I have always assumed, based on what has been written on this forum in the
past, that OpenSCAD functions like rotate(), translate(), scale(), etc are
just front ends for multmatrix(). Am I mistaken there and the actual
implementation of rotate() is independent of multmatrix()? It is always
possible to force special values like sin(90)->sin(pi/2)==1, but is it
actually done? From the code references Torsten has given, I at least am not
able to ascertain that, and thus I remain sceptical. Kudos to nophead for
finding a workaround, but I am looking for more.
I am looking for information that is trustworthy enough that I can build an
exception handler on it, an exception handler that lays to rest CGAL
assertion violations, once and for all. I have learned enough by now that I
can do just that manually - at least if the .stl files are small enough. But
I also want to do that under program control, and with large files, so that
others can benefit as well. So I need more accuracy.
X86 hardware provides accuracy these days for floating point operations
better than 1E-19 decimal or not worse than 2^-65 binary. OpenSCAD, on the
other hand, for the script known as issue1258
https://github.com/openscad/openscad/blob/master/testdata/scad/3D/issues/issue1258.scad
, suffers from accuracy not better than 1E-5 decimal, or 2^-18 binary, which
is a 47 binary digits difference. It is this big loss in precision that is
at the heart of degenerate triangles, and all that flows from it.
wolf
View this message in context: http://forum.openscad.org/Rounding-Errors-tp21821p21938.html
Some short answers to requested info:
OpenSCAD is source code that can be compiled on different C++ compilers. We use the default compiler for Linux distros and usually the most recent platform compiler for OS X. For Windows, we use whatever gcc version http://mxe.cc provides.
The source code is always going to be the authoritative information about how anything is implemented. If you cannot find it, ask here and someone can usually point you to the correct location.
