problem STL
Sat, Oct 8, 2016 2:39 PM
When I create this STL, it is defective, but I cannot figure out what
the defect is.  It looks fine in OpenSCAD.
minID = 35;
maxID = 45;
ht = 25;
th = 2;
$fn = 100;
minIR = minID/2;
maxIR = maxID/2;
module Cup()
rotate_extrude(convexity = 10)
polygon([[0,0],
[-minIR-th,0],
[-maxIR-th,ht],
[-maxIR-th-th,ht],
[-maxIR-th-th,ht+th],
[-maxIR,ht+th],
[-minIR,th],
[0,th]]);
Cup();
When I create this STL, it is defective, but I cannot figure out what the defect is. It looks fine in OpenSCAD. minID = 35; maxID = 45; ht = 25; th = 2; $fn = 100; minIR = minID/2; maxIR = maxID/2; module Cup() rotate_extrude(convexity = 10) polygon([[0,0], [-minIR-th,0], [-maxIR-th,ht], [-maxIR-th-th,ht], [-maxIR-th-th,ht+th], [-maxIR,ht+th], [-minIR,th], [0,th]]); Cup();
RU
Richard Urwin
Sat, Oct 8, 2016 3:21 PM
The whole thing is inside-out.
If you view it in Thrown-together mode it's all purple. If you view it in
MeshLab it's black.
To fix it, you can tell MeshaLab to reverse all the faces, Then it comes out
nice and grey like it is supposed to.
https://dl.dropboxusercontent.com/u/96640124/screenshot.png
Maybe you need to reverse the order of the nodes? I'm not enough of an
expert on OpenSCAD to know, but that is the issue.
View this message in context: http://forum.openscad.org/problem-STL-tp18608p18609.html
The whole thing is inside-out. If you view it in Thrown-together mode it's all purple. If you view it in MeshLab it's black. To fix it, you can tell MeshaLab to reverse all the faces, Then it comes out nice and grey like it is supposed to. https://dl.dropboxusercontent.com/u/96640124/screenshot.png Maybe you need to reverse the order of the nodes? I'm not enough of an expert on OpenSCAD to know, but that is the issue. -- View this message in context: http://forum.openscad.org/problem-STL-tp18608p18609.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sat, Oct 8, 2016 3:26 PM
Thank you.  I guess the polygon builder got everything backwards?  Or I
entered the points backwards.
MeshLab it's black.
Checked by AVG - www.avg.com
Version: 2016.0.7797 / Virus Database: 4656/13167 - Release Date: 10/07/16
Thank you. I guess the polygon builder got everything backwards? Or I entered the points backwards. Jon On 10/8/2016 11:21 AM, Richard Urwin wrote: > The whole thing is inside-out. > > If you view it in Thrown-together mode it's all purple. If you view it in > MeshLab it's black. > > To fix it, you can tell MeshaLab to reverse all the faces, Then it comes out > nice and grey like it is supposed to. > > https://dl.dropboxusercontent.com/u/96640124/screenshot.png > > Maybe you need to reverse the order of the nodes? I'm not enough of an > expert on OpenSCAD to know, but that is the issue. > > > > -- > View this message in context: http://forum.openscad.org/problem-STL-tp18608p18609.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > Version: 2016.0.7797 / Virus Database: 4656/13167 - Release Date: 10/07/16 > >
Sat, Oct 8, 2016 3:28 PM
2016-10-08 11:39 GMT-03:00 jon jon@jonbondy.com:
How have you detected it is defective? I had no issues importing the cup
stl file in OpenSCAD (Windows version 2015.03-2 ).
2016-10-08 11:39 GMT-03:00 jon <jon@jonbondy.com>: > When I create this STL, it is defective, but I cannot figure out what the > defect is. It looks fine in OpenSCAD. > How have you detected it is defective? I had no issues importing the cup stl file in OpenSCAD (Windows version 2015.03-2 ).
Sat, Oct 8, 2016 3:35 PM
Turns out if the shape is on the negative part of the Y plane, it will
always be inside out.
MeshLab it's black.
Turns out if the shape is on the negative part of the Y plane, it will always be inside out. On 10/8/2016 11:21 AM, Richard Urwin wrote: > The whole thing is inside-out. > > If you view it in Thrown-together mode it's all purple. If you view it in > MeshLab it's black. > > To fix it, you can tell MeshaLab to reverse all the faces, Then it comes out > nice and grey like it is supposed to. > > https://dl.dropboxusercontent.com/u/96640124/screenshot.png > > Maybe you need to reverse the order of the nodes? I'm not enough of an > expert on OpenSCAD to know, but that is the issue. > > > > -- > View this message in context: http://forum.openscad.org/problem-STL-tp18608p18609.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > Version: 2016.0.7797 / Virus Database: 4656/13167 - Release Date: 10/07/16 > >
Sat, Oct 8, 2016 3:36 PM
It appears as defective in NetFabb, and I cannot print it.
mailto:jon@jonbondy.com>:
cup stl file in OpenSCAD(Windows version 2015.03-2).
