Hi
I often want to remix work by others. This usually relates to moved fixings
and openings. I usually heal the original opening and then create a new one
to suit my needs. To do this I usually import the original stl and then
create a plug, union() the two together and then finally make the new hole
using difference().
I am trying to do this with an object from Thingiverse:
http://www.thingiverse.com/thing:588121
Here is my code that will not render correctly:
*$fn=60;
importOnly();
module importOnly(){
union(){
#cylinder(h=30.2, d=6);
translate([-100.55,-146.85,0])
import("Launchpad_Core_Rounded.stl", convexity=10);
What I get is just the cylinder that could be created with just this:
*cylinder(h=30.2, d=6);
I have tried using utilities that convert the STL to an OpenSCAD polygon,
such as:
http://jsfiddle.net/Riham/yzvGD/embedded/result/
I have the same issue either way, any ideas why this will not work?
View this message in context: http://forum.openscad.org/Rendering-Issue-tp16698.html
With my system the import has no problem. Try to update OpenSCAD (I am using
2016.01)
View this message in context: http://forum.openscad.org/Rendering-Issue-tp16698p16702.html
On my system it will Preview but the STL won't render using your code.
I get this error:
violation! Expr: pe_prev->is_border() ||
!internal::Plane_constructor::get_plane(pe_prev->facet(),pe_prev->facet()->plane()).is_degenerate()
File:
/Users/kintel/code/OpenSCAD/openscad/../libraries/install/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h
Line: 251
Strangely if I simply import the object by opening it with scad it creates a
new file with one line:
import("/Users/macdarren/Downloads/Launchpad_Core_Rounded.stl");
This is will both preview and render fine...
View this message in context: http://forum.openscad.org/Rendering-Issue-tp16698p16703.html
scad it creates a new file with one line:
This is normal as no CSG operation is done for just the import().
The STL has 17 Zero Faces (polygons without area) which OpenSCAD,
or more specifically libCGAL which is used to do the boolean
operations, does not like.
Using the repair filter in MeshLab as mentioned in the FAQ
fixes the issue for me:
For grins I ran the original STL through Netfabb,
now your code seems to both preview and render fine using the 'fixed' model.
Your fill plug shows as very slightly taller than the original surface of
the model. It did this on the earlier prefixed model in the preview to so
probably not the result of anything in the repair process.
My guess something odd about the STL file when openscad tried to merge the
plug into the shape.
https://modelrepair.azurewebsites.net
View this message in context: http://forum.openscad.org/Rendering-Issue-tp16698p16705.html
Thanks for all the replies, I will repair the original as advised and move
on. I think I am running one of the nightly builds at present so I will also
update.
View this message in context: http://forum.openscad.org/Rendering-Issue-tp16698p16708.html
