Fri, May 15, 2020 1:08 PM
I printed a 5/16" shaft in PLA and threaded it at 18 TPI with a die,
successfully. I then printed a similar shaft using NinjaTech's Cheetah,
and my attempts to put threads on that shaft have been laughable. It is
a tough and flexible material, which is why I like it, but threading it
is unlikely.
Has anyone had any success printing threads directly at resolutions like
this on a printer with an 0.4 mm nozzle?
Thanks!
is unlikely.
Thanks!
AG
Alex Gibson
Fri, May 15, 2020 1:13 PM
Hi Jon,
I'm not at all saying this would work - but if you already have the shaft printed in TPI/cheetah, would you be up for an experiment?
I would be interested to see if putting both the shaft and the die in the freezer overnight and repeating the attempt rapidly on removal might yield a better, if not 'good' result?
Cheers,
Alex Gibson
admg consulting
edumaker limited
• Project management
• Operations & Process improvement
• 3D Printing
From: Discuss [mailto:discuss-bounces@lists.openscad.org] On Behalf Of jon
Sent: 15 May 2020 14:08
Subject: [OpenSCAD] printing 5/16-18 threads
is unlikely.
Thanks!
Hi Jon,
Cheers,
Alex Gibson
admg consulting
edumaker limited
• 3D Printing
is unlikely.
Thanks!
Fri, May 15, 2020 4:31 PM
I have printed threaded containers without problems other than the first
item I printed with my own thread library came out with a left hand thread,
doh! East to fix.
I have also printed this https://www.thingiverse.com/thing:23030, which has
quite small threads, without problems.
On Fri, 15 May 2020 at 14:16, Alex Gibson alex@alexgibson.net wrote:
Hi Jon,
Cheers,
Alex Gibson
admg consulting
edumaker limited
• 3D Printing
is unlikely.
Thanks!
doh! East to fix.
On Fri, 15 May 2020 at 14:16, Alex Gibson <alex@alexgibson.net> wrote:
> Hi Jon,
> Cheers,
> Alex Gibson
> admg consulting
> edumaker limited
> • 3D Printing
> -----Original Message-----
> To: OpenSCAD general discussion
> is unlikely.
> Thanks!
> Jon
> This email has been checked for viruses by AVG.
> https://www.avg.com
Fri, May 15, 2020 4:51 PM
I froze a flexible part and managed to tap it, but attempts to use a die
on a rod have failed, even when frozen.
nop head: do you believe that print orientation is important when
printing threads? That is, better with the rod horizontal or vertical?
The vertical attempt failed, even on my Prusa MK3s
first item I printed with my own thread library came out with a left
hand thread, doh! East to fix.
https://www.thingiverse.com/thing:23030, which has quite small
mailto:alex@alexgibson.net> wrote:
Hi Jon,
Cheers,
Alex Gibson
> <mailto:alex@alexgibson.net>> wrote:
> Hi Jon,
> Cheers,
> Alex Gibson
Fri, May 15, 2020 8:18 PM
I printed 1/4-20 threading on a Prusa MK3 in PLA without any problems. They
worked great with each other and with matching metal hardware. Printed
them with bolts pointing up into the air and nuts in the same direction,
lying flat.
How did your print attempt fail? If you try to print threads horizontally
you're going to have a bunch of support problems. It might work with
interrupted threads, I guess.
lying flat.
arnholm@arnholm.org
Fri, May 15, 2020 8:34 PM
Cheetah, and my attempts to put threads on that shaft have been
laughable. It is a tough and flexible material, which is why I like
it, but threading it is unlikely.
like this on a printer with an 0.4 mm nozzle?
I have no idea what 5/16" means, but I have once designed and printed
(PLA) a M16 bolt and matching nut as a test for printing threads. It was
printed with a 0.3 mm nozzle.
https://www.thingiverse.com/thing:1445033
Fri, May 15, 2020 8:56 PM
5/16" in the diameter of the bolt in inches and the 18 is the threads per
inch. So roughly speaking it's about an M8-1.4 bolt.
Fri, May 15, 2020 9:19 PM
The first time I tried to print the rod vertically, using PLA and
without threads, it just snapped off. This time, with threads, and with
flexible filament, it printed to completion (although the top of the rod
was wobbling all over the place towards the end of the print). The
threads are recognizable, but there are enough small anomalies that it
is very difficult to screw into a nut. I tried to clean it up with a
die, but there was too much resistance.
lying flat.
> lying flat.
Fri, May 15, 2020 9:29 PM
My bolts are short, 20 mm including the head. But the threads are clean, no
need to do anything to get it to engage with other threaded parts other than
getting the tolerance right. Seems like if you need a really tall rod you
might have to support it from the side with some support structure, maybe?
I don't know. If you can't print a perfect 20mm long bolt then you need to
figure out what's wrong with your printer or filament. (I use Prusament
for my prints. Don't know how much difference that makes, but I have heard
that people experience more failures and problems with cheaper filament, and
I don't feel like messing around with that.)
There is the problem that a long tall rod will tend to be weak. I can't
snap my 20mm bolts by hand, but I wouldn't expect them to be particularly
strong, so if strength is critical, you need to do something different.
They
lying flat.
horizontally
>> They
>> lying flat.
>> horizontally
> Discuss@.openscad
Fri, May 15, 2020 10:13 PM
Why do you want a flexible bolt?
I often have problems with flexible prints wobbling. I think it needs a
dual filament machine so it can print a solid core that could be dissolved
out if the result needs to be flexible.
no
than
and
They
lying flat.
horizontally
> no
> than
> and
> >> They
> >> lying flat.
> >> horizontally
> die
> > Discuss@.openscad
