Why are manifolds important?
Tue, Feb 27, 2018 2:45 PM
One of the things that has puzzled me is the requirement that objects
for 3D printing be manifold.
First, I should note that I'm not strong on the math involved and so I'm
not absolutely sure what "manifold" means.
I understand that it's bad for objects to be self-intersecting.  A
self-intersecting object ... isn't exactly an object at all, and has no
translation to physical reality.  Well, except maybe through implicitly
unioning.  And, absent "polyhedra" and "polygons" that aren't polyhedra
or polygons, is there any way to get self-intersecting objects in OpenSCAD?
But I don't understand the requirement to avoid shared edges.
cube(1);
translate([1,1,0]) cube(1);
Why is this a problem?  Yeah, it's got a piece that's zero thickness
right along where the two cubes touch, but that doesn't seem any harder
than having it be infinitesimal.  It's more or less obvious what I mean,
so why should I have to worry about it?  Why should I have to keep
nudging objects around so that they don't touch, when in the physical
reality that I'm trying to model they do touch?
(And if you ask "should the slicer put a filament between the two
cubes", my answer is "I don't care".  If I wanted them to be separate
objects I would have kept them separate, and if I wanted them to be
solidly joined I would have made them solidly joined.  Again, this seems
like an extreme case of a piece of an object that is much smaller than
the extrusion width or thickness, or two objects that mathematically
don't touch but are separated by less than the printer resolution.)
Is it all about making unambiguous sense out of polygon soup?
One of the things that has puzzled me is the requirement that objects for 3D printing be manifold. First, I should note that I'm not strong on the math involved and so I'm not *absolutely* sure what "manifold" means. I understand that it's bad for objects to be self-intersecting.  A self-intersecting object ... isn't exactly an object at all, and has no translation to physical reality.  Well, except maybe through implicitly unioning.  And, absent "polyhedra" and "polygons" that aren't polyhedra or polygons, is there any way to get self-intersecting objects in OpenSCAD? But I don't understand the requirement to avoid shared edges. cube(1); translate([1,1,0]) cube(1); Why is this a problem?  Yeah, it's got a piece that's zero thickness right along where the two cubes touch, but that doesn't seem any harder than having it be infinitesimal.  It's more or less obvious what I mean, so why should I have to worry about it?  Why should I have to keep nudging objects around so that they don't touch, when in the physical reality that I'm trying to model they *do* touch? (And if you ask "should the slicer put a filament between the two cubes", my answer is "I don't care".  If I wanted them to be separate objects I would have kept them separate, and if I wanted them to be solidly joined I would have made them solidly joined.  Again, this seems like an extreme case of a piece of an object that is much smaller than the extrusion width or thickness, or two objects that mathematically don't touch but are separated by less than the printer resolution.) Is it all about making unambiguous sense out of polygon soup?
Tue, Feb 27, 2018 4:28 PM
Two objects can't share an edge in reality, so there is no reason to send
such models to a 3D printer. If you want them joined then have some
overlap, if not leave a gap.
On 27 February 2018 at 14:45, Jordan Brown openscad@jordan.maileater.net
cube(1);
Two objects can't share an edge in reality, so there is no reason to send such models to a 3D printer. If you want them joined then have some overlap, if not leave a gap. On 27 February 2018 at 14:45, Jordan Brown <openscad@jordan.maileater.net> wrote: > One of the things that has puzzled me is the requirement that objects for > 3D printing be manifold. > > First, I should note that I'm not strong on the math involved and so I'm > not *absolutely* sure what "manifold" means. > > I understand that it's bad for objects to be self-intersecting. A > self-intersecting object ... isn't exactly an object at all, and has no > translation to physical reality. Well, except maybe through implicitly > unioning. And, absent "polyhedra" and "polygons" that aren't polyhedra or > polygons, is there any way to get self-intersecting objects in OpenSCAD? > > But I don't understand the requirement to avoid shared edges. > > cube(1); > translate([1,1,0]) cube(1); > > Why is this a problem? Yeah, it's got a piece that's zero thickness right > along where the two cubes touch, but that doesn't seem any harder than > having it be infinitesimal. It's more or less obvious what I mean, so why > should I have to worry about it? Why should I have to keep nudging objects > around so that they don't touch, when in the physical reality that I'm > trying to model they *do* touch? > > (And if you ask "should the slicer put a filament between the two cubes", > my answer is "I don't care". If I wanted them to be separate objects I > would have kept them separate, and if I wanted them to be solidly joined I > would have made them solidly joined. Again, this seems like an extreme > case of a piece of an object that is much smaller than the extrusion width > or thickness, or two objects that mathematically don't touch but are > separated by less than the printer resolution.) > > Is it all about making unambiguous sense out of polygon soup? > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
Tue, Feb 27, 2018 5:02 PM
Jordan,
The manifold condition is demanded mainly for technical reasons.
