Re: Export to .STL / .3MF for later 3D-printing.
Sat, May 7, 2022 10:09 PM
Where did you get your model if you don't understand how to use
linear_extrude()?
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/2D_to_3D_Extrusion
With regards to use of path_sweep I have said that adding the two
characters "2d" will fix the problem.  This does not seem terribly
complex to me.  The other possibilities are to address the same
problem in different ways.  Arguably the self-intersecting shape is
ugly, so you might want to change the shape so it doesn't self
intersect, creating a line where the intersection occurs instead of a
smooth, rounded surface.
On Sat, May 7, 2022 at 5:40 PM Jan Öhman via Discuss
Cc:
Bcc:
Date: Sat, 7 May 2022 21:38:31 +0000 (UTC)
Subject: [OpenSCAD] Re: Export to .STL / .3MF for later 3D-printing.
Thanks every one.
I understand that Adrian Mariano has an explanation (probably pretty good).
But still do not understand what to do in my case.
"...It has a 2d polygon (easily found as there is one lone
polygon call) that needs to be removed "
I think it is the polygon call in the moule Box that it is referenced.
But if I delete the polygon call, that structure will disappear ... or ...?
"or linear_extruded" I don't understand...
"And it makes use of path_sweep in a manner that produces
a self-intersecting polyhedron."
Now it will be very difficult - I think
"This issue is explained in the manual page for path_sweep."
OK!
"This can be fixed either by switching to path_extrude2d() or
by changing the corner radius to eliminate the self-intersections."
"or changing to a profile that can actually be rounded at the desired radius."
Is this the same problem that is solved in another way?
Den lördag 7 maj 2022 19:50:51 CEST, Michael Möller private2michael@gmail.com skrev:
Indeed you did Adrian, I was curious what that long code was going to produce.
Michael, fra mobilen
lør. 7. maj 2022 19.06 skrev Adrian Mariano avm4@cornell.edu:
I already gave a full explanation of what's wrong and how to fix the
first program.  It has a 2d polygon (easily found as there is one lone
polygon call) that needs to be removed or linear_extruded as
appropriate.  And it makes use of path_sweep in a manner that produces
a self-intersecting polyhedron.  This issue is explained in the manual
page for path_sweep.  This can be fixed either by switching to
path_extrude2d() or by changing the corner radius to eliminate the
self-intersections.  Or changing to a profile that can actually be
https://github.com/revarbat/BOSL2/wiki/skin.scad#functionmodule-path_sweep
On Sat, May 7, 2022 at 12:57 PM Michael Möller
private2michael@gmail.com wrote:
Jan Öhman wrote it failed in Render/F6, but works in Preview/F5 - in so many words. I tried and got the following
First model
F6 Error: WARNING: Ignoring 2D child object for 3D operation in file , line 53
ERROR: CGAL error in CGALUtils::applyUnion3D: CGAL ERROR: assertion violation! Expr: G.mark(v1,0)==G.mark(v2,0)&& G.mark(v1,1)==G.mark(v2,1) File: /mxe/usr/x86_64-w64-mingw32.static.posix/include/CGAL/Nef_S2/SM_overlayer.h Line: 303
Which I think is pretty selfexplantory: Passed a 2D shape to something that expected a 3D shape - but you have to read the whole code to find it ... which I think Jan is more qualified to do :-)
2nd part
... which is one of those where zooming or rotating the model in preview takes >5 second
And I didn't bother waiting for the F6 error ... ;-)
Of course, we do not know if the above shapes I got are the ones that Jan wants - there are also sections of code commented out.
(From the comments it seems these are to be nice and alternative covers for wall outlet/switches.)
On Sat, 7 May 2022 at 18:26, Sanjeev Prabhakar sprabhakar2006@gmail.com wrote:
Quite a long code.
Can you paste a picture of what you are trying to draw.
Regards
Sanjeev
On Sat, 7 May 2022, 16:31 Jan Öhman via Discuss, discuss@lists.openscad.org wrote:
Cc:
Bcc:
Date: Sat, 7 May 2022 11:04:31 +0000 (UTC)
Thank you!
Begins to understand how it works. (It was not easy...)
but my solution was not good ...
Here are 2 files that do not work to render (F6)
= = product 1= = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = =
  • . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . -
fn = 150;
placering="left";
// placering="right"
box(0, 0, 0, placering, "#C0C0C0", fn); // (X, Y, Z, left/right, colorName)
// Monteringsplattan
// mountingPlate(0, 0, 0, placering);
// LED belysning
// LEDlampa(0, 0, 0, placering);
// - - - - m o d u l e r - - - - - - - - - - - - - - - - - -
//======  box
module box(posX=0, posY=0, posZ=0, mountSide="left", colorName="#00FF00", fn=24)
side = mountSide == "left" ? 0
: mountSide == "right" ? 1
: assert(false,"invalid moutSide value");  // message if no case worked
color(colorName)
translate([posX, posY, posZ])
mirror([side, 0, 0])
union()
// Skapa konturer på bottenplattan - x, y, r, angles, [grader], början
// Rotation medurs - vänster lamphållare (bakant saknas)
points1 = circSect( 140,  0,  0, [0, 0], "right",  1, fn);  // böj nere till höger
points2 = circSect(  60,  5,  5, [0, 5], "bottom",  1, fn); // brytpunkt längst ned
points3 = circSect(  10, 13,  10, [0, 90], "bottom", 1, fn); // böj nere till vänster
points4 = circSect(  5, 80,  5, [0, 90], "left",  1, fn); // böj uppe till vänster
points5 = circSect( 140, 80,  5, [0, 1], "top",  1, fn);  // böj uppe till höger
edge = concat(points1, points2, points3, points4, points5);
path = path3d(reverse(edge));
section = wall();
path_sweep( section, path, closed=false);
// Skapa bakkant lite högre och smalare i topp
bottom1 = concat(points5, points1);
polygon(bottom1);
path1 = path3d(reverse(bottom1));
section1 = wall1(); // lite högre bakvägg wall(b=4, f=8, h=15, t=3.5)
path_sweep( section1, path1, closed=false);
// fyll upp bottenplattansbaksida
linear_extrude(4) // Bottomplate - fill up
polygon(concat(points1, points2, points3, points4, points5));
// skapa Utskjutande del under (tänk spegelvänt)
pt1 = circSect(  19.5, 85, 0, [0, 50], "top", 1, fn);  // Uppe till höger - moturs
pt2 = circSect(  39, 1.35,  .1, [-5, 90], "right", 1, fn);  // Nere till höger
pt3 = circSect(  10, 13.05,  10, [0, 90], "bottom", 1, fn);  // Nere till vänster
pt4 = circSect(  5, 80, 5, [0, 90], "left",  1, fn);  // Uppe till vänster
translate([0, 0, -2])
linear_extrude(2.1)
polygon(concat(pt1, pt2, pt3, pt4));
// utgången för kabeln på baksidan (diam 10mm) - pekar lite nedåt
cableExit(65, 35, 0, 15, "cyan", $fn=100);
// skapa ett borrhål i bakkant
translate([132,60,15])
{ rotate([0, 90, 0])
{ cylinder(h=10, d=2, $fn=100);
cylinder(h=4, d=9, $fn=100);
// skapa en borrmarkering i bakkant
translate([139,25,15])
cylinder(h=2, d1=1, d2=2.5, $fn=100);
// ingravera årtalet på baksidan
translate([10, 80, -0.5])
{ mirror([side, 0, 0])
{ rotate([0, 180, 0])
{ linear_extrude(3)
text("2022", size=12, direction="ttb", font="Comic Sans MS:style=Bold");
// Markera skruvhål på bakkant
borr=3;
bredd=140;
hojd=8;
avstNed=20;
translate([bredd, avstNed, hojd])
{ rotate([0,90,0])
cylinder(h=2, d1=0.5, d2=borr, center=true, $fn=50);
// borrhål
mountingHole(20, 36, 0, 7, 90.1, 15); // posX, posY, posZ, diam, dist, deep, $fn=50
//========  Slut box
//======  cableExit
module cableExit(posX, posY, posZ, angle, colorName)
{ diamHole = 7;
diamHolder = 9.8;
hight = 12;
topRad = diamHolder/2;
topDiam = diamHolder/2-topRad/2;
bowRad = 7;
offs1 = 0.1;
color(colorName)
{  rotate([180, 0, 180-angle])
{ difference()
{ hull()
{ cylinder(h=hight, d=diamHolder, center=false);
translate([0, 0, hight])        // rundad topp
rotate_extrude(angle=360, convexity=2)
translate([topDiam, 0, 0])  // yttre diam topp
circle(d=topRad);        // radie topp
    inpHight  =  2;   // ett värde som styr var utgångshålet hamnar
    translate([0, 0, -offs1])
      cylinder(h=inpHight+offs1, d=diamHole, center=false); // Bottenhål
    translate([-bowRad, 0, inpHight-offs1]) // böjen
    { rotate([90, 0, 0])
        rotate_extrude(angle=90, convexity=10)
          translate([bowRad, 0, 0]) // ställ in radien på kabelböjen
            circle(d=diamHole);
//======  slut cableExit
//======  mountingHole
module mountingHole(posX=0, posY=0, posZ=0, diam=7, dist=90, deep=5, $fn=50)
{ // diam =  6;  // [mm]
// dist = 90;  // [mm]
// deep =  12;  // [mm]
{ translate([0, 0, -10])
cylinder(h=deep, d=diam);  // fästhål 1
//cableHold1(dist/2, 0, .2, "#D5D5D5");  // Kabelgenomföring
translate([dist/2, 0, 0])
{  hull()
  { cylinder(h=5, d=6);  // fästhål 1
    sphere(d=7.5);
translate([dist, 0, -10])
  cylinder(h=deep, d=diam); // fästhål 2
//======  slut mountingHole
//======  LEDlampa
// module LEDlampa(posX=8, posY=10, posZ=0)
module LEDlampa(posX=0, posY=0, posZ=0, mountSide="left")
{ side = mountSide == "left" ? 0
xpos = mountSide == "left" ? 121
: mountSide == "right" ? -10
ypos = mountSide == "left" ? 10.5
: mountSide == "right" ? 10.5
zpos = mountSide == "left" ? 5
: mountSide == "right" ? 5
// echo(xpos,ypos,zpos);
// translate([xpos, ypos, zpos])
translate([xpos, 10.5, 5])
mirror([1, 0, 0])
{ LEDbottom();
translate([0, 0, 11])
LEDglas();
//======  Slut LEDlampa
//======  LEDglas
module LEDglas()
// Variabler botten
length  = 111;  // längd mm
wideMid = 50.5;  // bredd i mitten mm
cornRad = 10;    // Radien i alla hörn
wideCorn = 48;  // Bredd i kanterna
diamHole = 6;    // håldiameter i mm
colorBot = "gray";
colorTop = "orange";
// Variabler top
cornHigh = 5;  //Höjd i ändarna
midHigh  = 8;
highTop = cornHigh + 1;  // höjd mm
p1tx = 10;      // the start value
p1ty = 49.25;
p2tx = 55.5;    // the middle value
p2ty = 50.5;
p3tx = 101;    // the end value
p3ty = p1ty;
p4tx = 101;    // the start value
p4ty = 1.25;
p5tx = 55.5;    // the middle value
p5ty = 0.0;
p6tx = 10;      // the end value
p6ty = p4ty;
// Ger ovalt glas
points1 = 3points_arc([p1tx,p1ty], [p2tx,p2ty], [p3tx,p3ty], fn=100);
points2 = 3points_arc([p4tx,p4ty], [p5tx,p5ty], [p6tx,p6ty], fn=100);
color("orange")
linear_extrude(height=cornHigh+.1)
{ polygon(concat(points1, points2));
translate([length-10 , wideMid / 2, -.2])
  circle(d=6);
translate([10 , wideMid / 2, -.2])
  circle(d=6);
// Top
color(colorTop)
{ hull()
{ // hörn1
translate([cornRad, wideMid - ((wideMid-wideCorn)/2) - cornRad, 0]) // [10,39]
cylinder(h=cornHigh, d=cornRad2, center=false);
// hörn2
translate([cornRad, cornRad + ((wideMid-wideCorn)/2), 0])          // [10,12]
2, center=false);
// hörn3
translate([length - cornRad, wideMid - ((wideMid-wideCorn)/2) - cornRad, 0]) // [101 ,39]
// hörn4
translate([length - cornRad, cornRad + ((wideMid-wideCorn)/2), 0])  //
2, center=false);
union()
{ // Monteringshål 1 & 2
    cylinder(d=diamHole, h=highTop+.5, center=false);
//========  Slut LEDglas
//======  LEDbottom
module LEDbottom()
{ p1x = 10;      // the start value
p1y = 49.25;
p2x = 55.5;    // the middle value
p2y = 50.5;
p3x = 101;    // the end value
p3y = p1y;
p4x = 101;    // the start value
p4y = 1.25;
p5x = 55.5;    // the middle value
p5y = 0.0;
p6x = 10;      // the end value
p6y = p4y;
// Variabler botten för borrhålen
midHigh  = 8;
// offs1 = 0.1;
heightHole = 15; //mm
height = 11; //mm
points1 = circSect(  10, 11.25,  10, [0, 90], "bottom", 1, fn); // Hörn nere till vänster
points2 = circSect(  10, 39.25,  10, [0, 90], "left",  1, fn); // Hörn uppe till vänster
points3 = 3points_arc([p1x,p1y], [p2x,p2y], [p3x,p3y], fn);
points4 = circSect( 101, 39.25,  10, [0, 90], "top",    1, fn); // Hörn uppe till höger
points5 = circSect( 101, 11.25,  10, [0, 90], "right",  1, fn); // Hörn nere till höger
points6 = 3points_arc([p4x,p4y], [p5x,p5y], [p6x,p6y], fn);
// The base plate for the LED lamp
{ color("gray", 0.5)
linear_extrude(height=height)
polygon(concat(points1, points2, points3, points4, points5, points6));
// union()
cylinder(d=diamHole, h=heightHole, center=false);
//========  Slut LEDbottom
//======  circleSect
// Create rounded corners 2D
// https://openhome.cc/eGossip/OpenSCAD/SectorArc.html
// ange .:  x, y, radien,
//          [från, till] vinkel,
//          var vinkeln startar, (left, bottom, right, top)
//          vilken rotation (-1=medsol, 1=motsols)
function circSect(x=0, y=0, radius=10, angles=[0,270], startRef="bottom", rotate=1, fn=24)  =
let(
startAngel  = (startRef == "left")  ?  0
: (startRef == "bottom") ?  90
: (startRef == "right")  ? 180
: (startRef == "top")    ? 270
: startRef,  // valfri vinkel
// : assert(false,"invalid moutSide value");  // Error message if no case worked
//: undef,
r = radius,
//r = radius / cos(180 / fn),
step = 360 / fn,
// points = [[x, y],
points = [
for(a = [angles[0]-startAngel : step : angles[1]-startAngel])
[-rotate * r * cos(a)+x, r * sin(a)+y]]
) points;
//========  Slut circleSect
//======  3points_arc
// Create an arc with three points 2D
function 3points_arc(p0, p1, p2, fn=10) =
// an alternative expression for D
// D  = 2 * ( (p1-p0).x * (p2-p0).y - (p1-p0).y * (p2-p0).x )
let( D  = 2 * cross(p1-p0, (p2-p0)) )
assert( abs(D)>1e-9, "The 3 points should not be collinear." )
let(
Ux    = ( (p2-p0).y*(p1-p0)(p1-p0) - (p1-p0).y(p2-p0)(p2-p0) )/D,
Uy    = ( (p1-p0).x
(p2-p0)(p2-p0) - (p2-p0).x(p1-p0)(p1-p0) )/D,
radius = norm([Ux,Uy]),
center = [Ux,Uy] + p0,
ang0  = atan2( (p0-center).y, (p0-center).x ),
ang2  = atan2( (p2-center).y, (p2-center).x ),
// the points are in a cw winding iff D<0
// the angular difference between vectors p2-center and p0-center
// measured from p0-center; dang is positive iff D is negative
dang  = D<0  ? ang2<ang0 ? ang2-ang0 : ang2-ang0-360
: ang2>ang0 ? ang2-ang0 : ang2-ang0+360
[ for(i=[0:fn-1])
let( ang = ang0 + i
dang/(fn-1) )
center + radius*[cos(ang),sin(ang)] ];
//========  Slut 3points_arc
//======  Wall som ett "L"
// Normal vägghöjd
function wall() =
let(
b =  4,    // botten - tjocklek
f =  8,    // Foten
h = 15,    // Höjd
t =  3.5,  // Top
x = (b+(t/2) - (h - ( (-h / (f-t)) *t) )) / (-h / (f-t))
let(
points = [[0,0], [f,0], [t,h], [0,h]] ,
top = move([t/2, h, 0], circle(d=t, $fn=20)),
sqr = square([10, b]),
diff =
difference([
move([x, b], square([t/2, t/2])),
move([x+(t/2), b+(t/2), 0], circle(d = t, $fn=20) ) ])
union([points, top, sqr, diff]);
//========  Slut Wall
//======  Wall1 som ett "L"
// En högre vägg
function wall1() =
let(
f =  7,    // Foten
h = 25,    // Höjd
t =  3,  // Top
x = (b+(t/2) - (h - ((-h / (f-t)) *t))) / (-h / (f-t))
let(
diff =
difference([
//========  Slut Wall1
//======  Plåt på släp
module mountingPlate(posX=0, posY=0, posZ=0, mountSide="left", colorName="#C0C0C0", $fn=50)
{ // Hörnpositionerna
posX1 = 120;
posY1 = 0;
posX2 = posX1;
posY2 = -200;
posX3 = 120 - 75;
posY3 = -200;
posX4 = 0;
posY4 = 0;
thick=2;  // tjocklek
xpos = mountSide == "left" ? 20
: mountSide == "right" ? -20
ypos = mountSide == "left" ? 85
: mountSide == "right" ? 85
zpos = mountSide == "left" ? -thick
: mountSide == "right" ? -thick
color(colorName)
{  translate([posX, posY, posZ])
translate([xpos, 85, -thick])
{ linear_extrude(thick)
hull()
{ translate([posX1, posY1, 0])
square(0.1, center = true);
translate([posX2, posY2, 0])
translate([posX3, posY3, 0])
translate([posX4, posY4, 0])
= = END product 1= = = = = = = = = = = = = = = = = = = = = = = = = = = = = =
= = product 2 = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = =
$fn=100;
//$fn=15;
//switch();
//cableHolder4(); //Switchboxen
// cableHolder3(0, 0, 0, 33.5, 23.5, 1.5, 2);
// showCables();
module cableHolder4(fn=24);
{ // idé från
// - https://www.thingiverse.com/thing:6400/files
// - https://ihrchive.wordpress.com/2011/02/14/openscad-tip-round-1-of-3-basic-rounding/
// mått på Switch
heightHold = 10.5;
widthHold = 33.5;
depthHold = 23.5;
spaceHold = 10.0; // utrymmet bakom switch
holdRadie = 2;  // radie i hörnen
thick = 2;
offset1=0.5;  // öka toleransen
// innermått
holeW = widthHold + offset1;
holeH = heightHold + offset1;
holeD = depthHold + spaceHold+offset1;
// yttermått
pad = 0.1;                  // Padding to maintain manifold
box_l = holeW + thick*2;  // Bredden på switchen
box_w = holeD + thick;            // Djupet på switchen
box_h = holeH + thick; // Height
round_r = holdRadie;        // Radius of round
smooth = 45;                // Number of facets of rounding cylinder
{ union() // Detta utförs i två steg.
