GS
Guenther Sohler
Mon, Oct 30, 2023 7:46 AM
Hi Glenn,
your Train model looks great, I like it!
I also tried to model a train before but I failed getting the correct
dimensions and correct proportions.
How did you manage to get those correct? did you use a physical reference ?
On Mon, Oct 30, 2023 at 2:58 AM Glenn Butcher glenn.butcher@gmail.com
Nah, a fair bit of hack code. Particularly nasty is an unholy amalgam of
polyround() and a path_extrude() routine I found on Thingiverse to make the
bell hangar.
I started this about a year ago, no previous experience with CAD or 3d
printing. I just wanted to build a model of the locomotive, OpenSCAD
appealed to the programmer I am, so I just started beating it until it
puked a locomotive... :D
On 10/29/2023 7:15 PM, Revar Desmera wrote:
Master Class work on that train model!
On Oct 29, 2023, at 2:34 PM, Glenn Butcher glenn.butcher@gmail.com
glenn.butcher@gmail.com wrote:
On 10/29/2023 2:22 PM, Jordan Brown wrote:
or maybe the downstream consumer will be OK with overlapping shapes.
Indeed. For 3d printing of scale model parts, all I care about is that at
a given point in a layer, at least one object renders a "1" pixel. With
that thinking, I defined and translated enough cubes, cylinders, and
extruded polygons to model this:
<2023-10-19_stl_integration-800x600.png>
Hi Glenn,
On Mon, Oct 30, 2023 at 2:58 AM Glenn Butcher <glenn.butcher@gmail.com>
> bell hangar.
> - Revar
> On Oct 29, 2023, at 2:34 PM, Glenn Butcher <glenn.butcher@gmail.com>
Mon, Oct 30, 2023 8:39 AM
On 10/30/23 00:34, Jordan Brown wrote:
On 10/29/2023 6:53 PM, Glenn Butcher wrote:
Preview rendering is very important to me, primarily in integrating
parts that have things like common screwholes. Manifold doesn't (yet)
improve that.
I believe that union is very fast in preview. It just throws all of the
triangles at OpenGL and OpenGL figures it out, quite possibly in hardware.
which is not what I get here. The attached .png just now took for an F6,
Total rendering time: 0:00:09.927
But an F5 was:
Total rendering time: 0:00:01.012
however the time to see the displayed result, both in the preview and in
the log window was over a full minute. And that was fast, I've got some
things that take half an hour for an f5, but 3 minutes for an f6? This
on a 6 core 3.8GHZ i5 with 32 GB of dram. Whats it doing before the
image is displayed? This from a Linux 64 bit AppImage dated
2023.09.10.ai16125.
One possible answer may be related to the fact that read/write access to
my raid10 /home by any so called file requester takes anywhere from 30
seconds to 5 minutes just to open that file requesters image on screen.
And its been that way since I installed bookworm, with the same raid10
on buster it was instant. DigiKam's latest AppImage won't wait, so I
cannot import from my camera. So maybe I'm blaming the wrong thing for
the F5 delay?
Cheers, Gene Heskett.
>> improve that.
But an F5 was:
2023.09.10.ai16125.
the F5 delay?
- Louis D. Brandeis
Mon, Oct 30, 2023 8:42 AM
On 10/30/23 03:47, Guenther Sohler wrote:
Hi Glenn,
I agree, that's very impressive.
mailto:glenn.butcher@gmail.com> wrote:
__
amalgam of polyround() and a path_extrude() routine I found on
Thingiverse to make the bell hangar.
3d printing. I just wanted to build a model of the locomotive,
OpenSCAD appealed to the programmer I am, so I just started beating
it until it puked a locomotive... :D
- Revar
is that at a given point in a layer, at least one object renders
a "1" pixel. With that thinking, I defined and translated enough
cubes, cylinders, and extruded polygons to model this:
To unsubscribe send an email todiscuss-leave@lists.openscad.org <mailto:discuss-leave@lists.openscad.org>
> Hi Glenn,
> <mailto:glenn.butcher@gmail.com>> wrote:
> __
>> - Revar
>>> _______________________________________________
>>> To unsubscribe send an email to discuss-leave@lists.openscad.org
- Louis D. Brandeis
GB
Glenn Butcher
Mon, Oct 30, 2023 3:45 PM
Firstly, the prototype still exists and is operable, sitting in
Antonito, CO USA. I've visited it quite a few times, taken many
pictures. In some photos, I've included a block of wood I have cut to
exactly 12 inches; with that, I can take some measurements from the photo.
