Hi to all,
i read in manual import_dxf shall be removed in future releases and
shall be replaced by import().
It's OK having only one import() function which is sensitive on file
extensions.
But, i please you do NOT remove import_dxl until import() is able to
handle dxf layer property.
If future version of import() can't handle the dxf layer property a
branch of dxf files must be created for import, each containing exactly
one layer. And that would make the use of dxf content, e.g. for easy
use with linear_extrude, extremely inconvenient.
With best regards
Peter
PS: openSCAD is fantastic, well done!
There was never 2 implementations for the actual import so there
should have never been any difference between import_dxf() and
import with a file that has *.dxf name.
If you see any specific problem that is not already reported
on github, please share the details (and ideally also example
files).
The documentation on the wiki says that the layer= argument only works with
import_dxf().
In actual fact, this argument works with import() as well. The wiki just
needs to be updated.
files).
Am Sun, 6 May 2018 18:15:03 +0200
schrieb Torsten Paul Torsten.Paul@gmx.de:
files).
Hi Torsten,
sorry, your help is appreciated, i'm not familiar with github.
So far I saw on
https://github.com/openscad/openscad/issues?utf8=%E2%9C%93&q=is%3Aissue+is%3Aopen+import+dxf+layer+
there is no request for "Add layer() support to DXF import" only for
export.
Right?
I'm unable to open a new issue - So, I have to be signed in for that?
Mit freundlichen Grüßen
Best Regards
Peter Ragosch
files).
Let's first clarify if there is anything wrong. Doug indicates
the documentation might be lacking for import(). So did you
actually try some specific model and it worked with import_dxf()
but not with import()?
While I don't see how that's possible, there could be an obscure
bug.
Can you post a working script using import_dxf() and one not
working with just import(), along with the DXF file?
Exporting layers is indeed a totally different topic.
Am Sun, 6 May 2018 12:23:19 -0400
schrieb doug moen doug@moens.org:
Best Regards
Peter Ragosch
Am Sun, 6 May 2018 18:47:32 +0200
files).
bug.
Well, I tried some days ago and was sure it doesn't work. But today,
with current nightly update, I tried again and it's working now (or
again?)
Anyhow, it's not worth the trouble :).
Best Regards
Peter Ragosch