Fortunately, it agrees with the common sense for 3D printing as nophead
likes to say. But many algorithms would be more complex if the manifold
condition is not met. For instance, imagine a slicer algorithm computing
the outer hotend path of a layer. When it arrives to the edge of the mesh,
it should decide where to go from there. If the edge is common to two cubes
there are three possible ways to go on and the algorithm should keep a
record of the decision it makes there in order to avoid retracing a path
already taken. With a manifold condition there is only one way to go on
from an edge and you don't need to keep any record.
2018-02-27 11:45 GMT-03:00 Jordan Brown openscad@jordan.maileater.net:
cube(1);
Jordan, The manifold condition is demanded mainly for technical reasons. Fortunately, it agrees with the common sense for 3D printing as nophead likes to say. But many algorithms would be more complex if the manifold condition is not met. For instance, imagine a slicer algorithm computing the outer hotend path of a layer. When it arrives to the edge of the mesh, it should decide where to go from there. If the edge is common to two cubes there are three possible ways to go on and the algorithm should keep a record of the decision it makes there in order to avoid retracing a path already taken. With a manifold condition there is only one way to go on from an edge and you don't need to keep any record. 2018-02-27 11:45 GMT-03:00 Jordan Brown <openscad@jordan.maileater.net>: > One of the things that has puzzled me is the requirement that objects for > 3D printing be manifold. > > First, I should note that I'm not strong on the math involved and so I'm > not *absolutely* sure what "manifold" means. > > I understand that it's bad for objects to be self-intersecting. A > self-intersecting object ... isn't exactly an object at all, and has no > translation to physical reality. Well, except maybe through implicitly > unioning. And, absent "polyhedra" and "polygons" that aren't polyhedra or > polygons, is there any way to get self-intersecting objects in OpenSCAD? > > But I don't understand the requirement to avoid shared edges. > > cube(1); > translate([1,1,0]) cube(1); > > Why is this a problem? Yeah, it's got a piece that's zero thickness right > along where the two cubes touch, but that doesn't seem any harder than > having it be infinitesimal. It's more or less obvious what I mean, so why > should I have to worry about it? Why should I have to keep nudging objects > around so that they don't touch, when in the physical reality that I'm > trying to model they *do* touch? > > (And if you ask "should the slicer put a filament between the two cubes", > my answer is "I don't care". If I wanted them to be separate objects I > would have kept them separate, and if I wanted them to be solidly joined I > would have made them solidly joined. Again, this seems like an extreme > case of a piece of an object that is much smaller than the extrusion width > or thickness, or two objects that mathematically don't touch but are > separated by less than the printer resolution.) > > Is it all about making unambiguous sense out of polygon soup? > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
Tue, Feb 27, 2018 6:37 PM
My printer makes the outsides of objects quite accurately. But when I
command a 3mm hole in openscad, I get something quite a lot smaller.
I can then command a 3.5mm hole and get something that fits a 3mm
bolt. Great.
The problem with this approach is that I can design perfect objects
for my printer, but they will work "not well" for others.
