TR
Thomas Richter
Mon, May 25, 2026 5:25 PM
I try to use animations for animated object creation: translated objects should not be deleted after the animation frame but shall remain in the scene.
Consider the following:
translate([$t * 10, 0, 0]) sphere(d = 2, $fn = 30);
This lets the sphere travel from the origin to [10, 0, 0]. I am looking for a possibility to not let the sphere travel but "pull a tail" of spheres such that it forms a tube with rounded ends as long as the animation has enough frames. I tried something like this:
But it still lets the sphere just travel. Is there some sort of switch or option that lets the results of operations (union, difference) persist between the animation frames?
I hope I could make clear what I'm asking for.
Thanks,
Thomas
Thanks,
Thomas
Mon, May 25, 2026 6:22 PM
scene.
Thanks,
Thomas
Replace union with hull.
On Mon, 25 May 2026 at 18:25, Thomas Richter via Discuss <
> scene.
> union() {
> Thanks,
> Thomas
Michael Möller
Mon, May 25, 2026 6:59 PM
As each frame is an independent render, and has NO dependence on the frame
before or after, you must duplicate the sphere.
Ok, sorry, I'm lazy, can't be bothered to fire up OpenSCAD and do it
(syntactically correct) but the outline is
for (i = [1:$t*10])
ie in the 1st frame you paint one sphere, in the second frame 2 spheres ...
You can do some stuff with conditionals so that spheres that are "older"
than 3 frames do not get rendered.
HTH, Michael
On Mon, 25 May 2026 at 20:23, nop head via Discuss <
scene.
Thanks,
Thomas
for (i = [1:$t*10])
HTH, Michael
>> scene.
>> union() {
>> Thanks,
>> Thomas
TR
Thomas Richter
Tue, May 26, 2026 7:56 AM
Thank you for the advice, it works well. Nonetheless, as soon as the path gets longer the animation becomes quite laggy. Thus it would have been nicer if it was possible to keep objects between animation frames. But I understand that it is conceptionally way more complicated than to just re-render the scene with a modified parameter. And it is better than nothing.
I am currently creating the design concept of a machine with a kind-of-welding toolhead that must be able to follow complex paths in space and wanted to do a quick check of the forward kinematics before going into the detailed design phase.
Am 25.05.2026 um 20:59 schrieb Michael Möller private2michael@gmail.com:
As each frame is an independent render, and has NO dependence on the frame before or after, you must duplicate the sphere.
Ok, sorry, I'm lazy, can't be bothered to fire up OpenSCAD and do it (syntactically correct) but the outline is
for (i = [1:$t*10])
ie in the 1st frame you paint one sphere, in the second frame 2 spheres ... You can do some stuff with conditionals so that spheres that are "older" than 3 frames do not get rendered.
HTH, Michael
On Mon, 25 May 2026 at 20:23, nop head via Discuss discuss@lists.openscad.org wrote:
On Mon, 25 May 2026 at 18:25, Thomas Richter via Discuss discuss@lists.openscad.org wrote:
Thanks,
Thomas
> Am 25.05.2026 um 20:59 schrieb Michael Möller <private2michael@gmail.com>:
> for (i = [1:$t*10])
> HTH, Michael
>> On Mon, 25 May 2026 at 20:23, nop head via Discuss <discuss@lists.openscad.org> wrote:
>>> On Mon, 25 May 2026 at 18:25, Thomas Richter via Discuss <discuss@lists.openscad.org> wrote:
>>> union() {
>>> Thanks,
>>> Thomas
Michael Marx (spintel)
Tue, May 26, 2026 8:35 AM
I think nophead's suggestion of hull() would not be laggy.
From: Thomas Richter via Discuss [mailto:discuss@lists.openscad.org]
Sent: Tuesday, May 26, 2026 5:56 PM
Cc: Michael Möller; Thomas Richter
Subject: [OpenSCAD] Re: "Drawing" with animations
than nothing.
for (i = [1:$t*10])
rendered.
this:
> -----Original Message-----
> To: OpenSCAD general discussion Mailing-list
> than nothing.
> > for (i = [1:$t*10])
> rendered.
> > HTH, Michael
> this:
> >>> union() {
> >>> Thanks,
> >>> Thomas
TR
Thomas Richter
Tue, May 26, 2026 9:32 AM
You are right but it wouldn't work as intended (create a track of spheres) for curved paths because the hull would become some large object hiding the actual track. The solution of Michael Möller is good enough for now.
Am 26.05.2026 um 10:35 schrieb Michael Marx (spintel) via Discuss discuss@lists.openscad.org:
than nothing.
for (i = [1:$t*10])
rendered.
this:
> Am 26.05.2026 um 10:35 schrieb Michael Marx (spintel) via Discuss <discuss@lists.openscad.org>:
>> than nothing.
>>> for (i = [1:$t*10])
>> rendered.
>>> HTH, Michael
>> this:
>>>>> union() {
>>>>> Thanks,
>>>>> Thomas
Michael Möller
Tue, May 26, 2026 9:39 AM
True, if that gives the visual impression desired. Leave the original
sphere and have one travelling sphere, and hull() them. "For additional
points" the first sphere can travel, too but with a lesser t$, eg
max(t$-0.3,0)
I suspect the travelling objects are more complicated than a sphere, so
hull() may have adverse effects.
BTW, if using animation for checking paths/collisions, use coarser fn$ or
otherwise reduce complexity. (F.ex, I don't draw teeth on my gears, but
draw teeth when not animating). If you want to do a nice film, use some
other software to collect the individual frames
tirs. 26. maj 2026, 10.35 skrev Michael Marx (spintel) via Discuss <
than nothing.
for (i = [1:$t*10])
max(t$-0.3,0)
> possible to keep
> And it is better
> > than nothing.
> quick check of the
> frame before or
> (syntactically
> > > for (i = [1:$t*10])
> frames do not get
> > rendered.
> > > HTH, Michael
> looking for a
> > this:
> > >>> union() {
> animation frames?
> > >>> Thanks,
> > >>> Thomas
Tue, May 26, 2026 9:50 AM
If the path is not a straight line then you need to hull each pair of
spheres separately.
On Tue, 26 May 2026, 10:40 Michael Möller via Discuss, <
max(t$-0.3,0)
than nothing.
for (i = [1:$t*10])
spheres separately.
> max(t$-0.3,0)
>> possible to keep
>> And it is better
>> > than nothing.
>> quick check of the
>> frame before or
>> (syntactically
>> > > for (i = [1:$t*10])
>> frames do not get
>> > rendered.
>> > > HTH, Michael
>> looking for a
>> > this:
>> > >>> union() {
>> animation frames?
>> > >>> Thanks,
>> > >>> Thomas
Tue, May 26, 2026 2:01 PM
Pretty much, only the simplest of animations will run at reasonable
speed directly in OpenSCAD. If you want a good-looking animation, you
need to dump the images and use an external tool (typically ImageMagick)
to combine them into a video file.