Checked by AVG - www.avg.com http://www.avg.com
It appears as defective in NetFabb, and I cannot print it. On 10/8/2016 11:28 AM, Ronaldo Persiano wrote: > 2016-10-08 11:39 GMT-03:00 jon <jon@jonbondy.com > <mailto:jon@jonbondy.com>>: > > When I create this STL, it is defective, but I cannot figure out > what the defect is. It looks fine in OpenSCAD. > > > How have you detected it is defective? I had no issues importing the > cup stl file in OpenSCAD(Windows version 2015.03-2). > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > Version: 2016.0.7797 / Virus Database: 4656/13167 - Release Date: 10/07/16 >
CA
Sat, Oct 8, 2016 3:58 PM
Your polygon is defined clockwise. Unless I am mistaken it needs to be
counterclockwise. Either reverse the order of the points or reverse the
sign of one of the coordinates.
As this is rotation symmetry about Z, it works to simply flip the sign
for the x coordinates:
minID = 35;
maxID = 45;
ht = 25;
th = 2;
$fn = 100;
minIR = minID/2;
maxIR = maxID/2;
module Cup()
polygon([[0,0],
[minIR+th,0],
[maxIR+th,ht],
[maxIR+th+th,ht],
[maxIR+th+th,ht+th],
[maxIR,ht+th],
[minIR,th],
[0,th]]);
Cup();
minID = 35;
maxID = 45;
ht = 25;
th = 2;
$fn = 100;
minIR = minID/2;
maxIR = maxID/2;
module Cup()
polygon([[0,0],
[-minIR-th,0],
[-maxIR-th,ht],
[-maxIR-th-th,ht],
[-maxIR,ht+th],
[-minIR,th],
[0,th]]);
Cup();
Your polygon is defined clockwise. Unless I am mistaken it needs to be counterclockwise. Either reverse the order of the points or reverse the sign of one of the coordinates. As this is rotation symmetry about Z, it works to simply flip the sign for the x coordinates: minID = 35; maxID = 45; ht = 25; th = 2; $fn = 100; minIR = minID/2; maxIR = maxID/2; module Cup() rotate_extrude(convexity = 10) polygon([[0,0], [minIR+th,0], [maxIR+th,ht], [maxIR+th+th,ht], [maxIR+th+th,ht+th], [maxIR,ht+th], [minIR,th], [0,th]]); Cup(); Carsten Arnholm On 08. okt. 2016 16:39, jon wrote: > When I create this STL, it is defective, but I cannot figure out what > the defect is. It looks fine in OpenSCAD. > > > minID = 35; > maxID = 45; > ht = 25; > th = 2; > > $fn = 100; > minIR = minID/2; > maxIR = maxID/2; > > module Cup() > rotate_extrude(convexity = 10) > polygon([[0,0], > [-minIR-th,0], > [-maxIR-th,ht], > [-maxIR-th-th,ht], > [-maxIR-th-th,ht+th], > [-maxIR,ht+th], > [-minIR,th], > [0,th]]); > > Cup(); > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Sat, Oct 8, 2016 4:01 PM
What version of OpenSCAD is that? Latest release?
I guess, that fix might be only in the snapshot versions:
https://github.com/openscad/openscad/issues/1282
On 10/08/2016 05:35 PM, jon wrote: > Turns out if the shape is on the negative part of the Y plane, > it will always be inside out. > What version of OpenSCAD is that? Latest release? I guess, that fix might be only in the snapshot versions: https://github.com/openscad/openscad/issues/1282 ciao, Torsten.
Sat, Oct 8, 2016 4:25 PM
2105.03
Yeah.  I know.  <blush>
Version: 2016.0.7797 / Virus Database: 4656/13171 - Release Date: 10/08/16
2105.03 Yeah. I know. <blush> On 10/8/2016 12:01 PM, Torsten Paul wrote: > On 10/08/2016 05:35 PM, jon wrote: >> Turns out if the shape is on the negative part of the Y plane, >> it will always be inside out. >> > What version of OpenSCAD is that? Latest release? > > I guess, that fix might be only in the snapshot versions: > https://github.com/openscad/openscad/issues/1282 > > ciao, > Torsten. > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > Version: 2016.0.7797 / Virus Database: 4656/13171 - Release Date: 10/08/16 > >
Ronaldo
Sat, Oct 8, 2016 7:42 PM
The polygon vertex circulation does not affect the orientation of the model
generated by rotate_extrude, neither with negative angles.
View this message in context: http://forum.openscad.org/problem-STL-tp18608p18620.html
cacb wrote > Your polygon is defined clockwise. Unless I am mistaken it needs to be > counterclockwise. Either reverse the order of the points or reverse the > sign of one of the coordinates. The polygon vertex circulation does not affect the orientation of the model generated by rotate_extrude, neither with negative angles. -- View this message in context: http://forum.openscad.org/problem-STL-tp18608p18620.html Sent from the OpenSCAD mailing list archive at Nabble.com.