{ difference()  // utför fasningar och kabelmarkeringar
{ mainBox(box_l, box_w, box_h, spaceHold+thick, round_r, thick, smooth, pad);
    // fasning vänster (underkant)
    translate([box_l/2-0.85, spaceHold-4.3, thick-offset1])  // sidled, fram/bak , upp/ned
      rotate([0,180,45])
        cylinder(h=thick, d1=holeW*1.414-thick-thick, d2=holeW*1.414, $fn=4);
    // fasning höger (underkant)
    translate([box_l/2-3.65, spaceHold-4.3, thick-offset1]) // sidled, fram/bak , upp/ned
      rotate([0,180,45])
    // kabelgenomföringar
    rotate([90, 180, 90]) // Markering ena sidan (vänster under)
      ovalCableHole(spaceHold/2-offset1, -1.75, -1.2);
    rotate([90, 180, 180]) // Markering bakkant (vänster under)
      ovalCableHole(spaceHold/2-1.55, -1.75, -spaceHold-0.85);
    rotate([90, 180, 180]) // Markering bakkant (höger under)
      ovalCableHole(widthHold-spaceHold/2-offset1, -1.75, -spaceHold-0.85);
    rotate([90, -180, 90])  // Markering ena sidan (höger under)
      ovalCableHole(3.75, -1.75, widthHold-0.1);
} // Slut union - kropp
translate([-offset1/2, -spaceHold+pad, -pad]) // hålet där switchen ska placeras
  cube([holeW, holeD+pad, holeH+pad], center=false);
  translate([4, 12, 0])
    cylinder(h=15,d=3.2);
  translate([4, 12, 17.7])
    sphere(r=6);
  translate([29.6, 12, 0])
  translate([29.6, 12, 17.7])
    sphere(r=6);
  /*  // Hål genom lock bak - om så önskas
  translate([box_l/2-thick, -6, offset1/2])
    cylinder(h=box_h+thick*4+offset1, d=3.2, $fn=100);  // hål genom lock bak
  translate([box_l/2-thick, -6, 17.7])
    sphere(r=6);    // kona hålet bak
} // Slut difference() - box
{ union()
  { translate([29.6, 12, heightHold-offset1*2])
      cylinder(h=2,d=5.2);        // Stödhylsa för Switchskruv1
    translate([4, 12, heightHold-offset1*2])
      cylinder(h=2,d=5.2);        // Stödhylsa för Switchskruv2
    translate([holeW/2, -spaceHold+thick+1, holeH/2])
      rotate([180,0,0])
         backHole();
  } // union - slut
  translate([4, 12, 0])     //  Hålen i stödhylsorna
  translate([29.6, 12, 0])  //  Hålen i stödhylsorna
  translate([box_l/2-thick, -6, -offset1])  // hål i stödhylsa bak
    cylinder(h=box_h+offset1, d=3.2, $fn=100);
  // Sänk stödhylsan
  translate([ widthHold/2-7, -spaceHold-offset1, -thick+offset1])  // hål i stödhylsa bak
      cube([15, 8, 3]);
  // kabelmarkering
  // translate([0, 0, 0])  // hål i stödhylsa bak
#cylinder(h=15,d=3.2);
//translate([4, 13.5, 17.3])
//#sphere(r=6);
  //translate([29.6, 13.5, 17.3])
    //#sphere(r=6);
module backHole()
{ wallH = 10.5;
wide1  = 12; // endast runt cylindern
wide2  = 35; // hela väggen
deep1    =  4;
height1  = 10.5;
cornRad1  =  2;
diam1 = 8;
opt1 = 0.1;
//rundadFot();
// Rundad stäcka mellan t.ex. vägg och tak -bakkant
translate([wide2/2, diam1/2-cornRad1/2, -height1/2])
{ rotate([90, 0, -90])
{ linear_extrude(wide2)
{ difference()
{ square([cornRad1, cornRad1]);
      translate([cornRad1, cornRad1])
        circle(r=cornRad1);
// rundad stäcka1 (vänster) mellan t.ex. vägg och tak
translate([-wide2/2+0.15, deep1/2+cornRad1/2, -height1/2])
rotate([90, 0, 0])
{ linear_extrude(spaceHold)
{ difference()
    circle(r=cornRad1);
// rundad stäcka2 mellan t.ex. vägg och tak
translate([wide2/2-0.65, deep1/2+cornRad1/2, -height1/2])
rotate([0, -90, 90])
{ difference()
      circle(r=cornRad1);
// Skapa stödfot - bak
{ union()
{ //själva cylindern
translate([0, 1, 0])
{ cylinder(h=height1, d=diam1, center=true);
translate([0, diam1/2, 0])
cube([diam1,diam1-1,height1], center=true);
  // Rundad fot under cylinder ovan
  translate([0, 1, -height1/2])
  { rotate_extrude()
    { translate([diam1/2, 0, 0])
      { difference()
            circle(r=cornRad1);
  // Rundad rakstäcka1 - cylinderfot - mellan t.ex. vägg och tak
  translate([diam1/2, diam1, -height1/2])
    { linear_extrude(diam1)
      { difference()
            circle(r=cornRad1);
  // Rundad rakstäcka2 - cylinderfot - mellan t.ex. vägg och tak
  translate([-diam1/2, diam1, -height1/2])
  { rotate([0, -90, 90])
      { difference()
            circle(r=cornRad1);
  //väggen bakom cylindern som ska rundas
  translate([0, diam1/2-cornRad1, 0])
    cube([wide1, cornRad1, height1], center=true);
// Avrunda hörn1 bak
translate([-wide1/2, cornRad1/2, cornRad1])
{ hull()
  { cylinder(h=height1+opt1, r=cornRad1, center=true);
    {  translate([0, 0, -height1/2])
        sphere(r=cornRad1);
// Avrunda hörn2 bak
translate([wide1/2, cornRad1/2, cornRad1])
{ hull()
        sphere(r=cornRad1);
// Plocka bort rundad fot bak samt det som sticker ut
translate([-wide1/2, diam1/2-cornRad1/2, -height1/2-opt1])
  cube([wide1, diam1/2+cornRad1, height1+opt1*2], center=false);
module ovalCableHole(posX, posY, posZ)
{ // Hål 5.5 x 3.5 mm
pan = 0.1;
cableHi = 1.5;
{ color("white")
{ translate([0, 0, -pan])
{ cylinder(h=cableHi, d=3.5);
//#translate([0, 0, 0]) cylinder(h=10, d=1);
//translate([0, 0, -1]) cylinder(h=1, d1=0, d2=1);
//translate([0, 0, 0]) sphere(d=1); // Inre kulan
//translate([0, 0, 1.5]) sphere(d=1); // Inre kulan
    translate([0, 0, -1]) sphere(d=0.8); // yttre kulan
    translate([0, 0, 2.5]) sphere(d=0.8); // yttre kulan
  translate([2, 0, -pan])
    // #translate([0, 0, -cableHi*2]) cylinder(h=10, d=0.5);
  translate([-3.5/2, 0, -pan])
    cube([5.5, 3.5/2, cableHi]);
  translate([-0.25, -1.74, -pan])
    cube([2.5, 1.75, cableHi]);
module rundadFot()
// specifika värden för skruvdistansen bak
wallH = 10.5;
wide2  = 34; // hela väggen
deep1    =  4;
height1  = 10;
cornRad1  =  2;
diam1 = 8;
opt1 = 0.1;
color("magenta")
{ translate([0, 0, wallH])
{ difference()
{ union()
{ // Bakgavel
translate([wide2/2, opt1, height1/2])
{ rotate([90, 180, 0])
cube([wide2, height1, opt1]);
      // Golv
      translate([wide2/2, -height1+opt1, -height1/2])
        rotate([0, 180, 0])
      //väggen bakom cylindern som kan rundas
      translate([0, -cornRad1/2, 0])
      //själva cylindern
      translate([0, -cornRad1/2, -height1/2])
      { rotate_extrude()
          { difference()
                circle(r=cornRad1);
      translate([wide2/2, 0, -height1/2])
          { difference()
                circle(r=cornRad1);
      // rundad stäcka mellan t.ex. vägg och tak -sida1
      translate([-wide2/2, 0, -height1/2])
        { linear_extrude(10)
          { difference()
              circle(r=cornRad1);
      // rundad stäcka mellan t.ex. vägg och tak -sida2
      translate([wide2/2, -10, -height1/2])
      { rotate([90, 0, 180])
          { difference()
              circle(r=cornRad1);
    } // Avsluta union = = = = = = = = = = = = = = = = = = = =
    translate([-wide1/2+opt1*1.3, -deep1/2, cornRad1])
          sphere(r=cornRad1);
    translate([wide1/2-opt1*1.3, -deep1/2, cornRad1])
          sphere(r=cornRad1);
    translate([-wide1/2, 0, -height1/2-opt1])
module mainBox(box_l, box_w, box_h, spaceHold, round_r, thick, smooth, pad)
{ translate([box_l/2-thick-offset1/2, box_w/2-spaceHold, box_h/2])
// To fix the corners cut the main cube with smaller cubes with spheres removed
{ cube([box_l, box_w, box_h], center = true);
  // Kant1 - liggande
  translate([0, -box_w/2+round_r, box_h/2-round_r])
  { difference()
    { translate([0,-round_r-pad,round_r+pad])
        cube([box_l+2*pad, round_r*2+pad, round_r*2+pad], center = true);
      rotate(a=[0,90,0])
        cylinder(box_l+4*pad,round_r,round_r,center=true,$fn=smooth);
  // Kant2 - liggande
  translate([0, box_w/2-round_r, box_h/2-round_r])
  { difference()
    { translate([0,round_r+pad,round_r+pad])
      rotate(a=[0,90,0])
  // Kant3 - liggande
  translate([0, -box_w/2+round_r, -box_h/2+round_r])
  { difference()
    { translate([0,-round_r-pad,-round_r-pad])
      rotate(a=[0,90,0])
  // Kant4 - liggande
  translate([0, box_w/2-round_r, -box_h/2+round_r])
  { difference()
    { translate([0,round_r+pad,-round_r-pad])
      rotate(a=[0,90,0])
  // Kant1 - stående
  translate([-box_l/2+round_r, box_w/2-round_r, 0])
  { difference()
    { translate([-round_r-pad,round_r+pad,0])
        cube([round_r*2+pad, round_r*2+pad, box_h+2*pad], center = true);
      cylinder(box_h+4*pad,round_r,round_r,center=true,$fn=smooth);
  // Kant2 - stående
  translate([box_l/2-round_r, box_w/2-round_r, 0])
  { difference()
    { translate([round_r+pad,round_r+pad,0])
  // Kant3 - stående
  translate([-box_l/2+round_r, -box_w/2+round_r, 0])
  { difference()
    { translate([-round_r-pad,-round_r-pad,0])
  // Kant4 - stående
  translate([box_l/2-round_r, -box_w/2+round_r, 0])
  { difference()
    { translate([round_r+pad,-round_r-pad,0])
  // Kant1 liggande (andra hållet)
  translate([-box_l/2+round_r, 0, box_h/2-round_r])
  { difference()
    { translate([-round_r-pad, 0, round_r+pad])
        cube([round_r*2+pad, box_w+2*pad, round_r*2+pad], center = true);
      rotate(a=[0,90,90])
        cylinder(box_w+4*pad,round_r,round_r,center=true,$fn=smooth);
  // Kant2 liggande (andra hållet)
  translate([box_l/2-round_r, 0, box_h/2-round_r])
  { difference()
    {  translate([round_r+pad, 0, round_r+pad])
      rotate(a=[0,90,90])
  // Kant3 liggande (andra hållet)
  translate([-box_l/2+round_r, 0, -box_h/2+round_r])
  { difference()
    { translate([-round_r-pad, 0, -round_r-pad])
      rotate(a=[0,90,90])
  // Kant4 liggande (andra hållet)
  translate([box_l/2-round_r, 0, -box_h/2+round_r])
  { difference()
    { translate([round_r+pad, 0, -round_r-pad])
      rotate(a=[0,90,90])
// Hörn1 (övre)
translate([box_l/2-round_r, box_w/2-round_r, box_h/2-round_r])
{ difference()
{ translate([round_r+pad, round_r+pad, round_r+pad])
cube([round_r
2+pad, round_r2+pad, round_r2+pad], center = true);
sphere(round_r,$fn=smooth);
// Hörn2 (övre)
translate([-box_l/2+round_r, box_w/2-round_r, box_h/2-round_r])
{ difference()
{ translate([-round_r-pad, round_r+pad, round_r+pad])
cube([round_r2+pad, round_r2+pad, round_r2+pad], center = true);
// Hörn3 (övre)
translate([box_l/2-round_r, -box_w/2+round_r, box_h/2-round_r])
{ difference()
{ translate([round_r+pad, -round_r-pad, round_r+pad])
cube([round_r
// Hörn4 (övre)
translate([-box_l/2+round_r, -box_w/2+round_r, box_h/2-round_r])
{ difference()
{ translate([-round_r-pad, -round_r-pad, round_r+pad])
// Hörn1 (undre)
translate([box_l/2-round_r, box_w/2-round_r, -box_h/2+round_r])
{ difference()
{ translate([round_r+pad, round_r+pad, -round_r-pad])
// Hörn2 (undre)
translate([-box_l/2+round_r, box_w/2-round_r, -box_h/2+round_r])
{ difference()
{ translate([-round_r-pad, round_r+pad, -round_r-pad])
cube([round_r
// Hörn3 (undre)
translate([box_l/2-round_r, -box_w/2+round_r, -box_h/2+round_r])
{ difference()
{ translate([round_r+pad, -round_r-pad, -round_r-pad])
// Hörn4 (undre)
translate([-box_l/2+round_r, -box_w/2+round_r, -box_h/2+round_r])
{ difference()
{ translate([-round_r-pad, -round_r-pad, -round_r-pad])
cube([round_r
module cableHolder3(posX, posY, posZ, length, width, height, radius)
{ // Skapa toppen över switchen
// mått på Switchen
fn = 96;          // upplösning (endast bågen?)
heightHold = 10.5;
widthHold = 33.5;
depthHold = 23.5;
holdRadie = 1.5;  // radie i hörnen
thick = 1.5;      // tjocklek
translate([0,-thick,0])
difference(0, 0, 0)
{ hull()
{ difference()
{ translate([thick, 0, heightHold]) // vänster kant
{ rotate([-90, 0, 0])
{ cylinder(h=depthHold, d=thick2);
translate([0, 0, depthHold])
sphere(d=thick
2);          // längst fram
translate([0, -0.1, heightHold]) // plocka bort underdelen
rotate([-90, 0, 0])
cube([thick*2, thick+.1, depthHold+thick+.1]);
    { translate([widthHold-thick, 0, heightHold]) // höger kant
        { cylinder(h=depthHold, d=thick*2);
            sphere(d=thick*2);         // längst fram
      translate([widthHold-thick*2, -0.1, heightHold]) // plocka bort underdelen
  // öppna hålen för monteringsskruvarna uppe på plattan
  translate([4, 13.5, 0])
    sphere(r=6);
  translate([29.6, 13.5, 0])
    sphere(r=6);
// halvbåge 1 bak
translate([thick, 0, heightHold/2+thick/2])
  rotate([0, 90, 180])
    rotate_extrude(angle = 180, convexity=20, $fn=64)
translate([heightHold/2-thick/2, 0, 0])
  circle(d=thick*2);
  sphere(d=thick*2);  // övre kulan
translate([thick, 0, thick])
  sphere(d=thick*2);  // undre kulan
// halvbåge 2 bak
translate([widthHold-thick, 0, heightHold/2+thick/2])
  circle(d=thick*2);
translate([widthHold-thick, 0, thick])
// en cylinder tvärsöver längst upp
{ rotate([0,90,0])
    cylinder(h=widthHold-thick*2, r=thick);
// Halvbågen (kabelhållaren) på baksidan switchen
translate([widthHold-thick, -thick, heightHold/2+thick/2])
{ rotate([0,90,180])
linear_extrude(widthHold-thick2)
arc(heightHold/2-thick/2, [0, 180], thick, fn); //radius, angles, width, fn)
// en cylinder tvärsöver längst ned
translate([thick, -thick, thick])
{ rotate([0,90,0])
2, r=thick);
module switch(posX=0, posY=0, posZ=0)
{ buttRadie = 1.5;
height = 10.5;
width = 33.5;
depth = 23.5;
h1x = buttRadie;
h1y = buttRadie;
h2x = width-buttRadie;
h2y = buttRadie;
h3x = width-buttRadie;
h3y = depth-buttRadie;
h4x = buttRadie;
h4y = depth-buttRadie;
{ difference()
{ color("#F9F9F3")
// tryck-knappen
union()
{ translate([width/2, depth+6-0.1, height/2])
{ translate([0,0,6])
circle(d=6.8);  // skuggan runt knapp
cylinder(h=6, d=6);
sphere(d=6);
    hull()  // Switchkropp
    { translate([h1x, h1y])
        cylinder(h=height, r=1.5);
      translate([h2x, h2y])
      translate([h3x, h3y])
      translate([h4x, h4y])
  // Skruvhålen för switchen
  hole( 4, 12, 0, "#FFD700", height);
  hole(29.6, 12, 0, "#FFD700", height);
  // hole( 4, 12, 0, "#FFD700", 50);
  // hole(29.6, 12, 0, "#FFD700", 50);
  // hål för kablar bak
  color("gray")
  { translate([9.5, 16, height/2])
        cylinder(h=16.5, d=4);
    translate([24.5, 16, height/2])
  // hål för kabelskruvar
  color("white")
  { translate([29.5, 17.1, height/2])
        cylinder(h=4.1, d=4.5);
    translate([-0.1, 17.1, height/2])
// Kabelskruvar
cableScrew(3, 17, height/2, 90);
cableScrew(31, 17, height/2, -90);
// Skruven som håller fast kabeln i switchen
module cableScrew(posX=0, posY=0, posZ=0, angle=0)
{ color("#FFD700")  // mässing
{ rotate([0, 0, angle])
{ difference()
{ // skruvskalle
rotate([90, 0, 0])
cylinder(h=2, d1=4, d2=3.5);
    // stjärnan i skruven
    translate([0, 1.85, -.25])
      rotate([0, 0, 0])
        cylinder(h=0.5, d=5);
    translate([-0.25, -.6, 2.25])
      rotate([0, 90, 0])
        cube([4.5, 2, 0.5]);
// borrhål
module hole(posX=0, posY=0, posZ=0, colorName="yellow", height)
{ diamHole1 = 3;
highHole1 = height;
diamHole2 = 6;
highHole2 = 2.5;
offs=0.1;
color(colorName)
{ translate([0, 0, 0])
cylinder(h=highHole1, d=diamHole1);
translate([0, 0, -offs])
cylinder(h=highHole2, d=diamHole2);
translate([0, 0, height-highHole2+offs])
module showCables()
{ translate([-25,8,24])
rotate([80,177,90])
cable(10,10,0,"brun");
translate([-43,8,15])
rotate([90,180,90])
cable(10,10,0,"blå");
module cable(posX=0, posY=0, posZ=0, colorName="blå", radius=1.26, width=0.62, thick=50, fn=24)
{ // default 1.5mm2
// radius = inner radie
// width = bredd/tjocklek på cirkeln (inte höjd)
// thick = höjd på cirken/ röret
// pin=
colCupper = "#D7715A";
colGreen  = "#07DA63";
colYellow = "#FFCC00";
if (colorName=="gröngul")
{ color(colGreen)
arc(radius, [0, 60], width, fn);
color(colYellow)
arc(radius, [60, 180], width, fn);
color(colGreen)
arc(radius, [180, 240], width, fn);
color(colYellow)
arc(radius, [240, 360], width, fn);
  color(colCupper)
    linear_extrude(10, center=true, convexity=10, $fn=100)
      circle(d=1.24);
else  // vanliga kablar 1.5mm2
cableColor = colorName == "blå" ? "#1870D5"
: colorName == "brun" ? "#9C6137"
: colorName == "svart" ? "#000000"
: assert(false,"invalid color value");  // message if no case worked
// : nodef
{             //el kabel - ena änden rak - andra böjd
  color(colCupper)    //kopparstump tråd rakkabel
      circle(d=1.24);
   color(cableColor)
   { cylinder(h=thick, r=radius);
    translate([-radius*2, 0, thick])  // kabelböj
    rotate([90, 0, 0])
    rotate_extrude(angle=90, convexity=20)
      translate([2.5, 0, 0])
        circle(r=1.26);
    translate([-radius*2, 0, thick+radius*2])
      rotate([0, -90, 0])
      cylinder(h=5, r=radius);
  translate([-10, 0, thick+radius*2])
  { rotate([0, -90, 0])
    { color(colCupper)
      { linear_extrude(5, center=true, convexity=10, $fn=100)
          circle(d=1.24);
module arc(radius, angles, width = 1, fn = 24) {
sector(radius + width, angles, fn); // ytterradie
sector(radius, angles, fn);        // innerradie (plockar bort invändigt
module sector(radius, angles, fn = 24) {
r = radius / cos(180 / fn);
step = -360 / fn;
points = concat([[0, 0]],
    [for(a = [angles[0] : step : angles[1] - 360])
        [r * cos(a), r * sin(a)]
    [[r * cos(angles[1]), r * sin(angles[1])]]
    circle(radius, $fn = fn);
    polygon(points);
= = END product 2 = = = = = = = = = = = = = = = = = = = = = = = = = = = = = =
Den fredag 6 maj 2022 14:06:55 CEST, Michael Möller private2michael@gmail.com skrev:
OpenSCAD code - is a description of your model in terms of a few cylinder/cubes added and cut out
cylinder(d=5,h=10);
translate([0,10,0]) cube([4,6,2]) ;
STL file is a list of triangles which make the same outer shell as your model. OpenSCAD makes this complicated transform from shapes to triangles.
solid OpenSCAD_Model
facet normal 0.92388 0.382682 0
outer loop
vertex 2.5 0 3
vertex 1.76777 1.76777 0
vertex 1.76777 1.76777 3
endloop
endfacet
outer loop
vertex 2.5 0 3
vertex 2.5 0 0
endloop
endfacet
: (and so on for 300 lines) There is a binary/compressed version, but the description is still just triangles.
Gcode is what a 3D printer understands - it is the exact list of moves that the head has to do with how much plastic to squeeze to trace the outline of your shape, layer, by layer. It will optionally create moves for filling the inside or support for overhangs. Such a program is called a SLICER and the printer will come with one.
G92 E0 ; reset extrusion distance
G1 Z2.330 F6600.000 ; lift Z
G1 X-0.000 Y1.505 F6600.000 ; move to first perimeter point
G1 Z0.330 F6600.000 ; restore layer Z
G1 E3.00000 F2400.00000 ; unretract extruder 0
G1 F1500
G1 X-1.064 Y1.064 E3.09259 ; perimeter
G1 X-1.505 Y0.000 E3.18517 ; perimeter
: (many similar lines)
G1 X1.515 Y1.515 E4.65860 ; perimeter
G1 X0.055 Y2.120 E4.78559 ; perimeter
G1 X-0.000 Y2.143 F6600.000 ; move inwards before travel
G1 X0.384 Y0.843 F6600.000 ; move to first infill point
G1 F1500
G1 X0.843 Y0.384 E4.84815 ; infill
G1 X1.097 Y-0.229 E4.91215 ; infill
(and so on for thousands of lines)
The 3MF still basically deals in triangles, and attributes (surface, infill material, picture, ticket info ... ) which probably are not used by your slicer/printer.
On Fri, 6 May 2022 at 12:37, Jan Öhman via Discuss discuss@lists.openscad.org wrote:
To: OpenSCAD General Discussion discuss@lists.openscad.org
Cc:
Bcc:
Date: Fri, 6 May 2022 10:38:46 +0000 (UTC)
Subject: [OpenSCAD] Export to .STL / .3MF for later 3D-printing.
Hi!
Thought to create some objects in openSCAD, to print later.
I do not have my own 3D printer (yet).
One I talked to, wanted to get the drawings in .STL or .3MF. (I don't know the difference).
If I had my own printer, have I been able to print directly from openSCAD?
(Without some export?)
In the openSCAD, no errors or problems occur.
but
The drawings I tested to export from openSCAD have given one or another error message.
One message .:
WARNING: Object may not be a valid 2-manifold and may need repair!
Another message .:
What to do?