The objects STL/openscad that we publish should be as close as
possible to "what works". People should preferably tell the slicer to
increase the hole sizes etc.etc.
Suppose I have
union () {
cube ([20,20,1]);
translate ([10,0,0]) cube (10);
translate ([0,10,0]) cube (10);
In theory two of these can mate. In practice, to make it work
you would have to do something like this.
tol=0.2;
union () {
cube ([20,20,1]);
translate ([10+tol,0,0]) cube ([10-tol,10,10]);
translate ([0,10+tol,0]) cube ([10,10-tol,10]);
So... I would think that "edges in common" are something that happen
commonly "theoretically ideal" files. And it would be preferable to be
able to load such theoretical files into slicers because that
eliminates the tolerances that individual printers have from the
object-description-files.
**    Delftechpark 26 2628 XH  Delft, The Netherlands. KVK: 27239233    **
On Tue, Feb 27, 2018 at 04:28:45PM +0000, nop head wrote: > Two objects can't share an edge in reality, so there is no reason to > send such models to a 3D printer. If you want them joined then have > some overlap, if not leave a gap. My printer makes the outsides of objects quite accurately. But when I command a 3mm hole in openscad, I get something quite a lot smaller. I can then command a 3.5mm hole and get something that fits a 3mm bolt. Great. The problem with this approach is that I can design perfect objects for my printer, but they will work "not well" for others. The objects STL/openscad that we publish should be as close as possible to "what works". People should preferably tell the slicer to increase the hole sizes etc.etc. Suppose I have union () { cube ([20,20,1]); translate ([10,0,0]) cube (10); translate ([0,10,0]) cube (10); } In theory two of these can mate. In practice, to make it work you would have to do something like this. tol=0.2; union () { cube ([20,20,1]); translate ([10+tol,0,0]) cube ([10-tol,10,10]); translate ([0,10+tol,0]) cube ([10,10-tol,10]); } So... I would think that "edges in common" are something that happen commonly "theoretically ideal" files. And it would be preferable to be able to load such theoretical files into slicers because that eliminates the tolerances that individual printers have from the object-description-files. Roger. -- ** R.E.Wolff@BitWizard.nl ** http://www.BitWizard.nl/ ** +31-15-2600998 ** ** Delftechpark 26 2628 XH Delft, The Netherlands. KVK: 27239233 ** *-- BitWizard writes Linux device drivers for any device you may have! --* The plan was simple, like my brother-in-law Phil. But unlike Phil, this plan just might work.
Troberg
Tue, Feb 27, 2018 7:50 PM
Very "explain like I'm 5" explanation:
The manifold is the surface that determines what's the inside and what's the
outside of the object, which is, of course extremely important when
3D-printing. So, if a polygon is facing the wrong way, or two sides or edges
line up perfectly, we get an ambiguous situation, where we can't always
figure out what's inside and what's outside, which of course messes things
up.
Very "explain like I'm 5" explanation: The manifold is the surface that determines what's the inside and what's the outside of the object, which is, of course extremely important when 3D-printing. So, if a polygon is facing the wrong way, or two sides or edges line up perfectly, we get an ambiguous situation, where we can't always figure out what's inside and what's outside, which of course messes things up. -- Sent from: http://forum.openscad.org/
Tue, Feb 27, 2018 11:43 PM
I can, by the way, readily believe that in a polygon soup it may be
difficult or perhaps even impossible to decide what parts are inside and
what parts are outside.  If you have six cubes laid out touching around
a central cubic void, I could easily believe that it would be hard to
tell whether that central cube should or should not be filled.  That
seems like a key problem with a "polygon soup" structure.
Can't they?
For all macroscopic purposes, they can - if I take two cubes and shove
them corner-to-corner, they sure look like they are sharing an edge.
Yes, I understand that at some microscopic / mathematical level they
aren't, but why do I have to care about that?
