AN
Adam Nielsen
Wed, Jul 15, 2026 1:29 AM
Hi all,
Does anyone know why this code works fine in preview but won't render?
The straight part renders, but the round part at the bottom only
appears in preview mode and disappears when rendering. It gives me the
error during rendering:
ERROR: The given mesh is not closed! Unable to convert to CGAL_Nef_Polyhedron.
The same polygon works if I rotate it at different angles, but this
particular orientation doesn't seem to work.
If I reduce $fn to 51 or below then it works, but above 51 the part
fails to render. If I remove the straight part, then the round part
renders fine, but when the straight part is present the round part
won't render. If I comment out some of the translate/rotate lines for
the round part then it renders, but the exact combination I have causes
the error.
Can anyone see what the problem is?
Many thanks,
Adam.
$fn = 51;
gap = 0.01;
bezel_height = 4.1;
b_depth = 1 + 10.4 + 3.9;
profile = [
[0, 0],
[1, 0],
[1, 2],
[4.2, bezel_height],
[10.4, 2],
[10.4, 0],
[b_depth, 0],
[b_depth, 14.2],
[0, 14.2],
dims = [240, 133];
// Left
rotate([0, 0, 90])
translate([0, 0, -dims.y])
linear_extrude(height = dims.y)
polygon(profile);
// Bottom-left
translate([0, b_depth, -dims.y])
rotate([0, 0, 180])
rotate([0, 90, 0])
rotate_extrude(angle = 90)
translate([b_depth, 0, 0])
rotate([0, 180, 0])
polygon(profile);
Hi all,
the error.
Many thanks,
Adam.
$fn = 51;
gap = 0.01;
bezel_height = 4.1;
profile = [
[0, 0],
[1, 0],
[1, 2],
[10.4, 2],
[10.4, 0],
[b_depth, 0],
[b_depth, 14.2],
[0, 14.2],
dims = [240, 133];
// Left
rotate([0, 0, 90])
polygon(profile);
// Bottom-left
rotate([0, 0, 180])
rotate([0, 90, 0])
rotate([0, 180, 0])
polygon(profile);
Wed, Jul 15, 2026 2:33 AM
rotate([0, 180, 0])
polygon(profile);
You're rotating a 2D object around an axis other than Z. That's almost
never a good idea. However, it isn't obviously the problem.
My guess is that the endpoint of the 90-degree rotational extrusion
isn't perfect, and it is matching up poorly with the linear extrusion.
You might try turning things around so that the rotational extrusion
starts at the linear extrusion, rather than ending there. That
doesn't help if you're going to attach another linear extrusion on the
other side.
Having the linear and rotational extrusions overlap just a hair - say,
extending the linear extrusion by 0.01 - might help.
> rotate([0, 180, 0])
> polygon(profile);
*starts* at the linear extrusion, rather than *ending* there. That
other side.
CC
Cory Cross
Wed, Jul 15, 2026 3:03 AM
Hi all,
the error.
Many thanks,
Adam.
$fn = 51;
gap = 0.01;
bezel_height = 4.1;
profile = [
[0, 0],
[1, 0],
[1, 2],
[10.4, 2],
[10.4, 0],
[b_depth, 0],
[b_depth, 14.2],
[0, 14.2],
dims = [240, 133];
// Left
rotate([0, 0, 90])
polygon(profile);
// Bottom-left
rotate([0, 0, 180])
rotate([0, 90, 0])
rotate([0, 180, 0])
polygon(profile);
Try it with Manifold instead of CGAL.
On July 14, 2026 6:29:19 PM PDT, Adam Nielsen via Discuss <discuss@lists.openscad.org> wrote:
>Hi all,
>the error.
>Many thanks,
>Adam.