From: "Jan Öhman via Discuss" discuss@lists.openscad.org
Cc: "Jan Öhman" jan_ohman@yahoo.com
Bcc:
Bcc:
Bcc:
Where did you get your model if you don't understand how to use linear_extrude()? https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/2D_to_3D_Extrusion With regards to use of path_sweep I have said that adding the two characters "2d" will fix the problem. This does not seem terribly complex to me. The other possibilities are to address the same problem in different ways. Arguably the self-intersecting shape is ugly, so you might want to change the shape so it doesn't self intersect, creating a line where the intersection occurs instead of a smooth, rounded surface. On Sat, May 7, 2022 at 5:40 PM Jan Öhman via Discuss <discuss@lists.openscad.org> wrote: > > > > > ---------- Forwarded message ---------- > From: "Jan Öhman" <jan_ohman@yahoo.com> > To: OpenSCAD general discussion <discuss@lists.openscad.org> > Cc: > Bcc: > Date: Sat, 7 May 2022 21:38:31 +0000 (UTC) > Subject: [OpenSCAD] Re: Export to .STL / .3MF for later 3D-printing. > Thanks every one. > I understand that Adrian Mariano has an explanation (probably pretty good). > But still do not understand what to do in my case. > > "...It has a 2d polygon (easily found as there is one lone > polygon call) that needs to be removed " > I think it is the polygon call in the moule Box that it is referenced. > But if I delete the polygon call, that structure will disappear ... or ...? > > "or linear_extruded" I don't understand... > > "And it makes use of path_sweep in a manner that produces > a self-intersecting polyhedron." > Now it will be very difficult - I think > > "This issue is explained in the manual page for path_sweep." > OK! > > "This can be fixed either by switching to path_extrude2d() or > by changing the corner radius to eliminate the self-intersections." > > "or changing to a profile that can actually be rounded at the desired radius." > Is this the same problem that is solved in another way? > > > Den lördag 7 maj 2022 19:50:51 CEST, Michael Möller <private2michael@gmail.com> skrev: > > > Indeed you did Adrian, I was curious what that long code was going to produce. > > Michael, fra mobilen > > lør. 7. maj 2022 19.06 skrev Adrian Mariano <avm4@cornell.edu>: > > I already gave a full explanation of what's wrong and how to fix the > first program. It has a 2d polygon (easily found as there is one lone > polygon call) that needs to be removed or linear_extruded as > appropriate. And it makes use of path_sweep in a manner that produces > a self-intersecting polyhedron. This issue is explained in the manual > page for path_sweep. This can be fixed either by switching to > path_extrude2d() or by changing the corner radius to eliminate the > self-intersections. Or changing to a profile that can actually be > rounded at the desired radius. > > https://github.com/revarbat/BOSL2/wiki/skin.scad#functionmodule-path_sweep > > On Sat, May 7, 2022 at 12:57 PM Michael Möller > <private2michael@gmail.com> wrote: > > > > Jan Öhman wrote it failed in Render/F6, but works in Preview/F5 - in so many words. I tried and got the following > > > > First model > > > > F6 Error: WARNING: Ignoring 2D child object for 3D operation in file , line 53 > > > > ERROR: CGAL error in CGALUtils::applyUnion3D: CGAL ERROR: assertion violation! Expr: G.mark(v1,0)==G.mark(v2,0)&& G.mark(v1,1)==G.mark(v2,1) File: /mxe/usr/x86_64-w64-mingw32.static.posix/include/CGAL/Nef_S2/SM_overlayer.h Line: 303 > > > > Which I think is pretty selfexplantory: Passed a 2D shape to something that expected a 3D shape - but you have to read the whole code to find it ... which I think Jan is more qualified to do :-) > > > > 2nd part > > > > ... which is one of those where zooming or rotating the model in preview takes >5 second > > > > And I didn't bother waiting for the F6 error ... ;-) > > > > > > Of course, we do not know if the above shapes I got are the ones that Jan wants - there are also sections of code commented out. > > > > (From the comments it seems these are to be nice and alternative covers for wall outlet/switches.) > > > > > > > > On Sat, 7 May 2022 at 18:26, Sanjeev Prabhakar <sprabhakar2006@gmail.com> wrote: > >> > >> Quite a long code. > >> Can you paste a picture of what you are trying to draw. > >> Regards > >> Sanjeev > >> > >> On Sat, 7 May 2022, 16:31 Jan Öhman via Discuss, <discuss@lists.openscad.org> wrote: > >>> > >>> > >>> > >>> > >>> ---------- Forwarded message ---------- > >>> From: "Jan Öhman" <jan_ohman@yahoo.com> > >>> To: OpenSCAD general discussion <discuss@lists.openscad.org> > >>> Cc: > >>> Bcc: > >>> Date: Sat, 7 May 2022 11:04:31 +0000 (UTC) > >>> Subject: [OpenSCAD] Re: Export to .STL / .3MF for later 3D-printing. > >>> Thank you! > >>> Begins to understand how it works. (It was not easy...) > >>> > >>> but my solution was not good ... > >>> > >>> Here are 2 files that do not work to render (F6) > >>> > >>> > >>> = = product 1= = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = > >>> - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - > >>> > >>> > >>> include <BOSL2/std.scad> > >>> fn = 150; > >>> > >>> placering="left"; > >>> // placering="right" > >>> > >>> box(0, 0, 0, placering, "#C0C0C0", fn); // (X, Y, Z, left/right, colorName) > >>> > >>> > >>> // Monteringsplattan > >>> // mountingPlate(0, 0, 0, placering); > >>> > >>> > >>> // LED belysning > >>> // LEDlampa(0, 0, 0, placering); > >>> > >>> > >>> // - - - - - - - - - - - - - - - - - - - - - - - - - - - - - > >>> // - - - - m o d u l e r - - - - - - - - - - - - - - - - - - > >>> > >>> > >>> //================================================================================== > >>> //====== box ===================================================================== > >>> module box(posX=0, posY=0, posZ=0, mountSide="left", colorName="#00FF00", fn=24) > >>> { > >>> side = mountSide == "left" ? 0 > >>> : mountSide == "right" ? 1 > >>> : assert(false,"invalid moutSide value"); // message if no case worked > >>> > >>> color(colorName) > >>> translate([posX, posY, posZ]) > >>> mirror([side, 0, 0]) > >>> difference() > >>> { > >>> union() > >>> { > >>> // Skapa konturer på bottenplattan - x, y, r, angles, [grader], början > >>> // Rotation medurs - vänster lamphållare (bakant saknas) > >>> points1 = circSect( 140, 0, 0, [0, 0], "right", 1, fn); // böj nere till höger > >>> points2 = circSect( 60, 5, 5, [0, 5], "bottom", 1, fn); // brytpunkt längst ned > >>> points3 = circSect( 10, 13, 10, [0, 90], "bottom", 1, fn); // böj nere till vänster > >>> points4 = circSect( 5, 80, 5, [0, 90], "left", 1, fn); // böj uppe till vänster > >>> points5 = circSect( 140, 80, 5, [0, 1], "top", 1, fn); // böj uppe till höger > >>> edge = concat(points1, points2, points3, points4, points5); > >>> path = path3d(reverse(edge)); > >>> section = wall(); > >>> path_sweep( section, path, closed=false); > >>> > >>> > >>> // Skapa bakkant lite högre och smalare i topp > >>> bottom1 = concat(points5, points1); > >>> polygon(bottom1); > >>> path1 = path3d(reverse(bottom1)); > >>> section1 = wall1(); // lite högre bakvägg wall(b=4, f=8, h=15, t=3.5) > >>> path_sweep( section1, path1, closed=false); > >>> > >>> // fyll upp bottenplattansbaksida > >>> linear_extrude(4) // Bottomplate - fill up > >>> polygon(concat(points1, points2, points3, points4, points5)); > >>> > >>> > >>> // skapa Utskjutande del under (tänk spegelvänt) > >>> pt1 = circSect( 19.5, 85, 0, [0, 50], "top", 1, fn); // Uppe till höger - moturs > >>> pt2 = circSect( 39, 1.35, .1, [-5, 90], "right", 1, fn); // Nere till höger > >>> pt3 = circSect( 10, 13.05, 10, [0, 90], "bottom", 1, fn); // Nere till vänster > >>> pt4 = circSect( 5, 80, 5, [0, 90], "left", 1, fn); // Uppe till vänster > >>> translate([0, 0, -2]) > >>> linear_extrude(2.1) > >>> polygon(concat(pt1, pt2, pt3, pt4)); > >>> > >>> // utgången för kabeln på baksidan (diam 10mm) - pekar lite nedåt > >>> cableExit(65, 35, 0, 15, "cyan", $fn=100); > >>> } > >>> > >>> // skapa ett borrhål i bakkant > >>> translate([132,60,15]) > >>> { rotate([0, 90, 0]) > >>> { cylinder(h=10, d=2, $fn=100); > >>> cylinder(h=4, d=9, $fn=100); > >>> } > >>> } > >>> > >>> // skapa en borrmarkering i bakkant > >>> translate([139,25,15]) > >>> { rotate([0, 90, 0]) > >>> cylinder(h=2, d1=1, d2=2.5, $fn=100); > >>> } > >>> > >>> > >>> // ingravera årtalet på baksidan > >>> translate([10, 80, -0.5]) > >>> { mirror([side, 0, 0]) > >>> { rotate([0, 180, 0]) > >>> { linear_extrude(3) > >>> text("2022", size=12, direction="ttb", font="Comic Sans MS:style=Bold"); > >>> } > >>> } > >>> } > >>> > >>> /* > >>> // Markera skruvhål på bakkant > >>> borr=3; > >>> bredd=140; > >>> hojd=8; > >>> avstNed=20; > >>> translate([bredd, avstNed, hojd]) > >>> { rotate([0,90,0]) > >>> cylinder(h=2, d1=0.5, d2=borr, center=true, $fn=50); > >>> } > >>> */ > >>> > >>> // borrhål > >>> mountingHole(20, 36, 0, 7, 90.1, 15); // posX, posY, posZ, diam, dist, deep, $fn=50 > >>> > >>> } > >>> } > >>> //======== Slut box ============================================================== > >>> > >>> > >>> //================================================================================== > >>> //====== cableExit =============================================================== > >>> module cableExit(posX, posY, posZ, angle, colorName) > >>> { diamHole = 7; > >>> diamHolder = 9.8; > >>> hight = 12; > >>> topRad = diamHolder/2; > >>> topDiam = diamHolder/2-topRad/2; > >>> bowRad = 7; > >>> offs1 = 0.1; > >>> > >>> color(colorName) > >>> translate([posX, posY, posZ]) > >>> { rotate([180, 0, 180-angle]) > >>> { difference() > >>> { hull() > >>> { cylinder(h=hight, d=diamHolder, center=false); > >>> translate([0, 0, hight]) // rundad topp > >>> rotate_extrude(angle=360, convexity=2) > >>> translate([topDiam, 0, 0]) // yttre diam topp > >>> circle(d=topRad); // radie topp > >>> } > >>> > >>> > >>> inpHight = 2; // ett värde som styr var utgångshålet hamnar > >>> translate([0, 0, -offs1]) > >>> cylinder(h=inpHight+offs1, d=diamHole, center=false); // Bottenhål > >>> > >>> translate([-bowRad, 0, inpHight-offs1]) // böjen > >>> { rotate([90, 0, 0]) > >>> rotate_extrude(angle=90, convexity=10) > >>> translate([bowRad, 0, 0]) // ställ in radien på kabelböjen > >>> circle(d=diamHole); > >>> } > >>> } > >>> } > >>> } > >>> } > >>> //====== slut cableExit ========================================================== > >>> > >>> > >>> //================================================================================== > >>> //====== mountingHole ============================================================ > >>> module mountingHole(posX=0, posY=0, posZ=0, diam=7, dist=90, deep=5, $fn=50) > >>> { // diam = 6; // [mm] > >>> // dist = 90; // [mm] > >>> // deep = 12; // [mm] > >>> > >>> translate([posX, posY, posZ]) > >>> { translate([0, 0, -10]) > >>> cylinder(h=deep, d=diam); // fästhål 1 > >>> > >>> //cableHold1(dist/2, 0, .2, "#D5D5D5"); // Kabelgenomföring > >>> translate([dist/2, 0, 0]) > >>> { hull() > >>> { cylinder(h=5, d=6); // fästhål 1 > >>> sphere(d=7.5); > >>> } > >>> } > >>> > >>> translate([dist, 0, -10]) > >>> cylinder(h=deep, d=diam); // fästhål 2 > >>> } > >>> } > >>> //====== slut mountingHole ======================================================= > >>> > >>> > >>> //================================================================================== > >>> //====== LEDlampa ================================================================ > >>> // module LEDlampa(posX=8, posY=10, posZ=0) > >>> module LEDlampa(posX=0, posY=0, posZ=0, mountSide="left") > >>> { side = mountSide == "left" ? 0 > >>> : mountSide == "right" ? 1 > >>> : assert(false,"invalid moutSide value"); // message if no case worked > >>> > >>> xpos = mountSide == "left" ? 121 > >>> : mountSide == "right" ? -10 > >>> : assert(false,"invalid moutSide value"); // message if no case worked > >>> /* > >>> ypos = mountSide == "left" ? 10.5 > >>> : mountSide == "right" ? 10.5 > >>> : assert(false,"invalid moutSide value"); // message if no case worked > >>> > >>> zpos = mountSide == "left" ? 5 > >>> : mountSide == "right" ? 5 > >>> : assert(false,"invalid moutSide value"); // message if no case worked > >>> */ > >>> // echo(xpos,ypos,zpos); > >>> // translate([xpos, ypos, zpos]) > >>> translate([xpos, 10.5, 5]) > >>> mirror([1, 0, 0]) > >>> translate([posX, posY, posZ]) > >>> { LEDbottom(); > >>> translate([0, 0, 11]) > >>> LEDglas(); > >>> } > >>> } > >>> //====== Slut LEDlampa =========================================================== > >>> > >>> > >>> //================================================================================== > >>> //====== LEDglas ================================================================= > >>> module LEDglas() > >>> { > >>> // Variabler botten > >>> length = 111; // längd mm > >>> wideMid = 50.5; // bredd i mitten mm > >>> > >>> cornRad = 10; // Radien i alla hörn > >>> wideCorn = 48; // Bredd i kanterna > >>> > >>> diamHole = 6; // håldiameter i mm > >>> > >>> colorBot = "gray"; > >>> colorTop = "orange"; > >>> > >>> // Variabler top > >>> cornHigh = 5; //Höjd i ändarna > >>> midHigh = 8; > >>> highTop = cornHigh + 1; // höjd mm > >>> > >>> p1tx = 10; // the start value > >>> p1ty = 49.25; > >>> p2tx = 55.5; // the middle value > >>> p2ty = 50.5; > >>> p3tx = 101; // the end value > >>> p3ty = p1ty; > >>> > >>> p4tx = 101; // the start value > >>> p4ty = 1.25; > >>> p5tx = 55.5; // the middle value > >>> p5ty = 0.0; > >>> p6tx = 10; // the end value > >>> p6ty = p4ty; > >>> // Ger ovalt glas > >>> points1 = 3points_arc([p1tx,p1ty], [p2tx,p2ty], [p3tx,p3ty], fn=100); > >>> points2 = 3points_arc([p4tx,p4ty], [p5tx,p5ty], [p6tx,p6ty], fn=100); > >>> > >>> color("orange") > >>> linear_extrude(height=cornHigh+.1) > >>> difference() > >>> { polygon(concat(points1, points2)); > >>> > >>> translate([length-10 , wideMid / 2, -.2]) > >>> circle(d=6); > >>> translate([10 , wideMid / 2, -.2]) > >>> circle(d=6); > >>> } > >>> > >>> // Top > >>> color(colorTop) > >>> difference() > >>> { hull() > >>> { // hörn1 > >>> translate([cornRad, wideMid - ((wideMid-wideCorn)/2) - cornRad, 0]) // [10,39] > >>> cylinder(h=cornHigh, d=cornRad*2, center=false); > >>> // hörn2 > >>> translate([cornRad, cornRad + ((wideMid-wideCorn)/2), 0]) // [10,12] > >>> cylinder(h=cornHigh, d=cornRad*2, center=false); > >>> // hörn3 > >>> translate([length - cornRad, wideMid - ((wideMid-wideCorn)/2) - cornRad, 0]) // [101 ,39] > >>> cylinder(h=cornHigh, d=cornRad*2, center=false); > >>> // hörn4 > >>> translate([length - cornRad, cornRad + ((wideMid-wideCorn)/2), 0]) // > >>> cylinder(h=cornHigh, d=cornRad*2, center=false); > >>> } > >>> > >>> union() > >>> { // Monteringshål 1 & 2 > >>> translate([length-10 , wideMid / 2, -.2]) > >>> cylinder(d=diamHole, h=highTop+.5, center=false); > >>> translate([10 , wideMid / 2, -.2]) > >>> cylinder(d=diamHole, h=highTop+.5, center=false); > >>> } > >>> } > >>> } > >>> //======== Slut LEDglas ========================================================== > >>> > >>> > >>> //================================================================================== > >>> //====== LEDbottom =============================================================== > >>> module LEDbottom() > >>> { p1x = 10; // the start value > >>> p1y = 49.25; > >>> p2x = 55.5; // the middle value > >>> p2y = 50.5; > >>> p3x = 101; // the end value > >>> p3y = p1y; > >>> > >>> p4x = 101; // the start value > >>> p4y = 1.25; > >>> p5x = 55.5; // the middle value > >>> p5y = 0.0; > >>> p6x = 10; // the end value > >>> p6y = p4y; > >>> > >>> // Variabler botten för borrhålen > >>> length = 111; // längd mm > >>> wideMid = 50.5; // bredd i mitten mm > >>> diamHole = 6; // håldiameter i mm > >>> cornHigh = 5; //Höjd i ändarna > >>> midHigh = 8; > >>> highTop = cornHigh + 1; // höjd mm > >>> // offs1 = 0.1; > >>> heightHole = 15; //mm > >>> height = 11; //mm > >>> > >>> points1 = circSect( 10, 11.25, 10, [0, 90], "bottom", 1, fn); // Hörn nere till vänster > >>> points2 = circSect( 10, 39.25, 10, [0, 90], "left", 1, fn); // Hörn uppe till vänster > >>> points3 = 3points_arc([p1x,p1y], [p2x,p2y], [p3x,p3y], fn); > >>> points4 = circSect( 101, 39.25, 10, [0, 90], "top", 1, fn); // Hörn uppe till höger > >>> points5 = circSect( 101, 11.25, 10, [0, 90], "right", 1, fn); // Hörn nere till höger > >>> points6 = 3points_arc([p4x,p4y], [p5x,p5y], [p6x,p6y], fn); > >>> > >>> // The base plate for the LED lamp > >>> > >>> > >>> difference() > >>> { color("gray", 0.5) > >>> linear_extrude(height=height) > >>> polygon(concat(points1, points2, points3, points4, points5, points6)); > >>> > >>> > >>> // union() > >>> { // Monteringshål 1 & 2 > >>> translate([length-10 , wideMid / 2, -.2]) > >>> cylinder(d=diamHole, h=heightHole, center=false); > >>> translate([10 , wideMid / 2, -.2]) > >>> cylinder(d=diamHole, h=heightHole, center=false); > >>> } > >>> } > >>> } > >>> //======== Slut LEDbottom ======================================================== > >>> > >>> > >>> > >>> //================================================================================== > >>> //====== circleSect ============================================================== > >>> // Create rounded corners 2D > >>> // https://openhome.cc/eGossip/OpenSCAD/SectorArc.html > >>> // ange .: x, y, radien, > >>> // [från, till] vinkel, > >>> // var vinkeln startar, (left, bottom, right, top) > >>> // vilken rotation (-1=medsol, 1=motsols) > >>> function circSect(x=0, y=0, radius=10, angles=[0,270], startRef="bottom", rotate=1, fn=24) = > >>> let( > >>> startAngel = (startRef == "left") ? 0 > >>> : (startRef == "bottom") ? 90 > >>> : (startRef == "right") ? 180 > >>> : (startRef == "top") ? 270 > >>> : startRef, // valfri vinkel > >>> // : assert(false,"invalid moutSide value"); // Error message if no case worked > >>> //: undef, > >>> r = radius, > >>> //r = radius / cos(180 / fn), > >>> step = 360 / fn, > >>> // points = [[x, y], > >>> points = [ > >>> for(a = [angles[0]-startAngel : step : angles[1]-startAngel]) > >>> [-rotate * r * cos(a)+x, r * sin(a)+y]] > >>> ) points; > >>> //======== Slut circleSect ======================================================= > >>> > >>> > >>> //================================================================================== > >>> //====== 3points_arc ============================================================= > >>> // Create an arc with three points 2D > >>> function 3points_arc(p0, p1, p2, fn=10) = > >>> // an alternative expression for D > >>> // D = 2 * ( (p1-p0).x * (p2-p0).y - (p1-p0).y * (p2-p0).x ) > >>> let( D = 2 * cross(p1-p0, (p2-p0)) ) > >>> assert( abs(D)>1e-9, "The 3 points should not be collinear." ) > >>> let( > >>> Ux = ( (p2-p0).y*(p1-p0)*(p1-p0) - (p1-p0).y*(p2-p0)*(p2-p0) )/D, > >>> Uy = ( (p1-p0).x*(p2-p0)*(p2-p0) - (p2-p0).x*(p1-p0)*(p1-p0) )/D, > >>> radius = norm([Ux,Uy]), > >>> center = [Ux,Uy] + p0, > >>> ang0 = atan2( (p0-center).y, (p0-center).x ), > >>> ang2 = atan2( (p2-center).y, (p2-center).x ), > >>> // the points are in a cw winding iff D<0 > >>> // the angular difference between vectors p2-center and p0-center > >>> // measured from p0-center; dang is positive iff D is negative > >>> dang = D<0 ? ang2<ang0 ? ang2-ang0 : ang2-ang0-360 > >>> : ang2>ang0 ? ang2-ang0 : ang2-ang0+360 > >>> ) > >>> [ for(i=[0:fn-1]) > >>> let( ang = ang0 + i*dang/(fn-1) ) > >>> center + radius*[cos(ang),sin(ang)] ]; > >>> //======== Slut 3points_arc ====================================================== > >>> > >>> > >>> //================================================================================== > >>> //====== Wall som ett "L" ======================================================== > >>> // Normal vägghöjd > >>> function wall() = > >>> let( > >>> b = 4, // botten - tjocklek > >>> f = 8, // Foten > >>> h = 15, // Höjd > >>> t = 3.5, // Top > >>> x = (b+(t/2) - (h - ( (-h / (f-t)) *t) )) / (-h / (f-t)) > >>> ) > >>> let( > >>> points = [[0,0], [f,0], [t,h], [0,h]] , > >>> top = move([t/2, h, 0], circle(d=t, $fn=20)), > >>> sqr = square([10, b]), > >>> diff = > >>> difference([ > >>> move([x, b], square([t/2, t/2])), > >>> move([x+(t/2), b+(t/2), 0], circle(d = t, $fn=20) ) ]) > >>> ) > >>> union([points, top, sqr, diff]); > >>> //======== Slut Wall ============================================================= > >>> > >>> > >>> > >>> //================================================================================== > >>> //====== Wall1 som ett "L" ======================================================= > >>> // En högre vägg > >>> function wall1() = > >>> let( > >>> b = 4, // botten - tjocklek > >>> f = 7, // Foten > >>> h = 25, // Höjd > >>> t = 3, // Top > >>> x = (b+(t/2) - (h - ((-h / (f-t)) *t))) / (-h / (f-t)) > >>> ) > >>> let( > >>> points = [[0,0], [f,0], [t,h], [0,h]] , > >>> top = move([t/2, h, 0], circle(d=t, $fn=20)), > >>> sqr = square([10, b]), > >>> diff = > >>> difference([ > >>> move([x, b], square([t/2, t/2])), > >>> move([x+(t/2), b+(t/2), 0], circle(d = t, $fn=20) ) ]) > >>> ) > >>> union([points, top, sqr, diff]); > >>> //======== Slut Wall1 ============================================================ > >>> > >>> > >>> //================================================================================== > >>> //====== Plåt på släp ============================================================ > >>> module mountingPlate(posX=0, posY=0, posZ=0, mountSide="left", colorName="#C0C0C0", $fn=50) > >>> { // Hörnpositionerna > >>> posX1 = 120; > >>> posY1 = 0; > >>> posX2 = posX1; > >>> posY2 = -200; > >>> posX3 = 120 - 75; > >>> posY3 = -200; > >>> posX4 = 0; > >>> posY4 = 0; > >>> thick=2; // tjocklek > >>> > >>> side = mountSide == "left" ? 0 > >>> : mountSide == "right" ? 1 > >>> : assert(false,"invalid moutSide value"); // message if no case worked > >>> > >>> xpos = mountSide == "left" ? 20 > >>> : mountSide == "right" ? -20 > >>> : assert(false,"invalid moutSide value"); // message if no case worked > >>> /* > >>> ypos = mountSide == "left" ? 85 > >>> : mountSide == "right" ? 