021 at 11:31 AM Ray West <raywest@raywest.com> wrote: > > On 12/05/2021 14:03, Terrypin via Discuss wrote: > > Here's my version based on hull with cylinders. I also used the > > exercise to learn how to work with modules, so that I can make more of > > these in future. > > Nice, glad you got there. Being critical, the rounded corners do not > look correct (as in the socket plate)., and you've still got to add the > blocks for the plate screw fixings, and probably cable holes and screw > holes.The internal radius should be less than the external. Still, If > you're happy, then that is good enough. I've written an extruded > version, I could post it, but maybe you'd rather try it for yourself, > although I've tried to include the steps in getting there. (and then > others can say I've got it wrong too 😁) > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
Terrypin
Wed, May 12, 2021 9:43 PM
Thanks. Yes,  I’ll correct the inside corner rounding. I expect to tackle the
other features later, once I’ve exhausted all aspects of the basic box. And
yes please, I’d much appreciate your extruded version. While trying it
myself it’s good to know I have a crib at hand!
Thanks. Yes, I’ll correct the inside corner rounding. I expect to tackle the other features later, once I’ve exhausted all aspects of the basic box. And yes please, I’d much appreciate your extruded version. While trying it myself it’s good to know I have a crib at hand! -- Sent from: http://forum.openscad.org/