If my two cubes were separated by a tiny distance - say, a micrometer -
then the slicer would know what to do.  It would probably try (and
probably fail) to separate the two paths by a micrometer, and the result
would probably be either a tiny gap or a tiny overlap.
If my two cubes were joined by a similarly tiny distance, the slicer
would again know what to do.  It would probably consider putting plastic
across the joint, realize that the plastic would have to be much smaller
than the extrusion width, and either leave a gap or lay down plastic far
larger than that called for by the model.
So if the slicer can handle a gap of epsilon, and it can handle a joint
of epsilon, and it produces pretty much the same result in both cases,
why does a gap of zero cause its brain to explode?  Or perhaps I should
say:  why SHOULD a gap of zero cause its brain to explode?
In 3D printing, the resolution is around 100um (depending on printer and
axis blah blah blah).  Anything below that is too small to care about...
so why should we have to care about it?
I can get that the algorithms might be a little simpler, but how many
slicer developers are there and how many model designers are there?
Which does it make sense to optimize for?
Also:  it seems like your slicer algorithm will inevitably be faced with
issues like this, because it's dealing with physical reality, not math.
If the two cubes have a joint that is only one extrusion width wide, the
slicer is faced with the same three-way choice.  Similarly if it's three
extrusion widths wide, when making the second loop.  In fact, the "zero"
case seems easier - there (if you've defined that the edge of the
mathematical object should be the edge of the physical object) it's
clear that it must stay on the "same" cube, because the centerline of
the extrusion must be 0.5EW inside the mathematical boundary... and
transitioning onto that other cube would necessarily take the plastic
outside of the bounds of the mathematical object.
I can, by the way, readily believe that in a polygon soup it may be difficult or perhaps even impossible to decide what parts are inside and what parts are outside.  If you have six cubes laid out touching around a central cubic void, I could easily believe that it would be hard to tell whether that central cube should or should not be filled.  That seems like a key problem with a "polygon soup" structure. On 2/27/2018 8:28 AM, nop head wrote: > Two objects can't share an edge in reality, so there is no reason to > send such models to a 3D printer. If you want them joined then have > some overlap, if not leave a gap. Can't they? For all macroscopic purposes, they can - if I take two cubes and shove them corner-to-corner, they sure *look* like they are sharing an edge. Yes, I understand that at some microscopic / mathematical level they aren't, but why do I have to care about that? On 2/27/2018 9:02 AM, Ronaldo Persiano wrote: > The manifold condition is demanded mainly for technical reasons. > Fortunately, it agrees with the common sense for 3D printing as > nophead likes to say. But many algorithms would be more complex if the > manifold condition is not met. For instance, imagine a slicer > algorithm computing the outer hotend path of a layer. When it arrives > to the edge of the mesh, it should decide where to go from there. If > the edge is common to two cubes there are three possible ways to go on > and the algorithm should keep a record of the decision it makes there > in order to avoid retracing a path already taken. With a manifold > condition there is only one way to go on from an edge and you don't > need to keep any record. If my two cubes were separated by a tiny distance - say, a micrometer - then the slicer would know what to do.  It would probably try (and probably fail) to separate the two paths by a micrometer, and the result would probably be either a tiny gap or a tiny overlap. If my two cubes were joined by a similarly tiny distance, the slicer would again know what to do.  It would probably consider putting plastic across the joint, realize that the plastic would have to be much smaller than the extrusion width, and either leave a gap or lay down plastic far larger than that called for by the model. So if the slicer can handle a gap of epsilon, and it can handle a joint of epsilon, and it produces pretty much the same result in both cases, why does a gap of zero cause its brain to explode?  Or perhaps I should say:  why SHOULD a gap of zero cause its brain to explode? In 3D printing, the resolution is around 100um (depending on printer and axis blah blah blah).  Anything below that is too small to care about... so why should we have to care about it? I can get that the algorithms might be a little simpler, but how many slicer developers are there and how many model designers are there?  Which does it make sense to optimize for? Also:  it seems like your slicer algorithm will inevitably be faced with issues like this, because it's dealing with physical reality, not math.  If the two cubes have a joint that is only one extrusion width wide, the slicer is faced with the same three-way choice.  Similarly if it's three extrusion widths wide, when making the second loop.  In fact, the "zero" case seems easier - there (if you've defined that the edge of the mathematical object should be the edge of the physical object) it's clear that it must stay on the "same" cube, because the centerline of the extrusion must be 0.5EW inside the mathematical boundary... and transitioning onto that other cube would necessarily take the plastic outside of the bounds of the mathematical object.
