Here are a few hexagon module I use frequently to make tapered sockets
for nuts [so they tighten up as they are pulled in], and hexagonal holes
with a chamfer in the outer wall.
These might help creating objects with a little stacking and difference
for each layer.
HTH
// hex_socket - parameters:
//size of nut af without print allowance (pa),
//height or size of lead in chamfer e.g. 1 [mm]
//height or depth of socket - socket tapers from hex_af + pa*3 to
hex_af -pa
//stack chamfer with hex taper, lead in chamfer uses lead in z to
determine
//height of incoming taper. Hex_taper uses size inflated by print
allowance
//which is the same as the lead in chamfer finishing size, smallest
part of hex_taper
//is the hex size with pa deducted rather than added.
module hex_socket (hex_af,lead_in_z,hex_socket_z) {
hex_chamfer (hex_af,lead_in_z);
translate ([0,0,lead_in_z-0.1]) hex_taper (hex_af,hex_socket_z);
module hex_chamfer (hex_af,lead_in_z) {
af_size = hex_af+2lead_in_z;
af_size2 = hex_af+pa2;//same as af_size in module hex_taper, see
below.
hull () {
cylinder(d=af_size2/sqrt(3),h=0.01,$fn=hex_nut);
translate ([0,0,lead_in_z])
cylinder(d=af_size22/sqrt(3),h=0.01,$fn=hex_nut);
}//end hull
}//end module
module hex_taper (hex_af,hex_taper_z){
af_size = hex_af+pa*2;
af_size2 = hex_af-pa;
hull () {
translate ([0,0,hex_taper_z])
}//end hull
}//end module
module make_chamfered_hex (hex_af,hex_z,hex_cham) {
hex_nut = 6;
hex_af_cham = hex_af-2hex_cham;
hull () {
translate ([0,0,0])
cylinder(d=hex_af_cham2/sqrt(3),h=hex_z,$fn=hex_nut);
translate ([0,0,hex_cham])
cylinder(d=hex_af2/sqrt(3),h=hex_z-2hex_cham,$fn=hex_nut);
}//end hull
}//end module
A chamfered hexagon hole cutter