85 > >>> : assert(false,"invalid moutSide value"); // message if no case worked > >>> > >>> zpos = mountSide == "left" ? -thick > >>> : mountSide == "right" ? -thick > >>> : assert(false,"invalid moutSide value"); // message if no case worked > >>> */ > >>> color(colorName) > >>> { translate([posX, posY, posZ]) > >>> translate([xpos, 85, -thick]) > >>> { mirror([side, 0, 0]) > >>> { linear_extrude(thick) > >>> hull() > >>> { translate([posX1, posY1, 0]) > >>> square(0.1, center = true); > >>> translate([posX2, posY2, 0]) > >>> square(0.1, center = true); > >>> translate([posX3, posY3, 0]) > >>> square(0.1, center = true); > >>> translate([posX4, posY4, 0]) > >>> square(0.1, center = true); > >>> } > >>> } > >>> } > >>> } > >>> } > >>> = = END product 1= = = = = = = = = = = = = = = = = = = = = = = = = = = = = = > >>> - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - > >>> > >>> > >>> > >>> > >>> = = product 2 = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = > >>> - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - > >>> > >>> $fn=100; > >>> //$fn=15; > >>> > >>> //switch(); > >>> //cableHolder4(); //Switchboxen > >>> > >>> > >>> // cableHolder3(0, 0, 0, 33.5, 23.5, 1.5, 2); > >>> // showCables(); > >>> > >>> > >>> > >>> module cableHolder4(fn=24); > >>> { // idé från > >>> // - https://www.thingiverse.com/thing:6400/files > >>> // - https://ihrchive.wordpress.com/2011/02/14/openscad-tip-round-1-of-3-basic-rounding/ > >>> > >>> // mått på Switch > >>> heightHold = 10.5; > >>> widthHold = 33.5; > >>> depthHold = 23.5; > >>> spaceHold = 10.0; // utrymmet bakom switch > >>> holdRadie = 2; // radie i hörnen > >>> thick = 2; > >>> offset1=0.5; // öka toleransen > >>> > >>> // innermått > >>> holeW = widthHold + offset1; > >>> holeH = heightHold + offset1; > >>> holeD = depthHold + spaceHold+offset1; > >>> > >>> // yttermått > >>> pad = 0.1; // Padding to maintain manifold > >>> box_l = holeW + thick*2; // Bredden på switchen > >>> box_w = holeD + thick; // Djupet på switchen > >>> box_h = holeH + thick; // Height > >>> round_r = holdRadie; // Radius of round > >>> smooth = 45; // Number of facets of rounding cylinder > >>> > >>> > >>> > >>> difference() > >>> { union() // Detta utförs i två steg. > >>> { difference() // utför fasningar och kabelmarkeringar > >>> { mainBox(box_l, box_w, box_h, spaceHold+thick, round_r, thick, smooth, pad); > >>> > >>> // fasning vänster (underkant) > >>> translate([box_l/2-0.85, spaceHold-4.3, thick-offset1]) // sidled, fram/bak , upp/ned > >>> rotate([0,180,45]) > >>> cylinder(h=thick, d1=holeW*1.414-thick-thick, d2=holeW*1.414, $fn=4); > >>> > >>> // fasning höger (underkant) > >>> translate([box_l/2-3.65, spaceHold-4.3, thick-offset1]) // sidled, fram/bak , upp/ned > >>> rotate([0,180,45]) > >>> cylinder(h=thick, d1=holeW*1.414-thick-thick, d2=holeW*1.414, $fn=4); > >>> > >>> // kabelgenomföringar > >>> rotate([90, 180, 90]) // Markering ena sidan (vänster under) > >>> ovalCableHole(spaceHold/2-offset1, -1.75, -1.2); > >>> > >>> rotate([90, 180, 180]) // Markering bakkant (vänster under) > >>> ovalCableHole(spaceHold/2-1.55, -1.75, -spaceHold-0.85); > >>> > >>> rotate([90, 180, 180]) // Markering bakkant (höger under) > >>> ovalCableHole(widthHold-spaceHold/2-offset1, -1.75, -spaceHold-0.85); > >>> > >>> rotate([90, -180, 90]) // Markering ena sidan (höger under) > >>> ovalCableHole(3.75, -1.75, widthHold-0.1); > >>> } > >>> } // Slut union - kropp > >>> > >>> translate([-offset1/2, -spaceHold+pad, -pad]) // hålet där switchen ska placeras > >>> cube([holeW, holeD+pad, holeH+pad], center=false); > >>> > >>> translate([4, 12, 0]) > >>> cylinder(h=15,d=3.2); > >>> translate([4, 12, 17.7]) > >>> sphere(r=6); > >>> > >>> translate([29.6, 12, 0]) > >>> cylinder(h=15,d=3.2); > >>> translate([29.6, 12, 17.7]) > >>> sphere(r=6); > >>> > >>> /* // Hål genom lock bak - om så önskas > >>> translate([box_l/2-thick, -6, offset1/2]) > >>> cylinder(h=box_h+thick*4+offset1, d=3.2, $fn=100); // hål genom lock bak > >>> > >>> translate([box_l/2-thick, -6, 17.7]) > >>> sphere(r=6); // kona hålet bak > >>> */ > >>> } // Slut difference() - box > >>> > >>> difference() > >>> { union() > >>> { translate([29.6, 12, heightHold-offset1*2]) > >>> cylinder(h=2,d=5.2); // Stödhylsa för Switchskruv1 > >>> translate([4, 12, heightHold-offset1*2]) > >>> cylinder(h=2,d=5.2); // Stödhylsa för Switchskruv2 > >>> > >>> translate([holeW/2, -spaceHold+thick+1, holeH/2]) > >>> rotate([180,0,0]) > >>> backHole(); > >>> } // union - slut > >>> > >>> translate([4, 12, 0]) // Hålen i stödhylsorna > >>> cylinder(h=15,d=3.2); > >>> > >>> translate([29.6, 12, 0]) // Hålen i stödhylsorna > >>> cylinder(h=15,d=3.2); > >>> > >>> translate([box_l/2-thick, -6, -offset1]) // hål i stödhylsa bak > >>> cylinder(h=box_h+offset1, d=3.2, $fn=100); > >>> > >>> // Sänk stödhylsan > >>> translate([ widthHold/2-7, -spaceHold-offset1, -thick+offset1]) // hål i stödhylsa bak > >>> cube([15, 8, 3]); > >>> > >>> > >>> // kabelmarkering > >>> // translate([0, 0, 0]) // hål i stödhylsa bak > >>> > >>> > >>> } > >>> > >>> > >>> > >>> > >>> > >>> > >>> /* > >>> translate([4, 12, 0]) > >>> #cylinder(h=15,d=3.2); > >>> //translate([4, 13.5, 17.3]) > >>> //#sphere(r=6); > >>> > >>> translate([29.6, 12, 0]) > >>> #cylinder(h=15,d=3.2); > >>> //translate([29.6, 13.5, 17.3]) > >>> //#sphere(r=6); > >>> */ > >>> > >>> > >>> } > >>> > >>> module backHole() > >>> { wallH = 10.5; > >>> > >>> wide1 = 12; // endast runt cylindern > >>> wide2 = 35; // hela väggen > >>> deep1 = 4; > >>> height1 = 10.5; > >>> cornRad1 = 2; > >>> diam1 = 8; > >>> opt1 = 0.1; > >>> > >>> //rundadFot(); > >>> > >>> > >>> // Rundad stäcka mellan t.ex. vägg och tak -bakkant > >>> translate([wide2/2, diam1/2-cornRad1/2, -height1/2]) > >>> { rotate([90, 0, -90]) > >>> { linear_extrude(wide2) > >>> { difference() > >>> { square([cornRad1, cornRad1]); > >>> > >>> translate([cornRad1, cornRad1]) > >>> circle(r=cornRad1); > >>> } > >>> } > >>> } > >>> } > >>> > >>> // rundad stäcka1 (vänster) mellan t.ex. vägg och tak > >>> translate([-wide2/2+0.15, deep1/2+cornRad1/2, -height1/2]) > >>> rotate([90, 0, 0]) > >>> { linear_extrude(spaceHold) > >>> { difference() > >>> { square([cornRad1, cornRad1]); > >>> > >>> translate([cornRad1, cornRad1]) > >>> circle(r=cornRad1); > >>> } > >>> } > >>> } > >>> > >>> // rundad stäcka2 mellan t.ex. vägg och tak > >>> translate([wide2/2-0.65, deep1/2+cornRad1/2, -height1/2]) > >>> rotate([0, -90, 90]) > >>> { linear_extrude(spaceHold) > >>> { difference() > >>> { square([cornRad1, cornRad1]); > >>> > >>> translate([cornRad1, cornRad1]) > >>> circle(r=cornRad1); > >>> } > >>> } > >>> } > >>> > >>> // Skapa stödfot - bak > >>> difference() > >>> { union() > >>> { //själva cylindern > >>> translate([0, 1, 0]) > >>> { cylinder(h=height1, d=diam1, center=true); > >>> translate([0, diam1/2, 0]) > >>> cube([diam1,diam1-1,height1], center=true); > >>> } > >>> > >>> // Rundad fot under cylinder ovan > >>> translate([0, 1, -height1/2]) > >>> { rotate_extrude() > >>> { translate([diam1/2, 0, 0]) > >>> { difference() > >>> { square([cornRad1, cornRad1]); > >>> > >>> translate([cornRad1, cornRad1]) > >>> circle(r=cornRad1); > >>> } > >>> } > >>> } > >>> } > >>> > >>> // Rundad rakstäcka1 - cylinderfot - mellan t.ex. vägg och tak > >>> translate([diam1/2, diam1, -height1/2]) > >>> { rotate([90, 0, 0]) > >>> { linear_extrude(diam1) > >>> { difference() > >>> { square([cornRad1, cornRad1]); > >>> > >>> translate([cornRad1, cornRad1]) > >>> circle(r=cornRad1); > >>> } > >>> } > >>> } > >>> } > >>> > >>> // Rundad rakstäcka2 - cylinderfot - mellan t.ex. vägg och tak > >>> translate([-diam1/2, diam1, -height1/2]) > >>> { rotate([0, -90, 90]) > >>> { linear_extrude(diam1) > >>> { difference() > >>> { square([cornRad1, cornRad1]); > >>> > >>> translate([cornRad1, cornRad1]) > >>> circle(r=cornRad1); > >>> } > >>> } > >>> } > >>> } > >>> > >>> //väggen bakom cylindern som ska rundas > >>> translate([0, diam1/2-cornRad1, 0]) > >>> cube([wide1, cornRad1, height1], center=true); > >>> > >>> } > >>> > >>> > >>> // Avrunda hörn1 bak > >>> translate([-wide1/2, cornRad1/2, cornRad1]) > >>> { hull() > >>> { cylinder(h=height1+opt1, r=cornRad1, center=true); > >>> { translate([0, 0, -height1/2]) > >>> sphere(r=cornRad1); > >>> } > >>> } > >>> } > >>> > >>> // Avrunda hörn2 bak > >>> translate([wide1/2, cornRad1/2, cornRad1]) > >>> { hull() > >>> { cylinder(h=height1+opt1, r=cornRad1, center=true); > >>> { translate([0, 0, -height1/2]) > >>> sphere(r=cornRad1); > >>> } > >>> } > >>> } > >>> > >>> > >>> // Plocka bort rundad fot bak samt det som sticker ut > >>> translate([-wide1/2, diam1/2-cornRad1/2, -height1/2-opt1]) > >>> cube([wide1, diam1/2+cornRad1, height1+opt1*2], center=false); > >>> > >>> } > >>> } > >>> > >>> > >>> > >>> > >>> > >>> module ovalCableHole(posX, posY, posZ) > >>> { // Hål 5.5 x 3.5 mm > >>> pan = 0.1; > >>> cableHi = 1.5; > >>> > >>> translate([posX, posY, posZ]) > >>> { color("white") > >>> { translate([0, 0, -pan]) > >>> { cylinder(h=cableHi, d=3.5); > >>> //#translate([0, 0, 0]) cylinder(h=10, d=1); > >>> //translate([0, 0, -1]) cylinder(h=1, d1=0, d2=1); > >>> //translate([0, 0, 0]) sphere(d=1); // Inre kulan > >>> //translate([0, 0, 1.5]) sphere(d=1); // Inre kulan > >>> > >>> translate([0, 0, -1]) sphere(d=0.8); // yttre kulan > >>> translate([0, 0, 2.5]) sphere(d=0.8); // yttre kulan > >>> > >>> } > >>> translate([2, 0, -pan]) > >>> { cylinder(h=cableHi, d=3.5); > >>> // #translate([0, 0, -cableHi*2]) cylinder(h=10, d=0.5); > >>> //translate([0, 0, 0]) sphere(d=1); // Inre kulan > >>> //translate([0, 0, 1.5]) sphere(d=1); // Inre kulan > >>> > >>> translate([0, 0, -1]) sphere(d=0.8); // yttre kulan > >>> translate([0, 0, 2.5]) sphere(d=0.8); // yttre kulan > >>> > >>> } > >>> translate([-3.5/2, 0, -pan]) > >>> cube([5.5, 3.5/2, cableHi]); > >>> translate([-0.25, -1.74, -pan]) > >>> cube([2.5, 1.75, cableHi]); > >>> } > >>> } > >>> } > >>> > >>> > >>> > >>> > >>> > >>> > >>> module rundadFot() > >>> { > >>> // specifika värden för skruvdistansen bak > >>> wallH = 10.5; > >>> > >>> wide1 = 12; // endast runt cylindern > >>> wide2 = 34; // hela väggen > >>> deep1 = 4; > >>> height1 = 10; > >>> cornRad1 = 2; > >>> diam1 = 8; > >>> opt1 = 0.1; > >>> > >>> > >>> color("magenta") > >>> { translate([0, 0, wallH]) > >>> { difference() > >>> { union() > >>> { // Bakgavel > >>> translate([wide2/2, opt1, height1/2]) > >>> { rotate([90, 180, 0]) > >>> cube([wide2, height1, opt1]); > >>> } > >>> > >>> // Golv > >>> translate([wide2/2, -height1+opt1, -height1/2]) > >>> rotate([0, 180, 0]) > >>> cube([wide2, height1, opt1]); > >>> > >>> //väggen bakom cylindern som kan rundas > >>> translate([0, -cornRad1/2, 0]) > >>> cube([wide1, cornRad1, height1], center=true); > >>> > >>> //själva cylindern > >>> translate([0, -cornRad1/2, 0]) > >>> cylinder(h=height1, d=diam1, center=true); > >>> > >>> // Rundad fot under cylinder ovan > >>> translate([0, -cornRad1/2, -height1/2]) > >>> { rotate_extrude() > >>> { translate([diam1/2, 0, 0]) > >>> { difference() > >>> { square([cornRad1, cornRad1]); > >>> > >>> translate([cornRad1, cornRad1]) > >>> circle(r=cornRad1); > >>> } > >>> } > >>> } > >>> } > >>> > >>> // Rundad stäcka mellan t.ex. vägg och tak -bakkant > >>> translate([wide2/2, 0, -height1/2]) > >>> { rotate([90, 0, -90]) > >>> { linear_extrude(wide2) > >>> { difference() > >>> { square([cornRad1, cornRad1]); > >>> > >>> translate([cornRad1, cornRad1]) > >>> circle(r=cornRad1); > >>> } > >>> } > >>> } > >>> } > >>> > >>> // rundad stäcka mellan t.ex. vägg och tak -sida1 > >>> translate([-wide2/2, 0, -height1/2]) > >>> { rotate([90, 0, 0]) > >>> { linear_extrude(10) > >>> { difference() > >>> { square([cornRad1, cornRad1]); > >>> > >>> translate([cornRad1, cornRad1]) > >>> circle(r=cornRad1); > >>> } > >>> } > >>> } > >>> } > >>> > >>> // rundad stäcka mellan t.ex. vägg och tak -sida2 > >>> translate([wide2/2, -10, -height1/2]) > >>> { rotate([90, 0, 180]) > >>> { linear_extrude(10) > >>> { difference() > >>> { square([cornRad1, cornRad1]); > >>> > >>> translate([cornRad1, cornRad1]) > >>> circle(r=cornRad1); > >>> } > >>> } > >>> } > >>> } > >>> } // Avsluta union = = = = = = = = = = = = = = = = = = = = > >>> > >>> > >>> // Avrunda hörn1 bak > >>> translate([-wide1/2+opt1*1.3, -deep1/2, cornRad1]) > >>> { cylinder(h=height1+opt1, r=cornRad1, center=true); > >>> translate([0, 0, -height1/2]) > >>> sphere(r=cornRad1); > >>> } > >>> > >>> // Avrunda hörn2 bak > >>> translate([wide1/2-opt1*1.3, -deep1/2, cornRad1]) > >>> { cylinder(h=height1+opt1, r=cornRad1, center=true); > >>> translate([0, 0, -height1/2]) > >>> sphere(r=cornRad1); > >>> } > >>> > >>> // Plocka bort rundad fot bak samt det som sticker ut > >>> translate([-wide1/2, 0, -height1/2-opt1]) > >>> cube([wide1, diam1/2+cornRad1, height1+opt1*2], center=false); > >>> } > >>> } > >>> } > >>> } > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> module mainBox(box_l, box_w, box_h, spaceHold, round_r, thick, smooth, pad) > >>> { translate([box_l/2-thick-offset1/2, box_w/2-spaceHold, box_h/2]) > >>> { > >>> // To fix the corners cut the main cube with smaller cubes with spheres removed > >>> difference() > >>> { cube([box_l, box_w, box_h], center = true); > >>> > >>> // Kant1 - liggande > >>> translate([0, -box_w/2+round_r, box_h/2-round_r]) > >>> { difference() > >>> { translate([0,-round_r-pad,round_r+pad]) > >>> cube([box_l+2*pad, round_r*2+pad, round_r*2+pad], center = true); > >>> rotate(a=[0,90,0]) > >>> cylinder(box_l+4*pad,round_r,round_r,center=true,$fn=smooth); > >>> } > >>> } > >>> // Kant2 - liggande > >>> translate([0, box_w/2-round_r, box_h/2-round_r]) > >>> { difference() > >>> { translate([0,round_r+pad,round_r+pad]) > >>> cube([box_l+2*pad, round_r*2+pad, round_r*2+pad], center = true); > >>> rotate(a=[0,90,0]) > >>> cylinder(box_l+4*pad,round_r,round_r,center=true,$fn=smooth); > >>> } > >>> } > >>> /* > >>> // Kant3 - liggande > >>> translate([0, -box_w/2+round_r, -box_h/2+round_r]) > >>> { difference() > >>> { translate([0,-round_r-pad,-round_r-pad]) > >>> cube([box_l+2*pad, round_r*2+pad, round_r*2+pad], center = true); > >>> rotate(a=[0,90,0]) > >>> cylinder(box_l+4*pad,round_r,round_r,center=true,$fn=smooth); > >>> } > >>> } > >>> > >>> // Kant4 - liggande > >>> translate([0, box_w/2-round_r, -box_h/2+round_r]) > >>> { difference() > >>> { translate([0,round_r+pad,-round_r-pad]) > >>> cube([box_l+2*pad, round_r*2+pad, round_r*2+pad], center = true); > >>> rotate(a=[0,90,0]) > >>> cylinder(box_l+4*pad,round_r,round_r,center=true,$fn=smooth); > >>> } > >>> } > >>> */ > >>> // ---- > >>> // Kant1 - stående > >>> translate([-box_l/2+round_r, box_w/2-round_r, 0]) > >>> { difference() > >>> { translate([-round_r-pad,round_r+pad,0]) > >>> cube([round_r*2+pad, round_r*2+pad, box_h+2*pad], center = true); > >>> cylinder(box_h+4*pad,round_r,round_r,center=true,$fn=smooth); > >>> } > >>> } > >>> // Kant2 - stående > >>> translate([box_l/2-round_r, box_w/2-round_r, 0]) > >>> { difference() > >>> { translate([round_r+pad,round_r+pad,0]) > >>> cube([round_r*2+pad, round_r*2+pad, box_h+2*pad], center = true); > >>> cylinder(box_h+4*pad,round_r,round_r,center=true,$fn=smooth); > >>> } > >>> } > >>> // Kant3 - stående > >>> translate([-box_l/2+round_r, -box_w/2+round_r, 0]) > >>> { difference() > >>> { translate([-round_r-pad,-round_r-pad,0]) > >>> cube([round_r*2+pad, round_r*2+pad, box_h+2*pad], center = true); > >>> cylinder(box_h+4*pad,round_r,round_r,center=true,$fn=smooth); > >>> } > >>> } > >>> // Kant4 - stående > >>> translate([box_l/2-round_r, -box_w/2+round_r, 0]) > >>> { difference() > >>> { translate([round_r+pad,-round_r-pad,0]) > >>> cube([round_r*2+pad, round_r*2+pad, box_h+2*pad], center = true); > >>> cylinder(box_h+4*pad,round_r,round_r,center=true,$fn=smooth); > >>> } > >>> } > >>> > >>> // ---- > >>> // Kant1 liggande (andra hållet) > >>> translate([-box_l/2+round_r, 0, box_h/2-round_r]) > >>> { difference() > >>> { translate([-round_r-pad, 0, round_r+pad]) > >>> cube([round_r*2+pad, box_w+2*pad, round_r*2+pad], center = true); > >>> rotate(a=[0,90,90]) > >>> cylinder(box_w+4*pad,round_r,round_r,center=true,$fn=smooth); > >>> } > >>> } > >>> // Kant2 liggande (andra hållet) > >>> translate([box_l/2-round_r, 0, box_h/2-round_r]) > >>> { difference() > >>> { translate([round_r+pad, 0, round_r+pad]) > >>> cube([round_r*2+pad, box_w+2*pad, round_r*2+pad], center = true); > >>> rotate(a=[0,90,90]) > >>> cylinder(box_w+4*pad,round_r,round_r,center=true,$fn=smooth); > >>> } > >>> } > >>> /* > >>> // Kant3 liggande (andra hållet) > >>> translate([-box_l/2+round_r, 0, -box_h/2+round_r]) > >>> { difference() > >>> { translate([-round_r-pad, 0, -round_r-pad]) > >>> cube([round_r*2+pad, box_w+2*pad, round_r*2+pad], center = true); > >>> rotate(a=[0,90,90]) > >>> cylinder(box_w+4*pad,round_r,round_r,center=true,$fn=smooth); > >>> } > >>> } > >>> > >>> // Kant4 liggande (andra hållet) > >>> translate([box_l/2-round_r, 0, -box_h/2+round_r]) > >>> { difference() > >>> { translate([round_r+pad, 0, -round_r-pad]) > >>> cube([round_r*2+pad, box_w+2*pad, round_r*2+pad], center = true); > >>> rotate(a=[0,90,90]) > >>> cylinder(box_w+4*pad,round_r,round_r,center=true,$fn=smooth); > >>> } > >>> } > >>> */ > >>> // ---- > >>> // Hörn1 (övre) > >>> translate([box_l/2-round_r, box_w/2-round_r, box_h/2-round_r]) > >>> { difference() > >>> { translate([round_r+pad, round_r+pad, round_r+pad]) > >>> cube([round_r*2+pad, round_r*2+pad, round_r*2+pad], center = true); > >>> sphere(round_r,$fn=smooth); > >>> } > >>> } > >>> // Hörn2 (övre) > >>> translate([-box_l/2+round_r, box_w/2-round_r, box_h/2-round_r]) > >>> { difference() > >>> { translate([-round_r-pad, round_r+pad, round_r+pad]) > >>> cube([round_r*2+pad, round_r*2+pad, round_r*2+pad], center = true); > >>> sphere(round_r,$fn=smooth); > >>> } > >>> } > >>> // Hörn3 (övre) > >>> translate([box_l/2-round_r, -box_w/2+round_r, box_h/2-round_r]) > >>> { difference() > >>> { translate([round_r+pad, -round_r-pad, round_r+pad]) > >>> cube([round_r*2+pad, round_r*2+pad, round_r*2+pad], center = true); > >>> sphere(round_r,$fn=smooth); > >>> } > >>> } > >>> // Hörn4 (övre) > >>> translate([-box_l/2+round_r, -box_w/2+round_r, box_h/2-round_r]) > >>> { difference() > >>> { translate([-round_r-pad, -round_r-pad, round_r+pad]) > >>> cube([round_r*2+pad, round_r*2+pad, round_r*2+pad], center = true); > >>> sphere(round_r,$fn=smooth); > >>> } > >>> } > >>> /* > >>> // Hörn1 (undre) > >>> translate([box_l/2-round_r, box_w/2-round_r, -box_h/2+round_r]) > >>> { difference() > >>> { translate([round_r+pad, round_r+pad, -round_r-pad]) > >>> cube([round_r*2+pad, round_r*2+pad, round_r*2+pad], center = true); > >>> sphere(round_r,$fn=smooth); > >>> } > >>> } > >>> // Hörn2 (undre) > >>> translate([-box_l/2+round_r, box_w/2-round_r, -box_h/2+round_r]) > >>> { difference() > >>> { translate([-round_r-pad, round_r+pad, -round_r-pad]) > >>> cube([round_r*2+pad, round_r*2+pad, round_r*2+pad], center = true); > >>> sphere(round_r,$fn=smooth); > >>> } > >>> } > >>> // Hörn3 (undre) > >>> translate([box_l/2-round_r, -box_w/2+round_r, -box_h/2+round_r]) > >>> { difference() > >>> { translate([round_r+pad, -round_r-pad, -round_r-pad]) > >>> cube([round_r*2+pad, round_r*2+pad, round_r*2+pad], center = true); > >>> sphere(round_r,$fn=smooth); > >>> } > >>> } > >>> // Hörn4 (undre) > >>> translate([-box_l/2+round_r, -box_w/2+round_r, -box_h/2+round_r]) > >>> { difference() > >>> { translate([-round_r-pad, -round_r-pad, -round_r-pad]) > >>> cube([round_r*2+pad, round_r*2+pad, round_r*2+pad], center = true); > >>> sphere(round_r,$fn=smooth); > >>> } > >>> } > >>> */ > >>> } > >>> } > >>> } > >>> // > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> module cableHolder3(posX, posY, posZ, length, width, height, radius) > >>> { // Skapa toppen över switchen > >>> // mått på Switchen > >>> fn = 96; // upplösning (endast bågen?) > >>> heightHold = 10.5; > >>> widthHold = 33.5; > >>> depthHold = 23.5; > >>> holdRadie = 1.5; // radie i hörnen > >>> thick = 1.5; // tjocklek > >>> > >>> > >>> translate([0,-thick,0]) > >>> { > >>> difference(0, 0, 0) > >>> { hull() > >>> { difference() > >>> { translate([thick, 0, heightHold]) // vänster kant > >>> { rotate([-90, 0, 0]) > >>> { cylinder(h=depthHold, d=thick*2); > >>> translate([0, 0, depthHold]) > >>> sphere(d=thick*2); // längst fram > >>> } > >>> } > >>> translate([0, -0.1, heightHold]) // plocka bort underdelen > >>> rotate([-90, 0, 0]) > >>> cube([thick*2, thick+.1, depthHold+thick+.1]); > >>> } > >>> > >>> difference() > >>> { translate([widthHold-thick, 0, heightHold]) // höger kant > >>> { rotate([-90, 0, 0]) > >>> { cylinder(h=depthHold, d=thick*2); > >>> translate([0, 0, depthHold]) > >>> sphere(d=thick*2); // längst fram > >>> } > >>> } > >>> translate([widthHold-thick*2, -0.1, heightHold]) // plocka bort underdelen > >>> { rotate([-90, 0, 0]) > >>> cube([thick*2, thick+.1, depthHold+thick+.1]); > >>> } > >>> } > >>> } > >>> > >>> // öppna hålen för monteringsskruvarna uppe på plattan > >>> translate([4, 13.5, 0]) > >>> cylinder(h=15,d=3.2); > >>> translate([4, 13.5, 17.3]) > >>> sphere(r=6); > >>> > >>> translate([29.6, 13.5, 0]) > >>> cylinder(h=15,d=3.2); > >>> > >>> translate([29.6, 13.5, 17.3]) > >>> sphere(r=6); > >>> } > >>> > >>> // halvbåge 1 bak > >>> translate([thick, 0, heightHold/2+thick/2]) > >>> rotate([0, 90, 180]) > >>> rotate_extrude(angle = 180, convexity=20, $fn=64) > >>> translate([heightHold/2-thick/2, 0, 0]) > >>> circle(d=thick*2); > >>> translate([thick, 0, heightHold]) > >>> sphere(d=thick*2); // övre kulan > >>> translate([thick, 0, thick]) > >>> sphere(d=thick*2); // undre kulan > >>> > >>> > >>> // halvbåge 2 bak > >>> translate([widthHold-thick, 0, heightHold/2+thick/2]) > >>> rotate([0, 90, 180]) > >>> rotate_extrude(angle = 180, convexity=20, $fn=64) > >>> translate([heightHold/2-thick/2, 0, 0]) > >>> circle(d=thick*2); > >>> translate([widthHold-thick, 0, heightHold]) > >>> sphere(d=thick*2); // övre