hello!
and thanks a lot for the help with the iaito, that one went really well!
this gave me the impulsion to try another one of my projects, i want to
make a hook, but at the moment i hit a performance problem....
i just started and i have preview rendering times of several minutes.....
i heavily suspect that there is a more efficient way to achieve this?
the sweep function needs polygons, but polygons, are, well, pointy.....
that's why i tried it with the 2D shapes and hull... but as is, dev on it
is very complicated..... and other than to buy a more powerful comp.....
this is what i tried:
radius = 15;
step = 5;
//quers(d1 = 2, d2 = 1.5*2, 2, maxb = 5);
for(angle = [0:step:110])
hull()
rotate([angle,0,0])
translate([0,radius,0])
linear_extrude(height = .1)quers(d1 = minrad(angle), d2 =
1.5minrad(angle), minrad(angle), maxb = 5);
rotate([angle+step,0,0])
linear_extrude(height = .1)quers(d1 = minrad(angle+step), d2 =
1.5minrad(angle+step), minrad(angle+step), maxb = 5);
function minrad(alpha) = -1/30alpha +5;
module quers(d1 = 2, d2 = 4, h= 2, maxb = 0)
$fn = 200;
hull()
if(maxb > 0)
union()
translate([0,h/2,0]) circle(d = d2);
translate([0,-h/2,0]) circle(d = d1);
union()
translate([1.9h,-h/2,0])
rotate([0,0,-atan((d2-d1)/h)/2])color("red") square(3h,h,center = true);
translate([-1.9h,-h/2,0])
rotate([0,0,atan((d2-d1)/h)/2])color("red") square(3*h,h,center = true);
else
}//module quers(d1 = 2, d2 = 4 )
ciao
Bruno
http://bboett.free.fr
http://aikido.zorn.free.fr
It only takes six second to preview with OpenSCAD 2019.05. I had to fix the
missing [ ] in the square calls first. I.e.
translate([1.9*h,-h/2,0])
rotate([0,0,-atan((d2-d1)/h)/2])color("red") square([3h,h],center = true);
rotate([0,0,atan((d2-d1)/h)/2])color("red") square([3*h,h],center = true);
F6 takes 1 minute 53 seconds, which doesn't seem bad for something with
$fn = 200.
On Wed, 22 Apr 2020 at 10:13, Bruno Boettcher bboett@gmail.com wrote:
hello!
radius = 15;
step = 5;
hull()
rotate([angle,0,0])
$fn = 200;
hull()
if(maxb > 0)
union()
union()
else
ciao
Bruno
Are we talking about the exact code below? That's
finishing preview in 3 seconds. I guess actual render
will be quite slow due to the high $fn count.
Just using a general already quite high resolution of
$fa = 2; $fs = 0.2; at the top of the script instead
of the $fn = 200; previews in 0 seconds and renders
in 19 though.
Note that the slightly strange warning is due to
square([3*h,h],center = true); missing the [ ] so
the 2nd h is where the positional argument center
is.
indeed....
adding the brackets i am down to 34s.....
no error message though.....
i have still 2019.01-RC2 , the one shipped with my distro....
and missing the long awaited svg import :( still waiting....
still, if there are suggestions on how to achieve this in a better way, i
take them :D
ciao
Bruno
Am Mi., 22. Apr. 2020 um 11:52 Uhr schrieb Torsten Paul <Torsten.Paul@gmx.de
in 19 though.
is.
ciao
Bruno
On 22.04.20 15:07, Bruno Boettcher wrote:
i have still 2019.01-RC2, the one shipped with my distro....
You can also check out the AppImage or install via flatpak.
