Overriding of user defined and non-user defined functions
adrian
Sun, Jan 25, 2015 6:44 PM
It is a bit scary that a user defined function can override a preexisting one
without some override keyword.  Especially if the language is growing and it
is possible that someone may define a function that is used in another
library which might cause unexpected results or if a user defines their own
function without realising that they had already defined it already.
Perhaps an override keyword could be added to indicate intent?  And without
it cause an error on compile?
Thanks,
View this message in context: http://forum.openscad.org/Overriding-of-user-defined-and-non-user-defined-functions-tp11242.html
It is a bit scary that a user defined function can override a preexisting one without some override keyword. Especially if the language is growing and it is possible that someone may define a function that is used in another library which might cause unexpected results or if a user defines their own function without realising that they had already defined it already. Perhaps an override keyword could be added to indicate intent? And without it cause an error on compile? Thanks, A -- View this message in context: http://forum.openscad.org/Overriding-of-user-defined-and-non-user-defined-functions-tp11242.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sun, Jan 25, 2015 10:03 PM
What is needed more is a way to call the built-in functions & modules [ie
cube() difference() etc] if they have been redefined. Or maybe call the next
lower version on the stack, thus having cascadable re-definitions. Sort of
like FORTH IIRC.
That would make it possible to override the default behavior.
(assuming the syntax is & to mean call the built-in)
module cube(v3,center) { // stupid example - all non centered cubes are red.
if (!center)
color("red")
&cube(v3,true)
else
&cube(v3,false);
View this message in context: http://forum.openscad.org/Overriding-of-user-defined-and-non-user-defined-functions-tp11242p11243.html
What is needed more is a way to call the built-in functions & modules [ie cube() difference() etc] if they have been redefined. Or maybe call the next lower version on the stack, thus having cascadable re-definitions. Sort of like FORTH IIRC. That would make it possible to override the default behavior. (assuming the syntax is & to mean call the built-in) module cube(v3,center) { // stupid example - all non centered cubes are red. if (!center) color("red") &cube(v3,true) else &cube(v3,false); } ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Overriding-of-user-defined-and-non-user-defined-functions-tp11242p11243.html Sent from the OpenSCAD mailing list archive at Nabble.com.
adrian
Tue, Jan 27, 2015 12:47 AM
That would help, but still, I want the intent to be perfectly clear that /"I,
the writer of this function/module, so do understand that I want to override
this function/module and do realize by doing so, I may totally shoot myself
in the foot."/
View this message in context: http://forum.openscad.org/Overriding-of-user-defined-and-non-user-defined-functions-tp11242p11250.html
That would help, but still, I want the intent to be perfectly clear that /"I, the writer of this function/module, so do understand that I want to override this function/module and do realize by doing so, I may totally shoot myself in the foot."/ A -- View this message in context: http://forum.openscad.org/Overriding-of-user-defined-and-non-user-defined-functions-tp11242p11250.html Sent from the OpenSCAD mailing list archive at Nabble.com.
