KE
Karl Exler
Tue, Jun 8, 2021 9:49 AM
could you please send me one small file, which works on my
OpenScad-Installation, where I can see the syntax and the stuff with
INCLUDE ? Please.
e.g. making an M8 screw and/or a M8 bolt..
That would be great
thank you very much in advance
Karl
Am 08.06.21 um 11:08 schrieb fred via Discuss:
INCLUDE ? Please.
That would be great
Karl
Ray West
Tue, Jun 8, 2021 10:23 AM
//twist nut 8mm blank
include<NopSCADlib/utils/thread.scad>
//module male_metric_thread(d, pitch, length, center = true, top = -1,
bot = -1, solid = true, colour = undef) { //! Create male thread with
metric profile
translate([0,0,10])
union(){
translate ([0,0, 5]) sphere( 12);
scale([1.5,1,1])translate ([0,0,-5]) rotate ([90,0,0])
cylinder(h=3,d=15,center=true);
cylinder (h=20,d=16,center=true);
male_metric_thread(8,1.25,21);
translate([0,0,-60]) cube([100,100,100],true); //chop off bottom
$fn=80;
fyi,well worth looking at NopSCADlib
hth
INCLUDE ? Please.
That would be great
Karl
metric profile
translate([0,0,10])
union(){
$fn=80;
hth
> INCLUDE ? Please.
> That would be great
> Karl
Terrypin
Wed, Jun 9, 2021 8:26 AM
D: Just tried that and get the error shown on line 5:
<http://forum.openscad.org/file/t3184/ThreadCodeError.jpg>
Terry
Wed, Jun 9, 2021 8:40 AM
You need to download NopSCADlib, or clone it from github, and set the
OPENSCADPATH environment variable to point to the directory containing
NopSCADlib. Or put it in one of the directories already listed in Hlep /
Library info.
I think the syntax error is because the commented out module definition is
split on to two lines and the second line isn't commented out. i.e. line 5
is part way through a comment. The line probably got broken by an email
client.
Library info.
client.
> Terry
> at Nabble.com.
Terrypin
Wed, Jun 9, 2021 2:03 PM
Thanks, understood. Should have set it up earlier but now done so. Does this
look OK?
OPENSCADPATH
C:\Program
Files\OpenSCAD\libraries;C:\Users\terry\Documents\OpenSCAD\libraries;C:\Users\terry\Dropbox\3D
Printer\OpenSCAD\LIBRARIES
I can see why I should leave those in \Program Files, but can I move the
contents of *C:\Users\terry\Documents\OpenSCAD\libraries
- to my newly defined \LIBRARIES folder?
look OK?
OPENSCADPATH
C:\Program
* to my newly defined *\LIBRARIES* folder?
Terrypin
Wed, Jun 9, 2021 2:43 PM
I'm expanding my earlier reply (as you're an email user so would not see it
if I just edited it).
I read the following in usage.md
"NopSCADlib usage
Requirements
OpenSCAD 2021.01 or later, download it from here:
https://www.openscad.org/downloads.html
Python 2.7+ or 3.6+ from https://www.python.org/downloads/
ImageMagick 7 www.imagemagick.org
As a mere end user, neither programmer nor developer, do I really need 2 &
3?
BTW, I note that Karl's post mid-thread renamed it to 'Re: Metric screws and
bolts' . But when I open the forum on the web to look for your post, the
thread is still named 'How do I edit/create code snippets?'.
"NopSCADlib usage
Requirements
1. OpenSCAD 2021.01 or later, download it from here:
2. Python 2.7+ or 3.6+ from https://www.python.org/downloads/
3. ImageMagick 7 www.imagemagick.org
3?
Wed, Jun 9, 2021 2:47 PM
You need 2 and 3 to run any of the scripts that do things like make the
bill of materials, STLs, assembly drawings and project instruction manual.
You don't need them to simply run the OpenSCAD code in the GUI and then
manually export the STL.
it if I just edited it).
"NopSCADlib usage
Requirements
3?
and bolts' . But when I open the forum on the web to look for your post,
the thread is still named 'How do I edit/create code snippets?'.
at Nabble.com.
> "NopSCADlib usage
> Requirements
> 3?
> at Nabble.com.
Ray West
Wed, Jun 9, 2021 5:09 PM
I've not bothered to put in the dimensions you need, I'm not sure if
they are correct anyway (whatever 😁), and if you go with hex socket you
need to check the af value (and the ,866, maybe) It takes a while to
render. but should get you on your way. I've printed 6mm and larger
threaded stuff, (see my previous post) but I would not bother with much
smaller on fdm. I started by making the studding (generally for bolt
lengths the length does not include the head) then added the head, then
took out the hex socket.
/ cap head screw
$fn=20; //whatever
length=30; //whatever
diam=2.7; // out of tolerance 3mm?
head_thick =4; // whatever
head_diameter = 6 ; //whatever
pitch =0.5; // whatever or 0.35
af =4 ; //hex socket
// make blank studding
union(){
male_metric_thread(diam,pitch,length+head_thick,false);
// head
cylinder (head_thick,d=head_diameter);
//socket
#cylinder(head_thick-1,d=af*0.866,$fn=6);
/ cap head screw
$fn=20; //whatever
union(){
// head
//socket
> see it if I just edited it).
> "NopSCADlib usage
> Requirements
> <https://www.openscad.org/downloads.html>
> <https://www.python.org/downloads/>
> 2 & 3?
> screws and bolts' . But when I open the forum on the web to look for
> your post, the thread is still named 'How do I edit/create code
> snippets?'.
> <http://forum.openscad.org/> at Nabble.com.
Terrypin
Wed, Jun 9, 2021 5:42 PM
Thanks. Did you also see my two previous questions?
Reply | Threaded | More
Jun 09, 2021; 3:03pm
Re: Metric screws and bolts
Terrypinonline
look OK?
OPENSCADPATH
C:\Program
contents of C:\Users\terry\Documents\OpenSCAD\libraries
Terrypinonline
look OK?
OPENSCADPATH
C:\Program
Terrypin
Wed, Jun 9, 2021 5:46 PM
... and here's the image I included in the web post:
<http://forum.openscad.org/file/t3184/NopSCADLib.jpg>
