A "cheap" way would be to use spheres, as shown in the following code.
//right angle tube for Richard Pitz's art system
$fn=60;
cylinder(40, 9, 9, center = false);
translate([0, 0, 40]) rotate([0, 90, 0]) cylinder(50, 9, 9, center =
false);
translate([0, 0, 40]) sphere(9);
translate([0, 0, -0.5]) cylinder(39, 6, 6, center = false);
translate([1.5, 0, 40]) rotate([0, 90, 0]) cylinder(49, 6, 6, center =
false);
translate([0, 0, 40]) sphere(6);
}//difference
If you want even softer bows you can try to use code like
rotate_extrude(angle=90) translate([15, 0, 0])circle(9);
rotate_extrude(angle=90) translate([15, 0, 0])circle(6);
of couse there are also good libraries out there in Thingiverse (e.g.
http://www.thingiverse.com/thing:1839527) or you can try with
View this message in context: http://forum.openscad.org/Making-an-elbow-tp21456p21458.html