>$fn = 51;
>gap = 0.01;
>bezel_height = 4.1;
>profile = [
> [0, 0],
> [1, 0],
> [1, 2],
> [10.4, 2],
> [10.4, 0],
> [b_depth, 0],
> [b_depth, 14.2],
> [0, 14.2],
>dims = [240, 133];
>// Left
>rotate([0, 0, 90])
> polygon(profile);
>// Bottom-left
>rotate([0, 0, 180])
>rotate([0, 90, 0])
> rotate([0, 180, 0])
> polygon(profile);
>_______________________________________________
>OpenSCAD mailing list
>To unsubscribe send an email to discuss-leave@lists.openscad.org
Michael Marx (spintel)
Wed, Jul 15, 2026 3:19 AM
Also use the development snapshot*, it renders fine on the one I have installed.
From: Adam Nielsen via Discuss [mailto:discuss@lists.openscad.org]
Sent: Wednesday, July 15, 2026 11:29 AM
Cc: Adam Nielsen
Subject: [OpenSCAD] Preview works, but parts missing from render - "mesh is not closed"
Hi all,
the error.
Many thanks,
Adam.
$fn = 51;
gap = 0.01;
bezel_height = 4.1;
profile = [
[0, 0],
[1, 0],
[1, 2],
[10.4, 2],
[10.4, 0],
[b_depth, 0],
[b_depth, 14.2],
[0, 14.2],
dims = [240, 133];
// Left
rotate([0, 0, 90])
polygon(profile);
// Bottom-left
rotate([0, 0, 180])
rotate([0, 90, 0])
rotate([0, 180, 0])
polygon(profile);
* https://openscad.org/downloads.html#snapshots
> -----Original Message-----
> Cc: Adam Nielsen
> Hi all,
> the error.
> Many thanks,
> Adam.
> $fn = 51;
> gap = 0.01;
> bezel_height = 4.1;
> profile = [
> [0, 0],
> [1, 0],
> [1, 2],
> [10.4, 2],
> [10.4, 0],
> [b_depth, 0],
> [b_depth, 14.2],
> [0, 14.2],
> dims = [240, 133];
> // Left
> rotate([0, 0, 90])
> polygon(profile);
> // Bottom-left
> rotate([0, 0, 180])
> rotate([0, 90, 0])
> rotate([0, 180, 0])
> polygon(profile);
Wed, Jul 15, 2026 9:14 AM
and works fine in my (older version)
OpenSCAD https://www.openscad.org/version 2024.12.03 (git fc3aa54a4)
To:discuss@lists.openscad.org
Cc: Adam Nielsen
Hi all,
the error.
Many thanks,
Adam.
$fn = 51;
gap = 0.01;
bezel_height = 4.1;
profile = [
[0, 0],
[1, 0],
[1, 2],
[10.4, 2],
[10.4, 0],
[b_depth, 0],
[b_depth, 14.2],
[0, 14.2],
dims = [240, 133];
// Left
rotate([0, 0, 90])
polygon(profile);
// Bottom-left
rotate([0, 0, 180])
rotate([0, 90, 0])
rotate([0, 180, 0])
polygon(profile);
OpenSCAD <https://www.openscad.org/>version 2024.12.03 (git fc3aa54a4)
> *https://openscad.org/downloads.html#snapshots
>> Cc: Adam Nielsen
>> Hi all,
>> the error.
>> Many thanks,
>> Adam.
>> $fn = 51;
>> gap = 0.01;
>> bezel_height = 4.1;
>> profile = [
>> [0, 0],
>> [1, 0],
>> [1, 2],
>> [10.4, 2],
>> [10.4, 0],
>> [b_depth, 0],
>> [b_depth, 14.2],
>> [0, 14.2],
>> dims = [240, 133];
>> // Left
>> rotate([0, 0, 90])
>> polygon(profile);
>> // Bottom-left
>> rotate([0, 0, 180])
>> rotate([0, 90, 0])
>> rotate([0, 180, 0])
>> polygon(profile);
>> To unsubscribe send an email todiscuss-leave@lists.openscad.org
