B
bac1024
Wed, Feb 15, 2017 12:41 AM
I'm sure I've done things like this before, but this one is giving me issues,
I'm sure it's related to the rotate, but my objects are not lining up right
with my translate commands... Can someone tell me what's going on here, and
how to fix it?
(The first hinge works ok, but the second one, the pieces don't all move the
same....)
module Hinge(x,y,z,d){
$fn=25;
Dir= d==0?0:7;
Rot= d==0?0:180;
echo (Dir);
rotate([0,0,0]) translate([x,y,z]) cube([29,16,2],center=false);
rotate([0,90,0]) translate([x,y+20,z+(7-Dir)]) sphere(d=2,center=false);
union(){
rotate([0,0,0]) translate([x,y+16,z])
cube([7,4,2],center=false);
rotate([0,90,0]) translate([x,y+20,z])
cylinder(h=7,d=4,center=false);
rotate([0,90,0]) translate([x,y+20,z+Dir])
rotate([0,90,0]) translate([x,y+20,z+(22-Dir)])
union(){
rotate([0,0,0]) translate([x+15,y+16,z])
rotate([0,90,0]) translate([x,y+20,z+15])
rotate([0,90,0]) translate([x,y+20,z+15+Dir])
Hinge(0,0,0,1);
Hinge(40,0,0,1);
View this message in context: http://forum.openscad.org/I-can-t-figure-out-what-s-going-on-with-rotate-and-translate-tp20443.html
how to fix it?
same....)
$fn=25;
Dir= d==0?0:7;
Rot= d==0?0:180;
echo (Dir);
union(){
union(){
Hinge(0,0,0,1);
Hinge(40,0,0,1);
Wed, Feb 15, 2017 2:51 AM
As a generalisation, you want to do rotates before translates, particularly
when tilting cylinders.
$fn=25;
Dir= d==0?0:7;
Rot= d==0?0:180;
echo (Dir);
translate([x,y+20,z+(7-Dir)]) rotate([0,90,0])
union(){
translate([x,y+20,z])rotate([0,90,0])
translate([x+7,y+20,z+(7-Dir)])rotate([0,90,0])
translate([x+15,y+20,z+(7-Dir)])rotate([0,90,0])
union(){
translate([x+15,y+20,z]) rotate([0,90,0])
translate([x+15+7,y+20,z+(7-Dir)]) rotate([0,90,0])
Hinge(0,0,0,1);
Hinge(40,0,0,1);
You may need to fix the Dir bits...
View this message in context: http://forum.openscad.org/I-can-t-figure-out-what-s-going-on-with-rotate-and-translate-tp20443p20444.html
$fn=25;
Dir= d==0?0:7;
Rot= d==0?0:180;
echo (Dir);
union(){
union(){
Hinge(0,0,0,1);
Hinge(40,0,0,1);
B
bac1024
Wed, Feb 15, 2017 3:58 AM
ok, I'm confused now (ok, a little more?) You say to do the rotates before
the translates, but then you moved my rotates to after the translates?
View this message in context: http://forum.openscad.org/I-can-t-figure-out-what-s-going-on-with-rotate-and-translate-tp20443p20445.html
B
bac1024
Wed, Feb 15, 2017 5:06 AM
Ok, nevermind. I got it straightened out.... I think you meant to do the
rotates AFTER the translates, because otherwise the XYZ order is changed.
View this message in context: http://forum.openscad.org/I-can-t-figure-out-what-s-going-on-with-rotate-and-translate-tp20443p20446.html
Wed, Feb 15, 2017 5:14 AM
Sorry, I should have been clearer.
Operations apply to the child, and rotate() rotates around an axis.
translate() sphere() translates the sphere,
rotate() sphere() rotates the sphere, in it's place, so you don't see any
effect
rotate() translate() sphere(), moves the sphere away from the axis, then
rotates it on an axis
So what I meant by do rotates before, was to apply the rotate to the object,
rotate() object()
then translate it
translate()
rotate()
object();
Try thinking like the {} brackets are in place
translate() {
rotate() {
object();
Or try this code:
module cubeOrigin(col) {
color(col)
cube([10,15,10]);
color("red")
cylinder(d=1,h=10);
cubeOrigin("lightgreen");
rotate([0,0,90])
cubeOrigin("green");
translate([0,20,0])
cubeOrigin("lightblue");
rotate([0,0,90])
translate([0,20,0])
cubeOrigin("blue");
translate([0,40,0])
cubeOrigin("plum");
rotate([0,0,90])
translate([0,40,0])
cubeOrigin("purple");
translate([0,0,30]) { // move up a layer & reverse order of translate/rotate
translate([0,20,0])
translate([0,20,0])
rotate([0,0,90])
cubeOrigin("blue");
translate([0,40,0])
cubeOrigin("plum");
translate([0,40,0])
rotate([0,0,90])
http://forum.openscad.org/file/n20447/trans-rota.jpg
Note the red origin (at [0,0,0] before any transformations).