I also have a rather crude drawing of a sister locomotive, #169, which
sits on display in Alamosa CO. I use that for validation.
Still, I have discrepancies to resolve. One is a gap in the printed
boiler from the frame; I think I've found it in the OpenSCAD render of
all the parts, boiler wasn't aligned correctly with the cylinder chest
and cab, so it didn't show in the render. I needed to add a bit to the
vertical dimension of the firebox. Haven't printed that yet, we'll see...
It's interesting sometimes to model something, make it pretty and
dimension-conformant, then print it and find something doesn't work.
For example, I print the handrail stanchions on the boiler, but they
were getting washed off in the alcohol bath after printing. I had to
add to the correct dimensions to help them survive.
Hi Glenn,
reference ?
> Hi Glenn,
> reference ?
Mon, Oct 30, 2023 4:59 PM
The furniture in my house model has many places where I bumped a 1" part
like a table or chair leg to 2" or more because a stack of 1mm donuts
was just too fragile. (And I didn't want to print those pieces flat and
glue them into place.)
Tue, Oct 31, 2023 10:32 AM
'You can't scale nature' - LBSC
photo.
Hi Glenn,
reference ?
> photo.
>> Hi Glenn,
>> reference ?
GB
Glenn Butcher
Tue, Oct 31, 2023 1:37 PM
That's the whole point of scale modeling: creating an artifact that
represents a "real" item, scaled down in size. The materials and
mechanisms don't have to be exact replications, if the intent is to just
present an appearance.
The compressor hanging on the port side of the boiler is a good
example. It has enough detail to look "detailed" at normal viewing
distances, but it's missing a lot of the tabs, bolts, pipes and other
fittings of the real article.
photo.
which sits on display in Alamosa CO. I use that for validation.
of all the parts, boiler wasn't aligned correctly with the cylinder
chest and cab, so it didn't show in the render. I needed to add a bit
to the vertical dimension of the firebox. Haven't printed that yet,
we'll see...
Hi Glenn,
correct dimensions and correct proportions.
reference ?
>> photo.
>> we'll see...
>>> Hi Glenn,
>>> reference ?
Tue, Oct 31, 2023 3:05 PM
I bet it looks fine if you scale up your model viewing distance to that
of the full size loco. e.g. normal viewing distance of your 3.5mm/ft
model, say 12 inches, cf distance of 30 yards or so. when viewing the
full size loco (somewhere I thought you mentioned it was ho scale)
On 31/10/2023 13:37, Glenn Butcher wrote:
It has enough detail to look "detailed" at normal viewing distances,
but it's missing a lot of the tabs, bolts, pipes and other fittings of
the real article.
> the real article.
CM
Curt McDowell
Wed, Nov 1, 2023 11:13 PM
Glenn, that's amazing! What a complicated and beautiful model. My dad
will love to see this. He's into model steam engines and locomotives. I
got him an Ender-3 at the age of 81 and he immediately took to OpenSCAD.
Version 2021.01 on my Linux box took 2h 15m to build this. I had to add
rules for pilot_truck.stl and wheel_set.stl to stl/Makefile, then was
able to open stl_integration.scad in the GUI.
Version 2023.10.31 on my Linux box with --enable=manifold took 37.4
seconds to build the same thing. Now if 215x speedup isn't a game
changer, I don't know what is. --enable=lazy-union did not speed it up
further.
Cheers,
Curt
that at a given point in a layer, at least one object renders a "1"
pixel. With that thinking, I defined and translated enough cubes,
this:_______________________________________________
further.
Cheers,
Curt
