Test example from RepRapPro
http://forum.openscad.org/file/n13392/screen4.png
If you want to try this build you will need to build from source
https://github.com/bobc/openscad/tree/carve_csg. I have only built linux
version so far, I will look at building a windows version later. Bear in
mind this is work in progress, not even really an alpha version.
Several things have been lost in the Carve implementation, notably 3D hull
and minkowski, as well as output to OFF, PLY. Other things that depend on
unique features of CGAL will have stopped working too. The triangulation is
buggy too, I need to implement a better triangulator.
View this message in context: http://forum.openscad.org/Now-in-color-tp13392.html
Nice.
You may need a method to ignore the separate colours and just do one STL,
for when color() is used for display/documentary reasons rather than
multi-material.
View this message in context: http://forum.openscad.org/Now-in-color-tp13392p13399.html
On 2 August 2015 at 07:38, MichaelAtOz oz.at.michael@gmail.com wrote:
Nice.
multi-material.
Yes, I would like a settings dialog somewhere to select options for the
export. There are a number of ways to output to AMF for example, I picked
the method that is compatible with slic3r. As a consequence, color is a
proxy for material id, but it would be possible to have the same material
in different colors.
For a particular model, it might be useful to select which parts to export,
perhaps in an extended Export... dialog.
I would like to add a material property to the language, there is some
discussion about how this should be done. It would be good to have
something that is reasonably flexible and extensible which could also be
used for things like DXF layers.
At this point, there are a number of bugs, loose ends, and missing features
that I will work on. However, if there are any features people would like
to see relating to color, materials etc, now is a good time to let me know.
