What is the way to increase text size for the preferences window.
I could not find any option or may the texts are too small I am not able to
find
Thanks
Which OS?
On Sat, Feb 10, 2024 at 11:10 AM Sanjeev Prabhakar via Discuss <
to find
Thanks
windows 11
On Sat, 10 Feb 2024 at 16:43, Dan Perry via Discuss <
Which OS?
to find
Thanks
[Re-sending to all]
I've found that this works for a lot of applications:
Go to installation directory and right-click the executable name
--> Properties --> Compatibility --> Change high DPI settings --> at bottom
click to Override and select 'System'
Dan
On Sat, Feb 10, 2024 at 11:15 AM Sanjeev Prabhakar sprabhakar2006@gmail.com
windows 11
Which OS?
to find
Thanks
Thanks Dan for this explanation, it worked for me
Regards
On Sat, 10 Feb 2024 at 16:56, Dan Perry dan.p3rry@gmail.com wrote:
[Re-sending to all]
bottom click to Override and select 'System'
Dan
On Sat, Feb 10, 2024 at 11:15 AM Sanjeev Prabhakar <
windows 11
Which OS?
able to find
Thanks
We just talked about this a little in the context of whether I should
expand the scope of some work I did to increase the size in the
Customizer pane. The answer seemed to be that we should first look to
conforming to global OS font size preferences. (Which, of course,
requires understanding those preferences.)
Windows 11 has Settings > System > Display > Scale. That affects some,
but not all, text in OpenSCAD. We should probably look into why it
doesn't affect all text.
There should be an option to set the font size of preferences window inside
openSCAD.
That would be easier for people like me.
Answer by Dan doesn't come naturally to my mind
On Sun, 11 Feb, 2024, 12:45 am Jordan Brown, openscad@jordan.maileater.net
expand the scope of some work I did to increase the size in the Customizer
pane. The answer seemed to be that we should first look to conforming to
global OS font size preferences. (Which, of course, requires
but not all, text in OpenSCAD. We should probably look into why it doesn't
affect all text.
On macOS, in System Settings > Accessibility > Display> Text > Text Size
there is OS support for setting the default text size, to either the system
provided one, or asserting that the app provides its own control or
overriding the system one for just that app.
But, it is useless. The underlying API is only available for the Catalyst
framework, the Swift UI framework, and WebKit. OpenSCAD uses QT which uses
the AppKit framework which doesn't give access to the Dynamic Text API.
See:
https://developer.apple.com/design/Human-Interface-Guidelines/typography#Platform-considerations
for confirmation from Apple of this.
So I agree that there should be an option to set the font size in the
preference window inside OpenSCAD.
On Sun, Feb 11, 2024 at 05:55:27AM +0530, Sanjeev Prabhakar via Discuss wrote:
openSCAD.
I don't think that's the right way to solve it: Conforming to an OS
setting that automatically makes the font size readable on your
high-DPI screen means you won't even have to think about where to find
that setting.
So Jordan's plan-of-attack seems to make sense to me: Figure out why
some stuff scales, while other stuff doesn't and then try to make the
not-scaling stuff the same as the scaling stuff.
affect all text.
