Creating a 3D object from scratch + convert drawing into 3D file
CM
charles meyer
Mon, Jan 31, 2022 8:20 PM
Hi all,
Most of the prints we've done have been modifications of .stl files found
on Thingiverse.
We have modified them in Tinkercad.
Have you found Tinkercad the best place to create 3D prints from scratch?
I wathed this YT instructional video -
https://www.youtube.com/watch?v=60xfIu-lqAs...
which was very good but the instructor did not explain how he derived all
the measurements to create the 3 parts of that wrench.
Is there any Web site which helps you derive measurements for your 3D print?
Also, if a person draws a design is there any site or software you can use
to develop that drawing into a 3D file (e.g. .stl or .obj)?
Thank you!
Hi all, Most of the prints we've done have been modifications of .stl files found on Thingiverse. We have modified them in Tinkercad. Have you found Tinkercad the best place to create 3D prints from scratch? I wathed this YT instructional video - https://www.youtube.com/watch?v=60xfIu-lqAs... which was very good but the instructor did not explain how he derived all the measurements to create the 3 parts of that wrench. Is there any Web site which helps you derive measurements for your 3D print? Also, if a person draws a design is there any site or software you can use to develop that drawing into a 3D file (e.g. .stl or .obj)? Thank you!
F
fred
Mon, Jan 31, 2022 8:29 PM
Our makerspace members, one of whom is a heavy Tinkercad user, has found there is an upper limit to the number of triangles/facets permitted within the program. As a result, the efforts are going into Fusion 360 (Free hobbyist version) and also Rhino3D (for more organic creations, but not free).
You may also find people recommending Blender, which has a challenging learning curve, as well as recommending SketchUp, which is problematic for creating models that can be printed. There are others (Sculptris, ZBrush, etc.) of which I am familiar only in passing.
As you've posted to an OpenSCAD mailing list, certainly you'll find people using this program for ground-up creations. I've not heard of anyone doing 3D modeling in Scratch, but I'm not familiar with the program.
Meshmixer and Fusion 360 have measuring capability, the latter being more user friendly.
The Tinkercad user frequently requests of me to modify a model, as he is unable to accomplish his objective within Tinkercad.
Respective of your measurement question, Tinkercad will present dimensions of a bounding box of a component selected, but it's not always the dimension you require. OpenSCAD will have dimension references if the code is created in a parametric manner, but that's the creator's responsibility.
I've been using Fusion 360 more frequently, as I am slowly learning the various features and capabilities and combining that knowledge with Meshmixer, OpenSCAD, Inkscape (with Paths to OpenSCAD extension) and Tinkercad.
Your last question has multiple solutions. My preferred method is Inkscape (v0.92, no higher) with the extension, but one can use linear_extrude() as well. Fusion 360 certainly supports this type of feature.
On Monday, January 31, 2022, 03:15:03 PM EST, charles meyer <reachmeplace@gmail.com> wrote:
Hi all,
Thank you!
Our makerspace members, one of whom is a heavy Tinkercad user, has found there is an upper limit to the number of triangles/facets permitted within the program. As a result, the efforts are going into Fusion 360 (Free hobbyist version) and also Rhino3D (for more organic creations, but not free). You may also find people recommending Blender, which has a challenging learning curve, as well as recommending SketchUp, which is problematic for creating models that can be printed. There are others (Sculptris, ZBrush, etc.) of which I am familiar only in passing. As you've posted to an OpenSCAD mailing list, certainly you'll find people using this program for ground-up creations. I've not heard of anyone doing 3D modeling in Scratch, but I'm not familiar with the program. Meshmixer and Fusion 360 have measuring capability, the latter being more user friendly. The Tinkercad user frequently requests of me to modify a model, as he is unable to accomplish his objective within Tinkercad. Respective of your measurement question, Tinkercad will present dimensions of a bounding box of a component selected, but it's not always the dimension you require. OpenSCAD will have dimension references if the code is created in a parametric manner, but that's the creator's responsibility. I've been using Fusion 360 more frequently, as I am slowly learning the various features and capabilities and combining that knowledge with Meshmixer, OpenSCAD, Inkscape (with Paths to OpenSCAD extension) and Tinkercad. Your last question has multiple solutions. My preferred method is Inkscape (v0.92, no higher) with the extension, but one can use linear_extrude() as well. Fusion 360 certainly supports this type of feature. On Monday, January 31, 2022, 03:15:03 PM EST, charles meyer <reachmeplace@gmail.com> wrote: Hi all, Most of the prints we've done have been modifications of .stl files found on Thingiverse. We have modified them in Tinkercad. Have you found Tinkercad the best place to create 3D prints from scratch? I wathed this YT instructional video - https://www.youtube.com/watch?v=60xfIu-lqAs... which was very good but the instructor did not explain how he derived all the measurements to create the 3 parts of that wrench. Is there any Web site which helps you derive measurements for your 3D print? Also, if a person draws a design is there any site or software you can use to develop that drawing into a 3D file (e.g. .stl or .obj)? Thank you! _______________________________________________ OpenSCAD mailing list To unsubscribe send an email to discuss-leave@lists.openscad.org
DP
David Phillip Oster
Mon, Jan 31, 2022 8:36 PM
I do a lot of: photo -> Convert to vectors using Inkscape, save as SVG ->
import SVG into OpenSCAD and extrude.
I do more: measure physical objects with a metric digital caliper, and in
OpenSCAD write down a bunch of named constants.
On Mon, Jan 31, 2022 at 12:14 PM charles meyer reachmeplace@gmail.com
Hi all,
on Thingiverse.
print?
Thank you!
I do a lot of: photo -> Convert to vectors using Inkscape, save as SVG -> import SVG into OpenSCAD and extrude. I do more: measure physical objects with a metric digital caliper, and in OpenSCAD write down a bunch of named constants. On Mon, Jan 31, 2022 at 12:14 PM charles meyer <reachmeplace@gmail.com> wrote: > Hi all, > > Most of the prints we've done have been modifications of .stl files found > on Thingiverse. > > We have modified them in Tinkercad. > > Have you found Tinkercad the best place to create 3D prints from scratch? > > I wathed this YT instructional video - > https://www.youtube.com/watch?v=60xfIu-lqAs... > > which was very good but the instructor did not explain how he derived all > the measurements to create the 3 parts of that wrench. > > Is there any Web site which helps you derive measurements for your 3D > print? > > Also, if a person draws a design is there any site or software you can use > to develop that drawing into a 3D file (e.g. .stl or .obj)? > > Thank you! > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
Mon, Jan 31, 2022 10:28 PM
Yep, exactly that.  Except that I measure in English (because my models
are 1mm:1in) and sometimes it's large enough that I use a tape measure.
On 1/31/2022 12:36 PM, David Phillip Oster wrote: > I do more: measure physical objects with a metric digital caliper, and > in OpenSCAD write down a bunch of named constants. Yep, exactly that.  Except that I measure in English (because my models are 1mm:1in) and sometimes it's large enough that I use a tape measure.