Tue, Feb 27, 2018 11:51 PM
Sorry, I thought I read ahead before responding, but it seems not.
Exactly!  :-)
up.
As you will have seen, that was my guess.
This is a "polygon soup" problem, that would be solved using a data
structure that directly represents polyhedra, right?
Sorry, I thought I read ahead before responding, but it seems not. On 2/27/2018 11:50 AM, Troberg wrote: > Very "explain like I'm 5" explanation: Exactly!  :-) > The manifold is the surface that determines what's the inside and what's the > outside of the object, which is, of course extremely important when > 3D-printing. So, if a polygon is facing the wrong way, or two sides or edges > line up perfectly, we get an ambiguous situation, where we can't always > figure out what's inside and what's outside, which of course messes things > up. As you will have seen, that was my guess. This is a "polygon soup" problem, that would be solved using a data structure that directly represents polyhedra, right?
N
NateTG
Wed, Feb 28, 2018 12:29 AM
I'm not sure that "directly represents polyhedra" means anything.
Something like a voxel model would not have these issues, but has its own
drawbacks.
JordanBrown wrote > ... > > As you will have seen, that was my guess. > > This is a "polygon soup" problem, that would be solved using a data > structure that directly represents polyhedra, right? > > ... I'm not sure that "directly represents polyhedra" means anything. Something like a voxel model would not have these issues, but has its own drawbacks. -- Sent from: http://forum.openscad.org/
arnholm@arnholm.org
Wed, Feb 28, 2018 8:52 AM
No, the issue of where the material is and where the void is, is
unrelated to the question of "polygon soup" vs. an explicitly connected
polyhedron, assuming the "polygon soup" is reasonable enough that
connectivity can be inferred from it.
What is is "inside" is entirely determined by the triangle face normal
vectors. The normal vector is computed from the 3 triangle vertex
coordinates, i.e. cross product of 2 vectors. It is the local order of
the triangle vertices that determines which way the face normal points
and therefore also where "inside" and "outside" is. This can be either
way in both a polyhedron and a polygon soup representation.
To make a meaningful solid you need to have faces that are properly
connected to a single neighbour at each edge (2 manifold) and the
normals must be consistently pointing the same way ("outwards") from one
face to its neighbour. The face normal requirement is valid also when
you have a polygon soup like STL.
Your six cube example is ok wrt. defining inside/outside as long as the
face normals all point out of the cubes. You will however have 12 edges
that are not 2 manifold (they are each referenced by 4 faces rather than
2).
size = 10;
delta = 0;
translate([-size+delta,0,0])cube(size,center=true);
translate([0,-size+delta,0])cube(size,center=true);
translate([+size-delta,0,0])cube(size,center=true);
translate([0,+size-delta,0])cube(size,center=true);
translate([0,0,-size+delta])cube(size,center=true);
translate([0,0,+size-delta])cube(size,center=true);
The material volume of this is well defined (6000) even if it is not
2-manifold. You could print it, but it would fall apart. For a real-life
print you would set delta to some reasonable small value, and the model
becomes 2-manifold and would hold together.
