ER
edmund ronald
Mon, May 12, 2025 2:28 PM
William,
Are you choosing a particular method eg static binding to ensure the core
of the “optional” embedded python stays the same over time?
Edmund
On Monday, May 12, 2025, William F. Adams via Discuss <
My concern here is of course only from the end-user pov, that in my very
limited experience OpenSCAD has always installed
flawlessly by drag and drop on the Mac and acted in a boring and
predictable fashion. Python on the other hand seems to be
very much into x.y.z version numbers, pip, conda, uv, requirements and
version conflict hell; I don’t call that a good drag and drop
experience. And I really dont find that my python software packages eg.
Pytorch and minions etc work exactly the same from
version to version. I would hate to see a novel render from an old file.
The two programming systems are quite separate/distinct and do not
interact, unless one chooses to put in place a .py file to load, and
invoke a command to load it in your .scad file.
I would like to note that I am somewhat curious about the possibility of
Python being present in the OpenSCAD binary, and a feature being
implemented using that and exposed to a .scad file --- is this something
which seems potentially workable to folks? Or is it a needless complication?
William,
Edmund
> On Monday, May 12, 2025 at 08:39:02 AM EDT, edmund ronald via Discuss <
> The two programming systems are quite separate/distinct and do _not_
> interact, unless one chooses to put in place a .py file to load, _and_
> William
Mon, May 12, 2025 2:42 PM
I agree with you, Edmund, (although I'm on windows) plus I am sort of
concerned about the reliability of python's stability, since not so long
ago there was upheaval going from v2 to 3. I would not like to build
serious objects on the back of python. Anyway I checked with ChatGPT,
and there is actually an 'official' body looking after python
development (unless it is guessing again) -
Python has a mature, formal governance system with predictable
releases and strong community involvement.
OpenSCAD is more artisanal — driven by passion, caution, and a small
team. That keeps it stable and focused, but slower and less open to
disruptive change.
I find I can do everything I need using OpenSCAD, although I use it
mainly as a mental exercise. I've tried various alternatives, which seem
to lever off openscad, but I have always returned to pure OpenSCAD.
Currently, I'm playing with pythonscad from pythonscad.org. Other than
that, I think python should be kept as far away from 'pure' OpenSCAD as
possible, it will likely pollute its purity... OpenSCAD is not broke,
no need to rush into fixing it.
Best wishes,
Ray
very limited experience OpenSCAD has always installed flawlessly by
drag and drop on the Mac and acted in a boring and predictable
fashion. Python on the other hand seems to be very much into x.y.z
version numbers, pip, conda, uv, requirements and version conflict
hell; I don’t call that a good drag and drop experience. And I really
dont find that my python software packages eg. Pytorch and minions etc
work exactly the same from version to version. I would hate to see a
On Sunday, May 11, 2025, Torsten Paul via Discuss
On 11.05.25 22:39, edmund ronald via Discuss wrote:
A complete Python seems completely incompatible with the idea
of OpenScad as a drop-in software package.
Why? What problem is there?
What does drop-in software package mean here? OpenSCAD is just
a single app, so what would it replace?
I would urge the designers and maintainers of OpenScad to
separate the ideas of Python scripting/syntax support and
complete Python support.
As the language goes, there is only *full* support. The
Python in OpenSCAD *is* just the official CPython not
some copy or partial re-implementation.
The discussion is "only" about using external packages
from pypi.org <http://pypi.org> (e.g. things normally installed
via pip or
some other package manager). Is that needed, and what are
the options to do so easily.
Python has a *mature, formal governance system* with predictable
OpenSCAD is *more artisanal* — driven by passion, caution, and a small
disruptive change.
Best wishes,
Ray
> via pip or
> ciao,
> Torsten.
> <mailto:discuss-leave@lists.openscad.org>
WF
William F. Adams
Mon, May 12, 2025 3:39 PM
OpenSCAD is not broke, no need to rush into fixing it.
Unless your project needs mutable variables or the ability to write out arbitrary files --- arguably:
is the poster-child for that. I certainly appreciate how tolerant the OpenSCAD devs were of my early efforts on this, and also their work/added features which seemed to attempt to accommodate it w/in the limits of OpenSCAD.
On Monday, May 12, 2025 at 09:52:58 AM EDT, Jon Bondy jon@jonbondy.com wrote:
I find the BOSL2 library to be the first place I go when I need a
complex facility that I do not care to write myself. I am curious as to
why you dismiss it so quickly and easily.
It's a large system which I find confusing, and which uses an approach which does not suit the direction I am trying to take --- I want to be able to model tool movement so as to create a 3D model and create DXFs and G-code directly in that process --- it's looking like I may presently get to a point where I have to re-implement some aspects of it, so will have to dig into it, but overall, thus far, I've found all the examples and mentionings of it confusing to me --- obviously it works well for other folks and is well-suited to a more typical approach.
That said, the first thing which I need is to re-implement the METAFONT/POST curve algorithm, so I'll probably start with that (and extending gcodepreview to write out .mp files).
On Monday, May 12, 2025 at 10:28:16 AM EDT, edmund ronald edmundronald@gmail.com wrote:
Are you choosing a particular method eg static binding to ensure the core of the “optional” embedded python
Since I'm on Windows, all I did was install Python per the instructions for PythonSCAD and I trust it to make use of that version. Hopefully, moving forward as Python updates, this process will continue to be simple and straight-forward and my code will continue to run --- I'm not doing anything that complex, and I'm not using any constructs which are version-specific, so I believe it will continue to work moving forward. If not, will address it then (there have been long stretches when I haven't updated PythonSCAD, so worst-case is I just stop updating).
I've also been careful not to take on any projects which involve more recent versions of Python --- I don't know if that's necessary or a concern, but I try to keep things as simple as possible.
Similarly, if OpenSCAD had just gained the ability to write out files I'd've probably figured out some way to make it work, but that's not an option for OpenSCAD itself, so the added capability and flexibility which Python adds via OpenPythonSCAD is esp. welcome to me.
On Monday, May 12, 2025 at 10:42:24 AM EDT, Raymond West via Discuss <discuss@lists.openscad.org> wrote:
On Monday, May 12, 2025 at 09:52:58 AM EDT, Jon Bondy <jon@jonbondy.com> wrote:
On Monday, May 12, 2025 at 10:28:16 AM EDT, edmund ronald <edmundronald@gmail.com> wrote:
Since I'm on Windows, all I did was install Python per the instructions for PythonSCAD and I trust it to make use of that version. Hopefully, moving forward as Python updates, this process will continue to be simple and straight-forward and my code will continue to run --- I'm not doing anything _that_ complex, and I'm not using any constructs which are version-specific, so I believe it will continue to work moving forward. If not, will address it then (there have been long stretches when I haven't updated PythonSCAD, so worst-case is I just stop updating).
Mon, May 12, 2025 5:22 PM
On 5/12/2025 12:07 AM, Karl Exler via Discuss wrote:
ähmm.. for all of us, who are not Prgrammers and who are happy to have
with OpenScad a fine modelling software..... has all this Phyton
"tamtam" any relevance for us ?
Tough question.
If you're happy with "no programming", if you think that a "for" loop or
an "if" is exotic, then... no. But then again lots of advanced OpenSCAD
stuff won't be interesting.
If you're interested in programmatic CAD (writing programs to produce
models) and OpenSCAD's limitations and quirks are a problem for you...
yes, definitely.
If you're somewhere in the middle... shrug, it's something you might
want to be aware of but probably not follow in detail.
Eventually I think we might need to split the mailing list into two or
more pieces, with one focusing on the OpenSCAD language and one on the
Python variant, and maybe another on the UI that's shared between the
two. I don't know when that would be.
Tough question.
yes, definitely.
Tue, May 13, 2025 1:22 AM
Python has a lot of different libraries which could be used to make very
complex sketches.
I mostly use numpy and scipy.
For quite sometime I have not written much but I have already written a lot
of different functions. For people who are using python can use my library.
It is quite powerful.
On Mon, 12 May, 2025, 10:53 pm Jordan Brown via Discuss, <
with OpenScad a fine modelling software..... has all this Phyton "tamtam"
Tough question.
models) and OpenSCAD's limitations and quirks are a problem for you... yes,
definitely.
If you're somewhere in the middle... shrug, it's something you might want
Python variant, and maybe another on the UI that's shared between the two.
complex sketches.
> Tough question.
> definitely.
John David
Tue, May 13, 2025 3:42 PM
complex sketches.
lot of different functions. For people who are using python can use my
library. It is quite powerful.
Tough question.
definitely.
@Sanjeev Prabhakar <sprabhakar2006@gmail.com>, which library? URL?
On Mon, May 12, 2025 at 9:22 PM Sanjeev Prabhakar via Discuss <
> complex sketches.
>> Tough question.
>> definitely.
Tue, May 13, 2025 4:10 PM
complex sketches.
Tough question.
definitely.
I think that it's at:
https://github.com/sprabhakar2006/openSCAD/tree/main
https://github.com/sprabhakar2006/openSCAD/blob/main/openscad2.py
On Tue, May 13, 2025 at 10:43 AM John David via Discuss <
>> complex sketches.
>>> Tough question.
>>> definitely.
Wed, May 14, 2025 1:38 AM
Thanks Leonard:
That is correct
the url: https://github.com/sprabhakar2006/openSCAD
Following files should be downloaded:
- openscad2.py
- dependencies2.scad
- dependencies.scad (optional, Initially I started writing functions in
pure openscad and very soon gave up, but still there are a lot of useful
functions written here with explanation).
for learning about the functions (kind of documentation):
- explanation of approaches\ example of various functions.pdf
In my view:
While sketching / modeling you very soon reach a point where openSCAD
native language falls short of doing things and it is very hard to write
complex functions.
Hats off to BOSL developers who have written such elaborate and complex
things in pure openscad. But despite their extraordinary skills, there are
a lot of things which still would be almost impossible to do effectively,
due to the limitation of structured language (e.g. finding the intersection
between solids, fillets in complex cases, offsets 2d and 3d effectively for
complex cases and so on)
I am not very good at python, but still could write very complex functions
with a short study of python language. Till today, I do not know the
concept of classes in python which probably would be very trivial for many
here.
I am sure a good python programmer can write much better and can be useful
to all here.
Thanks and Regards
Sanjeev
On Tue, 13 May 2025 at 21:41, Leonard Martin Struttmann via Discuss <
complex sketches.
Tough question.
or an "if" is exotic, then... no. But then again lots of advanced OpenSCAD
definitely.
Thanks Leonard:
That is correct
- openscad2.py
In my view:
complex functions.
here.
to all here.
Thanks and Regards
Sanjeev
>>> complex sketches.
>>>> Tough question.
>>>> definitely.
ER
edmund ronald
Wed, May 14, 2025 11:24 AM
I think all points of view discussed so far have merit.
One might freeze openSCAD basically as it stands now, why break something
useful? Just as TeX was frozen and serves as a base for the widely employed
LaTex macro system and environments. And then see whether new work which
allows more powerful scripting should build o what is here or on another of
the CodeCAD variants.
On Wed, May 14, 2025 at 3:39 AM Sanjeev Prabhakar via Discuss <
Thanks Leonard:
That is correct
- openscad2.py
In my view:
complex functions.
here.
to all here.
Thanks and Regards
Sanjeev
very complex sketches.
Tough question.
definitely.
> Thanks Leonard:
> That is correct
> - openscad2.py
> In my view:
> complex functions.
> here.
> to all here.
> Thanks and Regards
> Sanjeev
>>>>> Tough question.
>>>>> definitely.
GS
Guenther Sohler
Wed, May 14, 2025 12:49 PM
- Maybe because some of the folks dont like the intentional limitations
of OpenSCAD like Scoping and the inability to communicate with the
outside world ??
Please note that the intent is not to break or alter it, but to extend
while highest priority is to stay backward-compatible.
To ensure that, there exist over thousands of ctests to make sure, that we
don't inadvertently break something ...
On Wed, May 14, 2025 at 1:24 PM edmund ronald via Discuss <
Thanks Leonard:
That is correct
- openscad2.py
In my view:
complex functions.
functions with a short study of python language. Till today, I do not know
the concept of classes in python which probably would be very trivial for
many here.
useful to all here.
Thanks and Regards
Sanjeev
a lot of different functions. For people who are using python can use my
have with OpenScad a fine modelling software..... has all this Phyton
Tough question.
definitely.
or more pieces, with one focusing on the OpenSCAD language and one on the
* Maybe because some of the folks dont like the intentional limitations
outside world ??
>> Thanks Leonard:
>> That is correct
>> - openscad2.py
>> In my view:
>> complex functions.
>> many here.
>> useful to all here.
>> Thanks and Regards
>> Sanjeev
>>>>>> Tough question.
>>>>>> definitely.
