Re: [OpenSCAD] Create lightweight, latticed designs that are functionally optimized and accurate for 3D printing
Ronaldo
Wed, Mar 9, 2016 5:25 PM
Hi, lkcl.
That was your second mention to a non-NP-completeness of OpenSCAD language.
What do you by that? I know the expression relative to problems and
algorithms only.
Ronaldo
View this message in context: http://forum.openscad.org/Create-lightweight-latticed-designs-that-are-functionally-optimized-and-accurate-for-3D-printing-tp16279p16376.html
Hi, lkcl. That was your second mention to a non-NP-completeness of OpenSCAD language. What do you by that? I know the expression relative to problems and algorithms only. Ronaldo -- View this message in context: http://forum.openscad.org/Create-lightweight-latticed-designs-that-are-functionally-optimized-and-accurate-for-3D-printing-tp16279p16376.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Wed, Mar 9, 2016 8:17 PM
@Ronaldo The term NP-Complete comes from computability theory, and it
applies to algorithms, not to languages. Ikcl is probably thinking of
another term, "Turing complete", also from computability theory, which
refers to the expressive power of a language. A language is Turing complete
if you can write a program that simulates a Turing machine. OpenSCAD is
Turing complete, since it has numbers, conditionals, lists and recursive
functions.
On 9 March 2016 at 12:25, Ronaldo rcmpersiano@gmail.com wrote:
Hi, lkcl.
algorithms only.
Ronaldo
@Ronaldo The term NP-Complete comes from computability theory, and it applies to algorithms, not to languages. Ikcl is probably thinking of another term, "Turing complete", also from computability theory, which refers to the expressive power of a language. A language is Turing complete if you can write a program that simulates a Turing machine. OpenSCAD is Turing complete, since it has numbers, conditionals, lists and recursive functions. On 9 March 2016 at 12:25, Ronaldo <rcmpersiano@gmail.com> wrote: > Hi, lkcl. > > That was your second mention to a non-NP-completeness of OpenSCAD language. > What do you by that? I know the expression relative to problems and > algorithms only. > > Ronaldo > > > > -- > View this message in context: > http://forum.openscad.org/Create-lightweight-latticed-designs-that-are-functionally-optimized-and-accurate-for-3D-printing-tp16279p16376.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > >
Ronaldo
Wed, Mar 9, 2016 8:34 PM
Thank you doug, this makes sense.
View this message in context: http://forum.openscad.org/Create-lightweight-latticed-designs-that-are-functionally-optimized-and-accurate-for-3D-printing-tp16279p16378.html
Thank you doug, this makes sense. -- View this message in context: http://forum.openscad.org/Create-lightweight-latticed-designs-that-are-functionally-optimized-and-accurate-for-3D-printing-tp16279p16378.html Sent from the OpenSCAD mailing list archive at Nabble.com.