On 2018-02-28 00:43, Jordan Brown wrote: > I can, by the way, readily believe that in a polygon soup it may be > difficult or perhaps even impossible to decide what parts are inside > and what parts are outside. If you have six cubes laid out touching > around a central cubic void, I could easily believe that it would be > hard to tell whether that central cube should or should not be filled. > That seems like a key problem with a "polygon soup" structure. No, the issue of where the material is and where the void is, is unrelated to the question of "polygon soup" vs. an explicitly connected polyhedron, assuming the "polygon soup" is reasonable enough that connectivity can be inferred from it. What is is "inside" is entirely determined by the triangle face normal vectors. The normal vector is computed from the 3 triangle vertex coordinates, i.e. cross product of 2 vectors. It is the local order of the triangle vertices that determines which way the face normal points and therefore also where "inside" and "outside" is. This can be either way in both a polyhedron and a polygon soup representation. To make a meaningful solid you need to have faces that are properly connected to a single neighbour at each edge (2 manifold) and the normals must be consistently pointing the same way ("outwards") from one face to its neighbour. The face normal requirement is valid also when you have a polygon soup like STL. Your six cube example is ok wrt. defining inside/outside as long as the face normals all point out of the cubes. You will however have 12 edges that are not 2 manifold (they are each referenced by 4 faces rather than 2). size = 10; delta = 0; union() { translate([-size+delta,0,0])cube(size,center=true); translate([0,-size+delta,0])cube(size,center=true); translate([+size-delta,0,0])cube(size,center=true); translate([0,+size-delta,0])cube(size,center=true); translate([0,0,-size+delta])cube(size,center=true); translate([0,0,+size-delta])cube(size,center=true); } The material volume of this is well defined (6000) even if it is not 2-manifold. You could print it, but it would fall apart. For a real-life print you would set delta to some reasonable small value, and the model becomes 2-manifold and would hold together. Carsten Arnholm
Thu, Mar 1, 2018 8:55 PM
If you have a real polyhedron definition, where you know which triangles
belong together and how they are connected, do you still need to care
about normal vectors?
(Assuming that you define the rest of the universe to be "outside".)
Intuitively, it seems like a particular volume is "inside" if in getting
there from the outside you have to cross an odd number of faces.
rather than 2).
Yes.
Right.  It was intended as a geometry discussion point, not something
really printable.  (But two cubes with touching edges, on top of another
object, would be not-2-manifold, but would be reasonably sensible to print.)
On 2/28/2018 12:52 AM, arnholm@arnholm.org wrote: > On 2018-02-28 00:43, Jordan Brown wrote: >> I can, by the way, readily believe that in a polygon soup it may be >> difficult or perhaps even impossible to decide what parts are inside >> and what parts are outside.  If you have six cubes laid out touching >> around a central cubic void, I could easily believe that it would be >> hard to tell whether that central cube should or should not be filled. >>  That seems like a key problem with a "polygon soup" structure. > > No, the issue of where the material is and where the void is, is > unrelated to the question of "polygon soup" vs. an explicitly > connected polyhedron, assuming the "polygon soup" is reasonable enough > that connectivity can be inferred from it. > > What is is "inside" is entirely determined by the triangle face normal > vectors. The normal vector is computed from the 3 triangle vertex > coordinates, i.e. cross product of 2 vectors. It is the local order of > the triangle vertices that determines which way the face normal points > and therefore also where "inside" and "outside" is. This can be either > way in both a polyhedron and a polygon soup representation. If you have a real polyhedron definition, where you know which triangles belong together and how they are connected, do you still need to care about normal vectors? (Assuming that you define the rest of the universe to be "outside".) Intuitively, it seems like a particular volume is "inside" if in getting there from the outside you have to cross an odd number of faces. > Your six cube example is ok wrt. defining inside/outside as long as > the face normals all point out of the cubes. You will however have 12 > edges that are not 2 manifold (they are each referenced by 4 faces > rather than 2). Yes. > The material volume of this is well defined (6000) even if it is not > 2-manifold. You could print it, but it would fall apart. For a > real-life print you would set delta to some reasonable small value, > and the model becomes 2-manifold and would hold together. Right.  It was intended as a geometry discussion point, not something really printable.  (But two cubes with touching edges, on top of another object, would be not-2-manifold, but would be reasonably sensible to print.)
