The Command Glossary in the OpenSCAD User Manual is totally outdated by now
(03.2015).
When OpenSCAD evolves the wiki gets updated, but the Command Glossary stays
unchanged.
The CheatSheet (http://www.openscad.org/cheatsheet/index.html) has taken
the function
of the Command Glossary and it does get updated regularly.
I propose that we will remove the Command Glossary completely and link to
the CheatSheet instead. Also I dont know how to do this technically.
This is a big deletion and I would like to discus this here with you first.
TakeItAndRun
On Mar 17, 2015, at 16:34 PM, Peter Falke stempeldergeschichte@googlemail.com wrote:
I agree. Minimizing duplication is a good thing.
+1
View this message in context: http://forum.openscad.org/Command-Glossary-in-the-OpenSCAD-User-Manual-outdated-tp12073p12075.html
Removing the duplication is certainly a good thing.
The result is a bit strange though as the manual then links to the cheatsheet
which then in turn links back to the manual for details :-).
Is there maybe a way to put the data into the manual in some specifically
formatted way and just generate the cheatsheet from that (e.g. using the
XML export feature for that page)?