kulan > >>> translate([widthHold-thick, 0, thick]) > >>> sphere(d=thick*2); // undre kulan > >>> > >>> // en cylinder tvärsöver längst upp > >>> translate([thick, 0, heightHold]) > >>> { rotate([0,90,0]) > >>> cylinder(h=widthHold-thick*2, r=thick); > >>> } > >>> } > >>> > >>> // Halvbågen (kabelhållaren) på baksidan switchen > >>> translate([widthHold-thick, -thick, heightHold/2+thick/2]) > >>> { rotate([0,90,180]) > >>> linear_extrude(widthHold-thick*2) > >>> arc(heightHold/2-thick/2, [0, 180], thick, fn); //radius, angles, width, fn) > >>> } > >>> // en cylinder tvärsöver längst ned > >>> translate([thick, -thick, thick]) > >>> { rotate([0,90,0]) > >>> cylinder(h=widthHold-thick*2, r=thick); > >>> } > >>> } > >>> > >>> > >>> > >>> module switch(posX=0, posY=0, posZ=0) > >>> { buttRadie = 1.5; > >>> height = 10.5; > >>> width = 33.5; > >>> depth = 23.5; > >>> h1x = buttRadie; > >>> h1y = buttRadie; > >>> h2x = width-buttRadie; > >>> h2y = buttRadie; > >>> h3x = width-buttRadie; > >>> h3y = depth-buttRadie; > >>> h4x = buttRadie; > >>> h4y = depth-buttRadie; > >>> > >>> translate([posX, posY, posZ]) > >>> { difference() > >>> { color("#F9F9F3") > >>> // tryck-knappen > >>> union() > >>> { translate([width/2, depth+6-0.1, height/2]) > >>> { rotate([90, 0, 0]) > >>> { translate([0,0,6]) > >>> circle(d=6.8); // skuggan runt knapp > >>> cylinder(h=6, d=6); > >>> sphere(d=6); > >>> } > >>> } > >>> > >>> hull() // Switchkropp > >>> { translate([h1x, h1y]) > >>> cylinder(h=height, r=1.5); > >>> translate([h2x, h2y]) > >>> cylinder(h=height, r=1.5); > >>> translate([h3x, h3y]) > >>> cylinder(h=height, r=1.5); > >>> translate([h4x, h4y]) > >>> cylinder(h=height, r=1.5); > >>> } > >>> } > >>> > >>> // Skruvhålen för switchen > >>> hole( 4, 12, 0, "#FFD700", height); > >>> hole(29.6, 12, 0, "#FFD700", height); > >>> // hole( 4, 12, 0, "#FFD700", 50); > >>> // hole(29.6, 12, 0, "#FFD700", 50); > >>> // hål för kablar bak > >>> color("gray") > >>> { translate([9.5, 16, height/2]) > >>> { rotate([90, 0, 0]) > >>> cylinder(h=16.5, d=4); > >>> } > >>> translate([24.5, 16, height/2]) > >>> { rotate([90, 0, 0]) > >>> cylinder(h=16.5, d=4); > >>> } > >>> } > >>> > >>> // hål för kabelskruvar > >>> color("white") > >>> { translate([29.5, 17.1, height/2]) > >>> { rotate([0, 90, 0]) > >>> cylinder(h=4.1, d=4.5); > >>> } > >>> translate([-0.1, 17.1, height/2]) > >>> { rotate([0, 90, 0]) > >>> cylinder(h=4.1, d=4.5); > >>> } > >>> } > >>> } > >>> > >>> // Kabelskruvar > >>> cableScrew(3, 17, height/2, 90); > >>> cableScrew(31, 17, height/2, -90); > >>> > >>> } > >>> } > >>> > >>> // Skruven som håller fast kabeln i switchen > >>> module cableScrew(posX=0, posY=0, posZ=0, angle=0) > >>> { color("#FFD700") // mässing > >>> translate([posX, posY, posZ]) > >>> { rotate([0, 0, angle]) > >>> { difference() > >>> { // skruvskalle > >>> translate([0, 0, 0]) > >>> rotate([90, 0, 0]) > >>> cylinder(h=2, d1=4, d2=3.5); > >>> > >>> // stjärnan i skruven > >>> translate([0, 1.85, -.25]) > >>> rotate([0, 0, 0]) > >>> cylinder(h=0.5, d=5); > >>> translate([-0.25, -.6, 2.25]) > >>> rotate([0, 90, 0]) > >>> cube([4.5, 2, 0.5]); > >>> } > >>> } > >>> } > >>> } > >>> > >>> > >>> > >>> // borrhål > >>> module hole(posX=0, posY=0, posZ=0, colorName="yellow", height) > >>> { diamHole1 = 3; > >>> highHole1 = height; > >>> diamHole2 = 6; > >>> highHole2 = 2.5; > >>> offs=0.1; > >>> > >>> color(colorName) > >>> { > >>> translate([posX, posY, posZ]) > >>> { translate([0, 0, 0]) > >>> cylinder(h=highHole1, d=diamHole1); > >>> translate([0, 0, -offs]) > >>> cylinder(h=highHole2, d=diamHole2); > >>> translate([0, 0, height-highHole2+offs]) > >>> cylinder(h=highHole2, d=diamHole2); > >>> } > >>> } > >>> } > >>> > >>> module showCables() > >>> { translate([-25,8,24]) > >>> rotate([80,177,90]) > >>> cable(10,10,0,"brun"); > >>> translate([-43,8,15]) > >>> rotate([90,180,90]) > >>> cable(10,10,0,"blå"); > >>> } > >>> > >>> > >>> module cable(posX=0, posY=0, posZ=0, colorName="blå", radius=1.26, width=0.62, thick=50, fn=24) > >>> { // default 1.5mm2 > >>> // radius = inner radie > >>> // width = bredd/tjocklek på cirkeln (inte höjd) > >>> // thick = höjd på cirken/ röret > >>> // pin= > >>> > >>> colCupper = "#D7715A"; > >>> colGreen = "#07DA63"; > >>> colYellow = "#FFCC00"; > >>> > >>> if (colorName=="gröngul") > >>> { translate([posX, posY, posZ]) > >>> { color(colGreen) > >>> linear_extrude(thick) > >>> arc(radius, [0, 60], width, fn); > >>> color(colYellow) > >>> linear_extrude(thick) > >>> arc(radius, [60, 180], width, fn); > >>> color(colGreen) > >>> linear_extrude(thick) > >>> arc(radius, [180, 240], width, fn); > >>> color(colYellow) > >>> linear_extrude(thick) > >>> arc(radius, [240, 360], width, fn); > >>> > >>> color(colCupper) > >>> linear_extrude(10, center=true, convexity=10, $fn=100) > >>> circle(d=1.24); > >>> } > >>> } > >>> else // vanliga kablar 1.5mm2 > >>> { > >>> cableColor = colorName == "blå" ? "#1870D5" > >>> : colorName == "brun" ? "#9C6137" > >>> : colorName == "svart" ? "#000000" > >>> : assert(false,"invalid color value"); // message if no case worked > >>> // : nodef > >>> > >>> translate([posX, posY, posZ]) > >>> { //el kabel - ena änden rak - andra böjd > >>> color(colCupper) //kopparstump tråd rakkabel > >>> linear_extrude(10, center=true, convexity=10, $fn=100) > >>> circle(d=1.24); > >>> > >>> color(cableColor) > >>> { cylinder(h=thick, r=radius); > >>> > >>> translate([-radius*2, 0, thick]) // kabelböj > >>> rotate([90, 0, 0]) > >>> rotate_extrude(angle=90, convexity=20) > >>> translate([2.5, 0, 0]) > >>> circle(r=1.26); > >>> > >>> translate([-radius*2, 0, thick+radius*2]) > >>> rotate([0, -90, 0]) > >>> cylinder(h=5, r=radius); > >>> } > >>> translate([-10, 0, thick+radius*2]) > >>> { rotate([0, -90, 0]) > >>> { color(colCupper) > >>> { linear_extrude(5, center=true, convexity=10, $fn=100) > >>> circle(d=1.24); > >>> } > >>> } > >>> } > >>> } > >>> } > >>> } > >>> > >>> > >>> // ====================================================================== > >>> module arc(radius, angles, width = 1, fn = 24) { > >>> difference() { > >>> sector(radius + width, angles, fn); // ytterradie > >>> sector(radius, angles, fn); // innerradie (plockar bort invändigt > >>> } > >>> } > >>> > >>> module sector(radius, angles, fn = 24) { > >>> r = radius / cos(180 / fn); > >>> step = -360 / fn; > >>> > >>> points = concat([[0, 0]], > >>> [for(a = [angles[0] : step : angles[1] - 360]) > >>> [r * cos(a), r * sin(a)] > >>> ], > >>> [[r * cos(angles[1]), r * sin(angles[1])]] > >>> ); > >>> > >>> difference() { > >>> circle(radius, $fn = fn); > >>> polygon(points); > >>> } > >>> } > >>> = = END product 2 = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = > >>> - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - > >>> > >>> > >>> Den fredag 6 maj 2022 14:06:55 CEST, Michael Möller <private2michael@gmail.com> skrev: > >>> > >>> > >>> > >>> OpenSCAD code - is a description of your model in terms of a few cylinder/cubes added and cut out > >>> difference() { > >>> cylinder(d=5,h=10); > >>> translate([0,10,0]) cube([4,6,2]) ; > >>> } > >>> > >>> STL file is a list of triangles which make the same outer shell as your model. OpenSCAD makes this complicated transform from shapes to triangles. > >>> solid OpenSCAD_Model > >>> facet normal 0.92388 0.382682 0 > >>> outer loop > >>> vertex 2.5 0 3 > >>> vertex 1.76777 1.76777 0 > >>> vertex 1.76777 1.76777 3 > >>> endloop > >>> endfacet > >>> facet normal 0.92388 0.382682 0 > >>> outer loop > >>> vertex 1.76777 1.76777 0 > >>> vertex 2.5 0 3 > >>> vertex 2.5 0 0 > >>> endloop > >>> endfacet > >>> : (and so on for 300 lines) There is a binary/compressed version, but the description is still just triangles. > >>> > >>> Gcode is what a 3D printer understands - it is the exact list of moves that the head has to do with how much plastic to squeeze to trace the outline of your shape, layer, by layer. It will optionally create moves for filling the inside or support for overhangs. Such a program is called a SLICER and the printer will come with one. > >>> G92 E0 ; reset extrusion distance > >>> G1 Z2.330 F6600.000 ; lift Z > >>> G1 X-0.000 Y1.505 F6600.000 ; move to first perimeter point > >>> G1 Z0.330 F6600.000 ; restore layer Z > >>> G1 E3.00000 F2400.00000 ; unretract extruder 0 > >>> G1 F1500 > >>> G1 X-1.064 Y1.064 E3.09259 ; perimeter > >>> G1 X-1.505 Y0.000 E3.18517 ; perimeter > >>> : (many similar lines) > >>> G1 X1.515 Y1.515 E4.65860 ; perimeter > >>> G1 X0.055 Y2.120 E4.78559 ; perimeter > >>> G1 X-0.000 Y2.143 F6600.000 ; move inwards before travel > >>> G1 X0.384 Y0.843 F6600.000 ; move to first infill point > >>> G1 F1500 > >>> G1 X0.843 Y0.384 E4.84815 ; infill > >>> G1 X1.097 Y-0.229 E4.91215 ; infill > >>> : > >>> (and so on for thousands of lines) > >>> > >>> The 3MF still basically deals in triangles, and attributes (surface, infill material, picture, ticket info ... ) which probably are not used by your slicer/printer. > >>> > >>> On Fri, 6 May 2022 at 12:37, Jan Öhman via Discuss <discuss@lists.openscad.org> wrote: > >>> > >>> > >>> > >>> > >>> ---------- Forwarded message ---------- > >>> From: "Jan Öhman" <jan_ohman@yahoo.com> > >>> To: OpenSCAD General Discussion <discuss@lists.openscad.org> > >>> Cc: > >>> Bcc: > >>> Date: Fri, 6 May 2022 10:38:46 +0000 (UTC) > >>> Subject: [OpenSCAD] Export to .STL / .3MF for later 3D-printing. > >>> Hi! > >>> > >>> Thought to create some objects in openSCAD, to print later. > >>> I do not have my own 3D printer (yet). > >>> > >>> One I talked to, wanted to get the drawings in .STL or .3MF. (I don't know the difference). > >>> > >>> If I had my own printer, have I been able to print directly from openSCAD? > >>> (Without some export?) > >>> > >>> In the openSCAD, no errors or problems occur. > >>> but > >>> The drawings I tested to export from openSCAD have given one or another error message. > >>> One message .: > >>> WARNING: Object may not be a valid 2-manifold and may need repair! > >>> > >>> Another message .: > >>> WARNING: No top level geometry to render > >>> > >>> What to do? > >>> > >>> > >>> > >>> ---------- Forwarded message ---------- > >>> From: "Jan Öhman via Discuss" <discuss@lists.openscad.org> > >>> To: OpenSCAD General Discussion <discuss@lists.openscad.org> > >>> Cc: "Jan Öhman" <jan_ohman@yahoo.com> > >>> Bcc: > >>> Date: Fri, 6 May 2022 10:38:46 +0000 (UTC) > >>> Subject: [OpenSCAD] Export to .STL / .3MF for later 3D-printing. > >>> _______________________________________________ > >>> OpenSCAD mailing list > >>> To unsubscribe send an email to discuss-leave@lists.openscad.org > >>> > >>> _______________________________________________ > >>> OpenSCAD mailing list > >>> To unsubscribe send an email to discuss-leave@lists.openscad.org > >>> > >>> > >>> > >>> ---------- Forwarded message ---------- > >>> From: "Jan Öhman via Discuss" <discuss@lists.openscad.org> > >>> To: OpenSCAD general discussion <discuss@lists.openscad.org> > >>> Cc: "Jan Öhman" <jan_ohman@yahoo.com> > >>> Bcc: > >>> Date: Sat, 7 May 2022 11:04:31 +0000 (UTC) > >>> Subject: [OpenSCAD] Re: Export to .STL / .3MF for later 3D-printing. > >>> _______________________________________________ > >>> OpenSCAD mailing list > >>> To unsubscribe send an email to discuss-leave@lists.openscad.org > >> > >> _______________________________________________ > >> OpenSCAD mailing list > >> To unsubscribe send an email to discuss-leave@lists.openscad.org > > > > _______________________________________________ > > OpenSCAD mailing list > > To unsubscribe send an email to discuss-leave@lists.openscad.org > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > > > ---------- Forwarded message ---------- > From: "Jan Öhman via Discuss" <discuss@lists.openscad.org> > To: OpenSCAD general discussion <discuss@lists.openscad.org> > Cc: "Jan Öhman" <jan_ohman@yahoo.com> > Bcc: > Date: Sat, 7 May 2022 21:38:31 +0000 (UTC) > Subject: [OpenSCAD] Re: Export to .STL / .3MF for later 3D-printing. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
J�
Jan Öhman
Sun, May 8, 2022 9:39 AM
Thank you!
The problem is probably something else for me?
I have two libraries with script.One "C:\Program Files\OpenSCAD\libraries" (with professional scripts like BOSL2 etc.)
the other "C:\Users...\Dokument\OpenSCAD\libraries" (with my own small scripts)
I replaced path_sweep(...); to path_sweep2d(...) in two places (line 49 and line 56) in the script.
which gives the following error .:
ERROR: Assertion 'is_path(path, 2)' failed: "path must be a 2D path" in file ../../../../../../Program Files/OpenSCAD/libraries/BOSL2/skin.scad, line 1323
TRACE: called by 'path_sweep2d' in file ../../../../../../Program Files/OpenSCAD/libraries/BOSL2/skin.scad, line 1350 TRACE: called by 'path_sweep2d' in file Bottenplatta test 2d.scad, line 49
TRACE: called by 'union' in file Bottenplatta test 2d.scad, line 37
TRACE: called by 'difference' in file Bottenplatta test 2d.scad, line 35
TRACE: called by 'mirror' in file Bottenplatta test 2d.scad, line 34
TRACE: called by 'translate' in file Bottenplatta test 2d.scad, line 33
TRACE: called by 'color' in file Bottenplatta test 2d.scad, line 32
TRACE: called by 'box' in file Bottenplatta test 2d.scad, line 9
Den söndag 8 maj 2022 00:09:35 CEST, Adrian Mariano <avm4@cornell.edu> skrev:
linear_extrude()?
Cc:
Bcc:
Thanks every one.
OK!
Den lördag 7 maj 2022 19:50:51 CEST, Michael Möller private2michael@gmail.com skrev:
lør. 7. maj 2022 19.06 skrev Adrian Mariano avm4@cornell.edu:
First model
2nd part
On Sat, 7 May 2022 at 18:26, Sanjeev Prabhakar sprabhakar2006@gmail.com wrote:
Quite a long code.
Regards
Sanjeev
On Sat, 7 May 2022, 16:31 Jan Öhman via Discuss, discuss@lists.openscad.org wrote:
Cc:
Bcc:
Thank you!
  • . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . -
fn = 150;
placering="left";
// LED belysning
//======  box
  color(colorName)
  union()
  section = wall();
  polygon(bottom1);
    linear_extrude(2.1)
      { linear_extrude(3)
  borr=3;
  bredd=140;
  hojd=8;
  avstNed=20;
  { rotate([0,90,0])
  // borrhål
//========  Slut box
//======  cableExit
{ diamHole = 7;
  diamHolder = 9.8;
  hight = 12;
  bowRad = 7;
  offs1 = 0.1;
  color(colorName)
    { difference()
      { hull()
                circle(d=diamHole);
    {  hull()
        sphere(d=7.5);
//======  LEDlampa
  mirror([1, 0, 0])
  { LEDbottom();
        LEDglas();
//======  LEDglas
module LEDglas()
  // Variabler botten
  colorBot = "gray";
  // Variabler top
  midHigh  = 8;
  p1ty = 49.25;
  p2ty = 50.5;
  p3ty = p1ty;
  p4ty = 1.25;
  p5ty = 0.0;
  p6ty = p4ty;
  // Ger ovalt glas
  color("orange")
      circle(d=6);
      circle(d=6);
  // Top
  color(colorTop)
  { hull()
    { // hörn1
        cylinder(h=cornHigh, d=cornRad2, center=false);
      // hörn2
2, center=false);
      // hörn3
      // hörn4
2, center=false);
    union()
//======  LEDbottom
module LEDbottom()
  p1y = 49.25;
  p2y = 50.5;
  p3y = p1y;
  p4y = 1.25;
  p5y = 0.0;
  p6y = p4y;
  midHigh  = 8;
  // offs1 = 0.1;
  height = 11; //mm
    // union()
//======  circleSect
    let(
                  //: undef,
        r = radius,
        step = 360 / fn,
        points = [
    ) points;
  let(
      Ux    = ( (p2-p0).y*(p1-p0)(p1-p0) - (p1-p0).y(p2-p0)(p2-p0) )/D,
      Uy    = ( (p1-p0).x
(p2-p0)(p2-p0) - (p2-p0).x(p1-p0)(p1-p0) )/D,
  [ for(i=[0:fn-1])
      let( ang = ang0 + i
dang/(fn-1) )
// Normal vägghöjd
function wall() =
  let(
        f =  8,    // Foten
        h = 15,    // Höjd
        t =  3.5,  // Top
    let(
        diff =
            difference([
// En högre vägg
function wall1() =
  let(
    f =  7,    // Foten
    h = 25,    // Höjd
    t =  3,  // Top
  let(
    diff =
      difference([
  posX1 = 120;
  posY1 = 0;
  posX2 = posX1;
  posY2 = -200;
  posX3 = 120 - 75;
  posY3 = -200;
  posX4 = 0;
  posY4 = 0;
  color(colorName)
        hull()
$fn=100;
//$fn=15;
//switch();
// showCables();
{ // idé från
  // mått på Switch
  heightHold = 10.5;
  widthHold = 33.5;
  depthHold = 23.5;
  thick = 2;
  // innermått
  // yttermått
          rotate([0,180,45])
            cylinder(h=thick, d1=holeW1.414-thick-thick, d2=holeW1.414, $fn=4);
          rotate([0,180,45])
        sphere(r=6);
        sphere(r=6);
    { union()
      { translate([29.6, 12, heightHold-offset12])
2])
          rotate([180,0,0])
              backHole();
      } // union - slut
      // Sänk stödhylsan
          cube([15, 8, 3]);
      // kabelmarkering
        //#sphere(r=6);
        //#sphere(r=6);
module backHole()
{ wallH = 10.5;
  deep1    =  4;
  height1  = 10.5;
  cornRad1  =  2;
  diam1 = 8;
  opt1 = 0.1;
  //rundadFot();
      { difference()
            circle(r=cornRad1);
  rotate([90, 0, 0])
    { difference()
        circle(r=cornRad1);
    { difference()
          circle(r=cornRad1);
  { union()
      { rotate_extrude()
          { difference()
                circle(r=cornRad1);
          { difference()
                circle(r=cornRad1);
          { difference()
                circle(r=cornRad1);
    { hull()
            sphere(r=cornRad1);
    { hull()
            sphere(r=cornRad1);
  pan = 0.1;
  cableHi = 1.5;
  { color("white")
module rundadFot()
  wallH = 10.5;
  deep1    =  4;
  height1  = 10;
  cornRad1  =  2;
  diam1 = 8;
  opt1 = 0.1;
  color("magenta")
    { difference()
      { union()
        { // Bakgavel
          // Golv
            rotate([0, 180, 0])
          //själva cylindern
          { rotate_extrude()
              { difference()
                    circle(r=cornRad1);
              { difference()
                    circle(r=cornRad1);
              { difference()
                  circle(r=cornRad1);
              { difference()
                  circle(r=cornRad1);
              sphere(r=cornRad1);
              sphere(r=cornRad1);
      // Kant1 - liggande
      { difference()
            cube([box_l+2pad, round_r2+pad, round_r2+pad], center = true);
          rotate(a=[0,90,0])
            cylinder(box_l+4
      // Kant2 - liggande
      { difference()
          rotate(a=[0,90,0])
            cylinder(box_l+4
      // Kant3 - liggande
      { difference()
          rotate(a=[0,90,0])
            cylinder(box_l+4
      // Kant4 - liggande
      { difference()
          rotate(a=[0,90,0])
            cylinder(box_l+4
      // Kant1 - stående
      { difference()
            cube([round_r
2+pad, round_r2+pad, box_h+2pad], center = true);
          cylinder(box_h+4pad,round_r,round_r,center=true,$fn=smooth);
      // Kant2 - stående
      { difference()
            cube([round_r
      // Kant3 - stående
      { difference()
            cube([round_r
      // Kant4 - stående
      { difference()
            cube([round_r
      { difference()
            cube([round_r2+pad, box_w+2pad, round_r2+pad], center = true);
          rotate(a=[0,90,90])
            cylinder(box_w+4
      { difference()
          rotate(a=[0,90,90])
            cylinder(box_w+4
      { difference()
          rotate(a=[0,90,90])
            cylinder(box_w+4
      { difference()
          rotate(a=[0,90,90])
            cylinder(box_w+4
      // Hörn1 (övre)
      { difference()
            cube([round_r
2+pad, round_r2+pad, round_r2+pad], center = true);
      // Hörn2 (övre)
      { difference()
            cube([round_r2+pad, round_r2+pad, round_r2+pad], center = true);
      // Hörn3 (övre)
      { difference()
            cube([round_r
      // Hörn4 (övre)
      { difference()
      // Hörn1 (undre)
      { difference()
      // Hörn2 (undre)
      { difference()
            cube([round_r
      // Hörn3 (undre)
      { difference()
      // Hörn4 (undre)
      { difference()
            cube([round_r
  // mått på Switchen
  heightHold = 10.5;
  widthHold = 33.5;
  depthHold = 23.5;
    difference(0, 0, 0)
    { hull()
      { difference()
            { cylinder(h=depthHold, d=thick2);
                sphere(d=thick
2);          // längst fram
            rotate([-90, 0, 0])
                sphere(d=thick
2);        // längst fram
          translate([widthHold-thick2, -0.1, heightHold]) // plocka bort underdelen
              cube([thick
        sphere(r=6);
        sphere(r=6);
    // halvbåge 1 bak
      circle(d=thick2);
      sphere(d=thick
2);  // övre kulan
    // halvbåge 2 bak
      circle(d=thick2);
      sphere(d=thick
2);  // övre kulan
    { rotate([0,90,0])
      linear_extrude(widthHold-thick2)
  { rotate([0,90,0])
2, r=thick);
{ buttRadie = 1.5;
  height = 10.5;
  width = 33.5;
  depth = 23.5;
  h1x = buttRadie;
  h1y = buttRadie;
  h2y = buttRadie;
  h4x = buttRadie;
  { difference()
    { color("#F9F9F3")
        // tryck-knappen
      union()
            cylinder(h=6, d=6);
            sphere(d=6);
      color("gray")
      color("white")
    // Kabelskruvar
    { difference()
      { // skruvskalle
          rotate([90, 0, 0])
          rotate([0, 0, 0])
          rotate([0, 90, 0])
// borrhål
{ diamHole1 = 3;
  highHole1 = height;
  diamHole2 = 6;
  highHole2 = 2.5;
  offs=0.1;
  color(colorName)
module showCables()
    rotate([80,177,90])
    rotate([90,180,90])
{ // default 1.5mm2
  // pin=
    { color(colGreen)
      color(colYellow)
      color(colGreen)
      color(colYellow)
      color(colCupper)
          circle(d=1.24);
            // : nodef
          circle(d=1.24);
        color(cableColor)
        rotate([90, 0, 0])
            circle(r=1.26);
        translate([-radius2, 0, thick+radius2])
          rotate([0, -90, 0])
        { color(colCupper)
              circle(d=1.24);
    step = -360 / fn;
        polygon(points);
Den fredag 6 maj 2022 14:06:55 CEST, Michael Möller private2michael@gmail.com skrev:
  cylinder(d=5,h=10);
    outer loop
      vertex 2.5 0 3
    endloop
  endfacet
    outer loop
      vertex 2.5 0 3
      vertex 2.5 0 0
    endloop
  endfacet
G1 F1500
G1 F1500
On Fri, 6 May 2022 at 12:37, Jan Öhman via Discuss discuss@lists.openscad.org wrote:
To: OpenSCAD General Discussion discuss@lists.openscad.org
Cc:
Bcc:
Hi!
but
One message .:
Another message .:
What to do?