View this message in context: http://forum.openscad.org/I-can-t-figure-out-what-s-going-on-with-rotate-and-translate-tp20443p20447.html
effect
rotate() object()
then translate it
translate()
rotate()
object();
translate() {
rotate() {
object();
Or try this code:
color(col)
cube([10,15,10]);
color("red")
cylinder(d=1,h=10);
rotate([0,0,90])
translate([0,20,0])
rotate([0,0,90])
translate([0,20,0])
cubeOrigin("blue");
translate([0,40,0])
cubeOrigin("plum");
rotate([0,0,90])
translate([0,40,0])
translate([0,20,0])
translate([0,20,0])
rotate([0,0,90])
cubeOrigin("blue");
translate([0,40,0])
cubeOrigin("plum");
translate([0,40,0])
rotate([0,0,90])
<http://forum.openscad.org/file/n20447/trans-rota.jpg>
Jerry Davis
Wed, Feb 15, 2017 4:09 PM
you can also think of it this way.
the rightmost transformation gets done first, then the one to the left of
that, and so on.
Extra Ham Operator: K7AZJ
Registered Linux User: 275424
On Tue, Feb 14, 2017 at 10:14 PM, MichaelAtOz oz.at.michael@gmail.com
effect
object,
rotate() object()
then translate it
translate()
rotate()
object();
translate() {
rotate() {
object();
Or try this code:
color(col)
cube([10,15,10]);
color("red")
cylinder(d=1,h=10);
rotate([0,0,90])
translate([0,20,0])
rotate([0,0,90])
translate([0,20,0])
cubeOrigin("blue");
translate([0,40,0])
cubeOrigin("plum");
rotate([0,0,90])
translate([0,40,0])
translate/rotate
translate([0,20,0])
translate([0,20,0])
rotate([0,0,90])
cubeOrigin("blue");
translate([0,40,0])
cubeOrigin("plum");
translate([0,40,0])
rotate([0,0,90])
tp20443p20447.html
that, and so on.
*The most exciting phrase to hear in science - the one that heralds new
discoveries - is not "Eureka!" but "That's funny...".*- Isaac. Asimov
On Tue, Feb 14, 2017 at 10:14 PM, MichaelAtOz <oz.at.michael@gmail.com>
> effect
> object,
> rotate() object()
> then translate it
> translate()
> rotate()
> object();
> translate() {
> rotate() {
> object();
> Or try this code:
> color(col)
> cube([10,15,10]);
> color("red")
> cylinder(d=1,h=10);
> rotate([0,0,90])
> translate([0,20,0])
> rotate([0,0,90])
> translate([0,20,0])
> cubeOrigin("blue");
> translate([0,40,0])
> cubeOrigin("plum");
> rotate([0,0,90])
> translate([0,40,0])
> translate/rotate
> translate([0,20,0])
> translate([0,20,0])
> rotate([0,0,90])
> cubeOrigin("blue");
> translate([0,40,0])
> cubeOrigin("plum");
> translate([0,40,0])
> rotate([0,0,90])
> Admin - PM me if you need anything, or if I've done something stupid...
> Unless specifically shown otherwise above, my contribution is in the
> Public Domain; to the extent possible under law, I have waived all
> copyright and related or neighbouring rights to this work. Obviously
> inclusion of works of previous authors is not included in the above.
> tp20443p20447.html
B
bac1024
Thu, Feb 16, 2017 7:01 AM
heh, I actually did a test very similar to your graphic to figure out how all
of it worked. :) Thank you for your help.....
View this message in context: http://forum.openscad.org/I-can-t-figure-out-what-s-going-on-with-rotate-and-translate-tp20443p20463.html
