expressing multmatrix in translate and rotate?
pproj (at) posteo.de
Fri, Jul 23, 2021 5:05 PM
Hello Everybody
Openscads rendering speed on complex models is really difficult to
tolerate to me, it really slows down my work by an order of magnitude.
I was thinking of trying to export CSG from openscad and trying to feed
into impicitCad, in the hope it will be rendering much faster.
Strangely implicitCad does not know multmatrix, so i would like to
replace it by some translate  rotate or scale combination automatically.
is it even possible without an equation solver?
Anybody has an idea on how to do it?
Thanks Peter
Hello Everybody Openscads rendering speed on complex models is really difficult to tolerate to me, it really slows down my work by an order of magnitude. I was thinking of trying to export CSG from openscad and trying to feed into impicitCad, in the hope it will be rendering much faster. Strangely implicitCad does not know multmatrix, so i would like to replace it by some translate  rotate or scale combination automatically. is it even possible without an equation solver? Anybody has an idea on how to do it? Thanks Peter
Fri, Jul 23, 2021 5:45 PM
Peter:
Have you tried using AngelCAD?  For some OpenSCAD scripts, AngelCAD is
stunningly faster when generating an STL.
On 7/23/2021 1:05 PM, pproj@posteo.de wrote:
Hello Everybody
Thanks Peter
Peter: Have you tried using AngelCAD?  For some OpenSCAD scripts, AngelCAD is stunningly faster when generating an STL. Jon On 7/23/2021 1:05 PM, pproj@posteo.de wrote: > Hello Everybody > > Openscads rendering speed on complex models is really difficult to > tolerate to me, it really slows down my work by an order of magnitude. > > I was thinking of trying to export CSG from openscad and trying to > feed into impicitCad, in the hope it will be rendering much faster. > > Strangely implicitCad does not know multmatrix, so i would like to > replace it by some translate  rotate or scale combination > automatically. is it even possible without an equation solver? > > Anybody has an idea on how to do it? > > Thanks Peter > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
Fri, Jul 23, 2021 5:48 PM
You can compose translate, rotate, scale and skew into a single matrix but
I doubt there is a unique way of separating them out again.
On Fri, 23 Jul 2021 at 18:46, jon jon@jonbondy.com wrote:
Peter:
Hello Everybody
Thanks Peter
You can compose translate, rotate, scale and skew into a single matrix but I doubt there is a unique way of separating them out again. On Fri, 23 Jul 2021 at 18:46, jon <jon@jonbondy.com> wrote: > Peter: > > Have you tried using AngelCAD? For some OpenSCAD scripts, AngelCAD is > stunningly faster when generating an STL. > > Jon > > > On 7/23/2021 1:05 PM, pproj@posteo.de wrote: > > Hello Everybody > > > > Openscads rendering speed on complex models is really difficult to > > tolerate to me, it really slows down my work by an order of magnitude. > > > > I was thinking of trying to export CSG from openscad and trying to > > feed into impicitCad, in the hope it will be rendering much faster. > > > > Strangely implicitCad does not know multmatrix, so i would like to > > replace it by some translate rotate or scale combination > > automatically. is it even possible without an equation solver? > > > > Anybody has an idea on how to do it? > > > > Thanks Peter > > _______________________________________________ > > OpenSCAD mailing list > > To unsubscribe send an email to discuss-leave@lists.openscad.org > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
Fri, Jul 23, 2021 6:52 PM
Hello Nophead, the solution does not have to be unique. i am happy with
any solution, since it will compile into the same matrix in the end
anyway, i just wonder if it is possible without solving equations
mailto:jon@jonbondy.com> wrote:
 Peter:
 AngelCAD is
 On 7/23/2021 1:05 PM, pproj@posteo.de <mailto:pproj@posteo.de> wrote:
Hello Everybody
 magnitude.
Thanks Peter
Hello Nophead, the solution does not have to be unique. i am happy with  any solution, since it will compile into the same matrix in the end anyway, i just wonder if it is possible without solving equations On 23.07.21 19:48, nop head wrote: > You can compose translate, rotate, scale and skew into a single matrix > but I doubt there is a unique way of separating them out again. > > On Fri, 23 Jul 2021 at 18:46, jon <jon@jonbondy.com > <mailto:jon@jonbondy.com>> wrote: > > Peter: > > Have you tried using AngelCAD?  For some OpenSCAD scripts, > AngelCAD is > stunningly faster when generating an STL. > > Jon > > > On 7/23/2021 1:05 PM, pproj@posteo.de <mailto:pproj@posteo.de> wrote: > > Hello Everybody > > > > Openscads rendering speed on complex models is really difficult to > > tolerate to me, it really slows down my work by an order of > magnitude. > > > > I was thinking of trying to export CSG from openscad and trying to > > feed into impicitCad, in the hope it will be rendering much faster. > > > > Strangely implicitCad does not know multmatrix, so i would like to > > replace it by some translate  rotate or scale combination > > automatically. is it even possible without an equation solver? > > > > Anybody has an idea on how to do it? > > > > Thanks Peter > > _______________________________________________ > > OpenSCAD mailing list > > To unsubscribe send an email to discuss-leave@lists.openscad.org > <mailto:discuss-leave@lists.openscad.org> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > <mailto:discuss-leave@lists.openscad.org> > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email todiscuss-leave@lists.openscad.org
Fri, Jul 23, 2021 7:23 PM
I have a function that recovers a rotation from a rotation matrix here:
https://github.com/nophead/NopSCADlib/blob/master/utils/maths.scad#L107
Translate is easy as that is just the fourth column or row depending on
which way round it is, I forget.
Peter:
Hello Everybody
Thanks Peter
I have a function that recovers a rotation from a rotation matrix here: https://github.com/nophead/NopSCADlib/blob/master/utils/maths.scad#L107 Translate is easy as that is just the fourth column or row depending on which way round it is, I forget. On Fri, 23 Jul 2021 at 19:52, pproj@posteo.de <pproj@posteo.de> wrote: > Hello Nophead, the solution does not have to be unique. i am happy with > any solution, since it will compile into the same matrix in the end anyway, > i just wonder if it is possible without solving equations > On 23.07.21 19:48, nop head wrote: > > You can compose translate, rotate, scale and skew into a single matrix but > I doubt there is a unique way of separating them out again. > > On Fri, 23 Jul 2021 at 18:46, jon <jon@jonbondy.com> wrote: > >> Peter: >> >> Have you tried using AngelCAD? For some OpenSCAD scripts, AngelCAD is >> stunningly faster when generating an STL. >> >> Jon >> >> >> On 7/23/2021 1:05 PM, pproj@posteo.de wrote: >> > Hello Everybody >> > >> > Openscads rendering speed on complex models is really difficult to >> > tolerate to me, it really slows down my work by an order of magnitude. >> > >> > I was thinking of trying to export CSG from openscad and trying to >> > feed into impicitCad, in the hope it will be rendering much faster. >> > >> > Strangely implicitCad does not know multmatrix, so i would like to >> > replace it by some translate rotate or scale combination >> > automatically. is it even possible without an equation solver? >> > >> > Anybody has an idea on how to do it? >> > >> > Thanks Peter >> > _______________________________________________ >> > OpenSCAD mailing list >> > To unsubscribe send an email to discuss-leave@lists.openscad.org >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