From: "Jan Öhman via Discuss" discuss@lists.openscad.org
Cc: "Jan Öhman" jan_ohman@yahoo.com
Bcc:
Bcc:
Bcc:
Thank you! The problem is probably something else for me? I have two libraries with script.One "C:\Program Files\OpenSCAD\libraries" (with professional scripts like BOSL2 etc.) the other "C:\Users\...\Dokument\OpenSCAD\libraries" (with my own small scripts) I replaced path_sweep(...); to path_sweep2d(...) in two places (line 49 and line 56) in the script. which gives the following error .: ERROR: Assertion 'is_path(path, 2)' failed: "path must be a 2D path" in file ../../../../../../Program Files/OpenSCAD/libraries/BOSL2/skin.scad, line 1323 TRACE: called by 'path_sweep2d' in file ../../../../../../Program Files/OpenSCAD/libraries/BOSL2/skin.scad, line 1350 TRACE: called by 'path_sweep2d' in file Bottenplatta test 2d.scad, line 49 TRACE: called by 'union' in file Bottenplatta test 2d.scad, line 37 TRACE: called by 'difference' in file Bottenplatta test 2d.scad, line 35 TRACE: called by 'mirror' in file Bottenplatta test 2d.scad, line 34 TRACE: called by 'translate' in file Bottenplatta test 2d.scad, line 33 TRACE: called by 'color' in file Bottenplatta test 2d.scad, line 32 TRACE: called by 'box' in file Bottenplatta test 2d.scad, line 9  Den söndag 8 maj 2022 00:09:35 CEST, Adrian Mariano <avm4@cornell.edu> skrev: Where did you get your model if you don't understand how to use linear_extrude()? https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/2D_to_3D_Extrusion With regards to use of path_sweep I have said that adding the two characters "2d" will fix the problem.  This does not seem terribly complex to me.  The other possibilities are to address the same problem in different ways.  Arguably the self-intersecting shape is ugly, so you might want to change the shape so it doesn't self intersect, creating a line where the intersection occurs instead of a smooth, rounded surface. On Sat, May 7, 2022 at 5:40 PM Jan Öhman via Discuss <discuss@lists.openscad.org> wrote: > > > > > ---------- Forwarded message ---------- > From: "Jan Öhman" <jan_ohman@yahoo.com> > To: OpenSCAD general discussion <discuss@lists.openscad.org> > Cc: > Bcc: > Date: Sat, 7 May 2022 21:38:31 +0000 (UTC) > Subject: [OpenSCAD] Re: Export to .STL / .3MF for later 3D-printing. > Thanks every one. > I understand that Adrian Mariano has an explanation (probably pretty good). > But still do not understand what to do in my case. > > "...It has a 2d polygon (easily found as there is one lone > polygon call) that needs to be removed " > I think it is the polygon call in the moule Box that it is referenced. > But if I delete the polygon call, that structure will disappear ... or ...? > > "or linear_extruded" I don't understand... > > "And it makes use of path_sweep in a manner that produces > a self-intersecting polyhedron." > Now it will be very difficult - I think > > "This issue is explained in the manual page for path_sweep." > OK! > > "This can be fixed either by switching to path_extrude2d() or > by changing the corner radius to eliminate the self-intersections." > > "or changing to a profile that can actually be rounded at the desired radius." > Is this the same problem that is solved in another way? > > > Den lördag 7 maj 2022 19:50:51 CEST, Michael Möller <private2michael@gmail.com> skrev: > > > Indeed you did Adrian, I was curious what that long code was going to produce. > > Michael, fra mobilen > > lør. 7. maj 2022 19.06 skrev Adrian Mariano <avm4@cornell.edu>: > > I already gave a full explanation of what's wrong and how to fix the > first program.  It has a 2d polygon (easily found as there is one lone > polygon call) that needs to be removed or linear_extruded as > appropriate.  And it makes use of path_sweep in a manner that produces > a self-intersecting polyhedron.  This issue is explained in the manual > page for path_sweep.  This can be fixed either by switching to > path_extrude2d() or by changing the corner radius to eliminate the > self-intersections.  Or changing to a profile that can actually be > rounded at the desired radius. > > https://github.com/revarbat/BOSL2/wiki/skin.scad#functionmodule-path_sweep > > On Sat, May 7, 2022 at 12:57 PM Michael Möller > <private2michael@gmail.com> wrote: > > > > Jan Öhman wrote it failed in Render/F6, but works in Preview/F5 - in so many words. I tried and got the following > > > > First model > > > > F6 Error: WARNING: Ignoring 2D child object for 3D operation in file , line 53 > > > > ERROR: CGAL error in CGALUtils::applyUnion3D: CGAL ERROR: assertion violation! Expr: G.mark(v1,0)==G.mark(v2,0)&& G.mark(v1,1)==G.mark(v2,1) File: /mxe/usr/x86_64-w64-mingw32.static.posix/include/CGAL/Nef_S2/SM_overlayer.h Line: 303 > > > > Which I think is pretty selfexplantory: Passed a 2D shape to something that expected a 3D shape - but you have to read the whole code to find it ... which I think Jan is more qualified to do :-) > > > > 2nd part > > > > ... which is one of those where zooming or rotating the model in preview takes >5 second > > > > And I didn't bother waiting for the F6 error ... ;-) > > > > > > Of course, we do not know if the above shapes I got are the ones that Jan wants - there are also sections of code commented out. > > > > (From the comments it seems these are to be nice and alternative covers for wall outlet/switches.) > > > > > > > > On Sat, 7 May 2022 at 18:26, Sanjeev Prabhakar <sprabhakar2006@gmail.com> wrote: > >> > >> Quite a long code. > >> Can you paste a picture of what you are trying to draw. > >> Regards > >> Sanjeev > >> > >> On Sat, 7 May 2022, 16:31 Jan Öhman via Discuss, <discuss@lists.openscad.org> wrote: > >>> > >>> > >>> > >>> > >>> ---------- Forwarded message ---------- > >>> From: "Jan Öhman" <jan_ohman@yahoo.com> > >>> To: OpenSCAD general discussion <discuss@lists.openscad.org> > >>> Cc: > >>> Bcc: > >>> Date: Sat, 7 May 2022 11:04:31 +0000 (UTC) > >>> Subject: [OpenSCAD] Re: Export to .STL / .3MF for later 3D-printing. > >>> Thank you! > >>> Begins to understand how it works. (It was not easy...) > >>> > >>> but my solution was not good ... > >>> > >>> Here are 2 files that do not work to render (F6) > >>> > >>> > >>> = = product 1= = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = > >>> - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - > >>> > >>> > >>> include <BOSL2/std.scad> > >>> fn = 150; > >>> > >>> placering="left"; > >>> // placering="right" > >>> > >>> box(0, 0, 0, placering, "#C0C0C0", fn); // (X, Y, Z, left/right, colorName) > >>> > >>> > >>> // Monteringsplattan > >>> // mountingPlate(0, 0, 0, placering); > >>> > >>> > >>> // LED belysning > >>> // LEDlampa(0, 0, 0, placering); > >>> > >>> > >>> // - - - - - - - - - - - - - - - - - - - - - - - - - - - - - > >>> // - - - - m o d u l e r - - - - - - - - - - - - - - - - - - > >>> > >>> > >>> //================================================================================== > >>> //======  box  ===================================================================== > >>> module box(posX=0, posY=0, posZ=0, mountSide="left", colorName="#00FF00", fn=24) > >>> { > >>>  side = mountSide == "left" ? 0 > >>>        : mountSide == "right" ? 1 > >>>        : assert(false,"invalid moutSide value");  // message if no case worked > >>> > >>>  color(colorName) > >>>  translate([posX, posY, posZ]) > >>>  mirror([side, 0, 0]) > >>>  difference() > >>>  { > >>>  union() > >>>  { > >>>  // Skapa konturer på bottenplattan - x, y, r, angles, [grader], början > >>>  // Rotation medurs - vänster lamphållare (bakant saknas) > >>>  points1 = circSect( 140,  0,  0, [0, 0], "right",  1, fn);  // böj nere till höger > >>>  points2 = circSect(  60,  5,  5, [0, 5], "bottom",  1, fn); // brytpunkt längst ned > >>>  points3 = circSect(  10, 13,  10, [0, 90], "bottom", 1, fn); // böj nere till vänster > >>>  points4 = circSect(  5, 80,  5, [0, 90], "left",  1, fn); // böj uppe till vänster > >>>  points5 = circSect( 140, 80,  5, [0, 1], "top",  1, fn);  // böj uppe till höger > >>>  edge = concat(points1, points2, points3, points4, points5); > >>>  path = path3d(reverse(edge)); > >>>  section = wall(); > >>>  path_sweep( section, path, closed=false); > >>> > >>> > >>>  // Skapa bakkant lite högre och smalare i topp > >>>  bottom1 = concat(points5, points1); > >>>  polygon(bottom1); > >>>  path1 = path3d(reverse(bottom1)); > >>>  section1 = wall1(); // lite högre bakvägg wall(b=4, f=8, h=15, t=3.5) > >>>  path_sweep( section1, path1, closed=false); > >>> > >>>  // fyll upp bottenplattansbaksida > >>>  linear_extrude(4) // Bottomplate - fill up > >>>    polygon(concat(points1, points2, points3, points4, points5)); > >>> > >>> > >>>  // skapa Utskjutande del under (tänk spegelvänt) > >>>  pt1 = circSect(  19.5, 85, 0, [0, 50], "top", 1, fn);  // Uppe till höger - moturs > >>>  pt2 = circSect(  39, 1.35,  .1, [-5, 90], "right", 1, fn);  // Nere till höger > >>>  pt3 = circSect(  10, 13.05,  10, [0, 90], "bottom", 1, fn);  // Nere till vänster > >>>  pt4 = circSect(  5, 80, 5, [0, 90], "left",  1, fn);  // Uppe till vänster > >>>  translate([0, 0, -2]) > >>>    linear_extrude(2.1) > >>>      polygon(concat(pt1, pt2, pt3, pt4)); > >>> > >>>  // utgången för kabeln på baksidan (diam 10mm) - pekar lite nedåt > >>>  cableExit(65, 35, 0, 15, "cyan", $fn=100); > >>>  } > >>> > >>>  // skapa ett borrhål i bakkant > >>>  translate([132,60,15]) > >>>  { rotate([0, 90, 0]) > >>>    { cylinder(h=10, d=2, $fn=100); > >>>      cylinder(h=4, d=9, $fn=100); > >>>    } > >>>  } > >>> > >>>  // skapa en borrmarkering i bakkant > >>>  translate([139,25,15]) > >>>  { rotate([0, 90, 0]) > >>>      cylinder(h=2, d1=1, d2=2.5, $fn=100); > >>>  } > >>> > >>> > >>>  // ingravera årtalet på baksidan > >>>  translate([10, 80, -0.5]) > >>>  { mirror([side, 0, 0]) > >>>    { rotate([0, 180, 0]) > >>>      { linear_extrude(3) > >>>          text("2022", size=12, direction="ttb", font="Comic Sans MS:style=Bold"); > >>>      } > >>>    } > >>>  } > >>> > >>>  /* > >>>  // Markera skruvhål på bakkant > >>>  borr=3; > >>>  bredd=140; > >>>  hojd=8; > >>>  avstNed=20; > >>>  translate([bredd, avstNed, hojd]) > >>>  { rotate([0,90,0]) > >>>      cylinder(h=2, d1=0.5, d2=borr, center=true, $fn=50); > >>>  } > >>>  */ > >>> > >>>  // borrhål > >>>  mountingHole(20, 36, 0, 7, 90.1, 15); // posX, posY, posZ, diam, dist, deep, $fn=50 > >>> > >>>  } > >>> } > >>> //========  Slut box  ============================================================== > >>> > >>> > >>> //================================================================================== > >>> //======  cableExit  =============================================================== > >>> module cableExit(posX, posY, posZ, angle, colorName) > >>> { diamHole = 7; > >>>  diamHolder = 9.8; > >>>  hight = 12; > >>>  topRad = diamHolder/2; > >>>  topDiam = diamHolder/2-topRad/2; > >>>  bowRad = 7; > >>>  offs1 = 0.1; > >>> > >>>  color(colorName) > >>>  translate([posX, posY, posZ]) > >>>  {  rotate([180, 0, 180-angle]) > >>>    { difference() > >>>      { hull() > >>>        { cylinder(h=hight, d=diamHolder, center=false); > >>>          translate([0, 0, hight])        // rundad topp > >>>            rotate_extrude(angle=360, convexity=2) > >>>              translate([topDiam, 0, 0])  // yttre diam topp > >>>                circle(d=topRad);        // radie topp > >>>        } > >>> > >>> > >>>        inpHight  =  2;  // ett värde som styr var utgångshålet hamnar > >>>        translate([0, 0, -offs1]) > >>>          cylinder(h=inpHight+offs1, d=diamHole, center=false); // Bottenhål > >>> > >>>        translate([-bowRad, 0, inpHight-offs1]) // böjen > >>>        { rotate([90, 0, 0]) > >>>            rotate_extrude(angle=90, convexity=10) > >>>              translate([bowRad, 0, 0]) // ställ in radien på kabelböjen > >>>                circle(d=diamHole); > >>>        } > >>>      } > >>>    } > >>>  } > >>> } > >>> //======  slut cableExit  ========================================================== > >>> > >>> > >>> //================================================================================== > >>> //======  mountingHole  ============================================================ > >>> module mountingHole(posX=0, posY=0, posZ=0, diam=7, dist=90, deep=5, $fn=50) > >>> { // diam =  6;  // [mm] > >>>  // dist = 90;  // [mm] > >>>  // deep =  12;  // [mm] > >>> > >>>  translate([posX, posY, posZ]) > >>>  { translate([0, 0, -10]) > >>>      cylinder(h=deep, d=diam);  // fästhål 1 > >>> > >>>    //cableHold1(dist/2, 0, .2, "#D5D5D5");  // Kabelgenomföring > >>>    translate([dist/2, 0, 0]) > >>>    {  hull() > >>>      { cylinder(h=5, d=6);  // fästhål 1 > >>>        sphere(d=7.5); > >>>      } > >>>    } > >>> > >>>    translate([dist, 0, -10]) > >>>      cylinder(h=deep, d=diam); // fästhål 2 > >>>  } > >>> } > >>> //======  slut mountingHole  ======================================================= > >>> > >>> > >>> //================================================================================== > >>> //======  LEDlampa  ================================================================ > >>> // module LEDlampa(posX=8, posY=10, posZ=0) > >>> module LEDlampa(posX=0, posY=0, posZ=0, mountSide="left") > >>> { side = mountSide == "left" ? 0 > >>>        : mountSide == "right" ? 1 > >>>        : assert(false,"invalid moutSide value");  // message if no case worked > >>> > >>>  xpos = mountSide == "left" ? 121 > >>>        : mountSide == "right" ? -10 > >>>        : assert(false,"invalid moutSide value");  // message if no case worked > >>>  /* > >>>  ypos = mountSide == "left" ? 10.5 > >>>        : mountSide == "right" ? 10.5 > >>>        : assert(false,"invalid moutSide value");  // message if no case worked > >>> > >>>  zpos = mountSide == "left" ? 5 > >>>        : mountSide == "right" ? 5 > >>>        : assert(false,"invalid moutSide value");  // message if no case worked > >>> */ > >>> // echo(xpos,ypos,zpos); > >>>  // translate([xpos, ypos, zpos]) > >>>  translate([xpos, 10.5, 5]) > >>>  mirror([1, 0, 0]) > >>>  translate([posX, posY, posZ]) > >>>  { LEDbottom(); > >>>      translate([0, 0, 11]) > >>>        LEDglas(); > >>>  } > >>> } > >>> //======  Slut LEDlampa  =========================================================== > >>> > >>> > >>> //================================================================================== > >>> //======  LEDglas  ================================================================= > >>> module LEDglas() > >>> { > >>>  // Variabler botten > >>>  length  = 111;  // längd mm > >>>  wideMid = 50.5;  // bredd i mitten mm > >>> > >>>  cornRad = 10;    // Radien i alla hörn > >>>  wideCorn = 48;  // Bredd i kanterna > >>> > >>>  diamHole = 6;    // håldiameter i mm > >>> > >>>  colorBot = "gray"; > >>>  colorTop = "orange"; > >>> > >>>  // Variabler top > >>>  cornHigh = 5;  //Höjd i ändarna > >>>  midHigh  = 8; > >>>  highTop = cornHigh + 1;  // höjd mm > >>> > >>>  p1tx = 10;      // the start value > >>>  p1ty = 49.25; > >>>  p2tx = 55.5;    // the middle value > >>>  p2ty = 50.5; > >>>  p3tx = 101;    // the end value > >>>  p3ty = p1ty; > >>> > >>>  p4tx = 101;    // the start value > >>>  p4ty = 1.25; > >>>  p5tx = 55.5;    // the middle value > >>>  p5ty = 0.0; > >>>  p6tx = 10;      // the end value > >>>  p6ty = p4ty; > >>>  // Ger ovalt glas > >>>  points1 = 3points_arc([p1tx,p1ty], [p2tx,p2ty], [p3tx,p3ty], fn=100); > >>>  points2 = 3points_arc([p4tx,p4ty], [p5tx,p5ty], [p6tx,p6ty], fn=100); > >>> > >>>  color("orange") > >>>  linear_extrude(height=cornHigh+.1) > >>>  difference() > >>>  { polygon(concat(points1, points2)); > >>> > >>>    translate([length-10 , wideMid / 2, -.2]) > >>>      circle(d=6); > >>>    translate([10 , wideMid / 2, -.2]) > >>>      circle(d=6); > >>>  } > >>> > >>>  // Top > >>>  color(colorTop) > >>>  difference() > >>>  { hull() > >>>    { // hörn1 > >>>      translate([cornRad, wideMid - ((wideMid-wideCorn)/2) - cornRad, 0]) // [10,39] > >>>        cylinder(h=cornHigh, d=cornRad*2, center=false); > >>>      // hörn2 > >>>      translate([cornRad, cornRad + ((wideMid-wideCorn)/2), 0])          // [10,12] > >>>        cylinder(h=cornHigh, d=cornRad*2, center=false); > >>>      // hörn3 > >>>      translate([length - cornRad, wideMid - ((wideMid-wideCorn)/2) - cornRad, 0]) // [101 ,39] > >>>        cylinder(h=cornHigh, d=cornRad*2, center=false); > >>>      // hörn4 > >>>      translate([length - cornRad, cornRad + ((wideMid-wideCorn)/2), 0])  // > >>>        cylinder(h=cornHigh, d=cornRad*2, center=false); > >>>    } > >>> > >>>    union() > >>>    { // Monteringshål 1 & 2 > >>>      translate([length-10 , wideMid / 2, -.2]) > >>>        cylinder(d=diamHole, h=highTop+.5, center=false); > >>>      translate([10 , wideMid / 2, -.2]) > >>>        cylinder(d=diamHole, h=highTop+.5, center=false); > >>>    } > >>>  } > >>> } > >>> //========  Slut LEDglas  ========================================================== > >>> > >>> > >>> //================================================================================== > >>> //======  LEDbottom  =============================================================== > >>> module LEDbottom() > >>> { p1x = 10;      // the start value > >>>  p1y = 49.25; > >>>  p2x = 55.5;    // the middle value > >>>  p2y = 50.5; > >>>  p3x = 101;    // the end value > >>>  p3y = p1y; > >>> > >>>  p4x = 101;    // the start value > >>>  p4y = 1.25; > >>>  p5x = 55.5;    // the middle value > >>>  p5y = 0.0; > >>>  p6x = 10;      // the end value > >>>  p6y = p4y; > >>> > >>>  // Variabler botten för borrhålen > >>>  length  = 111;  // längd mm > >>>  wideMid = 50.5;  // bredd i mitten mm > >>>  diamHole = 6;    // håldiameter i mm > >>>  cornHigh = 5;  //Höjd i ändarna > >>>  midHigh  = 8; > >>>  highTop = cornHigh + 1;  // höjd mm > >>>  // offs1 = 0.1; > >>>  heightHole = 15; //mm > >>>  height = 11; //mm > >>> > >>>  points1 = circSect(  10, 11.25,  10, [0, 90], "bottom", 1, fn); // Hörn nere till vänster > >>>  points2 = circSect(  10, 39.25,  10, [0, 90], "left",  1, fn); // Hörn uppe till vänster > >>>  points3 = 3points_arc([p1x,p1y], [p2x,p2y], [p3x,p3y], fn); > >>>  points4 = circSect( 101, 39.25,  10, [0, 90], "top",    1, fn); // Hörn uppe till höger > >>>  points5 = circSect( 101, 11.25,  10, [0, 90], "right",  1, fn); // Hörn nere till höger > >>>  points6 = 3points_arc([p4x,p4y], [p5x,p5y], [p6x,p6y], fn); > >>> > >>>  // The base plate for the LED lamp > >>> > >>> > >>>  difference() > >>>  { color("gray", 0.5) > >>>    linear_extrude(height=height) > >>>      polygon(concat(points1, points2, points3, points4, points5, points6)); > >>> > >>> > >>>    // union() > >>>    { // Monteringshål 1 & 2 > >>>      translate([length-10 , wideMid / 2, -.2]) > >>>        cylinder(d=diamHole, h=heightHole, center=false); > >>>      translate([10 , wideMid / 2, -.2]) > >>>        cylinder(d=diamHole, h=heightHole, center=false); > >>>    } > >>>  } > >>> } > >>> //========  Slut LEDbottom  ======================================================== > >>> > >>> > >>> > >>> //================================================================================== > >>> //======  circleSect  ============================================================== > >>> // Create rounded corners 2D > >>> // https://openhome.cc/eGossip/OpenSCAD/SectorArc.html > >>> // ange .:  x, y, radien, > >>> //          [från, till] vinkel, > >>> //          var vinkeln startar, (left, bottom, right, top) > >>> //          vilken rotation (-1=medsol, 1=motsols) > >>> function circSect(x=0, y=0, radius=10, angles=[0,270], startRef="bottom", rotate=1, fn=24)  = > >>>    let( > >>>        startAngel  = (startRef == "left")  ?  0 > >>>                    : (startRef == "bottom") ?  90 > >>>                    : (startRef == "right")  ? 180 > >>>                    : (startRef == "top")    ? 