Not sure why you want the frame the same thickness as the centre, a
simpler solution is
$fn=100;
LB=127;
linear_extrude(1){
square(LB);
translate([7.5,7.5])square(LB-15);
translate([0.3,0.3,0])
import("P:/Docs/openscad/wallpaper2.svg");
which renders with no errors under OpenSCAD version 2022.11.18.ci12805
(git 1746d5a83)
Your version produces warnings wrt holes, but still renders OK.
If you want a thicker frame, then may be best to superimpose it on the
version above.
On 21/05/2023 18:11, Karl Exler wrote:
$fn=100;
path="wallpaper2.svg";
LB=127;
cube([LB,LB,1]);
translate([7,7,-0.1])
cube([LB-15,LB-15,1.2]);
//scale([0.056,0.056,1])
linear_extrude(1)
import(path);
