On Thu, 9 Dec, 2021 at 10:35 AM, Leonard Martin Struttmann lenstruttmann@gmail.com wrote:
To: openscad general discussion
Gene, I see it but it is very small.
Why are you passing a vector to cylinder()?
Should not that be:
cylinder(2,2,20,center=true); // latch bumps
Good question, I'm still learning the ropes, I see cylinder does NOT use the [] to
hold the vars, fixed that, now.
I see a big arrow pointing left. And the center= has historically been optional, it
is the state of the 4th argument that counts. But now that I can see it, I can shape
it and place it.
The worst part is just under a full day to print it and half a spool of filament.
Thank you Leonard.
Gene, try making the wall an integer multiple of your nozzle size. For
example, if you are using a 0.4mm nozzle, make
wall=2.4; // an integer multiple of 0.4
Using a 0.28 layer height, Cura predicts 8 hours 23 minutes, 141 grams
On Thu, Dec 9, 2021 at 10:14 AM Gene Heskett gheskett@shentel.net wrote:
On Thu, 9 Dec, 2021 at 10:35 AM, Leonard Martin Struttmann <
Should not that be:
the [] to
optional, it
can shape
it and place it.
filament.
Thank you Leonard.