270 > >>>                    : startRef,  // valfri vinkel > >>>                  // : assert(false,"invalid moutSide value");  // Error message if no case worked > >>>                  //: undef, > >>>        r = radius, > >>>        //r = radius / cos(180 / fn), > >>>        step = 360 / fn, > >>>        // points = [[x, y], > >>>        points = [ > >>>            for(a = [angles[0]-startAngel : step : angles[1]-startAngel]) > >>>                [-rotate * r * cos(a)+x, r * sin(a)+y]] > >>>    ) points; > >>> //========  Slut circleSect  ======================================================= > >>> > >>> > >>> //================================================================================== > >>> //======  3points_arc  ============================================================= > >>> // Create an arc with three points 2D > >>> function 3points_arc(p0, p1, p2, fn=10) = > >>>  // an alternative expression for D > >>>  // D  = 2 * ( (p1-p0).x * (p2-p0).y - (p1-p0).y * (p2-p0).x ) > >>>  let( D  = 2 * cross(p1-p0, (p2-p0)) ) > >>>  assert( abs(D)>1e-9, "The 3 points should not be collinear." ) > >>>  let( > >>>      Ux    = ( (p2-p0).y*(p1-p0)*(p1-p0) - (p1-p0).y*(p2-p0)*(p2-p0) )/D, > >>>      Uy    = ( (p1-p0).x*(p2-p0)*(p2-p0) - (p2-p0).x*(p1-p0)*(p1-p0) )/D, > >>>      radius = norm([Ux,Uy]), > >>>      center = [Ux,Uy] + p0, > >>>      ang0  = atan2( (p0-center).y, (p0-center).x ), > >>>      ang2  = atan2( (p2-center).y, (p2-center).x ), > >>>      // the points are in a cw winding iff D<0 > >>>      // the angular difference between vectors p2-center and p0-center > >>>      // measured from p0-center; dang is positive iff D is negative > >>>      dang  = D<0  ? ang2<ang0 ? ang2-ang0 : ang2-ang0-360 > >>>                    : ang2>ang0 ? ang2-ang0 : ang2-ang0+360 > >>>  ) > >>>  [ for(i=[0:fn-1]) > >>>      let( ang = ang0 + i*dang/(fn-1) ) > >>>      center + radius*[cos(ang),sin(ang)] ]; > >>> //========  Slut 3points_arc  ====================================================== > >>> > >>> > >>> //================================================================================== > >>> //======  Wall som ett "L"  ======================================================== > >>> // Normal vägghöjd > >>> function wall() = > >>>  let( > >>>        b =  4,    // botten - tjocklek > >>>        f =  8,    // Foten > >>>        h = 15,    // Höjd > >>>        t =  3.5,  // Top > >>>        x = (b+(t/2) - (h - ( (-h / (f-t)) *t) )) / (-h / (f-t)) > >>>    ) > >>>    let( > >>>        points = [[0,0], [f,0], [t,h], [0,h]] , > >>>        top = move([t/2, h, 0], circle(d=t, $fn=20)), > >>>        sqr = square([10, b]), > >>>        diff = > >>>            difference([ > >>>                  move([x, b], square([t/2, t/2])), > >>>                  move([x+(t/2), b+(t/2), 0], circle(d = t, $fn=20) ) ]) > >>>        ) > >>>    union([points, top, sqr, diff]); > >>> //========  Slut Wall  ============================================================= > >>> > >>> > >>> > >>> //================================================================================== > >>> //======  Wall1 som ett "L"  ======================================================= > >>> // En högre vägg > >>> function wall1() = > >>>  let( > >>>    b =  4,    // botten - tjocklek > >>>    f =  7,    // Foten > >>>    h = 25,    // Höjd > >>>    t =  3,  // Top > >>>    x = (b+(t/2) - (h - ((-h / (f-t)) *t))) / (-h / (f-t)) > >>>  ) > >>>  let( > >>>    points = [[0,0], [f,0], [t,h], [0,h]] , > >>>    top = move([t/2, h, 0], circle(d=t, $fn=20)), > >>>    sqr = square([10, b]), > >>>    diff = > >>>      difference([ > >>>        move([x, b], square([t/2, t/2])), > >>>        move([x+(t/2), b+(t/2), 0], circle(d = t, $fn=20) ) ]) > >>>    ) > >>>    union([points, top, sqr, diff]); > >>> //========  Slut Wall1  ============================================================ > >>> > >>> > >>> //================================================================================== > >>> //======  Plåt på släp  ============================================================ > >>> module mountingPlate(posX=0, posY=0, posZ=0, mountSide="left", colorName="#C0C0C0", $fn=50) > >>> { // Hörnpositionerna > >>>  posX1 = 120; > >>>  posY1 = 0; > >>>  posX2 = posX1; > >>>  posY2 = -200; > >>>  posX3 = 120 - 75; > >>>  posY3 = -200; > >>>  posX4 = 0; > >>>  posY4 = 0; > >>>  thick=2;  // tjocklek > >>> > >>>  side = mountSide == "left" ? 0 > >>>        : mountSide == "right" ? 1 > >>>        : assert(false,"invalid moutSide value");  // message if no case worked > >>> > >>>  xpos = mountSide == "left" ? 20 > >>>        : mountSide == "right" ? -20 > >>>        : assert(false,"invalid moutSide value");  // message if no case worked > >>> /* > >>>  ypos = mountSide == "left" ? 85 > >>>        : mountSide == "right" ? 85 > >>>        : assert(false,"invalid moutSide value");  // message if no case worked > >>> > >>>  zpos = mountSide == "left" ? -thick > >>>        : mountSide == "right" ? -thick > >>>        : assert(false,"invalid moutSide value");  // message if no case worked > >>> */ > >>>  color(colorName) > >>>  {  translate([posX, posY, posZ]) > >>>      translate([xpos, 85, -thick]) > >>>    { mirror([side, 0, 0]) > >>>      { linear_extrude(thick) > >>>        hull() > >>>        { translate([posX1, posY1, 0]) > >>>            square(0.1, center = true); > >>>          translate([posX2, posY2, 0]) > >>>            square(0.1, center = true); > >>>          translate([posX3, posY3, 0]) > >>>            square(0.1, center = true); > >>>          translate([posX4, posY4, 0]) > >>>            square(0.1, center = true); > >>>        } > >>>      } > >>>    } > >>>  } > >>> } > >>> = = END product 1= = = = = = = = = = = = = = = = = = = = = = = = = = = = = = > >>> - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - > >>> > >>> > >>> > >>> > >>> = = product 2 = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = > >>> - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - > >>> > >>> $fn=100; > >>> //$fn=15; > >>> > >>> //switch(); > >>> //cableHolder4(); //Switchboxen > >>> > >>> > >>> // cableHolder3(0, 0, 0, 33.5, 23.5, 1.5, 2); > >>> // showCables(); > >>> > >>> > >>> > >>> module cableHolder4(fn=24); > >>> { // idé från > >>>  // - https://www.thingiverse.com/thing:6400/files > >>>  // - https://ihrchive.wordpress.com/2011/02/14/openscad-tip-round-1-of-3-basic-rounding/ > >>> > >>>  // mått på Switch > >>>  heightHold = 10.5; > >>>  widthHold = 33.5; > >>>  depthHold = 23.5; > >>>  spaceHold = 10.0; // utrymmet bakom switch > >>>  holdRadie = 2;  // radie i hörnen > >>>  thick = 2; > >>>  offset1=0.5;  // öka toleransen > >>> > >>>  // innermått > >>>  holeW = widthHold + offset1; > >>>  holeH = heightHold + offset1; > >>>  holeD = depthHold + spaceHold+offset1; > >>> > >>>  // yttermått > >>>  pad = 0.1;                  // Padding to maintain manifold > >>>  box_l = holeW + thick*2;  // Bredden på switchen > >>>  box_w = holeD + thick;            // Djupet på switchen > >>>  box_h = holeH + thick; // Height > >>>  round_r = holdRadie;        // Radius of round > >>>  smooth = 45;                // Number of facets of rounding cylinder > >>> > >>> > >>> > >>>  difference() > >>>  { union() // Detta utförs i två steg. > >>>    { difference()  // utför fasningar och kabelmarkeringar > >>>      { mainBox(box_l, box_w, box_h, spaceHold+thick, round_r, thick, smooth, pad); > >>> > >>>        // fasning vänster (underkant) > >>>        translate([box_l/2-0.85, spaceHold-4.3, thick-offset1])  // sidled, fram/bak , upp/ned > >>>          rotate([0,180,45]) > >>>            cylinder(h=thick, d1=holeW*1.414-thick-thick, d2=holeW*1.414, $fn=4); > >>> > >>>        // fasning höger (underkant) > >>>        translate([box_l/2-3.65, spaceHold-4.3, thick-offset1]) // sidled, fram/bak , upp/ned > >>>          rotate([0,180,45]) > >>>            cylinder(h=thick, d1=holeW*1.414-thick-thick, d2=holeW*1.414, $fn=4); > >>> > >>>        // kabelgenomföringar > >>>        rotate([90, 180, 90]) // Markering ena sidan (vänster under) > >>>          ovalCableHole(spaceHold/2-offset1, -1.75, -1.2); > >>> > >>>        rotate([90, 180, 180]) // Markering bakkant (vänster under) > >>>          ovalCableHole(spaceHold/2-1.55, -1.75, -spaceHold-0.85); > >>> > >>>        rotate([90, 180, 180]) // Markering bakkant (höger under) > >>>          ovalCableHole(widthHold-spaceHold/2-offset1, -1.75, -spaceHold-0.85); > >>> > >>>        rotate([90, -180, 90])  // Markering ena sidan (höger under) > >>>          ovalCableHole(3.75, -1.75, widthHold-0.1); > >>>      } > >>>    } // Slut union - kropp > >>> > >>>    translate([-offset1/2, -spaceHold+pad, -pad]) // hålet där switchen ska placeras > >>>      cube([holeW, holeD+pad, holeH+pad], center=false); > >>> > >>>      translate([4, 12, 0]) > >>>        cylinder(h=15,d=3.2); > >>>      translate([4, 12, 17.7]) > >>>        sphere(r=6); > >>> > >>>      translate([29.6, 12, 0]) > >>>        cylinder(h=15,d=3.2); > >>>      translate([29.6, 12, 17.7]) > >>>        sphere(r=6); > >>> > >>>      /*  // Hål genom lock bak - om så önskas > >>>      translate([box_l/2-thick, -6, offset1/2]) > >>>        cylinder(h=box_h+thick*4+offset1, d=3.2, $fn=100);  // hål genom lock bak > >>> > >>>      translate([box_l/2-thick, -6, 17.7]) > >>>        sphere(r=6);    // kona hålet bak > >>>      */ > >>>  } // Slut difference() - box > >>> > >>>    difference() > >>>    { union() > >>>      { translate([29.6, 12, heightHold-offset1*2]) > >>>          cylinder(h=2,d=5.2);        // Stödhylsa för Switchskruv1 > >>>        translate([4, 12, heightHold-offset1*2]) > >>>          cylinder(h=2,d=5.2);        // Stödhylsa för Switchskruv2 > >>> > >>>        translate([holeW/2, -spaceHold+thick+1, holeH/2]) > >>>          rotate([180,0,0]) > >>>              backHole(); > >>>      } // union - slut > >>> > >>>      translate([4, 12, 0])    //  Hålen i stödhylsorna > >>>        cylinder(h=15,d=3.2); > >>> > >>>      translate([29.6, 12, 0])  //  Hålen i stödhylsorna > >>>        cylinder(h=15,d=3.2); > >>> > >>>      translate([box_l/2-thick, -6, -offset1])  // hål i stödhylsa bak > >>>        cylinder(h=box_h+offset1, d=3.2, $fn=100); > >>> > >>>      // Sänk stödhylsan > >>>      translate([ widthHold/2-7, -spaceHold-offset1, -thick+offset1])  // hål i stödhylsa bak > >>>          cube([15, 8, 3]); > >>> > >>> > >>>      // kabelmarkering > >>>      // translate([0, 0, 0])  // hål i stödhylsa bak > >>> > >>> > >>>      } > >>> > >>> > >>> > >>> > >>> > >>> > >>> /* > >>>      translate([4, 12, 0]) > >>>        #cylinder(h=15,d=3.2); > >>>      //translate([4, 13.5, 17.3]) > >>>        //#sphere(r=6); > >>> > >>>      translate([29.6, 12, 0]) > >>>        #cylinder(h=15,d=3.2); > >>>      //translate([29.6, 13.5, 17.3]) > >>>        //#sphere(r=6); > >>> */ > >>> > >>> > >>> } > >>> > >>> module backHole() > >>> { wallH = 10.5; > >>> > >>>  wide1  = 12; // endast runt cylindern > >>>  wide2  = 35; // hela väggen > >>>  deep1    =  4; > >>>  height1  = 10.5; > >>>  cornRad1  =  2; > >>>  diam1 = 8; > >>>  opt1 = 0.1; > >>> > >>>  //rundadFot(); > >>> > >>> > >>>  // Rundad stäcka mellan t.ex. vägg och tak -bakkant > >>>  translate([wide2/2, diam1/2-cornRad1/2, -height1/2]) > >>>  { rotate([90, 0, -90]) > >>>    { linear_extrude(wide2) > >>>      { difference() > >>>        { square([cornRad1, cornRad1]); > >>> > >>>          translate([cornRad1, cornRad1]) > >>>            circle(r=cornRad1); > >>>        } > >>>      } > >>>    } > >>>  } > >>> > >>>  // rundad stäcka1 (vänster) mellan t.ex. vägg och tak > >>>  translate([-wide2/2+0.15, deep1/2+cornRad1/2, -height1/2]) > >>>  rotate([90, 0, 0]) > >>>  { linear_extrude(spaceHold) > >>>    { difference() > >>>      { square([cornRad1, cornRad1]); > >>> > >>>        translate([cornRad1, cornRad1]) > >>>        circle(r=cornRad1); > >>>      } > >>>    } > >>>  } > >>> > >>>  // rundad stäcka2 mellan t.ex. vägg och tak > >>>  translate([wide2/2-0.65, deep1/2+cornRad1/2, -height1/2]) > >>>  rotate([0, -90, 90]) > >>>  { linear_extrude(spaceHold) > >>>    { difference() > >>>      { square([cornRad1, cornRad1]); > >>> > >>>        translate([cornRad1, cornRad1]) > >>>          circle(r=cornRad1); > >>>      } > >>>    } > >>>  } > >>> > >>>  // Skapa stödfot - bak > >>>  difference() > >>>  { union() > >>>    { //själva cylindern > >>>      translate([0, 1, 0]) > >>>      { cylinder(h=height1, d=diam1, center=true); > >>>        translate([0, diam1/2, 0]) > >>>          cube([diam1,diam1-1,height1], center=true); > >>>      } > >>> > >>>      // Rundad fot under cylinder ovan > >>>      translate([0, 1, -height1/2]) > >>>      { rotate_extrude() > >>>        { translate([diam1/2, 0, 0]) > >>>          { difference() > >>>            { square([cornRad1, cornRad1]); > >>> > >>>              translate([cornRad1, cornRad1]) > >>>                circle(r=cornRad1); > >>>            } > >>>          } > >>>        } > >>>      } > >>> > >>>      // Rundad rakstäcka1 - cylinderfot - mellan t.ex. vägg och tak > >>>      translate([diam1/2, diam1, -height1/2]) > >>>      { rotate([90, 0, 0]) > >>>        { linear_extrude(diam1) > >>>          { difference() > >>>            { square([cornRad1, cornRad1]); > >>> > >>>              translate([cornRad1, cornRad1]) > >>>                circle(r=cornRad1); > >>>            } > >>>          } > >>>        } > >>>      } > >>> > >>>      // Rundad rakstäcka2 - cylinderfot - mellan t.ex. vägg och tak > >>>      translate([-diam1/2, diam1, -height1/2]) > >>>      { rotate([0, -90, 90]) > >>>        { linear_extrude(diam1) > >>>          { difference() > >>>            { square([cornRad1, cornRad1]); > >>> > >>>              translate([cornRad1, cornRad1]) > >>>                circle(r=cornRad1); > >>>            } > >>>          } > >>>        } > >>>      } > >>> > >>>      //väggen bakom cylindern som ska rundas > >>>      translate([0, diam1/2-cornRad1, 0]) > >>>        cube([wide1, cornRad1, height1], center=true); > >>> > >>>    } > >>> > >>> > >>>    // Avrunda hörn1 bak > >>>    translate([-wide1/2, cornRad1/2, cornRad1]) > >>>    { hull() > >>>      { cylinder(h=height1+opt1, r=cornRad1, center=true); > >>>        {  translate([0, 0, -height1/2]) > >>>            sphere(r=cornRad1); > >>>        } > >>>      } > >>>    } > >>> > >>>    // Avrunda hörn2 bak > >>>    translate([wide1/2, cornRad1/2, cornRad1]) > >>>    { hull() > >>>      { cylinder(h=height1+opt1, r=cornRad1, center=true); > >>>        {  translate([0, 0, -height1/2]) > >>>            sphere(r=cornRad1); > >>>        } > >>>      } > >>>    } > >>> > >>> > >>>    // Plocka bort rundad fot bak samt det som sticker ut > >>>    translate([-wide1/2, diam1/2-cornRad1/2, -height1/2-opt1]) > >>>      cube([wide1, diam1/2+cornRad1, height1+opt1*2], center=false); > >>> > >>>  } > >>> } > >>> > >>> > >>> > >>> > >>> > >>> module ovalCableHole(posX, posY, posZ) > >>> { // Hål 5.5 x 3.5 mm > >>>  pan = 0.1; > >>>  cableHi = 1.5; > >>> > >>>  translate([posX, posY, posZ]) > >>>  { color("white") > >>>    { translate([0, 0, -pan]) > >>>      { cylinder(h=cableHi, d=3.5); > >>>        //#translate([0, 0, 0]) cylinder(h=10, d=1); > >>>        //translate([0, 0, -1]) cylinder(h=1, d1=0, d2=1); > >>>        //translate([0, 0, 0]) sphere(d=1); // Inre kulan > >>>        //translate([0, 0, 1.5]) sphere(d=1); // Inre kulan > >>> > >>>        translate([0, 0, -1]) sphere(d=0.8); // yttre kulan > >>>        translate([0, 0, 2.5]) sphere(d=0.8); // yttre kulan > >>> > >>>      } > >>>      translate([2, 0, -pan]) > >>>      { cylinder(h=cableHi, d=3.5); > >>>        // #translate([0, 0, -cableHi*2]) cylinder(h=10, d=0.5); > >>>        //translate([0, 0, 0]) sphere(d=1); // Inre kulan > >>>        //translate([0, 0, 1.5]) sphere(d=1); // Inre kulan > >>> > >>>        translate([0, 0, -1]) sphere(d=0.8); // yttre kulan > >>>        translate([0, 0, 2.5]) sphere(d=0.8); // yttre kulan > >>> > >>>      } > >>>      translate([-3.5/2, 0, -pan]) > >>>        cube([5.5, 3.5/2, cableHi]); > >>>      translate([-0.25, -1.74, -pan]) > >>>        cube([2.5, 1.75, cableHi]); > >>>    } > >>>  } > >>> } > >>> > >>> > >>> > >>> > >>> > >>> > >>> module rundadFot() > >>> { > >>>  // specifika värden för skruvdistansen bak > >>>  wallH = 10.5; > >>> > >>>  wide1  = 12; // endast runt cylindern > >>>  wide2  = 34; // hela väggen > >>>  deep1    =  4; > >>>  height1  = 10; > >>>  cornRad1  =  2; > >>>  diam1 = 8; > >>>  opt1 = 0.1; > >>> > >>> > >>>  color("magenta") > >>>  { translate([0, 0, wallH]) > >>>    { difference() > >>>      { union() > >>>        { // Bakgavel > >>>          translate([wide2/2, opt1, height1/2]) > >>>          { rotate([90, 180, 0]) > >>>              cube([wide2, height1, opt1]); > >>>          } > >>> > >>>          // Golv > >>>          translate([wide2/2, -height1+opt1, -height1/2]) > >>>            rotate([0, 180, 0]) > >>>              cube([wide2, height1, opt1]); > >>> > >>>          //väggen bakom cylindern som kan rundas > >>>          translate([0, -cornRad1/2, 0]) > >>>            cube([wide1, cornRad1, height1], center=true); > >>> > >>>          //själva cylindern > >>>          translate([0, -cornRad1/2, 0]) > >>>            cylinder(h=height1, d=diam1, center=true); > >>> > >>>          // Rundad fot under cylinder ovan > >>>          translate([0, -cornRad1/2, -height1/2]) > >>>          { rotate_extrude() > >>>            { translate([diam1/2, 0, 0]) > >>>              { difference() > >>>                { square([cornRad1, cornRad1]); > >>> > >>>                  translate([cornRad1, cornRad1]) > >>>                    circle(r=cornRad1); > >>>                } > >>>              } > >>>            } > >>>          } > >>> > >>>          // Rundad stäcka mellan t.ex. vägg och tak -bakkant > >>>          translate([wide2/2, 0, -height1/2]) > >>>          { rotate([90, 0, -90]) > >>>            { linear_extrude(wide2) > >>>              { difference() > >>>                { square([cornRad1, cornRad1]); > >>> > >>>                  translate([cornRad1, cornRad1]) > >>>                    circle(r=cornRad1); > >>>                } > >>>              } > >>>            } > >>>          } > >>> > >>>          // rundad stäcka mellan t.ex. vägg och tak -sida1 > >>>          translate([-wide2/2, 0, -height1/2]) > >>>          { rotate([90, 0, 0]) > >>>            { linear_extrude(10) > >>>              { difference() > >>>                { square([cornRad1, cornRad1]); > >>> > >>>                  translate([cornRad1, cornRad1]) > >>>                  circle(r=cornRad1); > >>>                } > >>>              } > >>>            } > >>>          } > >>> > >>>          // rundad stäcka mellan t.ex. vägg och tak -sida2 > >>>          translate([wide2/2, -10, -height1/2]) > >>>          { rotate([90, 0, 180]) > >>>            { linear_extrude(10) > >>>              { difference() > >>>                { square([cornRad1, cornRad1]); > >>> > >>>                  translate([cornRad1, cornRad1]) > >>>                  circle(r=cornRad1); > >>>                } > >>>              } > >>>            } > >>>          } > >>>        } // Avsluta union = = = = = = = = = = = = = = = = = = = = > >>> > >>> > >>>        // Avrunda hörn1 bak > >>>        translate([-wide1/2+opt1*1.3, -deep1/2, cornRad1]) > >>>        { cylinder(h=height1+opt1, r=cornRad1, center=true); > >>>            translate([0, 0, -height1/2]) > >>>              sphere(r=cornRad1); > >>>        } > >>> > >>>        // Avrunda hörn2 bak > >>>        translate([wide1/2-opt1*1.3, -deep1/2, cornRad1]) > >>>        { cylinder(h=height1+opt1, r=cornRad1, center=true); > >>>            translate([0, 0, -height1/2]) > >>>              sphere(r=cornRad1); > >>>        } > >>> > >>>        // Plocka bort rundad fot bak samt det som sticker ut > >>>        translate([-wide1/2, 0, -height1/2-opt1]) > >>>          cube([wide1, diam1/2+cornRad1, height1+opt1*2], center=false); > >>>      } > >>>    } > >>>  } > >>> } > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> module mainBox(box_l, box_w, box_h, spaceHold, round_r, thick, smooth, pad) > >>> { translate([box_l/2-thick-offset1/2, box_w/2-spaceHold, box_h/2]) > >>>  { > >>>    // To fix the corners cut the main cube with smaller cubes with spheres removed > >>>    difference() > >>>    { cube([box_l, box_w, box_h], center = true); > >>> > >>>      // Kant1 - liggande > >>>      translate([0, -box_w/2+round_r, box_h/2-round_r]) > >>>      { difference() > >>>        { translate([0,-round_r-pad,round_r+pad]) > >>>            cube([box_l+2*pad, round_r*2+pad, round_r*2+pad], center = true); > >>>          rotate(a=[0,90,0]) > >>>            cylinder(box_l+4*pad,round_r,round_r,center=true,$fn=smooth); > >>>        } > >>>      } > >>>      // Kant2 - liggande > >>>      translate([0, box_w/2-round_r, box_h/2-round_r]) > >>>      { difference() > >>>        { translate([0,round_r+pad,round_r+pad]) > >>>            cube([box_l+2*pad, round_r*2+pad, round_r*2+pad], center = true); > >>>          rotate(a=[0,90,0]) > >>>            cylinder(box_l+4*pad,round_r,round_r,center=true,$fn=smooth); > >>>        } > >>>      } > >>>      /* > >>>      // Kant3 - liggande > >>>      translate([0, -box_w/2+round_r, -box_h/2+round_r]) > >>>      { difference() > >>>        { translate([0,-round_r-pad,-round_r-pad]) > >>>            cube([box_l+2*pad, round_r*2+pad, round_r*2+pad], center = true); > >>>          rotate(a=[0,90,0]) > >>>            cylinder(box_l+4*pad,round_r,round_r,center=true,$fn=smooth); > >>>        } > >>>      } > >>> > >>>      // Kant4 - liggande > >>>      translate([0, box_w/2-round_r, -box_h/2+round_r]) > >>>      { difference() > >>>        { translate([0,round_r+pad,-round_r-pad]) > >>>            cube([box_l+2*pad, round_r*2+pad, round_r*2+pad], center = true); > >>>          rotate(a=[0,90,0]) > >>>            cylinder(box_l+4*pad,round_r,round_r,center=true,$fn=smooth); > >>>        } > >>>      } > >>>    */ > >>>    // ---- > >>>      // Kant1 - stående > >>>      translate([-box_l/2+round_r, box_w/2-round_r, 0]) > >>>      { difference() > >>>        { translate([-round_r-pad,round_r+pad,0]) > >>>            cube([round_r*2+pad, round_r*2+pad, box_h+2*pad], center = true); > >>>          cylinder(box_h+4*pad,round_r,round_r,center=true,$fn=smooth); > >>>        } > >>>      } > >>>      // Kant2 - stående > >>>      translate([box_l/2-round_r, box_w/2-round_r, 0]) > >>>      { difference() > >>>        { translate([round_r+pad,round_r+pad,0]) > >>>            cube([round_r*2+pad, round_r*2+pad, box_h+2*pad], center = true); > >>>          cylinder(box_h+4*pad,round_r,round_r,center=true,$fn=smooth); > >>>        } > >>>      } > >>>      // Kant3 - stående > >>>      translate([-box_l/2+round_r, -box_w/2+round_r, 0]) > >>>      { difference() > >>>        { translate([-round_r-pad,-round_r-pad,0]) > >>>            cube([round_r*2+pad, round_r*2+pad, box_h+2*pad], center = true); > >>>          cylinder(box_h+4*pad,round_r,round_r,center=true,$fn=smooth); > >>>        } > >>>      } > >>>      // Kant4 - stående > >>>      translate([box_l/2-round_r, -box_w/2+round_r, 0]) > >>>      { difference() > >>>        { translate([round_r+pad,-round_r-pad,0]) > >>>            cube([round_r*2+pad, round_r*2+pad, box_h+2*pad], center = true); > >>>          cylinder(box_h+4*pad,round_r,round_r,center=true,$fn=smooth); > >>>        } > >>>      } > >>> > >>>    // ---- > >>>      // Kant1 liggande (andra hållet) > >>>      translate([-box_l/2+round_r, 0, box_h/2-round_r]) > >>>      { difference() > >>>        { translate([-round_r-pad, 0, round_r+pad]) > >>>            cube([round_r*2+pad, box_w+2*pad, round_r*2+pad], center = true); > >>>          rotate(a=[0,90,90]) > >>>            cylinder(box_w+4*pad,round_r,round_r,center=true,$fn=smooth); > >>>        } > >>>      } > >>>      // Kant2 liggande (andra hållet) > >>>      translate([box_l/2-round_r, 0, box_h/2-round_r]) > >>>      { difference() > >>>        {  translate([round_r+pad, 0, round_r+pad]) > >>>            cube([round_r*2+pad, box_w+2*pad, round_r*2+pad], center = true); > >>>          rotate(a=[0,90,90]) > >>>            cylinder(box_w+4*pad,round_r,round_r,center=true,$fn=smooth); > >>>        } > >>>      } > >>>      /* > >>>      // Kant3 liggande (andra hållet) > >>>      translate([-box_l/2+round_r, 0, -box_h/2+round_r]) > >>>      { difference() > >>>        { translate([-round_r-pad, 0, -round_r-pad]) > >>>            cube([round_r*2+pad, box_w+2*pad, round_r*2+pad], center = true); > >>>          rotate(a=[0,90,90]) > >>>            cylinder(box_w+4*pad,round_r,round_r,center=true,$fn=smooth); > >>>        } > >>>      } > >>> > >>>      // Kant4 liggande (andra hållet) > >>>      translate([box_l/2-round_r, 0, -box_h/2+round_r]) > >>>      { difference() > >>>        { translate([round_r+pad, 0, -round_r-pad]) > >>>            cube([round_r*2+pad, box_w+2*pad, round_r*2+pad], center = true); > >>>          rotate(a=[0,90,90]) > >>>            cylinder(box_w+4*pad,round_r,round_r,center=true,$fn=smooth); > >>>        } > >>>      } > >>>  */ > >>>    // ---- > >>>      // Hörn1 (övre) > >>>      translate([box_l/2-round_r, box_w/2-round_r, box_h/2-round_r]) > >>>      { difference() > >>>        { translate([round_r+pad, round_r+pad, round_r+pad]) > >>>            cube([round_r*2+pad, round_r*2+pad, round_r*2+pad], center = true); > >>>          sphere(round_r,$fn=smooth); > >>>        } > >>>      } > >>>      // Hörn2 (övre) > >>>      translate([-box_l/2+round_r, box_w/2-round_r, box_h/2-round_r]) > >>>      { difference() > >>>        { translate([-round_r-pad, round_r+pad, round_r+pad]) > >>>            cube([round_r*2+pad, round_r*2+pad, round_r*2+pad], center = true); > >>>          sphere(round_r,$fn=smooth); > >>>        } > >>>      } > >>>      // Hörn3 (övre) > >>>      translate([box_l/2-round_r, -box_w/2+round_r, box_h/2-round_r]) > >>>      { difference() > >>>        { translate([round_r+pad, -round_r-pad, round_r+pad]) > >>>            cube([round_r*2+pad, round_r*2+pad, round_r*2+pad], center = true); > >>>          sphere(round_r,$fn=smooth); > >>>        } > >>>      } > >>>      // Hörn4 (övre) > >>>      translate([-box_l/2+round_r, -box_w/2+round_r, box_h/2-round_r]) > >>>      { difference() > >>>        { translate([-round_r-pad, -round_r-pad, round_r+pad]) > >>>            cube([round_r*2+pad, round_r*2+pad, round_r*2+pad], center = true); > >>>          sphere(round_r,$fn=smooth); > >>>        } > >>>      } > >>>      /* > >>>      // Hörn1 (undre) > >>>      translate([box_l/2-round_r, box_w/2-round_r, -box_h/2+round_r]) > >>>      { difference() > >>>        { translate([round_r+pad, round_r+pad, -round_r-pad]) > >>>            cube([round_r*2+pad, round_r*2+pad, round_r*2+pad], center = true); > >>>          sphere(round_r,$fn=smooth); > >>>        } > >>>      } > >>>      // Hörn2 (undre) > >>>      translate([-box_l/2+round_r, box_w/2-round_r, -box_h/2+round_r]) > >>>      { difference() > >>>        { translate([-round_r-pad, round_r+pad, -round_r-pad]) > >>>            cube([round_r*2+pad, round_r*2+pad, round_r*2+pad], center = true); > >>>          sphere(round_r,$fn=smooth); > >>>        } > >>>      } > >>>      // Hörn3 (undre) > >>>      translate([box_l/2-round_r, -box_w/2+round_r, -box_h/2+round_r]) > >>>      { difference() > >>>        { translate([round_r+pad, -round_r-pad, -round_r-pad]) > >>>            cube([round_r*2+pad, round_r*2+pad, round_r*2+pad], center = true); > >>>          sphere(round_r,$fn=smooth); > >>>        } > >>>      } > >>>      // Hörn4 (undre) > >>>      translate([-box_l/2+round_r, -box_w/2+round_r, -box_h/2+round_r]) > >>>      { difference() > >>>        { translate([-round_r-pad, -round_r-pad, -round_r-pad]) > >>>            cube([round_r*2+pad, round_r*2+pad, round_r*2+pad], center = true); > >>>          sphere(round_r,$fn=smooth); > >>>        } > >>>      } > >>>      */ > >>>    } > >>>  } > >>> } > >>> // > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> module cableHolder3(posX, posY, posZ, length, width, height, radius) > >>> { // Skapa toppen över switchen > >>>  // mått på Switchen > >>>  fn = 96;          // upplösning (endast bågen?) > >>>  heightHold = 10.5; > >>>  widthHold = 33.5; > >>>  depthHold = 23.5; > >>>  holdRadie = 1.5;  // radie i hörnen > >>>  thick = 1.5;      // tjocklek > >>> > >>> > >>>  translate([0,-thick,0]) > >>>  { > >>>    difference(0, 0, 0) > >>>    { hull() > >>>      { difference() > >>>        { translate([thick, 0, heightHold]) // vänster kant > >>>          { rotate([-90, 0, 0]) > >>>            { cylinder(h=depthHold, d=thick*2); > >>>              translate([0, 0, depthHold]) > >>>                sphere(d=thick*2);          // längst fram > >>>            } > >>>          } > >>>          translate([0, -0.1, heightHold]) // plocka bort underdelen > >>>            rotate([-90, 0, 0]) > >>>              cube([thick*2, thick+.1, depthHold+thick+.1]); > >>>        } > >>> > >>>        difference() > >>>        { translate([widthHold-thick, 0, heightHold]) // höger kant > >>>          { rotate([-90, 0, 0]) > >>>            { cylinder(h=depthHold, d=thick*2); > >>>              translate([0, 0, depthHold]) > >>>                sphere(d=thick*2);        // längst fram > >>>            } > >>>          } > >>>          translate([widthHold-thick*2, -0.1, heightHold]) // plocka bort underdelen > >>>          { rotate([-90, 0, 0]) > >>>              cube([thick*2, thick+.1, depthHold+thick+.1]); > >>>          } > >>>        } > >>>      } > >>> > >>>      // öppna hålen för monteringsskruvarna uppe på plattan > >>>      translate([4, 13.5, 0]) > >>>        cylinder(h=15,d=3.2); > >>>      translate([4, 13.5, 17.3]) > >>>        sphere(r=6); > >>> > >>>      translate([29.6, 13.5, 0]) > >>>        cylinder(h=15,d=3.2); > >>> > >>>      translate([29.6, 13.5, 17.3]) > >>>        sphere(r=6); > >>>    } > >>> > >>>    // halvbåge 1 bak > >>>    translate([thick, 0, heightHold/2+thick/2]) > >>>      rotate([0, 90, 180]) > >>>        rotate_extrude(angle = 180, convexity=20, $fn=64) > >>>    translate([heightHold/2-thick/2, 0, 0]) > >>>      circle(d=thick*2); > >>>    translate([thick, 0, heightHold]) > >>>      sphere(d=thick*2);  // övre kulan > >>>    translate([thick, 0, thick]) > >>>      sphere(d=thick*2);  // undre kulan > >>> > >>> > >>>    // halvbåge 2 bak > >>>    translate([widthHold-thick, 0, heightHold/2+thick/2]) > >>>      rotate([0, 90, 180]) > >>>        rotate_extrude(angle = 180, convexity=20, $fn=64) > >>>    translate([heightHold/2-thick/2, 0, 0]) > >>>      circle(d=thick*2); > >>>    translate([widthHold-thick, 0, heightHold]) > >>>      sphere(d=thick*2);  // övre kulan > >>>    translate([widthHold-thick, 0, thick]) > >>>      sphere(d=thick*2);  // undre kulan > >>> > >>>    // en cylinder tvärsöver längst upp > >>>    translate([thick, 0, heightHold]) > >>>    { rotate([0,90,0]) > >>>        cylinder(h=widthHold-thick*2, r=thick); > >>>    } > >>>  } > >>> > >>>  // Halvbågen (kabelhållaren) på baksidan switchen > >>>  translate([widthHold-thick, -thick, heightHold/2+thick/2]) > >>>  { rotate([0,90,180]) > >>>      linear_extrude(widthHold-thick*2) > >>>        arc(heightHold/2-thick/2, [0, 180], thick, fn); //radius, angles, width, fn) > >>>  } > >>>  // en cylinder tvärsöver längst ned > >>>  translate([thick, -thick, thick]) > >>>  { rotate([0,90,0]) > >>>      cylinder(h=widthHold-thick*2, r=thick); > >>>  } > >>> } > >>> > >>> > >>> > >>> module switch(posX=0, posY=0, posZ=0) > >>> { buttRadie = 1.5; > >>>  height = 10.5; > >>>  width = 33.5; > >>>  depth = 23.5; > >>>  h1x = buttRadie; > >>>  h1y = buttRadie; > >>>  h2x = width-buttRadie; > >>>  h2y = buttRadie; > >>>  h3x = width-buttRadie; > >>>  h3y = depth-buttRadie; > >>>  h4x = buttRadie; > >>>  h4y = depth-buttRadie; > >>> > >>>  translate([posX, posY, posZ]) > >>>  { difference() > >>>    { color("#F9F9F3") > >>>        // tryck-knappen > >>>      union() > >>>      { translate([width/2, depth+6-0.1, height/2]) > >>>        { rotate([90, 0, 0]) > >>>          { translate([0,0,6]) > >>>              circle(d=6.8);  // skuggan runt knapp > >>>            cylinder(h=6, d=6); > >>>            sphere(d=6); > >>>          } > >>>        } > >>> > >>>        hull()  // Switchkropp > >>>        { translate([h1x, h1y]) > >>>            cylinder(h=height, r=1.5); > >>>          translate([h2x, h2y]) > >>>            cylinder(h=height, r=1.5); > >>>          translate([h3x, h3y]) > >>>            cylinder(h=height, r=1.5); > >>>          translate([h4x, h4y]) > >>>            cylinder(h=height, r=1.5); > >>>        } > >>>      } > >>> > >>>      // Skruvhålen för switchen > >>>      hole( 4, 12, 0, "#FFD700", height); > >>>      hole(29.6, 12, 0, "#FFD700", height); > >>>      // hole( 4, 12, 0, "#FFD700", 50); > >>>      // hole(29.6, 12, 0, "#FFD700", 50); > >>>      // hål för kablar bak > >>>      color("gray") > >>>      { translate([9.5, 16, height/2]) > >>>        { rotate([90, 0, 0]) > >>>            cylinder(h=16.5, d=4); > >>>        } > >>>        translate([24.5, 16, height/2]) > >>>        {  rotate([90, 0, 0]) > >>>            cylinder(h=16.5, d=4); > >>>        } > >>>      } > >>> > >>>      // hål för kabelskruvar > >>>      color("white") > >>>      { translate([29.5, 17.1, height/2]) > >>>        { rotate([0, 90, 0]) > >>>            cylinder(h=4.1, d=4.5); > >>>        } > >>>        translate([-0.1, 17.1, height/2]) > >>>        { rotate([0, 90, 0]) > >>>            cylinder(h=4.1, d=4.5); > >>>        } > >>>      } > >>>    } > >>> > >>>    // Kabelskruvar > >>>    cableScrew(3, 17, height/2, 90); > >>>    cableScrew(31, 17, height/2, -90); > >>> > >>>  } > >>> } > >>> > >>> // Skruven som håller fast kabeln i switchen > >>> module cableScrew(posX=0, posY=0, posZ=0, angle=0) > >>> { color("#FFD700")  // mässing > >>>  translate([posX, posY, posZ]) > >>>  { rotate([0, 0, angle]) > >>>    { difference() > >>>      { // skruvskalle > >>>        translate([0, 0, 0]) > >>>          rotate([90, 0, 0]) > >>>            cylinder(h=2, d1=4, d2=3.5); > >>> > >>>        // stjärnan i skruven > >>>        translate([0, 1.85, -.25]) > >>>          rotate([0, 0, 0]) > >>>            cylinder(h=0.5, d=5); > >>>        translate([-0.25, -.6, 2.25]) > >>>          rotate([0, 90, 0]) > >>>            cube([4.5, 2, 0.5]); > >>>      } > >>>    } > >>>  } > >>> } > >>> > >>> > >>> > >>> // borrhål > >>> module hole(posX=0, posY=0, posZ=0, colorName="yellow", height) > >>> { diamHole1 = 3; > >>>  highHole1 = height; > >>>  diamHole2 = 6; > >>>  highHole2 = 2.5; > >>>  offs=0.1; > >>> > >>>  color(colorName) > >>>  { > >>>    translate([posX, posY, posZ]) > >>>    { translate([0, 0, 0]) > >>>        cylinder(h=highHole1, d=diamHole1); > >>>      translate([0, 0, -offs]) > >>>        cylinder(h=highHole2, d=diamHole2); > >>>      translate([0, 0, height-highHole2+offs]) > >>>        cylinder(h=highHole2, d=diamHole2); > >>>    } > >>>  } > >>> } > >>> > >>> module showCables() > >>> { translate([-25,8,24]) > >>>    rotate([80,177,90]) > >>>      cable(10,10,0,"brun"); > >>>  translate([-43,8,15]) > >>>    rotate([90,180,90]) > >>>      cable(10,10,0,"blå"); > >>> } > >>> > >>> > >>> module cable(posX=0, posY=0, posZ=0, colorName="blå", radius=1.26, width=0.62, thick=50, fn=24) > >>> { // default 1.5mm2 > >>>  // radius = inner radie > >>>  // width = bredd/tjocklek på cirkeln (inte höjd) > >>>  // thick = höjd på cirken/ röret > >>>  // pin= > >>> > >>>  colCupper = "#D7715A"; > >>>  colGreen  = "#07DA63"; > >>>  colYellow = "#FFCC00"; > >>> > >>>  if (colorName=="gröngul") > >>>  { translate([posX, posY, posZ]) > >>>    { color(colGreen) > >>>        linear_extrude(thick) > >>>          arc(radius, [0, 60], width, fn); > >>>      color(colYellow) > >>>        linear_extrude(thick) > >>>          arc(radius, [60, 180], width, fn); > >>>      color(colGreen) > >>>        linear_extrude(thick) > >>>          arc(radius, [180, 240], width, fn); > >>>      color(colYellow) > >>>        linear_extrude(thick) > >>>          arc(radius, [240, 360], width, fn); > >>> > >>>      color(colCupper) > >>>        linear_extrude(10, center=true, convexity=10, $fn=100) > >>>          circle(d=1.24); > >>>    } > >>>  } > >>>  else  // vanliga kablar 1.5mm2 > >>>  { > >>>    cableColor = colorName == "blå" ? "#1870D5" > >>>                : colorName == "brun" ? "#9C6137" > >>>                : colorName == "svart" ? "#000000" > >>>                : assert(false,"invalid color value");  // message if no case worked > >>>            // : nodef > >>> > >>>    translate([posX, posY, posZ]) > >>>    {            //el kabel - ena änden rak - andra böjd > >>>      color(colCupper)    //kopparstump tråd rakkabel > >>>        linear_extrude(10, center=true, convexity=10, $fn=100) > >>>          circle(d=1.24); > >>> > >>>        color(cableColor) > >>>        { cylinder(h=thick, r=radius); > >>> > >>>        translate([-radius*2, 0, thick])  // kabelböj > >>>        rotate([90, 0, 0]) > >>>        rotate_extrude(angle=90, convexity=20) > >>>          translate([2.5, 0, 0]) > >>>            circle(r=1.26); > >>> > >>>        translate([-radius*2, 0, thick+radius*2]) > >>>          rotate([0, -90, 0]) > >>>          cylinder(h=5, r=radius); > >>>      } > >>>      translate([-10, 0, thick+radius*2]) > >>>      { rotate([0, -90, 0]) > >>>        { color(colCupper) > >>>          { linear_extrude(5, center=true, convexity=10, $fn=100) > >>>              circle(d=1.24); > >>>          } > >>>        } > >>>      } > >>>    } > >>>  } > >>> } > >>> > >>> > >>> // ====================================================================== > >>> module arc(radius, angles, width = 1, fn = 24) { > >>>    difference() { > >>>        sector(radius + width, angles, fn); // ytterradie > >>>        sector(radius, angles, fn);        // innerradie (plockar bort invändigt > >>>    } > >>> } > >>> > >>> module sector(radius, angles, fn = 24) { > >>>    r = radius / cos(180 / fn); > >>>    step = -360 / fn; > >>> > >>>    points = concat([[0, 0]], > >>>        [for(a = [angles[0] : step : angles[1] - 360]) > >>>            [r * cos(a), r * sin(a)] > >>>        ], > >>>        [[r * cos(angles[1]), r * sin(angles[1])]] > >>>    ); > >>> > >>>    difference() { > >>>        circle(radius, $fn = fn); > >>>        polygon(points); > >>>    } > >>> } > >>> = = END product 2 = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = > >>> - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - > >>> > >>> > >>> Den fredag 6 maj 2022 14:06:55 CEST, Michael Möller <private2michael@gmail.com> skrev: > >>> > >>> > >>> > >>> OpenSCAD code - is a description of your model in terms of a few cylinder/cubes added and cut out > >>> difference() { > >>>  cylinder(d=5,h=10); > >>>  translate([0,10,0]) cube([4,6,2]) ; > >>> } > >>> > >>> STL file is a list of triangles which make the same outer shell as your model. OpenSCAD makes this complicated transform from shapes to triangles. > >>> solid OpenSCAD_Model > >>>  facet normal 0.92388 0.382682 0 > >>>    outer loop > >>>      vertex 2.5 0 3 > >>>      vertex 1.76777 1.76777 0 > >>>      vertex 1.76777 1.76777 3 > >>>    endloop > >>>  endfacet > >>>  facet normal 0.92388 0.382682 0 > >>>    outer loop > >>>      vertex 1.76777 1.76777 0 > >>>      vertex 2.5 0 3 > >>>      vertex 2.5 0 0 > >>>    endloop > >>>  endfacet > >>>  : (and so on for 300 lines) There is a binary/compressed version, but the description is still just triangles. > >>> > >>> Gcode is what a 3D printer understands - it is the exact list of moves that the head has to do with how much plastic to squeeze to trace the outline of your shape, layer, by layer. It will optionally create moves for filling the inside or support for overhangs. Such a program is called a SLICER and the printer will come with one. > >>> G92 E0 ; reset extrusion distance > >>> G1 Z2.330 F6600.000 ; lift Z > >>> G1 X-0.000 Y1.505 F6600.000 ; move to first perimeter point > >>> G1 Z0.330 F6600.000 ; restore layer Z > >>> G1 E3.00000 F2400.00000 ; unretract extruder 0 > >>> G1 F1500 > >>> G1 X-1.064 Y1.064 E3.09259 ; perimeter > >>> G1 X-1.505 Y0.000 E3.18517 ; perimeter > >>>  : (many similar lines) > >>> G1 X1.515 Y1.515 E4.65860 ; perimeter > >>> G1 X0.055 Y2.120 E4.78559 ; perimeter > >>> G1 X-0.000 Y2.143 F6600.000 ; move inwards before travel > >>> G1 X0.384 Y0.843 F6600.000 ; move to first infill point > >>> G1 F1500 > >>> G1 X0.843 Y0.384 E4.84815 ; infill > >>> G1 X1.097 Y-0.229 E4.91215 ; infill > >>>  : > >>> (and so on for thousands of lines) > >>> > >>> The 3MF still basically deals in triangles, and attributes (surface, infill material, picture, ticket info ... ) which probably are not used by your slicer/printer. > >>> > >>> On Fri, 6 May 2022 at 12:37, Jan Öhman via Discuss <discuss@lists.openscad.org> wrote: > >>> > >>> > >>> > >>> > >>> ---------- Forwarded message ---------- > >>> From: "Jan Öhman" <jan_ohman@yahoo.com> > >>> To: OpenSCAD General Discussion <discuss@lists.openscad.org> > >>> Cc: > >>> Bcc: > >>> Date: Fri, 6 May 2022 10:38:46 +0000 (UTC) > >>> Subject: [OpenSCAD] Export to .STL / .3MF for later 3D-printing. > >>> Hi! > >>> > >>> Thought to create some objects in openSCAD, to print later. > >>> I do not have my own 3D printer (yet). > >>> > >>> One I talked to, wanted to get the drawings in .STL or .3MF. (I don't know the difference). > >>> > >>> If I had my own printer, have I been able to print directly from openSCAD? > >>> (Without some export?) > >>> > >>> In the openSCAD, no errors or problems occur. > >>> but > >>> The drawings I tested to export from openSCAD have given one or another error message. > >>> One message .: > >>> WARNING: Object may not be a valid 2-manifold and may need repair! > >>> > >>> Another message .: > >>> WARNING: No top level geometry to render > >>> > >>> What to do? > >>> > >>> > >>> > >>> ---------- Forwarded message ---------- > >>> From: "Jan Öhman via Discuss" <discuss@lists.openscad.org> > >>> To: OpenSCAD General Discussion <discuss@lists.openscad.org> > >>> Cc: "Jan Öhman" <jan_ohman@yahoo.com> > >>> Bcc: > >>> Date: Fri, 6 May 2022 10:38:46 +0000 (UTC) > >>> Subject: [OpenSCAD] Export to .STL / .3MF for later 3D-printing. > >>> _______________________________________________ > >>> OpenSCAD mailing list > >>> To unsubscribe send an email to discuss-leave@lists.openscad.org > >>> > >>> _______________________________________________ > >>> OpenSCAD mailing list > >>> To unsubscribe send an email to discuss-leave@lists.openscad.org > >>> > >>> > >>> > >>> ---------- Forwarded message ---------- > >>> From: "Jan Öhman via Discuss" <discuss@lists.openscad.org> > >>> To: OpenSCAD general discussion <discuss@lists.openscad.org> > >>> Cc: "Jan Öhman" <jan_ohman@yahoo.com> > >>> Bcc: > >>> Date: Sat, 7 May 2022 11:04:31 +0000 (UTC) > >>> Subject: [OpenSCAD] Re: Export to .STL / .3MF for later 3D-printing. > >>> _______________________________________________ > >>> OpenSCAD mailing list > >>> To unsubscribe send an email to discuss-leave@lists.openscad.org > >> > >> _______________________________________________ > >> OpenSCAD mailing list > >> To unsubscribe send an email to discuss-leave@lists.openscad.org > > > > _______________________________________________ > > OpenSCAD mailing list > > To unsubscribe send an email to discuss-leave@lists.openscad.org > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > > > ---------- Forwarded message ---------- > From: "Jan Öhman via Discuss" <discuss@lists.openscad.org> > To: OpenSCAD general discussion <discuss@lists.openscad.org> > Cc: "Jan Öhman" <jan_ohman@yahoo.com> > Bcc: > Date: Sat, 7 May 2022 21:38:31 +0000 (UTC) > Subject: [OpenSCAD] Re: Export to .STL / .3MF for later 3D-printing. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org _______________________________________________ OpenSCAD mailing list To unsubscribe send an email to discuss-leave@lists.openscad.org
