I am new to this forum, and perhaps this is not where to ask the question?
I thought I posted the question to the forum yesterday, but I have
received no confirmation by email that I am accepted in this forum.
So I repeat my question and hope for an answer - at least whether I am
accepted or not.
Best regards
Bo Nystedt
Arrays openScad : I need to use the results of nested loops in
quicksort() function but it seems impossible.
'arr' in second last line (in code below) will not contain more than one
value at a time. In the first run of the loop arr gets the value 2.01,
in second run the value is 1.6125, and so on. What I need is an array
containing all four values in this way:
arr=[[2.01],[1.6125],[3.775],[4.8]], because quicksort needs such an
input. If is it possible to achieve that in openScad, how do I do it?
|function quicksort(arr) = !(len(arr)>0) ? [] : let(|
|pivot = arr[floor(len(arr)/2)],|
|lesser = [ for (y = arr) if (y < pivot) y ],|
|equal = [ for (y = arr) if (y == pivot) y ],|
|greater = [ for (y = arr) if (y > pivot) y ]|
|) concat(quicksort(lesser), equal, quicksort(greater));|
|x_0=262; y_0=140; x_1=17.5;y_1=305;x_2=500;y_2=255; x_3=575;y_3=385;|
|ads=[[x_0,y_0],[x_1,y_1],[x_2,y_2],[x_3,y_3]];|
|for(b=[0 : 3])|
|||for(c=[0:0])|
|||if(ads[b][0]>=0 && ads[b][1]>=0)|
|||asc_diff=((ads[b][0])+ads[b][1])/2*0.01; |
|||arr=asc_diff; |
|||//quicksort(arr) ; |
|||echo("27: arr", arr); |
You can use list comprehensions
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/List_Comprehensions to
compose lists:
