B
bboett
Thu, Jul 11, 2019 3:30 PM
Hello,
somehow, didn't find anything in the docu, so i must be looking at the wrong
places....
i am still dabbling with my spoolholder, and made one openscad file where i
assembled the 2 pieces (ok, i could print the separately, but since i am
still learning....)
somehow, i managed to put a gap around 1.5mm into my drawings....
so when i try to print them, one is fine, and the other is printed into thin
air.....
now i could tell the slicer to put in some raft, but thats unelegant....
so is there a way, when i use a module from another file, to tell it to
floor it on (0,0,0)?
or is there a way to tell exactly what the gap is, to be able to make a
translation?
thanks in advance
Bruno
Hello,
places....
still learning....)
air.....
translation?
thanks in advance
Bruno
AC
A. Craig West
Thu, Jul 11, 2019 3:34 PM
With imported objects, I spend a lot of time displaying various cubes with
% to find the exact position of various planes in the objects, so I can
offset them properly. Unfortunately, there seems to be no way to ask the
system for this information.
On Thu, 11 Jul 2019, 11:31 bboett, bboett@gmail.com wrote:
Hello,
wrong
places....
still learning....)
thin
air.....
translation?
thanks in advance
Bruno
On Thu, 11 Jul 2019, 11:31 bboett, <bboett@gmail.com> wrote:
> Hello,
> wrong
> places....
> still learning....)
> thin
> air.....
> translation?
> thanks in advance
> Bruno
JF
Joe Francis
Thu, Jul 11, 2019 3:39 PM
Right - OpenSCAD can't do this for you.
The "trick", really, is to design all your parts around a convenient
origin and then translate them to the assembled position. It seems most
people's intuition is to model the part in the assembled position and
then try to move it back to a convenient origin for printing (or
whatever else).
I'm sure some will debate this being a better way, but it's much more
obviously the best way if you get to a point where you're reusing models
that you created. Having a convenient origin makes this much more
practical, for a lot of reasons.
Joe
with % to find the exact position of various planes in the objects, so
I can offset them properly. Unfortunately, there seems to be no way to
ask the system for this information.
mailto:bboett@gmail.com> wrote:
Hello,
the wrong
places....
file where i
since i am
still learning....)
into thin
air.....
unelegant....
it to
make a
translation?
thanks in advance
Bruno
whatever else).
that you created. Having a convenient origin makes this *much* more
Joe
> <mailto:bboett@gmail.com>> wrote:
> Hello,
> the wrong
> places....
> file where i
> since i am
> still learning....)
> into thin
> air.....
> unelegant....
> it to
> make a
> translation?
> thanks in advance
> Bruno
AC
A. Craig West
Thu, Jul 11, 2019 3:44 PM
Generally I do the import with offsets to zero it to origin in a module,
then use offsets to position the module appropriately
people's intuition is to model the part in the assembled position and then
try to move it back to a convenient origin for printing (or whatever else).
Joe
Hello,
wrong
places....
i
still learning....)
thin
air.....
translation?
thanks in advance
Bruno
> Joe
>> Hello,
>> wrong
>> places....
>> i
>> still learning....)
>> thin
>> air.....
>> translation?
>> thanks in advance
>> Bruno
> OpenSCAD mailing listDiscuss@lists.openscad.orghttp://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
lar3ry
Thu, Jul 11, 2019 6:00 PM
thin
air.....
translation?
Repetier Host will lay it flat for you. Earier versions required the use of
the "Lay Flat" icon in the Object Placement tab, but in trying it just now,
a test cube, translated to 10,10,10 actually does drop to the bed when
loaded. Then, you can move it to the origin (0,0) of your bed, and export it
(Export icon, box with exiting arrow). My Repetier Host is V2.1.3
But a better way to import STL files and position them is to use a rather
nifty little python script written by Jamie Bainbridge, called stldim.py,
modified by me.. His original script can be found at:
https://www.reddit.com/r/3Dprinting/comments/7ehlfc/python_script_to_find_stl_dimensions/
I have modified it to produce a OpenSCAD translate() statements to position
any imported STL (or any other object, for that matter) in any one of the
four quadrants, or the center of X,Y, and Z.
See
http://forum.openscad.org/Getting-dimensions-of-imported-shape-tt24237.html#a26496
for my modified script and instructions for use.
I see that many folks have asked for a way to find and use a bounding box in
OpenSCAD, and I wonder if it will ever be implemented. It would be very
handy, and its use could be implemented as just information in the console,
or used directly in something that might be called "absolute_translate().
> thin
> air.....
> translation?
See
lar3ry
Thu, Jul 11, 2019 6:08 PM
oops... just realized that I made some more modifications to that script and
put it on github.
https://github.com/lar3ry/OpenSCAD---Move-STL-to-origin
put it on github.
Thu, Jul 11, 2019 6:21 PM
box in OpenSCAD, and I wonder if it will ever be implemented.
Perversely, I don't think OpenSCAD itself knows the bounding box,
because it doesn't do the geometry work. The output from OpenSCAD
execution is a list of objects, transformations, and boolean operations,
and OpenCSG and CGAL are the ones that do the geometry work.
If you look at Design > Display CSG Tree, I think that's the output from
the execution phase.
Maybe, after rendering, there could be a view of that tree that includes
bounding box information. You couldn't use it as part of the execution
of the program, but you could copy and paste it.
Perversely, I don't think OpenSCAD itself *knows* the bounding box,
Thu, Jul 11, 2019 6:30 PM
I should note that I have no actual knowledge of the internals. If my
mental model is wrong, I'd appreciate it if somebody who knows more were
to correct me.
to correct me.
G
GZ
Thu, Jul 11, 2019 9:01 PM
to correct me.
relativity.scad library does alignments
> to correct me.
Thu, Jul 11, 2019 9:55 PM
Aligning objects a priori is not hard. What's not possible is taking
some arbitrary object and determining its geometry after it's been
constructed.
That is:
cylinder(h=10, d=2);
translate([-1,-1,10]) cube(2);
will more or less reliably give you a cube atop a cylinder. However, if
you then
module foo() {
rotate([45,0,0]) {
there's no way to perch something on top of the resulting foo() without
doing math.
I'm too lazy right now to do the math, but experimentation says it's at
about [ 0, -7.8, 9.2 ]. There's no way to get that value out of
OpenSCAD, or to get the foo's bounding box.
Relativity helps you to construct a model with specified alignment, but
does it at the front of the pipeline. You can't give it an arbitrary
existing object like foo() above and expect it to be able to align
additional objects relative to it. Relativity can only work because it
knows the geometry of the objects it's putting together.
constructed.
That is:
you then
module foo() {
rotate([45,0,0]) {
doing math.
_knows_ the geometry of the objects it's putting together.
