JA
joe a
Wed, Feb 1, 2023 7:53 PM
Again the Noob.
Have some existing scad files I wish to modify.
I find myself wishing for a means to "step through" the code and have
the affected part in the rendered view become highlighted at least to
some "gross" degree.
Is it possible at this time?
Again the Noob.
Wed, Feb 1, 2023 7:57 PM
No.
But you might look at the modifiers; they can be helpful in that area.
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Modifier_Characters
have the affected part in the rendered view become highlighted at
least to some "gross" degree.
In classic sense: no.
You can add ! in front of something to render only this subtree.
You can add # in front of multiple parts to preview everything and
highlight those parts.
You can right click in the view port (in preview mode) to jump to
the code generating this geometry - with some limitations.
You can add ! in front of something to render *only* this subtree.
BC
Bob Carlson
Thu, Feb 2, 2023 3:52 AM
The # highlight works only when you do F5, not F6.
You can also use echo. It’s worth spending some time learning the various ways to use this. Use str() with it. Relevant to echo is all the threads, including the recent one, about order of execution. Echo can be really confusing if you do not understand order of execution when you do "A(args) B(args) C(args)" for example.
-Bob
Tucson AZ
-Bob
Tucson AZ
FH
Father Horton
Thu, Feb 2, 2023 4:01 AM
Also note that you can use echo() in a let statement. You have to supply a
dummy variable to receive the value of the function call, but it works.
-Bob
Tucson AZ
> -Bob
> Tucson AZ
> ciao,
> Torsten.
Thu, Feb 2, 2023 11:18 AM
You may need to use a dummy variable anyway, even in modules, do to order
of execution. If you have this:
echo(myvariable);
x=f(myvariable);
then the assignment to x runs before the echo, which is a module, and if it
creates an error, it will stop your program and prevent the echo from ever
running, so then you don't understand why you got the error. Changing it
to dummy=echo(myvariable) makes the echo into an assignment as well, and
then it runs before the x assignment.
On Wed, Feb 1, 2023 at 11:03 PM Father Horton fatherhorton@gmail.com
-Bob
Tucson AZ
echo(myvariable);
x=f(myvariable);
On Wed, Feb 1, 2023 at 11:03 PM Father Horton <fatherhorton@gmail.com>
>> -Bob
>> Tucson AZ
>> ciao,
>> Torsten.
FH
Father Horton
Thu, Feb 2, 2023 12:05 PM
Which is an example of why you can’t step through OpenSCAD code: execution
order is not necessarily linear.
echo(myvariable);
x=f(myvariable);
it creates an error, it will stop your program and prevent the echo from
ever running, so then you don't understand why you got the error.
Changing it to dummy=echo(myvariable) makes the echo into an assignment as
well, and then it runs before the x assignment.
a dummy variable to receive the value of the function call, but it works.
-Bob
Tucson AZ
> echo(myvariable);
> x=f(myvariable);
>>> -Bob
>>> Tucson AZ
>>> ciao,
>>> Torsten.
